Hello
I’m have difficulties with translating x86 architecture pipeline to Jetson Xavier architecture (JetPack 4.3).
Xavier (NV codecs) pipeline works fine when it is used with gst-launch-1.0 but it crash c++ application.
C++ application works fine on Xavier device with “x86” pipeline ( this pipeline is tested on x86 platform: Ubuntu 18.04) but then it is using too much cpu resources so I want to try hardware accelerated approach.
This application crashes while using accelerated pipeline with “segmentation fault (core dumped)” error.
Standard debug tools and Gstreamer debug tools shows nothing.
C++ application is using Gstreamer callbacks.
Those are the pipelines:
x86 pipeline:
udpsrc multicast-group=232.0.0.0 auto-multicast=true port=5000 multicast-iface=eth0 caps=“application/x-rtp, encoding-name=JPEG,payload=26” ! rtpjpegdepay ! jpegdec ! videoconvert ! video/x-raw, format=RGBA ! appsink name=sink emit-signals=true sync=false max-buffers=1 drop=true
Xavier (accelerated) pipeline:
udpsrc multicast-group=232.0.0.0 auto-multicast=true port=5000 multicast-iface=eth0 caps=“application/x-rtp, encoding-name=JPEG,payload=26” ! rtpjpegdepay ! nvjpegdec ! video/x-raw(memory:NVMM) ! nvvidconv ! video/x-raw, format=RGBA ! appsink name=sink emit-signals=true sync=false max-buffers=1 drop=true
