bumping up, so maybe some good Nvidia dev will have a mercy on my errors ;-)
Also here is the summary of what seems to be most important in these logs:
Jan 17 21:13:25 tcl-tuxedo kernel: NVRM: GPU 0000:07:00.0: RmInitAdapter failed! (0x26:0x56:1489)
2025-01-17T22:33:46.172698+01:00 morgwai-xps13 kernel: NVRM: GPU at PCI:0000:07:00: GPU-8aeb4eea-1497-5109-edbd-045d9bd60b8e
2025-01-17T22:33:46.172707+01:00 morgwai-xps13 kernel: NVRM: Xid (PCI:0000:07:00): 79, pid=‘’, name=, GPU has fallen off the bus.
2025-01-17T22:33:46.172708+01:00 morgwai-xps13 kernel: NVRM: GPU 0000:07:00.0: GPU has fallen off the bus.
2025-01-17T22:33:46.172708+01:00 morgwai-xps13 kernel: NVRM: kgspRcAndNotifyAllChannels_IMPL: RC all channels for critical error 79.
2025-01-17T22:33:46.172709+01:00 morgwai-xps13 kernel: NVRM: _threadNodeCheckTimeout: API_GPU_ATTACHED_SANITY_CHECK failed!
2025-01-17T22:33:46.172713+01:00 morgwai-xps13 kernel: message repeated 5 times: [ NVRM: _threadNodeCheckTimeout: API_GPU_ATTACHED_SANITY_CHECK failed!]
2025-01-17T22:33:46.172714+01:00 morgwai-xps13 kernel: NVRM: prbEncStartAlloc: Can’t allocate memory for protocol buffers.
2025-01-17T22:33:46.172717+01:00 morgwai-xps13 kernel: NVRM: A GPU crash dump has been created. If possible, please run
2025-01-17T22:33:46.172717+01:00 morgwai-xps13 kernel: NVRM: nvidia-bug-report.sh as root to collect this data before
2025-01-17T22:33:46.172718+01:00 morgwai-xps13 kernel: NVRM: the NVIDIA kernel module is unloaded.
2025-01-17T22:33:46.172718+01:00 morgwai-xps13 kernel: NVRM: _issueRpcAndWait: rpcSendMessage failed with status 0x0000000f for fn 78!
2025-01-17T22:33:46.172719+01:00 morgwai-xps13 kernel: NVRM: nvCheckOkFailedNoLog: Check failed: GPU lost from the bus [NV_ERR_GPU_IS_LOST] (0x0000000F) returned from nvdEngineDumpCallbackHelper(pGpu, pPrbEnc, pNvDumpState, pEngineCallback) @ nv_debug_dump.c:274
2025-01-17T22:33:46.172719+01:00 morgwai-xps13 kernel: NVRM: _issueRpcAndWait: rpcSendMessage failed with status 0x0000000f for fn 78!
2025-01-17T22:33:46.172720+01:00 morgwai-xps13 kernel: NVRM: _issueRpcAndWait: rpcSendMessage failed with status 0x0000000f for fn 78!
2025-01-17T22:33:46.172720+01:00 morgwai-xps13 kernel: NVRM: nvCheckOkFailedNoLog: Check failed: GPU lost from the bus [NV_ERR_GPU_IS_LOST] (0x0000000F) returned from nvdEngineDumpCallbackHelper(pGpu, pPrbEnc, pNvDumpState, pEngineCallback) @ nv_debug_dump.c:274
2025-01-17T22:33:46.172720+01:00 morgwai-xps13 kernel: NVRM: nvAssertFailedNoLog: Assertion failed: status == NV_OK @ journal.c:2143
2025-01-17T22:33:46.638715+01:00 morgwai-xps13 kernel: NVRM: Attempting to remove device 0000:07:00.0 with non-zero usage count!
2025-01-17T22:35:01.847722+01:00 morgwai-xps13 kernel: NVRM: _issueRpcAndWait: rpcSendMessage failed with status 0x0000000f for fn 78!
2025-01-17T22:35:01.847741+01:00 morgwai-xps13 kernel: NVRM: _issueRpcAndWait: rpcSendMessage failed with status 0x0000000f for fn 78!
