Please help! New nvidia a100 (model P1001B, S/N 1324620062195) not working/visible
Ubuntu 20.04, driver version 460
root@test:~# cat /proc/driver/nvidia/gpus/0000:2e:00.0/information
Model: A100-PCIE-40GB
IRQ: 107
GPU UUID: GPU-f361d716-d713-61b9-64d5-7d06adf98a71
Video BIOS: ??.??.??.??.??
Bus Type: PCI
DMA Size: 47 bits
DMA Mask: 0x7fffffffffff
Bus Location: 0000:2e:00.0
Device Minor: 1
Blacklisted: No
2e:00.0 3D controller: NVIDIA Corporation Device 20f1 (rev a1)
Subsystem: NVIDIA Corporation Device 145f
Flags: bus master, fast devsel, latency 0, IRQ 107
Memory at eb000000 (32-bit, non-prefetchable) [size=16M]
Memory at (64-bit, prefetchable)
Memory at ec000000 (64-bit, prefetchable) [size=32M]
Capabilities: [60] Power Management version 3
Capabilities: [68] Null
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [c8] MSI-X: Enable- Count=6 Masked-
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [bb0] Resizable BAR <?>
Capabilities: [bcc] Single Root I/O Virtualization (SR-IOV)
Capabilities: [c14] Alternative Routing-ID Interpretation (ARI)
Capabilities: [c1c] Physical Layer 16.0 GT/s <?>
Capabilities: [d00] Lane Margining at the Receiver <?>
Capabilities: [e00] Data Link Feature <?>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
nvidia-smi
Unable to determine the device handle for GPU 0000:2E:00.0: Unknown Error
I guess that the probable problem is with the firmware of the card. The card has been tested under Windows and Linux. The situation is the same for both systems. After installing the drivers, the cards are not visible and there are errors.
At the same time, other cards work fine on test systems. V100 and RTX3090 cards were tested in parallel
