It wouldn’t let me attach a .gz file to the post so heres the output from nvidia-bug-report.sh
Start of NVIDIA bug report log file. Please include this file
when reporting a graphics driver bug via the nV News NVIDIA
Linux forum (see www.nvnews.net) or by sending email to
‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 14225146
Date: Wed Nov 7 12:31:19 EST 2012
uname: Linux phenom 3.6.5-gentoo #1 SMP Wed Nov 7 00:14:58 EST 2012 x86_64 AMD Phenom™ II X4 955 Processor AuthenticAMD GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 30 2007-04-05 07:18:42.000000000 -0400 /etc/issue
This is \n.\O (\s \m \r) \t
*** /etc/gentoo-release
*** ls: -rw-r–r-- 1 root root 31 2012-08-21 15:58:16.000000000 -0400 /etc/gentoo-release
Gentoo Base System release 2.2
*** /var/log/nvidia-installer.log does not exist
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root cciechad 8397 2012-11-07 11:55:40.496848831 -0500 /var/log/Xorg.0.log
[ 529.821]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 529.821] X Protocol Version 11, Revision 0
[ 529.821] Build Operating System: Linux 3.6.0-gentoo x86_64 Gentoo
[ 529.821] Current Operating System: Linux phenom 3.6.5-gentoo #1 SMP Wed Nov 7 00:14:58 EST 2012 x86_64
[ 529.821] Kernel command line: domdadm dolvm udev lvmroot=/dev/md1,/dev/md2,/dev/md3 root=/dev/ram0 real_root=/dev/mapper/raid5-slash panic=30
[ 529.821] Build Date: 06 November 2012 11:58:02PM
[ 529.821]
[ 529.821] Current version of pixman: 0.27.4
[ 529.821] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 529.821] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 529.821] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Nov 7 11:55:31 2012
[ 529.843] (==) Using config file: “/etc/X11/xorg.conf”
[ 529.843] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 529.863] (==) ServerLayout “Layout0”
[ 529.863] () |–>Screen “Screen0” (0)
[ 529.863] () | |–>Monitor “Monitor0”
[ 529.864] () | |–>Device “Device0”
[ 529.864] (==) Automatically adding devices
[ 529.864] (==) Automatically enabling devices
[ 529.911] (WW) The directory “/usr/share/fonts/TTF/” does not exist.
[ 529.911] Entry deleted from font path.
[ 529.911] (WW) The directory “/usr/share/fonts/OTF/” does not exist.
[ 529.911] (WW) The directory “/usr/share/fonts/Type1/” does not exist.
[ 529.911] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/". [ 529.911] Entry deleted from font path. [ 529.911] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/"). [ 529.916] (WW)
fonts.dir’ not found (or not valid) in “/usr/share/fonts/75dpi/”.
[ 529.916] Entry deleted from font path.
[ 529.916] (Run ‘mkfontdir’ on “/usr/share/fonts/75dpi/”).
[ 529.916] (==) FontPath set to:
/usr/share/fonts/misc/
[ 529.916] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 529.916] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 529.916] (II) Loader magic: 0x7d9b00
[ 529.916] (II) Module ABI versions:
[ 529.916] X.Org ANSI C Emulation: 0.4
[ 529.916] X.Org Video Driver: 12.1
[ 529.916] X.Org XInput driver : 16.0
[ 529.916] X.Org Server Extension : 6.0
[ 529.916] (–) PCI:*(0:1:0:0) 10de:1087:1462:2574 rev 161, Mem @ 0xf6000000/16777216, 0xc8000000/134217728, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/524288
[ 529.916] (–) PCI: (0:7:0:0) 10de:0ca3:1682:3001 rev 162, Mem @ 0xf4000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000b000/128, BIOS @ 0x???/524288
[ 529.916] (II) Open ACPI successful (/var/run/acpid.socket)
[ 529.916] (II) “extmod” will be loaded. This was enabled by default and also specified in the config file.
[ 529.916] (II) “dbe” will be loaded. This was enabled by default and also specified in the config file.
[ 529.916] (II) “glx” will be loaded. This was enabled by default and also specified in the config file.
[ 529.916] (II) “record” will be loaded by default.
[ 529.916] (II) “dri” will be loaded by default.
[ 529.916] (II) “dri2” will be loaded by default.