2025-01-17T23:10:35.419775+01:00 morgwai-xps13 kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
2025-01-17T23:10:35.463816+01:00 morgwai-xps13 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.120 Fri Sep 13 10:10:01 UTC 2024
2025-01-17T23:10:35.580773+01:00 morgwai-xps13 kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.120 Fri Sep 13 10:01:25 UTC 2024
2025-01-17T23:10:35.744778+01:00 morgwai-xps13 kernel: [drm] [nvidia-drm] [GPU ID 0x00000700] Loading driver
2025-01-17T23:10:37.022767+01:00 morgwai-xps13 kernel: NVRM: GPU 0000:07:00.0: RmInitAdapter failed! (0x26:0x56:1610)
2025-01-17T23:10:37.022794+01:00 morgwai-xps13 kernel: NVRM: GPU 0000:07:00.0: rm_init_adapter failed, device minor number 0
2025-01-17T23:10:37.022796+01:00 morgwai-xps13 kernel: [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000700] Failed to allocate NvKmsKapiDevice
2025-01-17T23:10:37.022805+01:00 morgwai-xps13 kernel: [drm:nv_drm_register_drm_device [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000700] Failed to register device
2025-01-17T23:10:38.519757+01:00 morgwai-xps13 kernel: nvidia-uvm: Loaded the UVM driver, major device number 507.
2025-01-17T23:10:50.818798+01:00 morgwai-xps13 kernel: NVRM: GPU 0000:07:00.0: RmInitAdapter failed! (0x26:0x56:1610)
2025-01-17T23:10:50.818815+01:00 morgwai-xps13 kernel: NVRM: GPU 0000:07:00.0: rm_init_adapter failed, device minor number 0
(so there’s RmInitAdapter also, but with different code: 0x26:0x56:1610)
[ 8.322455] ------------[ cut here ]------------
[ 8.322461] WARNING: CPU: 15 PID: 1087 at drivers/gpu/drm/drm_file.c:312 drm_open_helper+0x132/0x150 [drm]
[ 8.322516] Modules linked in: qrtr rfcomm cmac algif_hash algif_skcipher af_alg bnep nvidia_drm(POE) nvidia_modeset(POE) binfmt_misc nls_ascii nls_cp437 vfat fat nvidia(POE) amd_atl intel_rapl_msr intel_rapl_common iwlmvm edac_mce_amd snd_sof_amd_rembrandt snd_sof_amd_acp kvm_amd snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_hda_codec_conexant snd_sof snd_hda_codec_generic kvm libarc4 snd_hda_codec_hdmi snd_sof_utils iwlwifi snd_hda_intel snd_soc_core snd_intel_dspcfg snd_intel_sdw_acpi btusb uvcvideo btrtl snd_hda_codec crct10dif_pclmul snd_compress btintel videobuf2_vmalloc ghash_clmulni_intel snd_pcm_dmaengine uvc sha512_ssse3 btbcm videobuf2_memops videobuf2_v4l2 btmtk sha256_ssse3 snd_pci_ps videodev snd_hda_core cfg80211 sha1_ssse3 snd_rpl_pci_acp6x bluetooth snd_pci_acp6x snd_hwdep videobuf2_common aesni_intel snd_pcm gf128mul mc crypto_simd asus_wmi cryptd sparse_keymap rapl platform_profile snd_pci_acp5x spd5118 wmi_bmof snd_timer snd_rn_pci_acp3x pcspkr ucsi_acpi snd_acp_config k10temp snd snd_soc_acpi
[ 8.322640] typec_ucsi sp5100_tco ccp rfkill snd_pci_acp3x watchdog typec soundcore roles amd_pmc joydev ac evdev serio_raw parport_pc ppdev lp parport configfs efi_pstore nfnetlink efivarfs ip_tables x_tables autofs4 ext4 mbcache jbd2 crc32c_generic usbhid amdgpu amdxcp drm_exec gpu_sched drm_buddy i2c_algo_bit drm_suballoc_helper drm_display_helper cec rc_core hid_multitouch drm_ttm_helper hid_generic xhci_pci xhci_hcd sdhci_pci ttm i2c_hid_acpi i2c_hid cqhci hid drm_kms_helper nvme thunderbolt sdhci usbcore nvme_core drm i2c_piix4 crc32_pclmul mmc_core crc32c_intel i2c_smbus nvme_auth crc16 usb_common video battery button wmi
