NvEGLImageFromFd(egl_display, render_fd) Failure
Hello.
On tx2 4g, when I try to use eglRender to display an image, I always received error report NvEGLImageFromFd: Failed to create EGLImage from dma-buf fd (1828717595).
Can you help to check what was wrong in my code?main_1.c (10.2 KB)
compile command is :
aarch64-linux-gnu-gcc -o main main_1.c -I/home/nvidia/tegra_multimedia_api/include/ -lX11 -lEGL -lGLESv2 -lnvbuf_utils -L/usr/lib/aarch64-linux-gnu/tegra/ -L/usr/lib/aarch64-linux-gnu -Xlinker -rpath-link=“/usr/lib/aarch64-linux-gnu/tegra”
Best regards
Hoover
Please try
egl_image = NvEGLImageFromFd(egl_display, dmabuf_fd);
Need to set EGLDisplay.
Same error is reported with egl_image = NvEGLImageFromFd(egl_display, dmabuf_fd);
However, error is gone when I set color Format to something other than ABGR32
, such as NvBufferColorFormat_xRGB32
input_params.colorFormat = NvBufferColorFormat_ABGR32;
maybe egl does not support abgr32? but the output is empty(black screen) with xRGB32 or ARGB32
any updates?
NvBufferColorFormat_ABGR32 is the format widely used in jetson_multimedia_api samples and we don’t observe the issue. Have you set EGLDisplay and try?
Yes we did try replacing NULL with EGLDisplay. but it still report
We don’t observe issue in running the sample:
Although it requires the patch:
