Subject: YOLOv8 Custom Parser Not Generating Bounding Boxes (Output Shape: 1x5x8400)
DeepStream Version: 7.0
TensorRT Engine: Working (no error)
Custom Parser: Implemented
Model Output Shape: (1, 5, 8400)
Problem: No bounding boxes rendered
Parser Code: Included below
Expected Behavior: Boxes should be drawn for confident detections
Observed Behavior: No bounding boxes appear, even when confidence is high
Inference Log Output: Shows valid detections and dimensions (see std::cout
π Description:
I am using a YOLOv8 engine that outputs shape (1, 5, 8400)
β i.e., 5 channels: [x_center, y_center, width, height, confidence]
I implemented the following DeepStream custom parser (nvdsinfer_custom_impl.cpp
) to parse the output and populate objectList
The engine runs without error, the parser logs correct dimensions and boxes, but no bounding boxes are drawn in DeepStream.
I confirmed that objectList.push_back()
is called and populated correctly β but nothing appears visually.
π Parser Code:
#include "nvdsinfer_custom_impl.h"
#include <iostream>
#include <vector>
#include <algorithm>
#include <cstring>
extern "C" bool NvDsInferParseCustomYoloV8(
const std::vector<NvDsInferLayerInfo> &outputLayers,
const NvDsInferNetworkInfo &networkInfo,
const NvDsInferParseDetectionParams &detectionParams,
std::vector<NvDsInferObjectDetectionInfo> &objectList)
if (outputLayers.empty()) {
std::cerr << "No output layers found!" << std::endl;
return false;
const NvDsInferLayerInfo &layer = outputLayers[0];
const float *output = static_cast<const float *>(layer.buffer);
const NvDsInferDims &dims = layer.inferDims;
std::cout << "Layer Name: " << layer.layerName << std::endl;
std::cout << "Dims: numDims=" << dims.numDims << " | ";
for (unsigned int i = 0; i < dims.numDims; ++i)
std::cout << "d[" << i << "]=" << dims.d[i] << " ";
std::cout << std::endl;
int channels = 0;
int numBoxes = 0;
if (dims.numDims == 3 && dims.d[0] == 1 && dims.d[1] == 5) {
// Shape: (1, 5, 8400)
channels = dims.d[1];
numBoxes = dims.d[2];
else if (dims.numDims == 2 && dims.d[0] == 5) {
// Shape: (5, 8400)
channels = dims.d[0];
numBoxes = dims.d[1];
else {
std::cerr << "Unexpected output dims. Got: ";
std::cerr << dims.d[i] << (i == dims.numDims - 1 ? "" : "x");
std::cerr << std::endl;
return false;
for (int i = 0; i < numBoxes; ++i) {
float x_center = output[0 * numBoxes + i];
float y_center = output[1 * numBoxes + i];
float width = output[2 * numBoxes + i];
float height = output[3 * numBoxes + i];
float conf = output[4 * numBoxes + i];
if (conf < detectionParams.perClassThreshold[0]) // Default 0.3
continue;
float x = x_center - width / 2.0f;
float y = y_center - height / 2.0f;
NvDsInferObjectDetectionInfo obj;
obj.classId = 0;
obj.left = x * networkInfo.width;
obj.top = y * networkInfo.height;
obj.width = width * networkInfo.width;
obj.height = height * networkInfo.height;
obj.detectionConfidence = conf;
objectList.push_back(obj);
return true;
extern "C" bool NvDsInferParseCustomYoloV8Cuda(
return NvDsInferParseCustomYoloV8(outputLayers, networkInfo, detectionParams, objectList);
βQuestions:
- Is there any known issue with shape
(1, 5, 8400)
? - Do bounding boxes require a minimum size to appear visually?
- Could
nvosd
or downstream elements be filtering objects unintentionally? - Is there a different expected format for YOLOv8 output in DeepStream?
my config file is β
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=0
[source0]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test3/data/videp>
num-sources=1
[sink0]
enable=1
type=5
sync=0
gpu-id=0
[streammux]
batch-size=1
width=640
height=640
batched-push-timeout=40000
[property]
process-mode=1
enable=1
nvbuf-memory-type=0
network-input-shape=3;640;640
gpu-id=0
batch-size=1
interval=0
gie-unique-id=1
net-scale-factor=1.0
network-type=1
num-detected-classes=1
infer-dims=3;640;640
maintain-aspect-ratio=1
custom-lib-path=./libnvdsinfer_custom_yolov3.so
parse-bbox-func-name=NvDsInferParseCustomYoloV8
output-blob-names=output0
onnx-file=models/yolov8n-face-lindevs.onnx
model-engine-file=models/yolov8n-face-lindevs3.engine
labelfile-path=labels.txt
[class-attrs-all]
pre-cluster-threshold=0.1
topk=100
nms-iou-threshold=0.5
Any help is appreciated. Thank you.