[ 529.916] (II) LoadModule: “extmod”
[ 529.943] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[ 529.957] (II) Module extmod: vendor=“X.Org Foundation”
[ 529.957] compiled for 1.12.4, module version = 1.0.0
[ 529.957] Module class: X.Org Server Extension
[ 529.957] ABI class: X.Org Server Extension, version 6.0
[ 529.957] (II) Loading extension MIT-SCREEN-SAVER
[ 529.957] (II) Loading extension XFree86-VidModeExtension
[ 529.957] (II) Loading extension XFree86-DGA
[ 529.957] (II) Loading extension DPMS
[ 529.957] (II) Loading extension XVideo
[ 529.957] (II) Loading extension XVideo-MotionCompensation
[ 529.957] (II) Loading extension X-Resource
[ 529.957] (II) LoadModule: “dbe”
[ 529.958] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[ 529.966] (II) Module dbe: vendor=“X.Org Foundation”
[ 529.966] compiled for 1.12.4, module version = 1.0.0
[ 529.966] Module class: X.Org Server Extension
[ 529.966] ABI class: X.Org Server Extension, version 6.0
[ 529.966] (II) Loading extension DOUBLE-BUFFER
[ 529.966] (II) LoadModule: “glx”
[ 529.974] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 530.037] (II) Module glx: vendor=“NVIDIA Corporation”
[ 530.037] compiled for 4.0.2, module version = 1.0.0
[ 530.037] Module class: X.Org Server Extension
[ 530.037] (II) NVIDIA GLX Module 304.64 Tue Oct 30 11:18:32 PDT 2012
[ 530.037] (II) Loading extension GLX
[ 530.037] (II) LoadModule: “record”
[ 530.037] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[ 530.045] (II) Module record: vendor=“X.Org Foundation”
[ 530.045] compiled for 1.12.4, module version = 1.13.0
[ 530.045] Module class: X.Org Server Extension
[ 530.045] ABI class: X.Org Server Extension, version 6.0
[ 530.045] (II) Loading extension RECORD
[ 530.045] (II) LoadModule: “dri”
[ 530.092] (WW) Warning, couldn’t open module dri
[ 530.092] (II) UnloadModule: “dri”
[ 530.092] (II) Unloading dri
[ 530.092] (EE) Failed to load module “dri” (module does not exist, 0)
[ 530.092] (II) LoadModule: “dri2”
[ 530.092] (WW) Warning, couldn’t open module dri2
[ 530.092] (II) UnloadModule: “dri2”
[ 530.092] (II) Unloading dri2
[ 530.092] (EE) Failed to load module “dri2” (module does not exist, 0)
[ 530.092] (II) LoadModule: “nvidia”
[ 530.092] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 530.156] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 530.156] compiled for 4.0.2, module version = 1.0.0
[ 530.156] Module class: X.Org Video Driver
[ 530.162] (II) NVIDIA dlloader X Driver 304.64 Tue Oct 30 10:59:51 PDT 2012
[ 530.162] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 530.166] (–) using VT number 7
[ 530.171] (II) Loading sub module “fb”
[ 530.171] (II) LoadModule: “fb”
[ 530.171] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 530.171] (II) Module fb: vendor=“X.Org Foundation”
[ 530.171] compiled for 1.12.4, module version = 1.0.0
[ 530.171] ABI class: X.Org ANSI C Emulation, version 0.4
[ 530.171] (II) Loading sub module “wfb”
[ 530.171] (II) LoadModule: “wfb”
[ 530.171] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 530.172] (II) Module wfb: vendor=“X.Org Foundation”
[ 530.172] compiled for 1.12.4, module version = 1.0.0
[ 530.172] ABI class: X.Org ANSI C Emulation, version 0.4
[ 530.172] (II) Loading sub module “ramdac”
[ 530.172] (II) LoadModule: “ramdac”
[ 530.172] (II) Module “ramdac” already built-in
[ 530.173] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 530.173] (==) NVIDIA(0): RGB weight 888
[ 530.173] (==) NVIDIA(0): Default visual is TrueColor
[ 530.173] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 530.173] () NVIDIA(0): Option “DPI” “100 x 100”
[ 530.173] (**) NVIDIA(0): Enabling 2D acceleration
[ 538.711] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[ 538.711] (EE) NVIDIA(0): check your system’s kernel log for additional error
[ 538.711] (EE) NVIDIA(0): messages and refer to Chapter 8: Common Problems in the
[ 538.711] (EE) NVIDIA(0): README for additional information.
[ 538.711] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device!
[ 538.711] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 538.711] (II) UnloadModule: “nvidia”
[ 538.711] (II) UnloadSubModule: “wfb”
[ 538.711] (II) UnloadSubModule: “fb”
[ 538.711] (EE) Screen(s) found, but none have a usable configuration.
[ 538.711]
Fatal server error:
[ 538.711] no screens found
[ 538.711]
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 538.711] Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 538.711]
[ 538.714] Server terminated with error (1). Closing log file.
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 690 2011-12-13 00:19:36.944408541 -0500 /etc/X11/xorg.conf
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
EndSection
Section “Files”
EndSection
Section “Module”
Load “extmod”
Load “dbe”
Load “type1”
Load “freetype”
Load “glx”
EndSection
Section “Monitor”
Identifier “Monitor0”
Option “DPMS” “true”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section “InputClass”
Identifier “keyboard-all”
Driver “evdev”
MatchIsKeyboard “On”
EndSection
*** /usr/share/X11/xorg.conf.d/10-evdev.conf
*** ls: -rw-r–r-- 1 root root 1099 2012-11-06 23:59:40.000000000 -0500 /usr/share/X11/xorg.conf.d/10-evdev.conf
Catch-all evdev loader for udev-based systems
We don’t simply match on any device since that also adds accelerometers
and other devices that we don’t really want to use. The list below
matches everything but joysticks.
