I have a need to pass a single char by value from C function to Fortran caller. This method works on other vendors’ compilers but not on nvfortran from at least 23.5 to 24.1 (probably never worked):
lib.c
char one(){
return '1';
main.f90
program c
use, intrinsic :: iso_c_binding
implicit none
interface
character(kind=c_char) function one() bind(C)
import
end function
end interface
character :: fone
fone = one()
print '(i0,1x,a)', len_trim(fone), fone
end program
This Fortran program prints random values for fone. I am guessing the C_CHAR is being handled as a pointer instead of value.
program test
implicit none
interface
character(kind=c_char) function three() bind(C)
import
end function
integer(kind=c_int) function c2i() bind(C)
import
end function
end interface
character :: fc
integer :: e
character :: ef
fc = three()
e = c2i()
ef = achar(e)
print '(a)', fc
print '(a,1x,i0)', 'ascii code', e
print '(a)', ef
end program
This workaround may not strictly be correct (general limitations across platforms of blindly casting char to int), so in my actual program, I have worked around by duplicating the C function algorithm into Fortran without trying to pass the char value from C to Fortran.
