Are there some differences between them? I understand that #1 uses dkms and #2 doesn’t. If dkms package is used, then kernel update would not break the driver. Is my understanding correct?
First of all, don’t install “cuda” but cuda-toolkit. The “cuda” metapackage also includes the driver.
The non-dkms package includes pre-compiled kernel modules, so they will be updated alongside the kernel. Those are only available for the stock kernel.
Thanks for your response.
I don’t understand for “don’t install “cuda” but cuda-toolkit”. Did you mean directly using the command “yum install cuda” to install both driver and toolkit?
If you want to take control over which driver gets installed, use yum install cuda-toolkit after installing the nvidia driver.
If you don’t care which driver gets installed then you can just install full “cuda” and call it a day. But then I don’t understand your initial question.
I ran the command “yum install cuda” on my centos7, and found the following in the output:
→ Finished Dependency Resolution
NVIDIA: No kernel module package kmod-nvidia-latest for kernel-3.10.0-1160.59.1.el7.x86_64 and 3:nvidia-driver-latest-510.47.03-1.el7.x86_64 found. Ignoring the new kernel
Then it installed kmod-nvidia-latest-dkms.
As per our previous discussion, “yum install cuda” uses nvidia-driver-latest package, which includes pre-compiled kernel modules. When the pre-compiled kernel modules like kmod-nvidia-latest is not availble, it installs kmod-nvidia-latest-dkms.
I have the same problem, and nvidia does not allow to post,
mine is this:
I installed alma9.3 (I guess very similar to centos),
and now I have probloem of nvidia,
I tried installing epel-release and nvidia-detect,
but when I type nvidia detect it shows nothing.
nvidia-smi:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