Identifier “evdev pointer catchall”
MatchIsPointer “on”
MatchDevicePath “/dev/input/event*”
Driver “evdev”
EndSection
Identifier “evdev keyboard catchall”
MatchIsKeyboard “on”
Driver “evdev”
EndSection
Identifier “evdev touchpad catchall”
MatchIsTouchpad “on”
Driver “evdev”
EndSection
Identifier “evdev tablet catchall”
MatchIsTablet “on”
Driver “evdev”
EndSection
Identifier “evdev touchscreen catchall”
MatchIsTouchscreen “on”
Driver “evdev”
EndSection
Skipping ldd output (glxinfo not found)
/usr/sbin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GF110 [GeForce GTX 560 Ti 448 Cores] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. Device 2574
Flags: bus master, fast devsel, latency 0, IRQ 24
Memory at f6000000 (32-bit, non-prefetchable)
Memory at c8000000 (64-bit, prefetchable)
Memory at d0000000 (64-bit, prefetchable)
I/O ports at e000
[virtual] Expansion ROM at f7000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024
Kernel driver in use: nvidia
00: de 10 87 10 07 00 10 10 a1 00 00 03 00 00 80 00
10: 00 00 00 f6 0c 00 00 c8 00 00 00 00 0c 00 00 d0
20: 00 00 00 00 01 e0 00 00 00 00 00 00 62 14 74 25
30: 00 00 00 00 60 00 00 00 00 00 00 00 0a 01 00 00
40: 62 14 74 25 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
60: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 b4 02 00 e0 8d 2c 01
80: 10 29 00 00 01 2d 05 00 40 01 01 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00
a0: 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
b0: 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01:00.1 Audio device: NVIDIA Corporation GF110 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 25
Memory at f7080000 (32-bit, non-prefetchable)
Kernel driver in use: snd_hda_intel
00: de 10 09 0e 06 00 10 00 a1 00 03 04 10 00 80 00
10: 00 00 08 f7 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 62 14 74 25
30: 00 00 00 00 60 00 00 00 00 00 00 00 07 02 00 00
50: 00 00 00 00 00 00 00 00 ce d6 23 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 02 00 a0 8d 2c 01
80: 00 28 00 00 01 2d 05 00 4b 01 01 11 00 00 00 00
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
07:00.0 VGA compatible controller: NVIDIA Corporation GT215 [GeForce GT 240] (rev a2) (prog-if 00 [VGA controller])
Subsystem: XFX Pine Group Inc. Device 3001
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f4000000 (32-bit, non-prefetchable)
Memory at b0000000 (64-bit, prefetchable)
Memory at c0000000 (64-bit, prefetchable)
I/O ports at b000
Expansion ROM at f5000000 [disabled]
00: de 10 a3 0c 07 00 10 00 a2 00 00 03 10 00 80 00
10: 00 00 00 f4 0c 00 00 b0 00 00 00 00 0c 00 00 c0
20: 00 00 00 00 01 b0 00 00 00 00 00 00 82 16 01 30
30: 00 00 00 f5 60 00 00 00 00 00 00 00 0a 01 00 00
40: 82 16 01 30 00 00 00 00 00 00 00 00 00 00 00 00
50: 00 00 00 00 01 00 00 00 ce d6 23 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 b4 02 00 a0 8d 2c 01
80: 00 28 00 00 01 2d 04 00 48 00 01 11 00 00 00 00
07:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 33
Memory at f5080000 (32-bit, non-prefetchable)
00: de 10 e4 0b 06 00 10 00 a1 00 03 04 10 00 80 00
10: 00 00 08 f5 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 82 16 01 30
/usr/sbin/lspci -d “10b5:*” -v -xxx
/usr/sbin/lspci -t
-[0000:00]-±00.0
±00.2
±02.0-[01]–±00.0
| -00.1
±04.0-[02]----00.0
±05.0-[03]----00.0
±06.0-[04]----00.0
±09.0-[05]----00.0
±0a.0-[06]----00.0
±0b.0-[07]–±00.0
| -00.1
±11.0
±12.0
±12.2
±13.0
±13.2
±14.0
±14.3
±14.4-[08]----07.0
±14.5
±16.0
±16.2
±18.0
±18.1
±18.2
±18.3
-18.4
/usr/sbin/lspci -nn
00:00.0 Host bridge [0600]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (external gfx0 port B) [1002:5a14] (rev 02)
00:00.2 IOMMU [0806]: Advanced Micro Devices [AMD] nee ATI RD990 I/O Memory Management Unit (IOMMU) [1002:5a23]
00:02.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (PCI express gpp port B) [1002:5a16]
00:04.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (PCI express gpp port D) [1002:5a18]
00:05.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (PCI express gpp port E) [1002:5a19]
00:06.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (PCI express gpp port F) [1002:5a1a]
00:09.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (PCI express gpp port H) [1002:5a1c]
00:0a.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (external gfx1 port A) [1002:5a1d]
00:0b.0 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI RD890 PCI to PCI bridge (NB-SB link) [1002:5a1f]
00:11.0 SATA controller [0106]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] [1002:4391] (rev 40)
00:12.0 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller [1002:4397]
00:12.2 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller [1002:4396]
00:13.0 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller [1002:4397]
00:13.2 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller [1002:4396]
00:14.0 SMBus [0c05]: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller [1002:4385] (rev 42)
00:14.3 ISA bridge [0601]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 LPC host controller [1002:439d] (rev 40)
00:14.4 PCI bridge [0604]: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge [1002:4384] (rev 40)
00:14.5 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI2 Controller [1002:4399]
00:16.0 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller [1002:4397]
00:16.2 USB controller [0c03]: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller [1002:4396]
00:18.0 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration [1022:1200]
00:18.1 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor Address Map [1022:1201]
00:18.2 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller [1022:1202]
00:18.3 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control [1022:1203]
00:18.4 Host bridge [0600]: Advanced Micro Devices [AMD] Family 10h Processor Link Control [1022:1204]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF110 [GeForce GTX 560 Ti 448 Cores] [10de:1087] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation GF110 High Definition Audio Controller [10de:0e09] (rev a1)
02:00.0 SATA controller [0106]: JMicron Technology Corp. JMB362 SATA Controller [197b:2362] (rev 10)
03:00.0 SATA controller [0106]: JMicron Technology Corp. JMB362 SATA Controller [197b:2362] (rev 10)
04:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller [1b21:1042]
05:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller [1b21:1042]
06:00.0 Network controller [0280]: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
07:00.0 VGA compatible controller [0300]: NVIDIA Corporation GT215 [GeForce GT 240] [10de:0ca3] (rev a2)
07:00.1 Audio device [0403]: NVIDIA Corporation High Definition Audio Controller [10de:0be4] (rev a1)
08:07.0 FireWire (IEEE 1394) [0c00]: VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller [1106:3044] (rev c0)
Skipping lsusb output (lsusb not found)
/usr/sbin/dmidecode
dmidecode 2.11
SMBIOS 2.7 present.
