NVIDIA K5000 and Samsung UA55F9000AR No better than 1920x1080
Bit of a longshot, i have a nvidia k5000 connected to a Samsung one connect box which in turn is connected to the Samsung UA55F9000AR. I am no expert in xorg.conf’s by any means and have been hacking following google and here and around and managed to get the Machine to output 3840x2160 and nvidia-settings confirms this but i get no output on the screen, am i doing something wrong or using wrong cables, etc. Currently it is using a hdmi converted to display port.
i can get an output at 1920x1080 but i would like better.
Below is my xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 310.32 (buildmeister@swio-display-x86-rhel47-01) Mon Jan 14 15:51:51 PST 2013
Xorg configuration created by pyxf86config
Begin HP Remote Graphics Software
End HP Remote Graphics Software
Section “ServerLayout”
Identifier “Default Layout”
Screen 0 “Screen0” 0 0
InputDevice “Mouse0” “CorePointer”
InputDevice “Keyboard0” “CoreKeyboard”
EndSection
Section “Module”
# HP Remote Graphics Extension
Load           "rge"
# extmod recommended for preventing XID overflow.
Load           "extmod"
# Ensure X.org defaults are loaded
Load           "glx"
Load           "dbe"
Load           "record"
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/input/mice”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
Identifier “Keyboard0”
Driver “kbd”
Option “XkbModel” “pc105”
Option “XkbLayout” “gb”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
Modeline “3840x2160_60.00” 712.75 3840 4160 4576 5312 2160 2163 2168 2237 -hsync +vsync
ModelName      "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
EndSection
Section “Device”
Identifier “Videocard0”
Driver “nvidia”
Option “ModeValidation” “AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoVertRefreshCheck, NoHorizSyncCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, AllowNonEdidModes, NoEdidMaxPClkCheck”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Videocard0”
Monitor “Monitor0”
DefaultDepth 24
Option “MetaModes” “3840x2160”
SubSection “Display”
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section “Extensions”
Option “Composite” “Disable”
EndSection
i have run a bug report if anyone is interested in looking :)
but here is a excerpt
(II) Setting vga for screen 0.
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
) NVIDIA(0): Option “ModeValidation” “AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoVertRefreshCheck, NoHorizSyncCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, AllowNonEdidModes, NoEdidMaxPClkCheck”
(WW) Jan 21 15:42:54 NVIDIA(0): Unrecognized ModeValidation token “AllowNon60hzmodesDFPModes”;
(WW) Jan 21 15:42:54 NVIDIA(0): ignoring.
(WW) Jan 21 15:42:54 NVIDIA(0): Unrecognized ModeValidation token “NoEDIDDFPMaxSizeCheck”;
() NVIDIA(0): Option “MetaModes” “3840x2160”
) Jan 21 15:42:54 NVIDIA(0): Enabling 2D acceleration
(II) Jan 21 15:42:55 NVIDIA(GPU-0): Display (SAMSUNG (DFP-1)) does not support NVIDIA 3D Vision
(II) Jan 21 15:42:55 NVIDIA(GPU-0): stereo.
(II) Jan 21 15:42:55 NVIDIA(0): NVIDIA GPU Quadro K5000 (GK104GL) at PCI:5:0:0 (GPU-0)
(–) Jan 21 15:42:55 NVIDIA(0): Memory: 4194304 kBytes
(–) Jan 21 15:42:55 NVIDIA(0): VideoBIOS: 80.04.50.00.02
(II) Jan 21 15:42:55 NVIDIA(0): Detected PCI Express Link width: 16X
(–) Jan 21 15:42:55 NVIDIA(0): Valid display device(s) on Quadro K5000 at PCI:5:0:0
(–) Jan 21 15:42:55 NVIDIA(0): CRT-0
(–) Jan 21 15:42:55 NVIDIA(0): DFP-0
(–) Jan 21 15:42:55 NVIDIA(0): SAMSUNG (DFP-1) (connected)
(–) Jan 21 15:42:55 NVIDIA(0): DFP-2
(–) Jan 21 15:42:55 NVIDIA(0): DFP-3
(–) Jan 21 15:42:55 NVIDIA(0): DFP-4
(–) Jan 21 15:42:55 NVIDIA(0): DFP-5
(–) Jan 21 15:42:55 NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): DFP-0: Internal Single Link TMDS
(–) Jan 21 15:42:55 NVIDIA(0): SAMSUNG (DFP-1): 165.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): SAMSUNG (DFP-1): Internal Single Link TMDS
(–) Jan 21 15:42:55 NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): DFP-2: Internal Single Link TMDS
(–) Jan 21 15:42:55 NVIDIA(0): DFP-3: 330.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): DFP-3: Internal Single Link TMDS
(–) Jan 21 15:42:55 NVIDIA(0): DFP-4: 960.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): DFP-4: Internal DisplayPort
(–) Jan 21 15:42:55 NVIDIA(0): DFP-5: 960.0 MHz maximum pixel clock
(–) Jan 21 15:42:55 NVIDIA(0): DFP-5: Internal DisplayPort
() Jan 21 15:42:55 NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
) Jan 21 15:42:55 NVIDIA(0): device SAMSUNG (DFP-1) (Using EDID frequencies has been
() Jan 21 15:42:55 NVIDIA(0): enabled on all display devices.)
