I am trying to build caffe on Tk1 pro, I get an error when i perform make runtest , The error i ge is as under.
.build_release/test/test_all.testbin 0 --gtest_shuffle --gtest_filter=“-GPU”
Cuda number of devices: 1
Setting to use device 0
Current device id: 0
Current device name: GK20A
Note: Google Test filter = -GPU
Note: Randomizing tests’ orders with a seed of 92112 .
[==========] Running 2057 tests from 271 test cases.
[----------] Global test environment set-up.
[----------] 6 tests from RNNLayerTest/0, where TypeParam = caffe::CPUDevice
[ RUN ] RNNLayerTest/0.TestSetUp
[ OK ] RNNLayerTest/0.TestSetUp (584 ms)
[ RUN ] RNNLayerTest/0.TestGradient
[ OK ] RNNLayerTest/0.TestGradient (292 ms)
[ RUN ] RNNLayerTest/0.TestGradientNonZeroCont
[ OK ] RNNLayerTest/0.TestGradientNonZeroCont (284 ms)
[ RUN ] RNNLayerTest/0.TestGradientNonZeroContBufferSize2WithStaticInput
[ OK ] RNNLayerTest/0.TestGradientNonZeroContBufferSize2WithStaticInput (2433 ms)
[ OK ] RNNLayerTest/0.TestGradientNonZeroContBufferSize2 (529 ms)
[ RUN ] RNNLayerTest/0.TestForward
[ OK ] RNNLayerTest/0.TestForward (16 ms)
[----------] 6 tests from RNNLayerTest/0 (4139 ms total)
[----------] 26 tests from NetTest/0, where TypeParam = caffe::CPUDevice
[ RUN ] NetTest/0.TestBottomNeedBackwardEuclideanForce
[ OK ] NetTest/0.TestBottomNeedBackwardEuclideanForce (4 ms)
[ RUN ] NetTest/0.TestUnsharedWeightsDiffNet
[ OK ] NetTest/0.TestUnsharedWeightsDiffNet (1 ms)
[ RUN ] NetTest/0.TestAllInOneNetVal
[ OK ] NetTest/0.TestAllInOneNetVal (3 ms)
[ OK ] NetTest/0.TestBottomNeedBackward (4 ms)
[ RUN ] NetTest/0.TestComboLossWeight
[ OK ] NetTest/0.TestComboLossWeight (8 ms)
[ RUN ] NetTest/0.TestGetLayerByName
[ OK ] NetTest/0.TestGetLayerByName (4 ms)
[ RUN ] NetTest/0.TestUnsharedWeightsDataNet
[ OK ] NetTest/0.TestUnsharedWeightsDataNet (2 ms)
[ RUN ] NetTest/0.TestAllInOneNetDeploy
[ OK ] NetTest/0.TestAllInOneNetDeploy (1 ms)
[ RUN ] NetTest/0.TestBottomNeedBackwardTricky
[ OK ] NetTest/0.TestBottomNeedBackwardTricky (5 ms)
[ RUN ] NetTest/0.TestParamPropagateDown
[ OK ] NetTest/0.TestParamPropagateDown (6 ms)
[ RUN ] NetTest/0.TestGetBlob
[ OK ] NetTest/0.TestGetBlob (4 ms)
[ RUN ] NetTest/0.TestSharedWeightsUpdate
[ OK ] NetTest/0.TestSharedWeightsUpdate (3 ms)
[ RUN ] NetTest/0.TestReshape
[ OK ] NetTest/0.TestReshape (131 ms)
[ RUN ] NetTest/0.TestSharedWeightsResume
[ OK ] NetTest/0.TestSharedWeightsResume (3 ms)
[ RUN ] NetTest/0.TestForcePropagateDown
[ OK ] NetTest/0.TestForcePropagateDown (2 ms)
[ RUN ] NetTest/0.TestFromTo
[ OK ] NetTest/0.TestFromTo (9 ms)
[ RUN ] NetTest/0.TestLossWeightMidNet
[ OK ] NetTest/0.TestLossWeightMidNet (12 ms)
[ RUN ] NetTest/0.TestSharedWeightsDiffNet
[ OK ] NetTest/0.TestSharedWeightsDiffNet (2 ms)
[ RUN ] NetTest/0.TestBackwardWithAccuracyLayer
[ OK ] NetTest/0.TestBackwardWithAccuracyLayer (7 ms)
[ RUN ] NetTest/0.TestAllInOneNetTrain
[ OK ] NetTest/0.TestAllInOneNetTrain (2 ms)
[ RUN ] NetTest/0.TestHasBlob
[ OK ] NetTest/0.TestHasBlob (4 ms)
[ RUN ] NetTest/0.TestSkipPropagateDown
[ OK ] NetTest/0.TestSkipPropagateDown (4 ms)
[ RUN ] NetTest/0.TestHasLayer
[ OK ] NetTest/0.TestHasLayer (4 ms)
[ RUN ] NetTest/0.TestBottomNeedBackwardForce
[ OK ] NetTest/0.TestBottomNeedBackwardForce (4 ms)
[ OK ] NetTest/0.TestLossWeight (10 ms)
[ RUN ] NetTest/0.TestSharedWeightsDataNet
[ OK ] NetTest/0.TestSharedWeightsDataNet (2 ms)
[----------] 26 tests from NetTest/0 (245 ms total)
[----------] 11 tests from AdaDeltaSolverTest/2, where TypeParam = caffe::GPUDevice
[ RUN ] AdaDeltaSolverTest/2.TestAdaDeltaLeastSquaresUpdateWithEverythingShare
F0226 10:13:36.866101 1860 math_functions.cu:26] Check failed: status == CUBLAS_STATUS_SUCCESS (13 vs. 0) CUBLAS_STATUS_EXECUTION_FAILED
*** Check failure stack trace: ***
@ 0x4337c060 (unknown)
@ 0x4337bf5c (unknown)
@ 0x4337bb78 (unknown)
@ 0x4337df98 (unknown)
@ 0x4396ef46 caffe::caffe_gpu_gemm<>()
@ 0x43989ad6 caffe::InnerProductLayer<>::Forward_gpu()
@ 0x4395fb8a caffe::Net<>::ForwardFromTo()
@ 0x4395fde8 caffe::Net<>::Forward()
@ 0x18d1d0 caffe::GradientBasedSolverTest<>::ComputeLeastSquaresUpdate()
@ 0x18e0ba caffe::GradientBasedSolverTest<>::TestLeastSquaresUpdate()
@ 0x18e30a caffe::AdaDeltaSolverTest_TestAdaDeltaLeastSquaresUpdateWithEverythingShare_Test<>::TestBody()
@ 0x405910 testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0x3ffea2 testing::Test::Run()
@ 0x3fff32 testing::TestInfo::Run()
@ 0x40000a testing::TestCase::Run()
@ 0x401862 testing::internal::UnitTestImpl::RunAllTests()
@ 0x401a54 testing::UnitTest::Run()
@ 0xe662e main
@ 0x43be6670 (unknown)
Aborted
make: *** [runtest] Error 134
I have tried many things but couldn’t figure out if any one had the same error , it builds few of the examples and stops randomly at one test…
I am using Cuda 7.0, Opencv2.4 , python 2.7, and caffe 1.0 … Looking forward for a kind reply
Wajahat