55 structures occupying 2528 bytes.
Table at 0x000EED90.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 1604
Release Date: 10/16/2012
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 4096 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 4.6
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: To be filled by O.E.M.
Product Name: To be filled by O.E.M.
Version: To be filled by O.E.M.
Serial Number: To be filled by O.E.M.
UUID: 1F0090C0-00C6-1A00-8632-5404A64192DD
Wake-up Type: Power Switch
SKU Number: To be filled by O.E.M.
Family: To be filled by O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: SABERTOOTH 990FX
Version: Rev 1.xx
Serial Number: 112696470000535
Asset Tag: To be filled by O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To be filled by O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
Manufacturer: To Be Filled By O.E.M.
Type: Desktop
Lock: Not Present
Version: To Be Filled By O.E.M.
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: Socket 942
Type: Central Processor
Family: Phenom II
Manufacturer: AMD
ID: 42 0F 10 00 FF FB 8B 17
Signature: Family 16, Model 4, Stepping 2
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD Phenom™ II X4 955 Processor
Voltage: 1.4 V
External Clock: 200 MHz
Max Speed: 3200 MHz
Current Speed: 3200 MHz
Status: Populated, Enabled
Upgrade: Socket AM3
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Part Number: To Be Filled By O.E.M.
Core Count: 4
Core Enabled: 4
Thread Count: 4
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 512 kB
Maximum Size: 512 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: 1 ns
Error Correction Type: Multi-bit ECC
System Type: Unified
Associativity: 2-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 2048 kB
Maximum Size: 2048 kB
Pipeline Burst
Speed: 1 ns
Associativity: 16-way Set-associative
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 6144 kB
Maximum Size: 6144 kB
Pipeline Burst
Speed: 1 ns
Associativity: 48-way Set-associative
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: PS2Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: J2A1
External Reference Designator: TV Out
External Connector Type: Mini Centronics Type-14
Port Type: Other
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: J2A2A
External Reference Designator: COM A
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J2A2B
External Reference Designator: Video
External Connector Type: DB-15 female
Port Type: Video Port
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: J3A1
External Reference Designator: USB1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: USB3
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: J9A1 - TPM HDR
Internal Connector Type: Other
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: J9C1 - PCIE DOCKING CONN
Port Type: Other
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: J2B3 - CPU FAN
Port Type: Other
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: J6C2 - EXT HDMI
Port Type: Other
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: J3C1 - GMCH FAN
Port Type: Other
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: J1D1 - ITP
Port Type: Other
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: J9E2 - MDC INTPSR
Port Type: Other
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: J9E4 - MDC INTPSR
Port Type: Other
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: J9E3 - LPC HOT DOCKING
Port Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: J9E1 - SCAN MATRIX
Port Type: Other
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: J9G1 - LPC SIDE BAND
Port Type: Other
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: J8F1 - UNIFIED
Port Type: Other
Handle 0x001C, DMI type 8, 9 bytes
Internal Reference Designator: J6F1 - LVDS
Port Type: Other
Handle 0x001D, DMI type 8, 9 bytes
Internal Reference Designator: J2F1 - LAI FAN
Port Type: Other
Handle 0x001E, DMI type 8, 9 bytes
Internal Reference Designator: J2G1 - GFX VID
Port Type: Other
Handle 0x001F, DMI type 8, 9 bytes
Internal Reference Designator: J1G6 - AC JACK
Port Type: Other
Handle 0x0020, DMI type 9, 17 bytes
System Slot Information
Designation: J6B2
Type: x16 PCI Express
Current Usage: In Use
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Bus Address: 0000:00:01.0
Handle 0x0021, DMI type 9, 17 bytes
Designation: J6B1
Type: x1 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:1c.3
Handle 0x0022, DMI type 9, 17 bytes
Designation: J6D1
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Bus Address: 0000:00:1c.4
Handle 0x0023, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: To Be Filled By O.E.M.
Handle 0x0024, DMI type 11, 5 bytes
OEM Strings
String 1: To Be Filled By O.E.M.
String 2: To Be Filled By O.E.M.
String 3: To Be Filled By O.E.M.
String 4: To Be Filled By O.E.M.
