Hello Nvidia,
i follow the Guide: Client Licensing User Guide - NVIDIA Docs
Driver is 538.15 on the Windows 10 Guest.
If i copy the Client token which is created by the DLS Server in the ClientConfigToken Folder and Restart the NvDisplayContainer , nvidia-smi -q tells me “unlicenend” and the NV Controll Panel woudnt start.
==============NVSMI LOG==============
Timestamp : Fri Jul 26 11:23:10 2024
Driver Version : 538.15
CUDA Version : 12.2
Attached GPUs : 1
GPU 00000000:00:10.0
Product Name : NVIDIA A10-2Q
Product Brand : NVIDIA RTX Virtual Workstation
Product Architecture : Ampere
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
Addressing Mode : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-2b2d2cfd-450e-11ef-bdc3-f5b8a28748ea
Minor Number : N/A
VBIOS Version : 00.00.00.00.00
MultiGPU Board : No
Board ID : 0x10
Board Part Number : N/A
GPU Part Number : 2236-890-A1
FRU Part Number : N/A
Module ID : N/A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GSP Firmware Version : N/A
GPU Virtualization Mode
Virtualization Mode : VGPU
Host VGPU Mode : N/A
vGPU Software Licensed Product
Product Name : NVIDIA RTX Virtual Workstation
License Status : Unlicensed (Restricted)
GPU Reset Status
Reset Required : N/A
Drain and Reset Recommended : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x00
Device : 0x10
Domain : 0x0000
Device Id : 0x223610DE
Bus Id : 00000000:00:10.0
Sub System Id : 0x14B910DE
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Device Current : N/A
Device Max : N/A
Host Max : N/A
Link Width
Max : N/A
Current : N/A
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : N/A
Replay Number Rollovers : N/A
Tx Throughput : N/A
Rx Throughput : N/A
Atomic Caps Inbound : N/A
Atomic Caps Outbound : N/A
Fan Speed : N/A
Performance State : P0
Clocks Event Reasons : N/A
FB Memory Usage
Total : 2048 MiB
Reserved : 263 MiB
Used : 290 MiB
Free : 1493 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 0 MiB
Free : 256 MiB
Conf Compute Protected Memory Usage
Total : N/A
Used : N/A
Free : N/A
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : N/A
OFA : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable : 0
DRAM Correctable : 0
DRAM Uncorrectable : 0
Aggregate
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 0 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : N/A
GPU Slowdown Temp : N/A
GPU Max Operating Temp : N/A
GPU Target Temperature : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Module Power Readings
Power Draw : N/A
Clocks
Graphics : 0 MHz
SM : 0 MHz
Memory : 0 MHz
Video : 0 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 0 MHz
SM : 0 MHz
Memory : 0 MHz
Video : 0 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 576
Type : C+G
Used GPU Memory : Not available in WDDM driver model
Process ID : 1180
Type : C+G
Name :
Process ID : 2732
Type : C+G
Process ID : 3048
Type : C+G
Process ID : 3636
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.WindowsStore_11910.1002.5.0_x64__8wekyb3d8bbwe\WinStore.App.exe
Process ID : 6568
Type : C+G
Name : C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
Process ID : 8496
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2019.19071.12548.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
Process ID : 10144
Type : C+G
Name : C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
Process ID : 10216
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.SkypeApp_14.53.77.0_x64__kzf8qxf38zg5c\SkypeApp.exe
What can i do to get more Debug Messages ? Do you know the Problem ?
Best regards,
René
