NVIDIA L4 GPU Not Detected in Linux Hyper-V VM After DDA
Environment Details:
  • Host Machine:
    • OS: Windows Server 2022 (Hyper-V)
    • GPU: NVIDIA L4 x 3
    • CPU: Intel Xeon Gold 6542Y (with VT-d enabled)
    • IOMMU and SR-IOV: Enabled in BIOS
  • Virtual Machine (VM):
    • OS: Linux ( Debian 12)
    • Hyper-V DDA Configurations completing without errors.
Steps Performed:
  1. Check the Current State of the VM
    PS C:\Users\Administrator> Get-VM
    Output:
    Name                State CPUUsage(%) MemoryAssigned(M) Uptime   Status     Version
    VM_4.5.12_Build Off   0           0                 00:00:00 正常稼働中 10.0
  2. Set the Automatic Stop Action
    PS C:\Users\Administrator> Set-VM -Name VM_4.5.12_Build -AutomaticStopAction TurnOff
  3. Enable Guest Controlled Cache Types
    PS C:\Users\Administrator> Set-VM -GuestControlledCacheTypes $true -VMName VM_4.5.12_Build
  4. Configure Memory-Mapped I/O Space
    • Allocated low memory-mapped I/O space:
      PS C:\Users\Administrator> Set-VM -LowMemoryMappedIoSpace 3Gb -VMName VM_4.5.12_Build
    • Allocated high memory-mapped I/O space:
      PS C:\Users\Administrator> Set-VM -HighMemoryMappedIoSpace 33280Mb -VMName VM_4.5.12_Build
  5. Dismount the GPU from the Host
    The GPU was removed from the host using the following command:
    PS C:\Users\Administrator> Dismount-VMHostAssignableDevice -LocationPath "PCIROOT(9E)#PCI(0100)#PCI(0000)" -Force
  6. Assign the GPU to the VM
    The GPU was assigned to the VM using:
    PS C:\Users\Administrator> Add-VMAssignableDevice -LocationPath "PCIROOT(9E)#PCI(0100)#PCI(0000)" -VMName VM_4.5.12_Build
  1. Start the VM
    After completing the DDA setup, the VM was started:
    PS C:\Users\Administrator> Start-VM -Name VM_4.5.12_Build
  2. Verify the GPU in the Guest OS
    Inside the guest OS, the following command was used to check if the GPU is visible:
    lspci | grep -i nvidia
  3. Started the VM and checked for the GPU in the guest OS using lspci.
Observed Issue:
  • The GPU does not appear in the output of lspci inside the Linux VM, despite all configurations completing without errors.
  • No errors or warnings were observed during the DDA setup process.
Additional Notes:
Hi All,
I wanted to provide an update regarding the issue I faced with NVIDIA L4 GPUs on Windows Server Hyper-V VMs using Discrete Device Assignment (DDA). I was able to resolve this issue successfully by following the guidance provided in the NVIDIA documentation:
Bug #2812853: Microsoft DDA not working with some GPUs.
The problem occurred because GPUs with more than 16 GB of memory require additional MMIO (Memory-Mapped Input/Output) space for proper mapping in the guest VM. Without this configuration, the GPU wouldn’t be detected properly in the VM.
Solution:
The workaround involves allocating sufficient HighMemoryMappedIoSpace for the VM based on the GPU’s BAR1 memory size and the number of GPUs assigned to the VM. Here’s the step-by-step process:
  1. Use the following formula to calculate the required MMIO space:
    MMIO space=2×gpu-bar1-memory×assigned-gpus
Where:
  • gpu-bar1-memory: The amount of BAR1 memory for one GPU (equal to total GPU memory if not specified).
  • assigned-gpus: The number of GPUs assigned to the VM.
  1. Assign the calculated MMIO space to the VM using the Set-VM PowerShell command on the Hyper-V host.
Example: NVIDIA L4 GPU with 23 GB Memory
For a VM with 1 GPU assigned, where each GPU has 23 GB of BAR1 memory:
MMIO space=2×23 GB×1=46 GB
PowerShell Command:
Run the following on the Hyper-V host to set the required MMIO space:
Set-VM –HighMemoryMappedIoSpace 46GB –VMName <VM_Name>
Example: Multiple GPUs Assigned
For 3 NVIDIA L4 GPUs, each with 23 GB of memory assigned to a single VM:
MMIO space=2×23 GB×3=138 GB
PowerShell Command:
Run the following to set the MMIO space for the VM:
Set-VM –HighMemoryMappedIoSpace 138GB –VMName <VM_Name>
Verification:
Once the MMIO space is configured, reboot the VM and check that the GPU is recognized correctly in the guest VM using tools like nvidia-smi or lspci (for Linux VMs).
I hope this helps anyone facing similar issues. If you have additional questions, feel free to ask!
