I’m getting the following message when NVIDIA-Linux-x86_64-440.44.run attempts to load the just-built module:
[12475.850890] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1c82)
NVRM: installed in this system is not supported by the
NVRM: NVIDIA 440.44 driver release.
NVRM: Please see ‘Appendix A - Supported NVIDIA GPU Products’
NVRM: in this release’s README, available on the operating system
NVRM: specific graphics driver download page at www.nvidia.com.
Yet my board is listed in “Appendix A - Supported NVIDIA GPU Products”
GeForce GTX 1050 Ti 1C82 H
I attempted to roll back to an earlier version (390) and the driver would load but it would not support my 4k screen.
Any advice about how to move forward?
Installer log:
cat /var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Jan 27 12:47:22 2020
installer version: 440.44
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
-> Installing NVIDIA driver version 440.44.
-> There appears to already be a driver installed on your system (version: 440.44). As part of installing this driver (version: 440.44), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
-> Running distribution scripts
executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Kernel source path: '/lib/modules/4.15.0-74-generic/build'
-> Kernel output path: '/lib/modules/4.15.0-74-generic/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.15.0-74-generic/build" SYSOUT="/lib/modules/4.15.0-74-generic/build"'...
rm -f -r conftest
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-74-generic'
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-74-generic'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.15.0-74-generic/build" SYSOUT="/lib/modules/4.15.0-74-generic/build"'...
SYMLINK /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_pages_uc
CONFTEST: set_memory_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_node_to_nid
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: timer_setup
CONFTEST: backlight_device_register
CONFTEST: pci_enable_msix_range
CONFTEST: do_gettimeofday
CONFTEST: kernel_read
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: pnv_npu2_init_context
CONFTEST: radix_tree_replace_slot
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_connector_list_iter
CONFTEST: drm_driver_prime_flag_present
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: nvidia_grid_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm/uvm8_thread_context_test.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
ld -r -o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-interface.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-frontend.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-pci.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-acpi.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-cray.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-dma.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-i2c.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-mempool.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-mmap.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-p2p.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-pat.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-procfs.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-usermap.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-vm.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-vtophys.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-interface.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-mlock.o /tmp/selfgz9537/NVIDIA-Linux-x
86_64-440.44/kernel/nvidia/os-pci.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-registry.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/os-usermap.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-pci-table.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-kthread-q.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-memdbg.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-report-err.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-rsync.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv-msi.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/nvlink_linux.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia/linux_nvswitch.o
ld -r -o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia.o
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm.mod.o
CC /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia.mod.o
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia.ko
LD [M] /tmp/selfgz9537/NVIDIA-Linux-x86_64-440.44/kernel/nvidia-uvm.ko
-> done.
-> Kernel module compilation complete.
-> Unable to determine if Secure Boot is enabled: No such file or directory
ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information.
-> Kernel module load error: No such device
-> Kernel messages:
[12475.850344] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[12475.850872] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
NVRM: Please see 'Appendix A - Supported NVIDIA GPU Products'
NVRM: in this release's README, available on the operating system
[12475.850925] nvidia: probe of 0000:01:00.0 failed with error -1
[12475.850945] NVRM: The NVIDIA probe routine failed for 1 device(s).
[12475.850946] NVRM: None of the NVIDIA devices were initialized.
[12475.851158] nvidia-nvlink: Unregistered the Nvlink Core, major device number 240
[12475.940226] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[12475.940738] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[12475.940759] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1c82)
[12475.940801] nvidia: probe of 0000:01:00.0 failed with error -1
[12475.940813] NVRM: The NVIDIA probe routine failed for 1 device(s).
[12475.940813] NVRM: None of the NVIDIA devices were initialized.
[12475.941021] nvidia-nvlink: Unregistered the Nvlink Core, major device number 240
[12476.020789] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