(II) Jan 21 15:42:55 NVIDIA(0): Mode Validation Overrides for SAMSUNG (DFP-1):
(II) Jan 21 15:42:55 NVIDIA(0): NoMaxPClkCheck
(II) Jan 21 15:42:55 NVIDIA(0): NoEdidMaxPClkCheck
(II) Jan 21 15:42:55 NVIDIA(0): NoMaxSizeCheck
(II) Jan 21 15:42:55 NVIDIA(0): NoHorizSyncCheck
(II) Jan 21 15:42:55 NVIDIA(0): NoVertRefreshCheck
(II) Jan 21 15:42:55 NVIDIA(0): NoDFPNativeResolutionCheck
(II) Jan 21 15:42:55 NVIDIA(0): AllowNonEdidModes
(II) Jan 21 15:42:55 NVIDIA(0): Validated MetaModes:
(II) Jan 21 15:42:55 NVIDIA(0): “3840x2160”
(II) Jan 21 15:42:55 NVIDIA(0): Virtual screen size determined to be 3840 x 2160
(–) Jan 21 15:42:55 NVIDIA(0): DPI set to (80, 80); computed from “UseEdidDpi” X config
(–) Jan 21 15:42:55 NVIDIA(0): option
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0xfbf02000 - 0xfbf02fff (0x1000) MX[B]
[5] -1 0 0xef300000 - 0xef300fff (0x1000) MX[B]
[6] -1 0 0xef410000 - 0xef411fff (0x2000) MX[B]
[7] -1 0 0xef400000 - 0xef40ffff (0x10000) MX[B]
[8] -1 0 0xef080000 - 0xef083fff (0x4000) MX[B]
[9] -1 0 0xe2400000 - 0xe27fffff (0x400000) MX[B]
[10] -1 0 0xe2800000 - 0xe2803fff (0x4000) MX[B]
[11] -1 0 0xef5e0000 - 0xef5e3fff (0x4000) MX[B]
[12] -1 0 0xef500000 - 0xef57ffff (0x80000) MX[B]
[13] -1 0 0xef5c0000 - 0xef5dffff (0x20000) MX[B]
[14] -1 0 0xef200000 - 0xef23ffff (0x40000) MX[B]
[15] -1 0 0xef240000 - 0xef24ffff (0x10000) MX[B]
[16] -1 0 0xef60b000 - 0xef60b0ff (0x100) MX[B]
[17] -1 0 0xef60c000 - 0xef60c7ff (0x800) MX[B]
[18] -1 0 0xef60d000 - 0xef60d3ff (0x400) MX[B]
[19] -1 0 0xef600000 - 0xef603fff (0x4000) MX[B]
[20] -1 0 0xef60e000 - 0xef60e3ff (0x400) MX[B]
[21] -1 0 0xef60a000 - 0xef60afff (0x1000) MX[B]
[22] -1 0 0xef000000 - 0xef07ffff (0x80000) MXB
[23] -1 0 0xe0000000 - 0xe1ffffff (0x2000000) MXB
[24] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[25] -1 0 0xee000000 - 0xeeffffff (0x1000000) MXB
[26] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[27] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[28] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[29] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[30] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[31] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
[32] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[33] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B]
[34] -1 0 0x0000e000 - 0x0000e01f (0x20) IX[B]
[35] -1 0 0x0000e020 - 0x0000e03f (0x20) IX[B]
[36] -1 0 0x0000e0a0 - 0x0000e0a3 (0x4) IX[B]
[37] -1 0 0x0000e0b0 - 0x0000e0b7 (0x8) IX[B]
[38] -1 0 0x0000e0c0 - 0x0000e0c3 (0x4) IX[B]
[39] -1 0 0x0000e0d0 - 0x0000e0d7 (0x8) IX[B]
[40] -1 0 0x0000a000 - 0x0000a07f (0x80) IXB
[41] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[42] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Jan 21 15:42:55 NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
(II) Jan 21 15:42:55 NVIDIA: access.
