I’ve never had any issues installing on a release-candidate kernel before, and I usually start using the release candidates from the first or second rc, but since 5.12 had that weird data corruption issue, I waited until 5.12-rc3. Well, the driver (both the vulkan dev and latest feature branch) fail to install:
Error! Bad return status for module build on kernel: 5.12.0-rc3-139-tkg-cfs (x86_64)
Consult /var/lib/dkms/nvidia/460.56/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m nvidia -v 460.56 -k 5.12.0-rc3-139-tkg-cfs' returned 10
The make.log logfile shows:
LD [M] /var/lib/dkms/nvidia/455.50.10/build/nvidia-uvm.o
/var/lib/dkms/nvidia/455.50.10/build/nvidia-drm/nvidia-drm-gem-user-memory.c: In function ‘nv_drm_gem_user_memory_import_sg_table’:
/var/lib/dkms/nvidia/455.50.10/build/nvidia-drm/nvidia-drm-gem-user-memory.c:211:9: error: implicit declaration of function ‘drm_prime_sg_to_page_addr_arrays’; did you mean ‘drm_prime_sg_to_dma_addr_array’? [-Werror=implicit-function-declaration]
211 | if (drm_prime_sg_to_page_addr_arrays(sgt, pages, NULL, pages_count) < 0) {
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:271: /var/lib/dkms/nvidia/455.50.10/build/nvidia-drm/nvidia-drm-gem-user-memory.o] Error 1
make[1]: *** [Makefile:1851: /var/lib/dkms/nvidia/455.50.10/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.12.0-rc3-139-tkg-cfs/build'
make: *** [Makefile:81: modules] Error 2
There’s another message earlier in the log that looks like it might be an error but I think it’s just spam, but here it is:
CC [M] /var/lib/dkms/nvidia/455.50.10/build/nvidia/os-mlock.o
/var/lib/dkms/nvidia/455.50.10/build/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/var/lib/dkms/nvidia/455.50.10/build/nvidia/nv-mmap.c:334:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
334 | if (NV_ALLOW_CACHING(memory_type))
/var/lib/dkms/nvidia/455.50.10/build/nvidia/nv-mmap.c:336:9: note: here
336 | default:
Anyway, as I’ve said, I’ve tried every driver that supports this GPU (RTX 3090), and obviously as soon as 5.12 comes out as stable, 5.11 will go end of life, so this needs to be fixed as fast as possible.
