there is no output
@tegra-ubuntu:~$ sudo modprobe nvidia-modeset
[sudo] password for ~:
@tegra-ubuntu:~$
there is no output
@tegra-ubuntu:~$
Then is nvidia-modeset
shown with lsmod
after the operation?
Still black screen?
lsmod result with nvidia_modeset
@tegra-ubuntu:~$ lsmod
Module Size Used by
nvidia_modeset 1093632 0
fuse 118784 3
lzo_rle 16384 64
lzo_compress 16384 1 lzo_rle
zram 32768 8
ramoops 28672 0
reed_solomon 20480 1 ramoops
bnep 28672 2
aes_ce_blk 36864 1
crypto_simd 24576 1 aes_ce_blk
rtk_btusb 65536 0
rtl8822ce 2994176 0
cryptd 28672 1 crypto_simd
btusb 53248 0
snd_soc_tegra210_ope 32768 1
snd_soc_tegra186_dspk 20480 2
aes_ce_cipher 20480 1 aes_ce_blk
snd_soc_tegra186_asrc 36864 1
btrtl 24576 1 btusb
ghash_ce 28672 0
snd_soc_tegra210_mvc 20480 2
snd_soc_tegra210_iqc 16384 0
btbcm 24576 1 btusb
snd_soc_tegra186_arad 24576 2 snd_soc_tegra186_asrc
snd_hda_codec_hdmi 57344 1
sha2_ce 20480 0
snd_soc_tegra210_afc 20480 6
snd_soc_tegra210_dmic 20480 4
snd_soc_tegra210_adsp 753664 1
snd_soc_tegra210_adx 28672 4
btintel 28672 1 btusb
sha256_arm64 28672 1 sha2_ce
snd_soc_tegra210_admaif 118784 1
snd_soc_tegra210_amx 32768 4
snd_hda_tegra 16384 0
ucsi_ccg 28672 0
snd_soc_tegra210_mixer 45056 1
snd_soc_tegra210_i2s 24576 6
snd_soc_tegra210_sfc 57344 4
snd_soc_tegra_machine_driver 16384 0
loop 36864 1
sha1_ce 20480 0
snd_soc_tegra_pcm 16384 1 snd_soc_tegra210_admaif
cfg80211 724992 1 rtl8822ce
snd_soc_tegra_utils 28672 3 snd_soc_tegra210_admaif,snd_soc_tegra_machine_driver,snd_soc_tegra210_adsp
snd_hda_codec 118784 2 snd_hda_codec_hdmi,snd_hda_tegra
typec_ucsi 32768 1 ucsi_ccg
typec 40960 1 typec_ucsi
snd_soc_simple_card_utils 24576 1 snd_soc_tegra_utils
snd_soc_spdif_tx 16384 0
snd_soc_tegra210_ahub 1257472 3 snd_soc_tegra210_ope,snd_soc_tegra210_sfc
nvadsp 110592 1 snd_soc_tegra210_adsp
snd_soc_rt5640 114688 1
snd_hda_core 81920 3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_tegra
nct1008 24576 0
tegra_bpmp_thermal 16384 0
userspace_alert 16384 0
tegra210_adma 28672 2 snd_soc_tegra210_admaif,snd_soc_tegra210_adsp
spi_tegra114 32768 0
snd_soc_rl6231 16384 1 snd_soc_rt5640
nvidia 1339392 1 nvidia_modeset
binfmt_misc 24576 1
ina3221 24576 0
pwm_fan 24576 0
nvgpu 2494464 0
nvmap 192512 2 nvgpu
ip_tables 36864 0
x_tables 49152 1 ip_tables
@tegra-ubuntu:~$ lsmod | grep nvidia
and it is still black
You need to restart the gdm3 process after you probe the driver.
sudo systemctl restart gdm3
Is command âsudo systemctl restart gdm3â? or âsudo systemctl restart gdm3.serviceâ?
@tegra-ubuntu:~$ sudo systemctl restart g
gdm3.service getty.target
gdm.service graphical.target
geoclue.service grub-common.service
getty-pre.target grub-initrd-fallback.service
getty-static.service
@tegra-ubuntu:~$ sudo systemctl restart gdm3
Warning: The unit file, source configuration file or drop-ins of gdm3.service changed on disk. Run 'systemctl daemon-reload' to reload units.
and should i run âsystemctl daemon-reloadâ?
sudo systemctl restart gdm3.service is equal to sudo systemctl restart gdm3.
Also run systemctl daemon-reload.
If the desktop still fails to show, please check if /var/log/Xorg.0.log got updated (check the time) and if it got updated, share the log again.
display still not work. i check changing of time when i run command âsystemctl daemon-reloadâ
@tegra-ubuntu:~$ modprobe nvidia-modeset
@tegra-ubuntu:~$ systemctl daemon-reload
==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
Authentication is required to reload the systemd state.
Authenticating as: ~
Password:
==== AUTHENTICATION COMPLETE ===
@tegra-ubuntu:~$ cat /var/log/Xorg.0.log
[ 2984.116] (--) Log file renamed from "/var/log/Xorg.pid-3071.log" to "/var/log/Xorg.0.log"
[ 2984.117]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[ 2984.117] Build Operating System: linux Ubuntu
[ 2984.117] Current Operating System: Linux tegra-ubuntu 5.10.104-tegra #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023 aarch64
[ 2984.117] Kernel command line: root=PARTUUID=1a31d192-41d2-44ad-8c1b-623a5ba1d0a0 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,1152
[ 2984.117] Build Date: 07 February 2023 12:48:13PM
[ 2984.117] xorg-server 2:1.20.13-1ubuntu1~20.04.6 (For technical support please see http://www.ubuntu.com/support)
[ 2984.117] Current version of pixman: 0.38.4
[ 2984.117] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2984.117] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2984.117] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 26 08:08:36 2023
[ 2984.117] (==) Using config file: "/etc/X11/xorg.conf"
[ 2984.117] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2984.117] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2984.118] (==) No Layout section. Using the first Screen section.