Handle 0x0025, DMI type 12, 5 bytes
System Configuration Options
Option 1: To Be Filled By O.E.M.
Handle 0x0026, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Maximum Capacity: 32 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0027, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x003FFFFFFFF
Range Size: 16 GB
Physical Array Handle: 0x0026
Partition Width: 255
Handle 0x0028, DMI type 17, 34 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK0
Type: DDR3
Type Detail: Synchronous
Speed: 1333 MHz
Manufacturer: Manufacturer0
Serial Number: SerNum0
Asset Tag: AssetTagNum0
Part Number: Array1_PartNumber0
Rank: Unknown
Configured Clock Speed: 667 MHz
Handle 0x0029, DMI type 20, 35 bytes
Memory Device Mapped Address
Range Size: 16 GB
Physical Device Handle: 0x0028
Memory Array Mapped Address Handle: 0x0027
Partition Row Position: Unknown
Interleave Position: Unknown
Interleaved Data Depth: Unknown
Handle 0x002A, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK1
Type: DDR3
Speed: 1333 MHz
Manufacturer: Manufacturer1
Serial Number: SerNum1
Asset Tag: AssetTagNum1
Part Number: Array1_PartNumber1
Rank: Unknown
Handle 0x002B, DMI type 20, 35 bytes
Range Size: 16 GB
Physical Device Handle: 0x002A
Handle 0x002C, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM2
Bank Locator: BANK2
Type: DDR3
Speed: 1333 MHz
Manufacturer: Manufacturer2
Serial Number: SerNum2
Asset Tag: AssetTagNum2
Part Number: Array1_PartNumber2
Rank: Unknown
Handle 0x002D, DMI type 20, 35 bytes
Range Size: 16 GB
Physical Device Handle: 0x002C
Handle 0x002E, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM3
Bank Locator: BANK3
Type: DDR3
Speed: 1333 MHz
Manufacturer: Manufacturer3
Serial Number: SerNum3
Asset Tag: AssetTagNum3
Part Number: Array1_PartNumber3
Rank: Unknown
Handle 0x002F, DMI type 20, 35 bytes
Range Size: 16 GB
Physical Device Handle: 0x002E
Handle 0x0030, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0031, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard IGD
Type: Video
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:02.0
Handle 0x0032, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard LAN
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:19.0
Handle 0x0033, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Onboard 1394
Type: Other
Status: Enabled
Type Instance: 1
Bus Address: 0000:03:1c.2
Handle 0x0034, DMI type 139, 54 bytes
OEM-specific Type
Header and Data:
8B 36 34 00 00 1F C6 00 00 1A 86 32 04 04 32 55
F8 00 A2 02 A1 00 40 63 43 10 FE 81 03 DF 40 B2
00 20 00 73 3C 10 08 00 00 00 00 00 00 00 00 00
00 00 00 00 00 01
Strings:
V1394GUID
Handle 0x0035, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 8
en|US|iso8859-1
fr|FR|iso8859-1
es|ES|iso8859-1
de|DE|iso8859-1
ru|RU|iso8859-5
zh|TW|unicode
zh|CN|unicode
ja|JP|unicode
Currently Installed Language: en|US|iso8859-1
Handle 0x0037, DMI type 127, 4 bytes
End Of Table
/usr/bin/modinfo nvidia | grep vermagic
vermagic: 3.6.5-gentoo SMP mod_unload modversions
Scanning kernel log files for NVRM messages:
/var/log/messages:
Nov 5 08:48:33 phenom kernel: NVRM: API mismatch: the client has the version 304.60, but
Nov 5 08:48:33 phenom kernel: NVRM: this kernel module has the version 295.40. Please
Nov 5 08:48:33 phenom kernel: NVRM: make sure that this kernel module and all NVIDIA driver
Nov 5 08:48:33 phenom kernel: NVRM: components have the same version.
Nov 5 08:48:34 phenom kernel: NVRM: API mismatch: the client has the version 304.60, but
Nov 5 08:48:34 phenom kernel: NVRM: this kernel module has the version 295.40. Please
Nov 5 08:48:34 phenom kernel: NVRM: make sure that this kernel module and all NVIDIA driver
Nov 5 08:48:34 phenom kernel: NVRM: components have the same version.
Nov 5 08:49:18 phenom kernel: NVRM: API mismatch: the client has the version 304.60, but
Nov 5 08:49:18 phenom kernel: NVRM: this kernel module has the version 295.40. Please
Nov 5 08:49:18 phenom kernel: NVRM: make sure that this kernel module and all NVIDIA driver
Nov 5 08:49:18 phenom kernel: NVRM: components have the same version.
