cloning the nvidia GIT repos seem not to be working at the moment. Could you please confirm?
git clone git://nv-tegra.nvidia.com/linux-5.10.git
fatal: unable to connect to nv-tegra.nvidia.com :
nv-tegra.nvidia.com [0: 35.82.181.43]: errno=Connection refused
nv-tegra.nvidia.com [1: 34.216.216.36]: errno=Connection refused
The source_sync.sh script included in the L4T fails.
Looking forward to your feedback.
Same here. Connection refused on all of them. Looks like they had config issues in 2022 that caused this - hopefully it’s something simple and won’t take a week to fix this time.
kayccc
April 17, 2025, 2:17am
3
Thanks for reproting this issue, I have forwarded this problem to internal team to fix it.
Please stay tuned. Thanks
When replacing the git:// into https:// works form most repositories except the kernel-jammy-src source for the moment to me.
0.242 Cloning into '/jetson/Linux_for_Tegra/source/kernel/kernel-jammy-src'...
61.27 error: RPC failed; HTTP 502 curl 22 The requested URL returned error: 502
61.27 fatal: error reading section header 'shallow-info'
61.27 /jetson/Linux_for_Tegra/source/kernel/kernel-jammy-src source sync failed!
Hi @kayccc ,
Thanks for your confirmation. Would you have an update or ETA to resolution? It still looks the same to me.
Best regards
kayccc
April 23, 2025, 11:28pm
6
From internal team at 8 hours ago:
If they were using the git protocol, it was still down, it’s up now
Supposed it should work, could you get it a try? Thanks
There are up again indeed, thanks a lot.
