the aim is we currently have Centos7 & want to deploy Nvidia drivers & docker containers to all machines with Ansible, but iI want to restrict install to a certain version/branch so the configuration of all are the same & upgrade process can be restricted & rolled out slowly.
this repo here is what our developers are after installing from
Looking at the repo, there’s no “branch locking” for dkms installs, only -latest.
For branch locking, you’ll have to use the standard kernel and the pre-compiled, non-dkms driver.
That’s the docker container, not a driver. There are no branches.
Regarding the driver repo, that’s only a preview supporting only one older kernel.
Since there’s no further info about that, I don’t know if that ever went to production, if RH took over or this was just dropped silently. Only just noticed that you can’t even download any other driver but the .run installer directly from nvidia anymore now.
Maybe some nvidia staff member will be so kind to clear things up.
the aim is we currently have Centos7 & want to deploy Nvidia drivers & docker containers to all machines with Ansible, but i want to restrict install to a certain version/branch so configuration of all are the same & upgrade process can be restrticted & rolled out slowly.
