NVfortran compiles the code, a dummy example is given below. Yet when it is run, it gives the segmentation fault (core dumped) in the OpenACC data region.
The main code alike:
program main
USE MOD
! counters
INTEGER T, I, J, K
INTEGER J_P = 2
! counters +
INTEGER OS, OE, IG
! variables
INTEGER*8 M
INTEGER N
INTEGER TP,ATP
INTEGER ACP = 0
DOUBLE PRECISION AN(MAT_DDT(1)%NUMCSR)
DOUBLE PRECISION CN(NON_DDT%NUMCSR,HFKS)
! ALLOCATABLE ARRAYS
DOUBLE PRECISION, ALLOCATABLE :: FAN(:,:)
DOUBLE PRECISION, ALLOCATABLE :: FCN(:,:,:)
! Allocatables are allocated
DO T = 0,180
!$acc data copyin(FAN(:,:),AN(:), FCN(:,:,:),CN(:,:)) copy(AN(:),CN(:,:))
CALL COPY2DEVICE_MAT(J_P)
CALL COPY2DEVICE_NON(J_P)
!$acc parallel loop present(MAT(1),NON) collapse(2)
DO I = OS,OE
! ASSEMBLE
DO J = 1,IG
DO K = 1,IG
M = (I-1)*IG*IG + (J-1)*IG + (K-1) + 1
N = (MIN(J,K)-1)*IG + (MAX(J,K)-1) + 1
TP = MAT%TAL(J_P)%CAL(M)
ATP = TP ; IF (ACP .EQ. 1) ATP = NON%TAL(J_P)%CAL(M)
IF (NOCSR .GT. 0) THEN ! (ATP>0 AS WELL)
AN(TP) = AN(TP) + FAN(I-OS+1,N) !*** SYMMETRY IS ASSUMED ***
CN(ATP,:) = CN(ATP,:) + FCN(I-OS+1,N,:) !*** SYMMETRY IS ASSUMED ***
END IF
END DO
END DO
END DO ! I
!$acc end parallel loop
CALL COPY2HOST_MAT(J_P)
CALL COPY2HOST_NON(J_P)
!$acc end data
END DO ! T
end program main
The MOD module:
MODULE MOD
IMPLICIT NONE
TYPE T02
INTEGER, ALLOCATABLE, DIMENSION(:) :: CAL
END TYPE T02
TYPE T01
TYPE (T02), ALLOCATABLE, DIMENSION(:) :: TAL
END TYPE T01
TYPE (T01), ALLOCATABLE, DIMENSION(:) :: MAT
TYPE (T01) :: NON
CONTAINS
!FOR KEY
SUBROUTINE COPY2DEVICE_MAT(J_P)
INTEGER :: i
INTEGER :: J_P
!$acc enter data copyin(MAT(1))
!$acc enter data copyin(MAT(1)%TAL(:))
DO i = 1,J_P
!$acc enter data copyin(MAT(1)%TAL(i)%CAL(:))
END DO
END SUBROUTINE
SUBROUTINE COPY2HOST_MAT(J_P)
INTEGER :: i
INTEGER :: J_P
DO i = 1,J_P
!$acc exit data copyout(MAT(1)%TAL(i)%CAL(:))
END DO
!$acc exit data copyout(MAT(1)%TAL(:))
!$acc exit data copyout(MAT(1))
END
SUBROUTINE COPY2DEVICE_NON_PAT_KEY(J_P)
INTEGER :: i
INTEGER :: J_P
!$acc enter data copyin(NON)
!$acc enter data copyin(NON%TAL(:))
DO i = 1,J_P
!$acc enter data copyin(NON%TAL(i)%CAL(:))
END DO
END SUBROUTINE
SUBROUTINE COPY2HOST_NON(J_P)
INTEGER :: i
INTEGER :: J_P
DO i = 1,J_P
!$acc exit data copyout(NON%TAL(i)%CAL(:))
END DO
!$acc exit data copyout(NON%TAL(:))
!$acc exit data copyout(NON)
END SUBROUTINE
END MODULE MOD
When I compiled and run the code without the parallel regions as shown below, it still gave the segmentation fault.
program main
USE MOD
! counters
INTEGER T, I, J, K
INTEGER J_P = 2
! counters +
INTEGER OS, OE, IG
! variables
INTEGER*8 M
INTEGER N
INTEGER TP,ATP
INTEGER ACP = 0
DO T = 0,180
DO I = OS,OE
! ASSEMBLE
DO J = 1,IG
DO K = 1,IG
END IF
END DO
END DO
END DO ! I
!$acc end data
END DO ! T
end program main
