This crash is happening several times an hour, screens go black for about 5 seconds and eventually come back, usually but not always with Windows Explorer staying black and windows doing the ol’ solitaire win animation when you drag them around. Requires manual restart of Explorer from task manager or reboot to fully recover.
The crash generally occurs regularly while watching a Youtube video and scrolling down to the comments while its playing (in Chrome). Other apps I also have running are Discord, and Slack.
Software:
Nvidia Driver: 455.41-desktop-win10-64bit-international-dch-wsl-preview
Windows Version: Windows 10 Pro Insider Preview 20170.rs_prerelease.200710-1419
WSL: Ubuntu 18.04 w/ cuda-toolkit-11-0
Event Details:
Log Name: System
Source: nvlddmkm
Date: 7/21/2020 11:35:58 AM
Event ID: 14
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: TheGibson
Description:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
CMDre 00000003 00000200 00000000 00000005 00000018
The message resource is present but the message was not found in the message table
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="nvlddmkm" />
<EventID Qualifiers="49322">14</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-07-21T16:35:58.1770905Z" />
<EventRecordID>3672</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="21616" />
<Channel>System</Channel>
<Computer>TheGibson</Computer>
<Security />
</System>
<EventData>
<Data>\Device\Video3</Data>
<Data>CMDre 00000003 00000200 00000000 00000005 00000018</Data>
<Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Software:
Windows Version: Windows 10 Pro Insider Preview 20150.rs_prerelease.200612-1734
Nvidia Driver: 451.67 installed via Geforce Experience
I never get it while gaming, getting it while browsing Discord or watching YouTube. I’ve got the exact same error. My way of fixing it is plugging the monitor off the GPU and back in.
local computer.
\Device\Video7
Windows Version: Windows 10 Pro Insider Preview 20175.rs_prerelease.200717-1349
Nvidia Driver: 455.41.
My event viewer report the following:
No se encuentra la descripción del id. de evento 14 en el origen nvlddmkm. El componente que provoca este evento no está instalado en el equipo local, o bien la instalación está dañada. Puede instalar o reparar el componente en el equipo local.
Si el evento se originó en otro equipo, la información que se va a mostrar tenía que haberse guardado con el evento.
Se incluyó la siguiente información con el evento:
\Device\Video3
El sistema no puede encontrar el texto del mensaje para el mensaje número 0x%1 en el archivo de mensajes para %2
Same issue here when browsing pages with video content.
Reddit/Youtube/embedded video in forums.
When the video reaches the border while scrolling, the screen goes black and the driver hangs, coming back 2 seconds later.
Sometimes my taskbar will not reappear too.
Same issue as well, the event log has hundreds of continual errors that last for a few minutes before the machine crashes to BSOD. I’ve had several moments when the screen goes to black for a second or two and then appears to reset itself over the past couple years, but lately the issue seems to lead to system crash.
I’ve updated the nvida drivers as of last week. I’m using the GeForce GTX 1080ti on a windows 10 pro 64bit system (Acer Predator 9000), nvidia driver version 457.30. My computer has crashed to BSOD twice since the latest driver download and update.
I’ve read that sometimes reinstalling the video card helps, but honestly everything from the system overheating to bad ram to a cornucopia of other issues have been suggested, which leads me to believe the answer is there is no answer and people like to guess a lot. My system temp is cooler than average computers, I do not overclock the computer, I have been using this computer a lot over the past year while working from home due to covid-19.