[ 8.322750] CPU: 15 UID: 0 PID: 1087 Comm: Xorg.wrap Tainted: P OE 6.12.9-amd64 #1 Debian 6.12.9-1
[ 8.322758] Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 8.322760] Hardware name: TUXEDO TUXEDO InfinityBook Pro AMD Gen9/GXxHRXx, BIOS N.1.14A12 11/12/2024
[ 8.322763] RIP: 0010:drm_open_helper+0x132/0x150 [drm]
[ 8.322794] Code: 7f a4 eb 31 c0 48 83 c4 08 5b 5d 41 5c 41 5d 41 5e 41 5f e9 db b2 c5 eb 48 89 df 89 44 24 04 e8 64 fa ff ff 8b 44 24 04 eb db <0f> 0b b8 ea ff ff ff eb d2 b8 ea ff ff ff eb cb b8 f0 ff ff ff eb
[ 8.322798] RSP: 0018:ffffadf042473a50 EFLAGS: 00010246
[ 8.322803] RAX: ffffffffc2026220 RBX: ffff9a630f26d1a8 RCX: 0000000000000000
[ 8.322806] RDX: ffff9a63188cc000 RSI: ffff9a630f26d1a8 RDI: ffff9a64699ed8c0
[ 8.322808] RBP: ffff9a64699ed8c0 R08: ffff9a6322c6f678 R09: ffff9a63001c51d0
[ 8.322810] R10: 00000000000000e2 R11: 0000000000000002 R12: ffff9a63094bc000
[ 8.322813] R13: ffffffffc2026220 R14: 00000000ffffffed R15: ffff9a630e7267d0
[ 8.322816] FS: 00007fc076404740(0000) GS:ffff9a71a0180000(0000) knlGS:0000000000000000
[ 8.322819] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 8.322822] CR2: 00005568536c7fc0 CR3: 0000000113db6000 CR4: 0000000000f50ef0
[ 8.322825] PKRU: 55555554
[ 8.322827] Call Trace:
[ 8.322834]
[ 8.322838] ? drm_open_helper+0x132/0x150 [drm]
[ 8.322864] ? __warn.cold+0x93/0xf6
[ 8.322872] ? drm_open_helper+0x132/0x150 [drm]
[ 8.322903] ? report_bug+0xff/0x140
[ 8.322910] ? handle_bug+0x58/0x90
[ 8.322914] ? exc_invalid_op+0x17/0x70
[ 8.322918] ? asm_exc_invalid_op+0x1a/0x20
[ 8.322930] ? drm_open_helper+0x132/0x150 [drm]
[ 8.322958] drm_open+0x73/0x110 [drm]
[ 8.322986] drm_stub_open+0x9b/0xd0 [drm]
[ 8.323020] chrdev_open+0xb2/0x230
[ 8.323027] ? __pfx_chrdev_open+0x10/0x10
[ 8.323032] do_dentry_open+0x14c/0x440
[ 8.323039] vfs_open+0x2e/0xe0
[ 8.323045] path_openat+0x82e/0x12d0
[ 8.323051] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323055] ? kfree+0x2ec/0x360
[ 8.323062] do_filp_open+0xc4/0x170
[ 8.323075] do_sys_openat2+0xae/0xe0
[ 8.323082] __x64_sys_openat+0x55/0xa0
[ 8.323086] do_syscall_64+0x82/0x190
[ 8.323092] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323096] ? do_syscall_64+0x8e/0x190
[ 8.323101] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323104] ? __pm_runtime_suspend+0x69/0xc0
[ 8.323111] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323115] ? amdgpu_drm_ioctl+0x6e/0x80 [amdgpu]
[ 8.323422] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323426] ? syscall_exit_to_user_mode+0x4d/0x210
[ 8.323432] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323435] ? do_syscall_64+0x8e/0x190
[ 8.323440] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323443] ? count_memcg_events.constprop.0+0x1a/0x30
[ 8.323447] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323450] ? handle_mm_fault+0x1bb/0x2c0
[ 8.323456] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323459] ? do_user_addr_fault+0x36c/0x620
[ 8.323467] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323471] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.323475] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 8.323480] RIP: 0033:0x7fc076509c3c
