I was using Ubuntu 20.04 with nvidia installed. After update, it installed kernel 5.11.0-41-generic and then I started facing issue in nvidia driver which reports “NVIDIA-SMI” has failed. I uninstalled the driver using sudo apt remove --purge '^nvidia-.*'and then re-installed after reboot with sudo ubuntu-drivers autoinstall which installed nvidia-470. However, after reboot, I see the same error. The bug report is attached. Please guide. Thanks.
nvidia-bug-report.log.gz (118.8 KB)
The driver seems to be blacklisted. Please try:
- run
sudo prime-select nvidia
- run
grep nvidia /etc/modprobe.d/* /lib/modprobe.d/*
to find a file containing
blacklist nvidia
and remove it,
then run
sudo update-initramfs -u
and reboot.
Thanks a lot for the outstanding reply. I was trying for different methods without any success. Thanks again.