(II) Jan 21 15:42:55 NVIDIA(0): Setting mode “3840x2160”
(II) Loading extension NV-GLX
(==) NVIDIA(0): Disabling shared memory pixmaps
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(RG) 15:42:58.762 HP Remote Graphics extension. Build date : Jun 29 2012
(RG) 15:42:58.791 Listening for RG connections at /var/opt/hpremote/rgsender/sockets/rgsender-rge:0
(RG) 15:42:58.795 Started rgsender process PID = 8931
(RG) 15:42:58.795 Save gamma ramp
(RG) 15:42:58.796 RG nVidia support is available
(II) Initializing extension GLX
) Option “Protocol” “auto”
() Mouse0: Device: “/dev/input/mice”
) Mouse0: Protocol: “auto”
() Option “CorePointer”
) Mouse0: Core Pointer
() Option “Device” “/dev/input/mice”
) Option “Emulate3Buttons” “no”
() Option “ZAxisMapping” “4 5”
) Mouse0: ZAxisMapping: buttons 4 and 5
() Mouse0: Buttons: 9
) Option “CoreKeyboard”
() Keyboard0: Core Keyboard
) Option “Protocol” “standard”
() Keyboard0: Protocol: standard
) Option “AutoRepeat” “500 30”
() Option “XkbRules” “xorg”
) Keyboard0: XkbRules: “xorg”
() Option “XkbModel” “pc105”
) Keyboard0: XkbModel: “pc105”
() Option “XkbLayout” “gb”
) Keyboard0: XkbLayout: “gb”
() Option “CustomKeycodes” “off”
) Keyboard0: CustomKeycodes disabled
(II) XINPUT: Adding extended input device “Keyboard0” (type: KEYBOARD)
(II) XINPUT: Adding extended input device “Mouse0” (type: MOUSE)
(RG) 15:42:59.342 rgeSigChildHandler: received signal: 17
(–) Mouse0: PnP-detected protocol: “ExplorerPS/2”
(II) Mouse0: ps2EnableDataReporting: succeeded
(RG) 15:43:01.393 Established connection with rgsender
(RG) 15:56:58.598 Attach to Shared Framebuffer, ID: 6127625, Width: 3840, Height: 2160
(RG) 15:56:58.598 Attach to Shared Framebuffer, ID: 6160394, Width: 3840, Height: 2160
nvidia-bin-310.32 is the driver i am using.
I answered your PM but I didn’t realize you were using the DP adapter.
You will probably need to use this active adapter and you will be limited to 30 Hz until the dp 1.2 → HDMI 2.0 adapters come out (sometime in the next few months) or buy a gtx 970 or 980 like I mentioned before for 60Hz.
http://www.amazon.com/Accell-B086B-008B-2-UltraAV-DisplayPort-Adapter/dp/B00DOZHL82
(chose DisplayPort version instead of mini displayport)
I would expect you to have no issues with 30Hz 4k with that adapter right out of the box with any drivers.
Hi, thanks for the pm answer, i have kinda got it working :)
Updated the Drivers to
Installing NVIDIA driver version 346.35.
I now get this when i look at xorg.
(II) Jan 22 15:04:12 NVIDIA(0): NVIDIA GPU Quadro K5000 (GK104GL) at PCI:5:0:0 (GPU-0)
(–) Jan 22 15:04:12 NVIDIA(0): Memory: 4194304 kBytes
(–) Jan 22 15:04:12 NVIDIA(0): VideoBIOS: 80.04.50.00.02
(II) Jan 22 15:04:12 NVIDIA(0): Detected PCI Express Link width: 16X
(–) Jan 22 15:04:12 NVIDIA(0): Valid display device(s) on Quadro K5000 at PCI:5:0:0
(–) Jan 22 15:04:12 NVIDIA(0): CRT-0
(–) Jan 22 15:04:12 NVIDIA(0): DFP-0
(–) Jan 22 15:04:12 NVIDIA(0): SAMSUNG (DFP-1) (boot, connected)
(–) Jan 22 15:04:12 NVIDIA(0): DFP-2
(–) Jan 22 15:04:12 NVIDIA(0): DFP-3
(–) Jan 22 15:04:12 NVIDIA(0): DFP-4
(–) Jan 22 15:04:12 NVIDIA(0): DFP-5
(–) Jan 22 15:04:12 NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
(–) Jan 22 15:04:12 NVIDIA(0): DFP-0: Internal TMDS
(–) Jan 22 15:04:12 NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
(–) Jan 22 15:04:12 NVIDIA(0): SAMSUNG (DFP-1): Internal TMDS
(–) Jan 22 15:04:12 NVIDIA(GPU-0): SAMSUNG (DFP-1): 300.0 MHz maximum pixel clock
(–) Jan 22 15:04:12 NVIDIA(0): DFP-2: Internal TMDS
(–) Jan 22 15:04:12 NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
(–) Jan 22 15:04:12 NVIDIA(0): DFP-3: Internal TMDS
(–) Jan 22 15:04:12 NVIDIA(GPU-0): DFP-3: 330.0 MHz maximum pixel clock
(–) Jan 22 15:04:12 NVIDIA(0): DFP-4: Internal DisplayPort
(–) Jan 22 15:04:12 NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
(–) Jan 22 15:04:12 NVIDIA(0): DFP-5: Internal DisplayPort
(–) Jan 22 15:04:12 NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
So pixel clock is greater now than the 165 i had Earlier.
The screen is outputting now at 3840x2160 at 30hz
is there any way to improve the refresh rate?
my xorg looks like this , notice the modeline is hashed out at present :)
EndSection
Section “Module”
Load           "rge"
Load           "extmod"
Load           "glx"
Load           "dbe"
Load           "record"
EndSection
Identifier “Mouse0”
Driver “mouse”
EndSection
Driver “kbd”
EndSection
Section “Monitor”
ModelName      "Unknown"
EndSection
Section “Device”
Driver “nvidia”
EndSection
Section “Screen”
Device “Videocard0”
Monitor “Monitor0”
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
EndSection