[ 8.323516] Code: 83 e2 40 75 51 89 f0 f7 d0 a9 00 00 41 00 74 46 80 3d 37 c4 0e 00 00 74 6a 89 da 48 89 ee bf 9c ff ff ff b8 01 01 00 00 0f 05 <48> 3d 00 f0 ff ff 0f 87 90 00 00 00 48 8b 54 24 28 64 48 2b 14 25
[ 8.323519] RSP: 002b:00007fff50de6720 EFLAGS: 00000202 ORIG_RAX: 0000000000000101
[ 8.323523] RAX: ffffffffffffffda RBX: 0000000000000002 RCX: 00007fc076509c3c
[ 8.323526] RDX: 0000000000000002 RSI: 00007fff50de68a0 RDI: 00000000ffffff9c
[ 8.323528] RBP: 00007fff50de68a0 R08: 0000000000000064 R09: 00000000ffffffff
[ 8.323530] R10: 0000000000000000 R11: 0000000000000202 R12: 00007fff50de68a0
[ 8.323533] R13: 0000000000000001 R14: 00000000c04064a0 R15: 0000000000000001
[ 8.323541]
[ 8.323543] —[ end trace 0000000000000000 ]—
[ 8.550260] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
[ 8.550419] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 9.298094] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
[ 9.298174] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 11.413079] wlp3s0: authenticate with 60:38:e0:a3:47:4c (local address=08:b4:d2:83:47:94)
[ 11.414330] wlp3s0: send auth to 60:38:e0:a3:47:4c (try 1/3)
[ 11.455542] wlp3s0: authenticated
[ 11.456380] wlp3s0: associate with 60:38:e0:a3:47:4c (try 1/3)
[ 11.459166] wlp3s0: RX AssocResp from 60:38:e0:a3:47:4c (capab=0x411 status=0 aid=3)
[ 11.470978] wlp3s0: associated
[ 19.727896] amdgpu 0000:66:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn31_program_compbuf_size line:141
[ 19.727963] ------------[ cut here ]------------
[ 19.727964] WARNING: CPU: 3 PID: 1087 at drivers/gpu/drm/amd/amdgpu/…/display/dc/hubbub/dcn31/dcn31_hubbub.c:151 dcn31_program_compbuf_size+0xd1/0x230 [amdgpu]
[ 19.728216] Modules linked in: ccm snd_seq_dummy snd_hrtimer snd_seq snd_seq_device qrtr rfcomm cmac algif_hash algif_skcipher af_alg bnep nvidia_drm(POE) nvidia_modeset(POE) binfmt_misc nls_ascii nls_cp437 vfat fat nvidia(POE) amd_atl intel_rapl_msr intel_rapl_common iwlmvm edac_mce_amd snd_sof_amd_rembrandt snd_sof_amd_acp kvm_amd snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_hda_codec_conexant snd_sof snd_hda_codec_generic kvm libarc4 snd_hda_codec_hdmi snd_sof_utils iwlwifi snd_hda_intel snd_soc_core snd_intel_dspcfg snd_intel_sdw_acpi btusb uvcvideo btrtl snd_hda_codec crct10dif_pclmul snd_compress btintel videobuf2_vmalloc ghash_clmulni_intel snd_pcm_dmaengine uvc sha512_ssse3 btbcm videobuf2_memops videobuf2_v4l2 btmtk sha256_ssse3 snd_pci_ps videodev snd_hda_core cfg80211 sha1_ssse3 snd_rpl_pci_acp6x bluetooth snd_pci_acp6x snd_hwdep videobuf2_common aesni_intel snd_pcm gf128mul mc crypto_simd asus_wmi cryptd sparse_keymap rapl platform_profile snd_pci_acp5x spd5118 wmi_bmof snd_timer snd_rn_pci_acp3x pcspkr
[ 19.728273] ucsi_acpi snd_acp_config k10temp snd snd_soc_acpi typec_ucsi sp5100_tco ccp rfkill snd_pci_acp3x watchdog typec soundcore roles amd_pmc joydev ac evdev serio_raw parport_pc ppdev lp parport configfs efi_pstore nfnetlink efivarfs ip_tables x_tables autofs4 ext4 mbcache jbd2 crc32c_generic usbhid amdgpu amdxcp drm_exec gpu_sched drm_buddy i2c_algo_bit drm_suballoc_helper drm_display_helper cec rc_core hid_multitouch drm_ttm_helper hid_generic xhci_pci xhci_hcd sdhci_pci ttm i2c_hid_acpi i2c_hid cqhci hid drm_kms_helper nvme thunderbolt sdhci usbcore nvme_core drm i2c_piix4 crc32_pclmul mmc_core crc32c_intel i2c_smbus nvme_auth crc16 usb_common video battery button wmi
