I am having the same error. I have attatched the bug report. please help
nvidia-bug-report.log (598.3 KB)
Following the suggestion worked.
Thanks for sharing.
Although, then I have to re-install my CUDA libraries again. sigh
Linux version 5.11.0-7614-generic (buildd@lgw01-amd64-025) (gcc (Ubuntu 10.2.0-13ubuntu1)
Kernel was built with gcc 10.
gcc version 9.3.0 (Ubuntu 9.3.0-18ubuntu1)
But you (now) have v. 9.
Guess you set that?
I told you to look at /proc/version.
Check if gcc and g++ v. 10 are installed. And if yes, use update-alternatives.
Purge and reinstall the driver using apt.
You just need to install cuda-toolkit, not complete cuda (which would try to install its own driver when following the nvidia guide).
It was originally set to v10. I saw you changing it to v9 in this thread so I did so. So maybe this isn’t an issue related to gcc as I had this problem before changing the version.
Well, set it back to default.
purge all driver and cuda files.
reinstall the driver from repo and then install cuda-toolkit.
