My RTX 3060 mobile is throttling at low temperatures such as ~70c. Voltage drops from 80W to 30W, so does gpu & memory clock and usage. Im pretty sure this is tied to the temp, as when operating in very cold conditions it happens way less. Ive tried: open source drivers, proprietary, underclocking, overclocking ( with cool bits), forcing nvidia to use performance mode, changing the fan curve (doesnt seem to change anything, probably overwritten by laptop bios). It seems to be overwritten by bios or something low level. Returning the laptop is not an option. My laptop is from HP Victus 16 line. The airflow design is dumb but if you lift it from the back of the screen it gets fine airflow. Exuse me if this isnt the correct category / tags.
Related topics
Topic | Replies | Views | Activity | |
NVIDIA 1660ti throttling despite <60C temps | 1 | 510 | December 18, 2024 | |
GPU throttling at low temperature | 5 | 597 | October 25, 2024 | |
RTX 3090 throttles down underload temps looks fine | 3 | 922 | January 10, 2022 | |
Nvidia RTX 3090 SW Thermal Slowdown always active | 6 | 4327 | June 15, 2023 | |
How can I reduce graphics card temperature? | 0 | 402 | August 4, 2022 | |
Clock Throttle Reasons RTX 3060 mobile - Idle - active? | 9 | 3699 | February 2, 2023 | |
GPU Max Operating Temp seems low for Laptop 3060 | 3 | 11500 | August 10, 2023 | |
RTX 3060 Ti Auto Fan Speed/ Power Draw | 0 | 322 | December 10, 2024 | |
Nvidia 40 series bug in victus laptops, high idle power draw | 1 | 117 | January 14, 2025 | |
Technical Issues with RTX 3060 (hardware, maybe clock?) | 5 | 2696 | April 22, 2025 |
