Dear All
I am facing a problem while porting a large code with many subroutines using the PGI Accelerator directives. When I compile the code with pgf90 (without a target acceleraor flag) the program works. Now I just added two !$acc region / !$acc end region directives over two loops of one subroutine two convert them to two GPU compute regions. When I now compile the code with the -ta=nvidia flag I get the following compiler feedback for this particular subroutine.
When I now run the program it terminates with a “Segmentation fault”.
I also tried to accelerate several other loops (each one individualy) and I always faced the same problem.
What do I have to pay attention to? What could cause this fault?
Thank you very much in advance.
162, Generating copyout(vort$p(1:3,1:knend))
Generating compute capability 1.3 binary
163, Loop carried dependence of 'uf$p' prevents parallelization
Loop carried backward dependence of 'uf$p' prevents vectorization
Complex loop carried dependence of 'vort$p' prevents parallelization
Sequential loop scheduled on host
Loop not vectorized/parallelized: contains call
164, Loop is parallelizable
Accelerator kernel generated
164, !$acc do parallel, vector(3)
CC 1.3 : 4 registers; 24 shared, 24 constant, 0 local memory bytes; 25 occupancy
185, Generating copyin(pcell$p(1:8,1:kcend))
195, Complex loop carried dependence of 'q$p' prevents parallelization
Complex loop carried dependence of 'qt$p' prevents parallelization
Complex loop carried dependence of 'vc$p' prevents parallelization
Complex loop carried dependence of 'sixl$p' prevents parallelization
Complex loop carried dependence of 'sixr$p' prevents parallelization
Complex loop carried dependence of 'siyl$p' prevents parallelization
Complex loop carried dependence of 'siyr$p' prevents parallelization
Complex loop carried dependence of 'sizl$p' prevents parallelization
Complex loop carried dependence of 'sizr$p' prevents parallelization
Complex loop carried dependence of 'sjxl$p' prevents parallelization
Complex loop carried dependence of 'sjxr$p' prevents parallelization
Complex loop carried dependence of 'sjyl$p' prevents parallelization
Complex loop carried dependence of 'sjyr$p' prevents parallelization
Complex loop carried dependence of 'sjzl$p' prevents parallelization
Complex loop carried dependence of 'sjzr$p' prevents parallelization
Complex loop carried dependence of 'skxl$p' prevents parallelization
Complex loop carried dependence of 'skxr$p' prevents parallelization
Complex loop carried dependence of 'skyl$p' prevents parallelization
Complex loop carried dependence of 'skyr$p' prevents parallelization
Complex loop carried dependence of 'skzl$p' prevents parallelization
Complex loop carried dependence of 'skzr$p' prevents parallelization
Loop carried dependence of 'dudx$p' prevents parallelization
Loop carried backward dependence of 'dudx$p' prevents vectorization
Complex loop carried dependence of 'dudx$p' prevents parallelization
Loop carried dependence of 'dudy$p' prevents parallelization
Loop carried backward dependence of 'dudy$p' prevents vectorization
Complex loop carried dependence of 'dudy$p' prevents parallelization
Loop carried dependence of 'dudz$p' prevents parallelization
Loop carried backward dependence of 'dudz$p' prevents vectorization
Complex loop carried dependence of 'dudz$p' prevents parallelization
Loop carried dependence of 'dvdx$p' prevents parallelization
Loop carried backward dependence of 'dvdx$p' prevents vectorization
Complex loop carried dependence of 'dvdx$p' prevents parallelization
Loop carried dependence of 'dvdy$p' prevents parallelization
Loop carried backward dependence of 'dvdy$p' prevents vectorization
Complex loop carried dependence of 'dvdy$p' prevents parallelization
Loop carried dependence of 'dvdz$p' prevents parallelization
Loop carried backward dependence of 'dvdz$p' prevents vectorization
Complex loop carried dependence of 'dvdz$p' prevents parallelization
Loop carried dependence of 'dwdx$p' prevents parallelization
Loop carried backward dependence of 'dwdx$p' prevents vectorization
Complex loop carried dependence of 'dwdx$p' prevents parallelization
Loop carried dependence of 'dwdy$p' prevents parallelization
Loop carried backward dependence of 'dwdy$p' prevents vectorization
Complex loop carried dependence of 'dwdy$p' prevents parallelization
Loop carried dependence of 'dwdz$p' prevents parallelization
Loop carried backward dependence of 'dwdz$p' prevents vectorization
Complex loop carried dependence of 'dwdz$p' prevents parallelization
Loop carried dependence of 'dtdx$p' prevents parallelization
Loop carried backward dependence of 'dtdx$p' prevents vectorization
Complex loop carried dependence of 'dtdx$p' prevents parallelization
Loop carried dependence of 'dtdy$p' prevents parallelization
Loop carried backward dependence of 'dtdy$p' prevents vectorization
Complex loop carried dependence of 'dtdy$p' prevents parallelization
Loop carried dependence of 'dtdz$p' prevents parallelization
Loop carried backward dependence of 'dtdz$p' prevents vectorization
Complex loop carried dependence of 'dtdz$p' prevents parallelization
Loop carried dependence of 'dkdx$p' prevents parallelization
Loop carried backward dependence of 'dkdx$p' prevents vectorization
Complex loop carried dependence of 'dkdx$p' prevents parallelization
Loop carried dependence of 'dkdy$p' prevents parallelization
Loop carried backward dependence of 'dkdy$p' prevents vectorization
Complex loop carried dependence of 'dkdy$p' prevents parallelization
Loop carried dependence of 'dkdz$p' prevents parallelization
Loop carried backward dependence of 'dkdz$p' prevents vectorization
Complex loop carried dependence of 'pcell$p' prevents parallelization
Generating copyout(k(1:8))
196, Loop is parallelizable
196, !$acc do parallel, vector(8)
CC 1.3 : 4 registers; 24 shared, 32 constant, 0 local memory bytes; 25 occupancy
408, Loop not vectorized: may not be beneficial
Loop unrolled 4 times
410, Loop not vectorized: data dependency
473, Loop not vectorized: data dependency
699, Loop not vectorized: may not be beneficial
701, Loop not vectorized: data dependency
728, Loop not vectorized: data dependency
921, Loop not vectorized: data dependency
950, Loop not vectorized: data dependency
980, Loop not vectorized: data dependency
995, Loop not vectorized: data dependency
