Hi! I am working with the Jetson Nano Board and the Sony IMX290 (MIPI-CSI2) 2-lane camera and I have modified the device driver according to the “Driver Programming Guide”, the file is attached bellow. The camera is connected to CSI_C and I can detect /dev/video0 entry, also when I run:
$ v4l2-ctl –list-devices
I can see that the port bindings are correct. But, when I try to test the camera and take an image with the command:
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='Y10 ' --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=-test.raw
The camera is stuck in a loop and the .raw file is empty. In the dmesg log I get this output:
[ 247.045714] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00004000
[ 247.052931] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000012
[ 247.058639] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00060060
[ 247.064733] video4linux video0: tegra_channel_capture_setup(): valid_ports=1: width,height=1920,1080 word_count=2400
What I got from reading the CSI registers in the TRM manual it seems that the start sequence is not correct, but when I look at the start sequence on an oscilloscope it looks like the sequence stated in the camera manual.
Also, when I run the v42l-compliance test I get some errors, but I am not sure what they mean.
v4l2-compliance SHA : not available
Driver Info:
Driver name : tegra-video
Card type : vi-output, imx290 7-001a
Bus info : platform:54080000.vi:2
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 16
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1184): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
fail: v4l2-test-formats.cpp(434): pixelformat 20303159 (Y10 ) for buftype 1 not reported by ENUM_FMT
test VIDIOC_G_FMT: FAIL
test VIDIOC_TRY_FMT: OK (Not Supported)
test VIDIOC_S_FMT: OK (Not Supported)
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
fail: v4l2-test-buffers.cpp(574): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_MMAP support is missing, probably due to earlier failing format tests.
test VIDIOC_EXPBUF: OK (Not Supported)
Test input 0:
Total: 43, Succeeded: 41, Failed: 2, Warnings: 0
imx290.c (68.1 KB)
imx290.dtsi (19.5 KB)
Any ideas what could be wrong?
Thank you in advance!
