What could be still wrong? The whole error messages are
atic@ubuntu:/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/Rectitude$ ./deepstream-app -c ../../../../samples/configs/deepstream-app/rectitude_config_main.txt
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:00.482160099 5891 0xaaaad831fe10 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Rectitude/frcnn_resnet50_ver1.onnx_b4_gpu0_fp16.engine open error
0:00:02.671591647 5891 0xaaaad831fe10 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Rectitude/frcnn_resnet50_ver1.onnx_b4_gpu0_fp16.engine failed
0:00:02.733998285 5891 0xaaaad831fe10 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Rectitude/frcnn_resnet50_ver1.onnx_b4_gpu0_fp16.engine failed, try rebuild
0:00:02.734101773 5891 0xaaaad831fe10 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:375: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: onnx2trt_utils.cpp:403: One or more weights outside the range of INT32 was clamped
ERROR: [TRT]: Validation failed: libNamespace == nullptr
/opt/nvidia/deepstream/deepstream-6.3/sources/TensorRT/plugin/proposalPlugin/proposalPlugin.cpp:528
ERROR: [TRT]: std::exception
WARNING: [TRT]: builtin_op_importers.cpp:5243: Attribute isBatchAgnostic not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
ERROR: [TRT]: 4: [network.cpp::validate::3096] Error Code 4: Internal Error (input_image: for dimension number 2 in profile 0 does not match network definition (got min=544, opt=544, max=544), expected min=opt=max=720).)
ERROR: Build engine failed from config file
ERROR: failed to build trt engine.
0:00:04.569594349 5891 0xaaaad831fe10 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2022> [UID = 1]: build engine file failed
0:00:04.636431551 5891 0xaaaad831fe10 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2108> [UID = 1]: build backend context failed
0:00:04.636543967 5891 0xaaaad831fe10 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1282> [UID = 1]: generate backend failed, check config file settings
0:00:04.637036732 5891 0xaaaad831fe10 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:04.637084155 5891 0xaaaad831fe10 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/restitude_config_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
[NvMultiObjectTracker] De-initialized
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
please update infer-dims=3;544;960 to infer-dims=3;720:1280. from the screenshot, the input is 3x720x1280.
about “Validation failed: libNamespace == nullptr”, I can’t reproduce this issue on DS6.3 docker. could you share the frcnn model by forum private email? Thanks! please click forum avatar-> email.
Yes thanks it worked. But still have “Validation failed: libNamespace == nullptr” error.
Directly convert on deepsteram-app also worked eventhough it showed “Validation failed: libNamespace == nullptr” error.
Is the error important?
