Trained a yolo_v4 TLTV3 model . The custom bounding box parser is not working properly after integrating into deepstream
tlt-infer output
pgie_config
output-blob-names=BatchedNMS
parse-bbox-func-name=NvDsInferParseCustomBatchedNMSTLT
But Getting wrong bounding boxes in Deepstream
Deepstream output
[Uploading: IMG_1708.JPG…](Deepstream output)
Can you share the config file of deepstream?
tlt-encoded-model=yolov4_resnet18_epoch_011.etlt
tlt-model-key=key
model-engine-file=yolov4_resnet18_epoch_011.etlt_b1_gpu0_fp16.engine
labelfile-path=./labels.txt
infer-dims=3;1280;1440
maintain-aspect-ratio=1
uff-input-order=0
uff-input-blob-name=Input
process-mode=1
network-mode=2
num-detected-classes=1
network-type=0
cluster-mode=3
custom-lib-path=libnvds_infercustomparser_tlt.so
[class-attrs-all]
# nms-iou-threshold=0.5
pre-cluster-threshold=0.1
Hi Morgan ,
Using the same pgie_yolov4_tlt_config.txt. Even getting the error
To narrow down, can you download sample yolo_v4 model to check if you can run it successfully?
cd deepstream_tlt_apps/
wget https://nvidia.box.com/shared/static/i1cer4s3ox4v8svbfkuj5js8yqm3yazo.zip -O models.zip
unzip models.zip
rm models.zip