Nov 5 08:53:24 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.60 Sun Oct 14 20:23:00 PDT 2012
Nov 5 11:20:28 phenom kernel: NVRM: GPU at 0000:01:00: GPU-3ff527ed-944a-51ed-07e5-476f0dad40e4
Nov 5 11:20:28 phenom kernel: NVRM: Xid (0000:01:00): 32, Channel ID 00000001 intr 00040000
Nov 5 13:37:34 phenom kernel: NVRM: Xid (0000:01:00): 32, Channel ID 00000003 intr 00040000
Nov 5 13:38:00 phenom kernel: NVRM: Xid (0000:01:00): 32, Channel ID 00000001 intr 00040000
Nov 5 13:38:00 phenom kernel: NVRM: Xid (0000:01:00): 12, COCOD 00000001 5c00014f 00009039 00001f1c 42b5d2c7
Nov 5 13:38:16 phenom kernel: NVRM: Xid (0000:01:00): 31, Ch 00000003, engmask 00000101, intr 10000000
Nov 5 13:38:36 phenom kernel: NVRM: Xid (0000:01:00): 59, !0095(12ac)
Nov 5 23:45:40 phenom kernel: NVRM: Xid (0000:01:00): 31, Ch 00000000, engmask 00000101, intr 10000000
Nov 5 23:45:42 phenom kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Nov 5 23:45:57 phenom kernel: NVRM: Xid (0000:01:00): 8, Channel 00000001
Nov 5 23:45:59 phenom kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Nov 5 23:49:34 phenom kernel: NVRM: GPU at 0000:01:00.0 has fallen off the bus.
Nov 5 23:49:34 phenom kernel: NVRM: os_pci_init_handle: invalid context!
Nov 5 23:49:36 phenom kernel: NVRM: GPU at 0000:01:00.0 has fallen off the bus.
Nov 5 23:49:36 phenom kernel: NVRM: os_pci_init_handle: invalid context!
Nov 5 23:49:38 phenom kernel: NVRM: RmInitAdapter failed! (0x26:0xffffffff:1183)
Nov 5 23:49:38 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 5 23:50:07 phenom kernel: NVRM: VM: nvidia_exit_module:1262: 0xffff880116763cc0, 1 page(s), count = 1, flags = 0x00010015, key = 0x3773b0000, page_table = 0xffff880393f245e8
Nov 5 23:50:12 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.60 Sun Oct 14 20:23:00 PDT 2012
Nov 6 23:44:43 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.60 Sun Oct 14 20:23:00 PDT 2012
Nov 6 23:44:52 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 6 23:44:52 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 6 23:45:30 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 6 23:45:30 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 6 23:46:08 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 6 23:46:08 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 6 23:49:04 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.60 Sun Oct 14 20:23:00 PDT 2012
Nov 6 23:49:17 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 6 23:49:17 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 6 23:49:42 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 6 23:49:42 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 00:00:33 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.60 Sun Oct 14 20:23:00 PDT 2012
Nov 7 00:00:45 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 00:00:45 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 00:05:10 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.51 Tue Sep 18 17:16:56 PDT 2012
Nov 7 00:05:23 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 00:05:23 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 00:38:30 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.60 Sun Oct 14 20:23:00 PDT 2012
Nov 7 00:38:39 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 00:38:39 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 00:39:00 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 00:39:00 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 00:54:09 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.43 Sun Aug 19 20:14:03 PDT 2012
Nov 7 00:54:22 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 00:54:22 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 01:02:15 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.64 Tue Oct 30 10:58:20 PDT 2012
Nov 7 01:02:27 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 01:02:27 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 10:07:44 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 10:07:44 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 10:07:57 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 10:07:57 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 10:08:09 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 10:08:09 phenom kernel: NVRM: rm_init_adapter(0) failed
Nov 7 11:47:03 phenom kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.64 Tue Oct 30 10:58:20 PDT 2012
Nov 7 11:55:40 phenom kernel: NVRM: RmInitAdapter failed! (0x27:0x38:1203)
Nov 7 11:55:40 phenom kernel: NVRM: rm_init_adapter(0) failed
/var/log/kernel.log is not readable
dmesg:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.6.5-gentoo (root@phenom) (gcc version 4.6.3 (Gentoo 4.6.3 p1.6, pie-0.5.2) ) #1 SMP Wed Nov 7 00:14:58 EST 2012
[ 0.000000] Command line: domdadm dolvm udev lvmroot=/dev/md1,/dev/md2,/dev/md3 root=/dev/ram0 real_root=/dev/mapper/raid5-slash panic=30
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ad836fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ad837000-0x00000000ad885fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ad886000-0x00000000ad88ffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ad890000-0x00000000ad890fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ad891000-0x00000000adadcfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000adadd000-0x00000000adaedfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000adaee000-0x00000000adb02fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000adb03000-0x00000000adb04fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000adb05000-0x00000000adb0dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000adb0e000-0x00000000adb13fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000adb14000-0x00000000adb75fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000adb76000-0x00000000add78fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000add79000-0x00000000adefffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec20000-0x00000000fec20fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed61000-0x00000000fed70fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fef00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100001000-0x000000044fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI 2.7 present.
