I try to install CUDA on my Ubuntu environment, but I always get error “dpkg: error processing package nvidia-dkms-550”
Ubuntu 22.04.2
Kernal: 6.2.0-26
GCC:11.4.0
GLIBC:2.35
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
Removing old nvidia-550.54.14 DKMS files…
Loading new nvidia-550.54.14 DKMS files…
Error! DKMS tree already contains: nvidia-550.54.14
You cannot add the same module/version combo more than once.
dpkg: error processing package nvidia-dkms-550 (–configure):
*** installed nvidia-dkms-550 package post-installation script subprocess returned error exit status 3***
Setting up cuda-profiler-api-12-4 (12.4.99-1) …
Setting up cuda-demo-suite-12-4 (12.4.99-1) …
Setting up cuda-nvdisasm-12-4 (12.4.99-1) …
Setting up cuda-nvvm-12-4 (12.4.99-1) …
Setting up cuda-nvprune-12-4 (12.4.99-1) …
Setting up nsight-systems-2023.4.4 (2023.4.4.54-234433681190v0) …
update-alternatives: using /opt/nvidia/nsight-systems/2023.4.4/target-linux-x64/ nsys to provide /usr/local/bin/nsys (nsys) in manual mode
update-alternatives: using /opt/nvidia/nsight-systems/2023.4.4/host-linux-x64/ns ys-ui to provide /usr/local/bin/nsys-ui (nsys-ui) in manual mode
Setting up cuda-nvtx-12-4 (12.4.99-1) …
Setting up cuda-cuxxfilt-12-4 (12.4.99-1) …
Setting up nsight-compute-2024.1.0 (2024.1.0.13-1) …
Setting up cuda-nsight-12-4 (12.4.99-1) …
Setting up cuda-driver-dev-12-4 (12.4.99-1) …
Setting up cuda-nvprof-12-4 (12.4.99-1) …
Setting up cuda-cuobjdump-12-4 (12.4.99-1) …
Setting up cuda-toolkit-12-4-config-common (12.4.99-1) …
Setting alternatives
update-alternatives: using /usr/local/cuda-12.4 to provide /usr/local/cuda (cuda ) in auto mode
update-alternatives: using /usr/local/cuda-12.4 to provide /usr/local/cuda-12 (c uda-12) in auto mode
Setting up libnvjitlink-12-4 (12.4.99-1) …
Setting up cuda-nsight-systems-12-4 (12.4.0-1) …
Setting up cuda-nvrtc-12-4 (12.4.99-1) …
Setting up cuda-sanitizer-12-4 (12.4.99-1) …
Setting up libcurand-12-4 (10.3.5.119-1) …
dpkg: dependency problems prevent configuration of nvidia-driver-550:
nvidia-driver-550 depends on nvidia-dkms-550 (<= 550.54.14-1); however:
Package nvidia-dkms-550 is not configured yet.
nvidia-driver-550 depends on nvidia-dkms-550 (>= 550.54.14); however:
