NVDisplay.Container.exe 0xC0000409 crash at offset 0x932E5 with 6x RTX 5880 Ada on Windows 11
Field Details
Container Version NVDisplay.Container.exe 1.39.3323.1171 (compiled 2023-08-25)
Exception Code 0xC0000409 (STATUS_STACK_BUFFER_OVERRUN)
Fault Offset 0x00000000000932E5 (consistent across all crashes)
Crash Timing ~181 seconds after service start (runtime crash, not initialization)
Hardware 6× NVIDIA RTX 5880 Ada Generation (all WDDM mode)
Motherboard Supermicro X12DPG-OA6, Dual Intel Xeon Gold 6354, 1TB RAM
OS Windows 11 Enterprise 24H2 (Build 26100.1)
GPU Bus IDs PCI 4F:00.0, 52:00.0, 57:00.0, CE:00.0, D1:00.0, D6:00.0
Impact 4 of 6 GPUs show “Error” status in Device Manager / WMI after crash; nvidia-smi and CUDA remain fully functional; status self-recovers in ~30s when service restarts
Reproduction 100% reproducible on every boot; crash always at same fault offset
Related Bug Forum Topic #360403 — “Handle leak in NVDisplay.Container.exe version 1.39.3323.1171” (same Container version, reports 47,905 leaked handles)
After every system boot, the NVIDIA Display Container LS service (NVDisplay.Container.exe, version 1.39.3323.1171) crashes with exception code 0xC0000409 (STATUS_STACK_BUFFER_OVERRUN) at a fixed fault offset of 0x932E5, approximately 181 seconds after the service starts.
The crash causes 4 of 6 RTX 5880 Ada GPUs to temporarily report “Error” status via WMI/PnP (Win32_VideoController), while nvidia-smi continues to report all 6 GPUs as healthy throughout the event. The PnP error status is transient (~30 seconds) and self-recovers when the service restarts via its FAILURE_ACTIONS configuration.
This suggests the crash only affects the WDDM user-mode driver stack connection managed by the Container service, not the kernel-mode driver (nvlddmkm.sys) or the NVML/CUDA path.
The consistent fault offset (0x932E5) across all crashes indicates a deterministic code path failure, potentially related to the handle leak documented in Forum Topic #360403 for the same Container version (1.39.3323.1171), where accumulated unreleased handles eventually corrupt the stack.
Expected Behavior: NVDisplay.Container.exe should run stably without crashing, and all 6 GPUs should maintain consistent “OK” status in both nvidia-smi and WMI/Device Manager.
Workaround: Disabling the NVIDIA Display Container LS service entirely has no impact on CUDA/NVML compute workloads, as these use the kernel driver path directly.