[ 19.728336] CPU: 3 UID: 0 PID: 1087 Comm: Xorg Tainted: P W OE 6.12.9-amd64 #1 Debian 6.12.9-1
[ 19.728340] Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 19.728342] Hardware name: TUXEDO TUXEDO InfinityBook Pro AMD Gen9/GXxHRXx, BIOS N.1.14A12 11/12/2024
[ 19.728344] RIP: 0010:dcn31_program_compbuf_size+0xd1/0x230 [amdgpu]
[ 19.728498] Code: 00 48 8b 43 28 8b 88 b0 01 00 00 48 8b 43 20 0f b6 50 6c 48 8b 43 18 8b b0 14 01 00 00 e8 a7 44 0e 00 85 c0 0f 85 33 01 00 00 <0f> 0b 48 8b 44 24 08 65 48 2b 04 25 28 00 00 00 0f 85 35 01 00 00
[ 19.728500] RSP: 0018:ffffadf0424733c8 EFLAGS: 00010202
[ 19.728502] RAX: 0000000000000001 RBX: ffff9a6305d87400 RCX: 000000000000001f
[ 19.728504] RDX: 0000000000000000 RSI: 000000000000397a RDI: ffff9a631d580000
[ 19.728505] RBP: 0000000000000004 R08: ffffadf0424733cc R09: 0000000000000019
[ 19.728506] R10: ffffffffaceb4348 R11: 0000000000000003 R12: ffff9a630e000000
[ 19.728507] R13: ffff9a632a000000 R14: ffff9a6305d87400 R15: 0000000000000001
[ 19.728508] FS: 00007f8fb3eacb00(0000) GS:ffff9a719fb80000(0000) knlGS:0000000000000000
[ 19.728509] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 19.728510] CR2: 00007f9d6a5af000 CR3: 00000001037c8000 CR4: 0000000000f50ef0
[ 19.728512] PKRU: 55555554
[ 19.728513] Call Trace:
[ 19.728516]
[ 19.728516]
[ 19.728517] ? dcn31_program_compbuf_size+0xd1/0x230 [amdgpu]
[ 19.728643] ? __warn.cold+0x93/0xf6
[ 19.728650] ? dcn31_program_compbuf_size+0xd1/0x230 [amdgpu]
[ 19.728747] ? report_bug+0xff/0x140
[ 19.728751] ? handle_bug+0x58/0x90
[ 19.728753] ? exc_invalid_op+0x17/0x70
[ 19.728755] ? asm_exc_invalid_op+0x1a/0x20
[ 19.728760] ? dcn31_program_compbuf_size+0xd1/0x230 [amdgpu]
[ 19.728850] ? dcn31_program_compbuf_size+0xc9/0x230 [amdgpu]
[ 19.728940] dcn20_optimize_bandwidth+0xe4/0x220 [amdgpu]
[ 19.729079] dc_commit_state_no_check+0xc5c/0xeb0 [amdgpu]
[ 19.729206] dc_commit_streams+0x31f/0x420 [amdgpu]
[ 19.729328] amdgpu_dm_atomic_commit_tail+0x738/0x3b40 [amdgpu]
[ 19.729481] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729484] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729485] ? dma_resv_get_fences+0xb2/0x2a0
[ 19.729490] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729491] ? dma_resv_get_singleton+0x44/0x140
[ 19.729494] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729495] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729496] ? wait_for_completion_timeout+0x13b/0x170
[ 19.729499] ? wait_for_completion_interruptible+0x12d/0x1e0
[ 19.729501] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729504] ? ttm_resource_move_to_lru_tail+0x10a/0x130 [ttm]
[ 19.729511] commit_tail+0x91/0x130 [drm_kms_helper]
[ 19.729522] drm_atomic_helper_commit+0x11a/0x140 [drm_kms_helper]
[ 19.729528] drm_atomic_commit+0xa6/0xe0 [drm]
[ 19.729551] ? __pfx___drm_printfn_info+0x10/0x10 [drm]
[ 19.729564] drm_atomic_connector_commit_dpms+0xe9/0x110 [drm]
[ 19.729576] drm_mode_obj_set_property_ioctl+0x1ba/0x3e0 [drm]
[ 19.729593] ? __pfx_drm_connector_property_set_ioctl+0x10/0x10 [drm]
[ 19.729606] drm_connector_property_set_ioctl+0x3d/0x60 [drm]
[ 19.729618] drm_ioctl_kernel+0xad/0x100 [drm]
[ 19.729634] drm_ioctl+0x277/0x4f0 [drm]
