I’m attempting to install the NVIDIA driver version 470 on my Ubuntu 20.04 LTS. I have tried various things I found online, which seemed vaguely relevant, but unfortunately to no avail. My latest attempt, which in theory should just work, is to attempt a clean install:
$ sudo apt purge nvidia* libnvidia*
$ sudo apt install nvidia-driver-470
However, this appears to be running into configuration problems during the install:
Setting up nvidia-kernel-source-470 (470.63.01-0ubuntu0.20.04.2) ...
Setting up nvidia-prime (0.8.16~0.20.04.1) ...
Setting up libnvidia-compute-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up libnvidia-extra-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up nvidia-utils-470 (470.63.01-0ubuntu0.20.04.2) ...
Setting up libnvidia-fbc1-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up nvidia-compute-utils-470 (470.63.01-0ubuntu0.20.04.2) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 130) ...
Adding new group `nvidia-persistenced' (GID 139) ...
Adding new user `nvidia-persistenced' (UID 130) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up libnvidia-cfg1-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up libnvidia-common-470 (470.63.01-0ubuntu0.20.04.2) ...
Setting up nvidia-kernel-common-470 (470.63.01-0ubuntu0.20.04.2) ...
update-initramfs: deferring update (trigger activated)
update-initramfs: Generating /boot/initrd.img-5.4.0-84-generic
Created symlink /etc/systemd/system/systemd-hibernate.service.requires/nvidia-hibernate.service → /lib/systemd/system/nvidia-hibernate.service.
Created symlink /etc/systemd/system/systemd-suspend.service.requires/nvidia-resume.service → /lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-hibernate.service.requires/nvidia-resume.service → /lib/systemd/system/nvidia-resume.service.
Created symlink /etc/systemd/system/systemd-suspend.service.requires/nvidia-suspend.service → /lib/systemd/system/nvidia-suspend.service.
Setting up libnvidia-gl-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up libnvidia-gl-470:i386 (470.63.01-0ubuntu0.20.04.2) ...
Setting up nvidia-settings (465.19.01-0ubuntu1) ...
Setting up libnvidia-decode-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up xserver-xorg-video-nvidia-470 (470.63.01-0ubuntu0.20.04.2) ...
Setting up libnvidia-ifr1-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
Setting up nvidia-dkms-470 (470.63.01-0ubuntu0.20.04.2) ...
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
Loading new nvidia-470.63.01 DKMS files...
Building for 5.4.0-84-generic 5.4.0-88-generic
Building for architecture x86_64
Building initial module for 5.4.0-84-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-kernel-source-470.0.crash'
Error! Bad return status for module build on kernel: 5.4.0-84-generic (x86_64)
Consult /var/lib/dkms/nvidia/470.63.01/build/make.log for more information.
dpkg: error processing package nvidia-dkms-470 (--configure):
installed nvidia-dkms-470 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of nvidia-driver-470:
nvidia-driver-470 depends on nvidia-dkms-470 (<= 470.63.01-1); however:
Package nvidia-dkms-470 is not configured yet.
nvidia-driver-470 depends on nvidia-dkms-470 (>= 470.63.01); however:
dpkg: error processing package nvidia-driver-470 (--configure):
dependency problems - leaving unconfigured
Setting up libnvidia-encode-470:amd64 (470.63.01-0ubuntu0.20.04.2) ...
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu2) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for initramfs-tools (0.136ubuntu6.6) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-88-generic
Errors were encountered while processing:
nvidia-dkms-470
nvidia-driver-470
E: Sub-process /usr/bin/dpkg returned an error code (1)
Am I doing something obviously wrong, is there a workaround, or is this something that will be fixed in the future?
Many thanks and best regards
make.log (359.8 KB)