[ 0.000000] DMI: To be filled by O.E.M. To be filled by O.E.M./SABERTOOTH 990FX, BIOS 1604 10/16/2012
[ 0.000000] e820: update [mem 0x00000000-0x0000ffff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] No AGP bridge found
[ 0.000000] e820: last_pfn = 0x450000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-CDFFF write-protect
[ 0.000000] CE000-EBFFF uncachable
[ 0.000000] EC000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000ADF00000 mask FFFFFFF00000 uncachable
[ 0.000000] 3 base 0000AE000000 mask FFFFFE000000 uncachable
[ 0.000000] 4 base 0000B0000000 mask FFFFF0000000 uncachable
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000450000000 aka 17664M
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820: update [mem 0xadf00000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xadf00 max_arch_pfn = 0x400000000
[ 0.000000] initial memory mapped: [mem 0x00000000-0x1fffffff]
[ 0.000000] Base memory trampoline at [ffff880000097000] 97000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] init_memory_mapping: [mem 0x00000000-0xadefffff]
[ 0.000000] [mem 0x00000000-0x7fffffff] page 1G
[ 0.000000] [mem 0x80000000-0xaddfffff] page 2M
[ 0.000000] [mem 0xade00000-0xadefffff] page 4k
[ 0.000000] kernel direct mapping tables up to 0xadefffff @ [mem 0x1fffd000-0x1fffffff]
[ 0.000000] init_memory_mapping: [mem 0x100001000-0x44fffffff]
[ 0.000000] [mem 0x100001000-0x1001fffff] page 4k
[ 0.000000] [mem 0x100200000-0x13fffffff] page 2M
[ 0.000000] [mem 0x140000000-0x43fffffff] page 1G
[ 0.000000] [mem 0x440000000-0x44fffffff] page 2M
[ 0.000000] kernel direct mapping tables up to 0x44fffffff @ [mem 0xadefc000-0xadefffff]
[ 0.000000] RAMDISK: [mem 0x37cfd000-0x37feffff]
[ 0.000000] ACPI: RSDP 00000000000f0450 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 00000000ad886070 00054 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 00000000ad88ec48 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI BIOS Bug: Warning: Optional FADT field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20120711/tbfadt-598)
[ 0.000000] ACPI: DSDT 00000000ad886158 08AEC (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.000000] ACPI: FACS 00000000adb0ef80 00040
[ 0.000000] ACPI: APIC 00000000ad88ed40 0009E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 00000000ad88ede0 0003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: HPET 00000000ad88ee20 00038 (v01 ALASKA A M I 01072009 AMI 00000004)
[ 0.000000] ACPI: SSDT 00000000ad88ef90 008BC (v01 AMD POWERNOW 00000001 AMD 00000001)
[ 0.000000] ACPI: IVRS 00000000ad88eeb0 000E0 (v01 AMD RD890S 00202031 AMD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] [ffffea0000000000-ffffea00113fffff] PMD → [ffff88043f600000-ffff88044f5fffff] on node 0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00010000-0x00ffffff]
[ 0.000000] DMA32 [mem 0x01000000-0xffffffff]
[ 0.000000] Normal [mem 0x100000000-0x44fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00010000-0x0009cfff]
[ 0.000000] node 0: [mem 0x00100000-0xad836fff]
[ 0.000000] node 0: [mem 0xadd79000-0xadefffff]
[ 0.000000] node 0: [mem 0x100001000-0x44fffffff]
[ 0.000000] On node 0 totalpages: 4184394
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 6 pages reserved
[ 0.000000] DMA zone: 3911 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 16320 pages used for memmap
[ 0.000000] DMA32 zone: 690686 pages, LIFO batch:31
[ 0.000000] Normal zone: 54272 pages used for memmap
[ 0.000000] Normal zone: 3419135 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x06] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x08] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x05] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IOAPIC (id[0x06] address[0xfec20000] gsi_base[24])
[ 0.000000] IOAPIC[1]: apic_id 6, version 33, address 0xfec20000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x43538210 base: 0xfed00000
[ 0.000000] smpboot: 8 Processors exceeds NR_CPUS limit of 4
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 72
[ 0.000000] e820: [mem 0xadf00000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:4 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 26 pages/cpu @ffff88044fc00000 s77312 r8192 d20992 u524288
[ 0.000000] pcpu-alloc: s77312 r8192 d20992 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4113732
[ 0.000000] Kernel command line: domdadm dolvm udev lvmroot=/dev/md1,/dev/md2,/dev/md3 root=/dev/ram0 real_root=/dev/mapper/raid5-slash panic=30
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] Checking aperture…
[ 0.000000] Node 0: aperture @ f8000000 size 64 MB
[ 0.000000] Memory: 16374012k/18087936k available (4303k kernel code, 1350360k absent, 363564k reserved, 1767k data, 564k init)
[ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:4352 nr_irqs:1024 16
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.003333] tsc: Detected 3210.767 MHz processor
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency… 6424.09 BogoMIPS (lpj=10702556)
[ 0.000228] pid_max: default: 32768 minimum: 301
[ 0.000338] Mount-cache hash table entries: 256
[ 0.000546] Initializing cgroup subsys cpuacct
[ 0.000645] tseg: 00adf00000
[ 0.000647] CPU: Physical Processor ID: 0
[ 0.000731] CPU: Processor Core ID: 0
[ 0.000815] mce: CPU supports 6 MCE banks
[ 0.000903] LVT offset 0 assigned for vector 0xf9
[ 0.000993] process: using AMD E400 aware idle routine
[ 0.001084] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0
tlb_flushall_shift is 0xffffffff
[ 0.001779] ACPI: Core revision 20120711
[ 0.211747] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.244748] smpboot: CPU0: AMD Phenom™ II X4 955 Processor stepping 02
[ 0.349180] Performance Events: AMD PMU driver.