[ 19.729645] ? __pfx_drm_connector_property_set_ioctl+0x10/0x10 [drm]
[ 19.729658] amdgpu_drm_ioctl+0x4b/0x80 [amdgpu]
[ 19.729756] __x64_sys_ioctl+0x91/0xd0
[ 19.729760] do_syscall_64+0x82/0x190
[ 19.729764] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729765] ? syscall_exit_to_user_mode+0x164/0x210
[ 19.729768] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729769] ? do_syscall_64+0x8e/0x190
[ 19.729772] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729774] ? sock_poll+0x51/0xf0
[ 19.729777] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729778] ? ep_item_poll.isra.0+0x56/0x90
[ 19.729781] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729782] ? do_epoll_ctl+0x1e8/0x1020
[ 19.729786] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729787] ? syscall_exit_to_user_mode+0x164/0x210
[ 19.729789] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729790] ? do_syscall_64+0x8e/0x190
[ 19.729792] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729793] ? do_syscall_64+0x8e/0x190
[ 19.729795] ? ep_item_poll.isra.0+0x56/0x90
[ 19.729797] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729798] ? do_epoll_ctl+0x1e8/0x1020
[ 19.729800] ? do_syscall_64+0x8e/0x190
[ 19.729803] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729804] ? syscall_exit_to_user_mode+0x164/0x210
[ 19.729806] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729807] ? do_syscall_64+0x8e/0x190
[ 19.729810] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729811] ? syscall_exit_to_user_mode+0x172/0x210
[ 19.729813] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729815] ? do_syscall_64+0x8e/0x190
[ 19.729816] ? srso_alias_return_thunk+0x5/0xfbef5
[ 19.729818] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 19.729821] RIP: 0033:0x7f8fb424a33b
[ 19.729850] Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1c 48 8b 44 24 18 64 48 2b 04 25 28 00 00
[ 19.729851] RSP: 002b:00007ffed39f4bf0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 19.729853] RAX: ffffffffffffffda RBX: 0000560eb7bdb940 RCX: 00007f8fb424a33b
[ 19.729855] RDX: 00007ffed39f4c80 RSI: 00000000c01064ab RDI: 000000000000000f
[ 19.729856] RBP: 00007ffed39f4c80 R08: 0000560eb7bdfa00 R09: 0000000000000000
[ 19.729857] R10: 0000000000000000 R11: 0000000000000246 R12: 00000000c01064ab
[ 19.729858] R13: 000000000000000f R14: 0000560eb7bdb230 R15: 0000000000000000
[ 19.729861]
[ 19.729861] —[ end trace 0000000000000000 ]—
[ 29.733993] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
[ 29.734073] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 30.450106] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
[ 30.450185] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 31.369222] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 31.390848] nvidia-uvm: Loaded the UVM driver, major device number 511.
[ 155.084503] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
[ 155.084583] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
[ 155.802413] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
[ 155.802490] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
(so there’s a warning stack-trace from drm, then the same RmInitAdapter failed! (0x26:0x56:1489) as in the first log and finally a warning stack-trace from amdgpu).
