Seeing the same issue that was reported here:
https://bugzilla.kernel.org/show_bug.cgi?id=205661
Error seen when installing 5.4.x kernel:
Building module:
cleaning build area...
unset ARCH; env NV_VERBOSE=1 'make' -j16 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=5.4.2-050402-generic IGNORE_XEN_PRESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/lib/modules/5.4.2-050402-generic/build LD=/usr/bin/ld.bfd modules....(bad exit status: 2)
ERROR (dkms apport): kernel package linux-headers-5.4.2-050402-generic is not supported
Error! Bad return status for module build on kernel: 5.4.2-050402-generic (x86_64)
Consult /var/lib/dkms/nvidia/440.36/build/make.log for more information.
...done.
Error seen in log:DKMS make.log for nvidia-440.36 for kernel 5.4.2-050402-generic (x86_64)
Thu Dec 5 19:17:41 PST 2019
make[1]: Entering directory '/usr/src/linux-headers-5.4.2-050402-generic'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
The files autoconf.h and auto.conf appear to exist in 5.4.2 directory. Here is summary of all the 'Error’s that occurred.
cat /var/lib/dkms/nvidia/440.36/build/make.log | egrep “Error”
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-frontend.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-i2c.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-pci.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-cray.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-usermap.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-dma.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-mempool.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-vtophys.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-mmap.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-procfs.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-pat.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-p2p.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/os-interface.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-acpi.o] Error 1
make[2]: *** [/var/lib/dkms/nvidia/440.36/build/nvidia/nv-vm.o] Error 1
make[1]: *** [/var/lib/dkms/nvidia/440.36/build] Error 2
make: *** [modules] Error 2
Drivers work just fine on kernels 4.3.10 and 4.3.15 , guessing no issues with 4.3.x.
towo
December 6, 2019, 6:46am
2
I can’t confirm your problem here (Debian Sid / siduction).
towo:OMPC-AV2> sudo dkms status
nvidia-current, 440.36, 5.3.12-towo.2-siduction-amd64, x86_64: installed
nvidia-current, 440.36, 5.3.13-towo.1-siduction-amd64, x86_64: installed
nvidia-current, 440.36, 5.3.14-towo.1-siduction-amd64, x86_64: installed
nvidia-current, 440.36, 5.4.2-towo.1-siduction-amd64, x86_64: installed
Builds and working fine.
birdie
December 6, 2019, 11:33am
3
I’m running vanilla 5.4.2 and it works for me.
$ uname -a
Linux zen 5.4.2-az2 #1 SMP PREEMPT Thu Dec 5 16:41:53 2019 x86_64 x86_64 x86_64 GNU/Linux
$ modinfo nvidia | grep version
version: 440.36
Looks like this was resolved in 5.4.3.
Thanks everybody.
Reference: Bug #1855590 “Kernel module failures for mainline kernel 5.4+ - ...” : Bugs : nvidia-graphics-drivers-440 package : Ubuntu
I’m currently running 5.3.15-050315-generic , will try updating shortly to 5.4.3 to confirm it resolves my issue.
Unfortunately, that did not work for me.
OS: Ubuntu 18.04.3 LTS x86_64
Video Card: GeForce RTX 2080 Ti
Im currently running 5.3.15-050315-generic and nvidia driver is seen and loads fine:
lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1e04 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10f7 (rev a1)
01:00.2 USB controller: NVIDIA Corporation Device 1ad6 (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation Device 1ad7 (rev a1)
lsmod | grep -i nvida
nvidia_uvm 929792 0
nvidia_drm 49152 7
nvidia_modeset 1114112 15 nvidia_drm
nvidia 20402176 763 nvidia_uvm,nvidia_modeset
drm_kms_helper 184320 1 nvidia_drm
drm 491520 10 drm_kms_helper,nvidia_drm
ipmi_msghandler 102400 2 ipmi_devintf,nvidia
i2c_nvidia_gpu 16384 0
How can I run build/install nvidia kernel module manually on 5.4.x?
What information can I post here that would be useful?
Thanks again for all the help.
generix
December 16, 2019, 9:10am
6
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/
Attached nvidia-bug-report.log.gz to my last post.
x11
December 21, 2019, 7:00pm
8
same issue with the latest Kernel 5.4.6.
I’am currently running Kernel 5.3.2 without problems.
generix
December 22, 2019, 1:57am
9
You’re running a kernel compiled with gcc 9.2.1 but the system compiler is set to gcc 7.4.0. If you want to keep the current kernel, please switch to the corresponding gcc.
x11
December 22, 2019, 9:41am
10
so, i installed gcc version 9.2.1 and it’s running :)
Thx for helping me! Have good days and a nice new year.
Installing gcc 9.2.1 also solved it for me. Thank you and happy new year.
Exactly the same problem I faced last 3 days but not succeed. I have server machine with Ubuntu 18.04 with Telsa K80, and want to install Driver Version: 440.82 but facing this error :
ERROR (dkms apport): kernel package linux-headers-5.4.9-050409-generic is not supported
compile using gcc 6
But When I install driver using sudo apt install nvidia-driver-440 with gcc 9.3 I resolved the problem
Make sure to reboot machine after driver installation
Thanks @generix