[ 0.349310] … version: 0
[ 0.349395] … bit width: 48
[ 0.349480] … generic registers: 4
[ 0.349564] … value mask: 0000ffffffffffff
[ 0.349655] … max period: 00007fffffffffff
[ 0.349745] … fixed-purpose events: 0
[ 0.349830] … event mask: 000000000000000f
[ 0.363210] process: System has AMD C1E enabled
[ 0.363229] process: Switch to broadcast mode on CPU1
[ 0.363429] process: Switch to broadcast mode on CPU0
[ 0.376742] process: Switch to broadcast mode on CPU2
[ 0.350028] smpboot: Booting Node 0, Processors #1 #2 #3 OK
[ 0.390095] process: Switch to broadcast mode on CPU3
[ 0.390194] Brought up 4 CPUs
[ 0.390276] smpboot: Total of 4 processors activated (25696.39 BogoMIPS)
[ 0.394757] devtmpfs: initialized
[ 0.394961] xor: automatically using best checksumming function:
[ 0.426400] generic_sse: 12806.400 MB/sec
[ 0.426515] NET: Registered protocol family 16
[ 0.426886] node 0 link 0: io port [a000, ffff]
[ 0.426888] TOM: 00000000b0000000 aka 2816M
[ 0.426975] Fam 10h mmconf [mem 0xe0000000-0xefffffff]
[ 0.426976] node 0 link 0: mmio [b0000000, fef0ffff] ==> [b0000000, dfffffff] and [f0000000, fef0ffff]
[ 0.426979] TOM2: 0000000450000000 aka 17664M
[ 0.427066] bus: [bus 00-1f] on node 0 link 0
[ 0.427067] bus: 00 [io 0x0000-0xffff]
[ 0.427068] bus: 00 [mem 0xb0000000-0xdfffffff]
[ 0.427069] bus: 00 [mem 0xf0000000-0xffffffff]
[ 0.427069] bus: 00 [mem 0x450000000-0xfcffffffff]
[ 0.427110] ACPI: bus type pci registered
[ 0.427255] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.427398] PCI: not using MMCONFIG
[ 0.427480] PCI: Using configuration type 1 for base access
[ 0.427602] PCI: Using configuration type 1 for extended access
[ 0.430826] bio: create slab at 0
[ 0.486230] raid6: sse2x1 4303 MB/s
[ 0.542733] raid6: sse2x2 7241 MB/s
[ 0.599233] raid6: sse2x4 8472 MB/s
[ 0.599317] raid6: using algorithm sse2x4 (8472 MB/s)
[ 0.599407] raid6: using intx1 recovery algorithm
[ 0.599572] ACPI: Added _OSI(Module Device)
[ 0.599657] ACPI: Added _OSI(Processor Device)
[ 0.599744] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.599832] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.600557] ACPI: EC: Look up EC in DSDT
[ 0.601160] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.619615] ACPI: Interpreter enabled
[ 0.619699] ACPI: (supports S0 S5)
[ 0.619899] ACPI: Using IOAPIC for interrupt routing
[ 0.620080] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.620243] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.658435] ACPI: EC: GPE = 0xa, I/O: command/status = 0x66, data = 0x62
[ 0.658640] ACPI: No dock devices found.
[ 0.658727] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.658966] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.659266] PCI host bridge to bus 0000:00
[ 0.659354] pci_bus 0000:00: busn_res: [bus 00-ff] is inserted under domain [bus 00-ff]
[ 0.659356] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.659448] pci_bus 0000:00: root bus resource [io 0x0000-0x03af]
[ 0.659543] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7]
[ 0.659638] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df]
[ 0.659733] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.659828] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.659926] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.660024] pci_bus 0000:00: root bus resource [mem 0xb0000000-0xffffffff]
[ 0.660133] pci 0000:00:00.0: [1002:5a14] type 00 class 0x060000
[ 0.660176] pci 0000:00:00.2: [1002:5a23] type 00 class 0x080600
[ 0.660218] pci 0000:00:02.0: [1002:5a16] type 01 class 0x060400
[ 0.660244] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.660257] pci 0000:00:04.0: [1002:5a18] type 01 class 0x060400
[ 0.660316] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[ 0.660327] pci 0000:00:05.0: [1002:5a19] type 01 class 0x060400
[ 0.660352] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[ 0.660363] pci 0000:00:06.0: [1002:5a1a] type 01 class 0x060400
[ 0.660388] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.660401] pci 0000:00:09.0: [1002:5a1c] type 01 class 0x060400
[ 0.660426] pci 0000:00:09.0: PME# supported from D0 D3hot D3cold
[ 0.660437] pci 0000:00:0a.0: [1002:5a1d] type 01 class 0x060400
[ 0.660463] pci 0000:00:0a.0: PME# supported from D0 D3hot D3cold
[ 0.660474] pci 0000:00:0b.0: [1002:5a1f] type 01 class 0x060400
[ 0.660500] pci 0000:00:0b.0: PME# supported from D0 D3hot D3cold
[ 0.660519] pci 0000:00:11.0: [1002:4391] type 00 class 0x010601
[ 0.660532] pci 0000:00:11.0: reg 10: [io 0xf040-0xf047]
[ 0.660539] pci 0000:00:11.0: reg 14: [io 0xf030-0xf033]
[ 0.660545] pci 0000:00:11.0: reg 18: [io 0xf020-0xf027]
[ 0.660552] pci 0000:00:11.0: reg 1c: [io 0xf010-0xf013]
[ 0.660558] pci 0000:00:11.0: reg 20: [io 0xf000-0xf00f]
[ 0.660565] pci 0000:00:11.0: reg 24: [mem 0xf5107000-0xf51073ff]
[ 0.660606] pci 0000:00:1
