This error shows up under “device manager” in windows. I tried windows 10 and windows server 2022 on two different machines. One a workstation and the other Supermicro Server.
The driver installed was 516.94-data-center-tesla-desktop-win10-win11-64bit-dch-international.exe
The error that shows is:
This device cannot start. (Code 10)
Insufficient system resources exist to complete the API.
What is the use case? Seems to be a vGPU use case and wojld require the vGPU driver and licenses. Please try to start with a eval for vGPU and the vGPU driver.
Yes, I just use it to do some compute. I don’t need to use vGPU. When I try to use nvidia to adjust the mode I get the following error “`
C:\Windows\system32>nvidia-smi -g 0 -dm 1
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running. This can also be happening if non-NVIDIA GPU is running as primary display, and NVIDIA GPU is in WDDM mode.
How should I fix it?
So I’m having this same issue with my Tesla T4 on a X13 Supermicro motherboard. I don’t see a resolution posted. Any update on what might be causing this?
Everything has been fine for months with the display driver included in cuda_11.7.0_516.01_windows.exe and a Tesla T4 on a Windows server 2019 VM hosted by Microsoft Azure. But today it suddenly has stopped working with the exact same errors from device manager and nvidia-smi. No idea what happened except Windows auto update installed 2 security udpates aout Windows Defender.
n.b: no more chance with the display driver of cuda_11.7.1_516.94_windows.exe
