libEGL_nvidia.so.0 appears to install an exit handler which can fail for some applications and possibly result in kernel panics.
On archlinux with the nvidia-utils 495.44-5 package which appears to contain the top level library blamed in the stack trace. The system has been restarted so ensure there were no driver/kernel/userland inconsistencies.
The full stacktrace follows
Thread 1 "demo" received signal SIGSEGV, Segmentation fault.
0x00007ffff7587f70 in ?? () from /usr/lib/libnvidia-glsi.so.495.44
(gdb) bt
#0 0x00007ffff7587f70 in ?? () from /usr/lib/libnvidia-glsi.so.495.44
#1 0x00007ffff758de0e in _nv004glsi () from /usr/lib/libnvidia-glsi.so.495.44
#2 0x00007ffff6236339 in ?? () from /usr/lib/libnvidia-eglcore.so.495.44
#3 0x00007ffff6228d05 in ?? () from /usr/lib/libnvidia-eglcore.so.495.44
#4 0x00007ffff6249c30 in ?? () from /usr/lib/libnvidia-eglcore.so.495.44
#5 0x00007ffff796d66f in ?? () from /usr/lib/libEGL_nvidia.so.0
#6 0x00007ffff796d737 in ?? () from /usr/lib/libEGL_nvidia.so.0
#7 0x00007ffff79d9a75 in ?? () from /usr/lib/libEGL_nvidia.so.0
#8 0x00007ffff79d9aed in ?? () from /usr/lib/libEGL_nvidia.so.0
#9 0x00007ffff796ca79 in ?? () from /usr/lib/libEGL_nvidia.so.0
#10 0x00007ffff79d9d4f in ?? () from /usr/lib/libEGL_nvidia.so.0
#11 0x00007ffff7dae4a7 in __run_exit_handlers () from /usr/lib/libc.so.6
#12 0x00007ffff7dae64e in exit () from /usr/lib/libc.so.6
#13 0x00007ffff7d96b2c in __libc_start_main () from /usr/lib/libc.so.6
#14 0x00005555555561ce in _start ()
Reproduction steps as follows:
- Reboot
- Start an X11 session.
- Start a nested gnome-shell session with
gnome-shell --nested --wayland - Start the sample application
- In the gnome session click the application name (Unknown) in the title bar and select “Quit”
- Observe the segfault inside nvidia drivers userland.
- Observe kernel panic after attempting a reboot due to nvidia drivers kernel modules.
Test environment:
Archlinux 5.15.2-arch1-1
nvidia 495.44-9
egl-wayland 1:1.1.9+2+gdaab854-1
gnome-shell 1:41.1-1
xorg-server 21.1.1-3
Test application: GitHub - kkartaltepe/wayland-egl-simple: It's as simple as I could make it.
GTX 1070, no other graphics devices.
Note: The sample application is leaking a number of wayland and egl resources on exit, but I would expect the driver to be robust against such a common case as such crashes do not occur in similarly leaky x11/glx applications
