NVIDIA HPC SDK nvcc compiler can not compile a simple program
I’m trying to transit from old 19.10 pgc++ compiler (the license has expired) to the new NVIDIA HPC SDK’s nvc++ compiler. I installed NVIDIA HPC SDK on my PC: CPU 64-core Intel Xeon Phi KNL (Knights Landing) + NVIDIA Titan V GPU. I use the following compile line (https://forums.developer.nvidia.com/t/how-to-allocate-and-treat-class-member-dynamic-array-data-on-gpu/145851/3):
cmake . -DCMAKE_C_COMPILER=nvcc -DCMAKE_CXX_COMPILER=nvc++ -DCMAKE_C_FLAGS="-acc=gpu -Minfo=acc -mcmodel=medium -tp=haswell -Minline -cuda -gpu=cuda11.0,cc70" -DCMAKE_CXX_FLAGS="-acc=gpu -Minfo=acc -mcmodel=medium -tp=haswell -Minline -cuda -gpu=cuda11.0,cc70" -DCMAKE_CXX_STANDARD=17
But the compilation immediately fails with the output in the attached .txt file.
I have installed the NVIDIA HPC SDK:
nvc++ 20.7-0 LLVM 64-bit target on x86-64 Linux -tp knl
NVIDIA Compilers and Tools
Copyright (c) 2020, NVIDIA CORPORATION.  All rights reserved.
There is gcc 7.4.0 on my PC:
g++ (Debian 7.4.0-6) 7.4.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
And CUDA version 11 and NVIDIA GPU driver version 455.23.05:
[COMPILER_ERROR.txt|attachment](upload://ggrxnuyJ8MnyBlaWlnwLvh6NSOK.txt) (3.6 KB) NVIDIA-SMI 455.23.05    Driver Version: 455.23.05    CUDA Version: 11.1
How to get the nvc++ compiler to work?
It is written in the compiler output:
Check for working C compiler: /opt/nvidia/hpc_sdk/Linux_x86_64/20.7/compilers/bin/nvcc --
broken
Should I reinstall the compiler?
COMPILER_ERROR.txt (3.6 KB)
Hi _and,
Here’s the error from the text file:
Building C object CMakeFiles/cmTC_db1fc.dir/testCCompiler.c.o
/opt/nvidia/hpc_sdk/Linux_x86_64/20.7/compilers/bin/nvcc   -acc=gpu -Minfo=acc -mcmodel=medium -tp=haswell -Minline -cuda -gpu=cuda11.0,cc70    -o CMakeFiles/cmTC_db1fc.dir/testCCompiler.c.o   -c /data/70-gaa/Desktop/CURRENT_WORK/LAST_TRY/CMakeFiles/CMakeTmp/testCCompiler.c
nvcc fatal   : 'cmodel=medium': expected a number
The C compiler is called “nvc”, but here you’re trying to use “nvcc”, which is the CUDA C++ compiler so doesn’t recognize the “-mcmodel=medium” option. Try setting "-DCMAKE_C_COMPILER=nvc ".
-Mat
Thank You. With
it compiles and works properly.
I have another PC with CPU Intel Core i7 and GPU NVIDIA Geforce GTX 650 Ti (cc30) and OS Fedora 23.
It is rather an old operating system. Will Linux_x86_64 Tarball downloaded from https://developer.nvidia.com/nvidia-hpc-sdk-downloads work on it or I have to update my OS from Fedora 23 to the current Fedora version? And does NVIDIA HPC SDK nvc++ compiler support this old GPU NVIDIA Geforce GTX 650 Ti (compute capability 3.0)? If it doesn’t support, the compiler nvc++ will not work with this graphics card or nevertheless I can try launching the code on GPU Geforce GTX 650 Ti using nvc++ compiler?
No sorry. NVIDIA discontinued support for CC3.0 devices awhile ago and as such the compilers no longer support it either.
Again, sorry, but no. CC3.0 devices are not forward compatible so binaries built targeting newer devices wont run.
Installing on older OSs might work, but is not something we test.
You can find a list of supported OSs at: NVIDIA HPC SDK Release Notes — HPC SDK Release Notes 26.1 documentation
