NVIDIA 1660ti throttling despite <60C temps
I may need to buy a whole new computer which I can barely afford, so any help would be greatly appreciated.
I’m on popOS 22.04 gtx 1660TI mobile laptop that’s plugged into AC power. This throttling is a recent problem despite temperatures being 60C or lower. I’ve tried multiple driver updates and downgrades and setting it to high performance mode while using only the dedicated GPU. Currently on nvidia-driver-530.
Here’s the output of nvidia-smi -q -d PERFORMANCE, which shows that both SW power and thermal slowdown are active after merely tabbing between terminal windows (no other apps were open).
Here’s the nvidia-bug-report.log.gz (845.2 KB) and here’s the output of nvidia-smi:
$ nvidia-smi -q -d PERFORMANCE
==============NVSMI LOG==============
Timestamp                                 : Thu Jun 15 15:44:27 2023
Driver Version                            : 530.41.03
CUDA Version                              : 12.1
Attached GPUs                             : 1
GPU 00000000:01:00.0
Performance State                     : P5
Clocks Throttle Reasons
Idle                              : Not Active
Applications Clocks Setting       : Not Active
SW Power Cap                      : Active
HW Slowdown                       : Not Active
HW Thermal Slowdown           : Not Active
HW Power Brake Slowdown       : Not Active
Sync Boost                        : Not Active
SW Thermal Slowdown               : Active
Display Clock Setting             : Not Active
I’ve noticed something as minor as tabbing between terminal windows can cause the SW power cap + SW thermal slowdown to activate.
Same thing with 3060 mobile, managed to fix it?
