Nvidia_fs can't be loaded on RHEL9.2
based upon RHEL9.2 I have to setup CUDA 12.2.2 with nvidia driver 535.104.05.
While installing nvidia-fs-dkms the kernel module nvidia_fs gets compiled, but cannot be loaded:
  Running scriptlet: nvidia-fs-dkms-2.17.5-1.x86_64        41/84
/usr/bin/which: no ofed_info in (/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/usr/lib/dkms)
Deprecated feature: REMAKE_INITRD (/usr/src/nvidia-fs-2.17.5/dkms.conf)
Creating symlink /var/lib/dkms/nvidia-fs/2.17.5/source -> /usr/src/nvidia-fs-2.17.5
Sign command: /lib/modules/5.14.0-284.25.1.el9_2.x86_64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Deprecated feature: REMAKE_INITRD (/var/lib/dkms/nvidia-fs/2.17.5/source/dkms.conf)
Building module:
Cleaning build area...
'make' -j32 KVER=5.14.0-284.25.1.el9_2.x86_64 IGNORE_CC_MISMATCH='1'........
Signing module /var/lib/dkms/nvidia-fs/2.17.5/build/nvidia-fs.ko
nvidia-fs.ko.xz:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/5.14.0-284.25.1.el9_2.x86_64/extra/
Adding any weak-modules
depmod....
modprobe: ERROR: could not insert 'nvidia_fs': Unknown symbol in module, or unknown parameter (see dmesg)
dmesg says:
[454112.282587] nvidia_fs: module using GPL-only symbols uses symbols from proprietary module nvidia.
[454112.282591] nvidia_fs: Unknown symbol nvidia_p2p_dma_unmap_pages (err -2)
Does anybody has an idea what’s wrong and how to fix it? Any hint welcome!
Thanks & best regards,
Ruediger