[ 2984.118] (==) No screen section available. Using defaults.
[ 2984.118] (**) |-->Screen "Default Screen Section" (0)
[ 2984.118] (**) | |-->Monitor "<default monitor>"
[ 2984.118] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 2984.118] (**) | |-->Device "Tegra0"
[ 2984.118] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 2984.118] (==) Automatically adding devices
[ 2984.118] (==) Automatically enabling devices
[ 2984.118] (==) Automatically adding GPU devices
[ 2984.118] (==) Automatically binding GPU devices
[ 2984.118] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2984.118] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 2984.118] Entry deleted from font path.
[ 2984.118] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 2984.118] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 2984.118] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 2984.118] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 2984.118] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 2984.118] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2984.118] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2984.118] (II) Loader magic: 0xaaaad3b8a010
[ 2984.118] (II) Module ABI versions:
[ 2984.118] X.Org ANSI C Emulation: 0.4
[ 2984.118] X.Org Video Driver: 24.1
[ 2984.118] X.Org XInput driver : 24.1
[ 2984.118] X.Org Server Extension : 10.0
[ 2984.120] (++) using VT number 1
[ 2984.122] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c5
[ 2984.123] (II) no primary bus or device found
[ 2984.123] (WW) "dri" will not be loaded unless you've specified it to be loaded elsewhere.
[ 2984.123] (II) "glx" will be loaded by default.
[ 2984.123] (II) LoadModule: "extmod"
[ 2984.124] (II) Module "extmod" already built-in
[ 2984.124] (II) LoadModule: "glx"
[ 2984.124] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2984.125] (II) Module glx: vendor="X.Org Foundation"
[ 2984.125] compiled for 1.20.13, module version = 1.0.0
[ 2984.125] ABI class: X.Org Server Extension, version 10.0
[ 2984.125] (II) LoadModule: "nvidia"
[ 2984.126] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 2984.131] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 2984.131] compiled for 1.6.99.901, module version = 1.0.0
[ 2984.131] Module class: X.Org Video Driver
[ 2984.131] (II) NVIDIA dlloader X Driver 35.3.1 Release Build (bugfix_main) (buildbrain@mobile-u64-6289-d7000) Sun Mar 19 08:03:06 PDT 2023
[ 2984.131] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 2984.131] (WW) Falling back to old probe method for NVIDIA
[ 2984.131] (II) Loading sub module "fb"
[ 2984.131] (II) LoadModule: "fb"
[ 2984.131] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2984.131] (II) Module fb: vendor="X.Org Foundation"
[ 2984.131] compiled for 1.20.13, module version = 1.0.0
[ 2984.131] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2984.131] (II) Loading sub module "wfb"
[ 2984.132] (II) LoadModule: "wfb"
[ 2984.132] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 2984.132] (II) Module wfb: vendor="X.Org Foundation"
[ 2984.132] compiled for 1.20.13, module version = 1.0.0
[ 2984.132] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2984.132] (II) Loading sub module "ramdac"
[ 2984.132] (II) LoadModule: "ramdac"
[ 2984.132] (II) Module "ramdac" already built-in
[ 2984.228] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2984.229] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2984.229] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 2984.229] (==) NVIDIA(0): RGB weight 888
[ 2984.229] (==) NVIDIA(0): Default visual is TrueColor
[ 2984.229] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2984.229] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 2984.229] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[ 2984.229] (**) NVIDIA(0): Enabling 2D acceleration
[ 2984.229] (II) Loading sub module "glxserver_nvidia"
[ 2984.229] (II) LoadModule: "glxserver_nvidia"
[ 2984.229] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 2984.232] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 2984.232] compiled for 1.6.99.901, module version = 1.0.0
[ 2984.232] Module class: X.Org Server Extension
[ 2984.233] (II) NVIDIA GLX Module 35.3.1 Release Build (bugfix_main) (buildbrain@mobile-u64-6289-d7000) Sun Mar 19 08:02:08 PDT 2023
[ 2984.233] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 2984.233] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 2984.233] (EE) NVIDIA(0): Failing initialization of X screen
[ 2984.233] (II) UnloadModule: "nvidia"
[ 2984.233] (II) UnloadSubModule: "glxserver_nvidia"
[ 2984.233] (II) Unloading glxserver_nvidia
[ 2984.233] (II) UnloadSubModule: "wfb"
[ 2984.233] (II) UnloadSubModule: "fb"
[ 2984.233] (EE) Screen(s) found, but none have a usable configuration.
[ 2984.233] (EE)
Fatal server error:
[ 2984.233] (EE) no screens found(EE)
[ 2984.233] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 2984.233] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 2984.233] (EE)
[ 2984.237] (EE) Server terminated with error (1). Closing log file.
Could you help me check if there is always no ânvidia-modesetâ in your lsmod command after each reboot?
If it is, could you modprobe it and share me the dmesg after you probed that?
Yes.
When i reboot jetson, there are no ânvidia-modesetâ in lsmod command output
nvidia 1339392 0
following txt file is dmesg output when i reboot jetson (before modprobe)
dmesg_before_modprobe.txt (70.2 KB)
and i run modprobe command
dmesg_after_modprobe.txt (70.4 KB)
Do you need dmesg output when i run âsudo systemctl restart gdm3â and âsystemctl daemon-reloadâ ?
Hi @knt0613
Could you wait for about few days ~ 1 week and try the new jetpack release?
Hi @knt0613
The JetPack 5.1.2 was released, please have a try to see if issue still presented. Thanks
