Nviaia prime cant run nvidia card. laptop with dual gpu
Hello guys.
Does not switch to nvidia card.
There is an intel 4000 and nvidia 680m card.
Installed the latest driver nvidia-418 for my videocard.
Did prime-select nvidia
reboot
Option “PrimaryGPU” “yes”
in /usr/share/X11/xorg.conf.d/10-nvidia.conf
sudo update-initramfs -u
reboot
dont work
nvidia-bug-report.log.gz (99.9 KB)
Try swith
prime-select intel
reboot
and then
prime-select nvidia
reboot
nothing
lsmod | grep nvidia
nothing
tried to install 390ver driver, didnt help
now i get blackscreen when trying to start nvidia card
nvidia-bug-report.log.gz (243.9 KB)
Please install the 470 legacy driver from repo and delete /etc/X11/xorg.conf
Installed and del xorg.conf
I think all work, but why glxgears show low framerate?
Because it’s locked to vsync. You have a 60Hz display.
Please also delete /usr/share/X11/xorg.conf.d/10-nvidia.conf
The mode is handled by prime-select, if you set “PrimaryGpu” manually, you’ll run into problems.
Thank you so much!
I spent a day to fix the problem.
and you decided in 5 minutes
