My JetPack version is 3.0
Hello. I downloaded the Caffe from GitHub - RadekSimkanic/caffe-for-cudnn-v2.5.48: Caffe: a fast open framework for deep learning.
Make -j4 all
works fine.
But when I tried to:
make -j4 runtest
Error:
--------] 12 tests from SGDSolverTest/3 (5532 ms total)
[----------] 5 tests from DBTest/1, where TypeParam = caffe::TypeLMDB
[ RUN ] DBTest/1.TestWrite
F0802 16:50:22.540390 1062 db_lmdb.hpp:14] Check failed: mdb_status == 0 (-30792 vs. 0) MDB_MAP_FULL: Environment mapsize limit reached
*** Check failure stack trace: ***
@ 0x432ed060 (unknown)
@ 0x432ecf5c (unknown)
@ 0x432ecb78 (unknown)
@ 0x432eef98 (unknown)
@ 0x43d96656 caffe::db::LMDBTransaction::Put()
@ 0x2dd1ba caffe::DBTest_TestWrite_Test<>::TestBody()
@ 0x343484 testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0x33ca74 testing::Test::Run()
@ 0x33cb06 testing::TestInfo::Run()
@ 0x33cbda testing::TestCase::Run()
@ 0x33cd88 testing::internal::UnitTestImpl::RunAllTests()
@ 0x34320c testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0x33c576 testing::UnitTest::Run()
@ 0xbf76c main
@ 0x44250670 (unknown)
make: *** [runtest] Aborted
I tried to download new caffe but I have a problem with compute_arch. Tried everything but didnt solve.
After the runtest error I tried the import caffe. It works but kind of…
Like this:
raceback (most recent call last):
File "test.py", line 1, in <module>
import numpy as np
File "/usr/lib/python2.7/dist-packages/numpy/__init__.py", line 153, in <module>
from . import add_newdocs
File "/usr/lib/python2.7/dist-packages/numpy/add_newdocs.py", line 13, in <module>
from numpy.lib import add_newdoc
File "/usr/lib/python2.7/dist-packages/numpy/lib/__init__.py", line 22, in <module>
from .npyio import *
File "/usr/lib/python2.7/dist-packages/numpy/lib/npyio.py", line 4, in <module>
from . import format
File "/usr/lib/python2.7/dist-packages/numpy/lib/format.py", line 141, in <module>
import io
File "/home/ubuntu/python/caffe/io.py", line 2, in <module>
import skimage.io
File "/usr/lib/python2.7/dist-packages/skimage/__init__.py", line 166, in <module>
from .util.dtype import *
File "/usr/lib/python2.7/dist-packages/skimage/util/__init__.py", line 1, in <module>
from .dtype import (img_as_float, img_as_int, img_as_uint, img_as_ubyte,
File "/usr/lib/python2.7/dist-packages/skimage/util/dtype.py", line 8, in <module>
dtype_range = {np.bool_: (False, True),
AttributeError: 'module' object has no attribute 'bool_'
What i need to?
