Hi
When i start to use Jetson AGX Orin delelop kit, the monitor was black after nvidia boot screen and system configure wizard. So i try to flash Jetson board using host computer and sdkmanager
This is my host computer setting
- ubuntu18.04.6 LTS
- kernel : 5.4.0-150-generic
I use SDK Manager 1.9.3.10904 and Jetpack 5.1.1
First i make jetson Force recovery mode. I check Jetson is under recovery mode using “lsusb” command (number 7023)(Quick Start — Jetson Linux<br/>Developer Guide 34.1 documentation)
and i choose “manaul setup” and try two options “OEM configuretion : Pre config / runtime”
In sdkmanager gui, it looks ok. but when i turn on the jetson board, it still not display after nvidia logo.
In sdkmanager termial, there are several error message during flashing.
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1719 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1831 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1836 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1838 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1840 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1842 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1845 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1847 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1848 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1848 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1848 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1849 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
15:28:38 ERROR: Flash Jetson Linux - flash: [ 0.1947 ] Error: Skip generating mem_bct because sdram_config is not defined
15:28:41 ERROR: Flash Jetson Linux - flash: [ 0.0130 ] ERROR: failed to read rcm_state
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0774 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0776 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0779 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0781 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0783 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0784 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0786 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0789 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0791 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0793 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0796 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0798 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0801 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0803 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
15:30:03 ERROR: Flash Jetson Linux - flash: [ 2.0805 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3952 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3955 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3957 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3958 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3960 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3962 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3963 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3965 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3966 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3968 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3969 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3970 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3972 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3973 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3974 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3976 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.3977 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4172 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4175 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4176 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4177 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4179 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4181 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4182 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4183 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4185 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4186 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4187 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4189 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4190 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4192 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4193 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4195 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
15:30:05 ERROR: Flash Jetson Linux - flash: [ 3.4196 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
15:43:28 SUMMARY: Flash Jetson Linux - flash: Install completed successfully.
so how works i can do to have a working monitor?
Following files are full sdk manager log and “dmesg” output in jetson orin using “minicom -D /dev/ttyUSB1 -8 -b 115200”
SDKM_logs_2023-07-25_14-16-01.zip (500.0 KB)
orin_serial_dmesg.txt (93.3 KB)
