Hi all!
Originally following:
and
https://docs.mellanox.com/display/BlueFieldSWv35011563/IPsec+Functionality
I have two /dev/mst/mt41686_pciconf0 cards connected back to back
Outputs after commands in documentation run look like this on the DPUs:
root@localhost:~# /opt/mellanox/iproute2/sbin/devlink dev show
pci/0000:03:00.0
pci/0000:03:00.1
root@localhost:~# cat /sys/class/net/p0/compat/devlink/ipsec_mode
full
root@localhost:~# cat /sys/bus/pci/devices/0000\:03\:00.0/net/p0/compat/devlink/steering_mode
dmfs
root@localhost:~# devlink dev eswitch show pci/0000:03:00.0
pci/0000:03:00.0: mode switchdev inline-mode none encap enable
root@localhost:~# cat /sys/class/net/p1/compat/devlink/ipsec_mode
full
root@localhost:~# cat /sys/bus/pci/devices/0000\:03\:00.1/net/p1/compat/devlink/steering_mode
dmfs
root@localhost:~# devlink dev eswitch show pci/0000:03:00.1
pci/0000:03:00.1: mode switchdev inline-mode none encap enable
`(For reference this was also run)`
root@localhost:~# ethtool -K p0 hw-tc-offload on
I am unsure if the commands under “Configuring IPsec Rules with iproute2” on
are relevant as they do not appear on
/doca/sdk/east-west-overlay-encryption/index.html
Currently there is no IPSec tunnel set up.
For the time being I am using the default OVS config:
root@localhost:/etc/swanctl/conf.d# sudo ovs-vsctl show
1e02a588-b026-4917-82f2-eb150be01790
Bridge ovsbr2
Port en3f1pf1sf0
Interface en3f1pf1sf0
Port pf1hpf
Interface pf1hpf
Port p1
Interface p1
Port ovsbr2
Interface ovsbr2
type: internal
Bridge ovsbr1
Port ovsbr1
Interface ovsbr1
type: internal
Port p0
Interface p0
Port pf0hpf
Interface pf0hpf
Port en3f0pf0sf0
Interface en3f0pf0sf0
ovs_version: "2.14.1"
I can currently ping between p1p1 on both hosts and see an output when running
ovs-appctl dpctl/dump-flows type=offloaded
on the DPUs
Which looks a bit like this (Modified MAC addresses before posting):
root@localhost:/etc/swanctl/conf.d# sudo ovs-appctl dpctl/dump-flows type=offloaded
recirc_id(0),in_port(4),eth(src=0c:42:a1:e7:1d:d1,dst=0c:42:a1:e7:1e:b0),eth_type(0x0800),ipv4(frag=no), packets:2, bytes:196, used:0.410s, actions:1
recirc_id(0),in_port(1),eth(src=0c:42:a1:e7:1e:b0,dst=0c:42:a1:e7:1d:d1),eth_type(0x0800),ipv4(frag=no), packets:2, bytes:204, used:0.410s, actions:4
I am unsure if the config under Setting IPSec Full Offload Using strongSwan should be on the Host or on the DPU
from: /display/BlueFieldSWv35011563/IPsec+Functionality
Additionally further down the document it mentions
You may now send encrypted data over the HOST VF interface (192.168.70.[1|2]) configured for VXLAN.
But 192.168.70.1 is not mentioned anywhere else in the documents.
