NVIDIA® Nsight™ Compute 2026.2 is now available for download in the NVIDIA Registered Developer Program.
Updates in 2026.2.1
- Added support for in-process profiling workflows that dynamically load the CUDA injection library. See the new CUDA injection API header
extras/Api/nvComputeInj.hfor usage details. - Added the
--process-idcommand line option for--mode attachto attach to a specific process. - Added the
--list-injection-path-64and--list-injection-path-32command line options to report the paths used to load the CUDA injection library. - Fixed an issue on QNX where Nsight Compute could fail to create temporary files or lock files in the default location.
- Fixed an issue where profiling a green-context kernel could fail after a non-green-context kernel had already been profiled in the same process.
- Fixed an issue that could cause
ncu --mode attachto fail when range replay was followed by kernel replay in the same process. - Fixed a crash in the CUDA injection library when an application initialized CUDA before the injection library was loaded.
General
Resolved Issues
Updates in 2026.2.0
- Added support for CUDA 13.3.
- Added metrics for the size of
SASS instructions. - Added profiling support for previously unsupported SKUs, with reduced metric support, including GPUs such as RTX 6000D BSE (GB202-891), RTX 5090DD (GB202-240), and RTX 5090D (GB202-250). For more details, refer to ERR_NVGPU.
Updated the overall layout to pin several
tool windowsby default.Improved CUDA Tile support on the Source page.
Added a progress indicator for long-running source comparisons.
The
Function Statisticstool window now shows per high-level source line data and the represented time range.The Instruction Statistics section now shows warp-can't issue stall samples per
HW warp ID slot.Added a Device Information tool window to show information for local and remote systems from the
Start Activity Dialogor theConnection menu.Improved the
Report Merge Tooldialog UI.The
CUDA Graph Viewernow shows the source of each graph. It also updates in the background without blocking the UI and provides progress information.The Demangled Name column tooltip now always shows the full demangled name.
Improved the performance to first result when loading reports in the
Python Report Interface.Fixed several issues when merging reports.
Fixed UI crashes on Linux (aarch64 sbsa) platforms.
Fixed the
achieved_fp32formula in the SOL roofline rules.Fixed an issue on the Source page that blank lines were highlighted in some cases for inlined functions.
Fixed failing SSH connections when the OpenSSH config contained unsupported escape sequences.
General
NVIDIA Nsight Compute
Resolved Issues
For a complete overview of all NVIDIA® Nsight™ Compute features and access to resources, please visit the main Nsight Compute Overview page.
Version 2026.2.1 Overview | New Features | Getting Started | Download | Documentation
Latest PRODUCT INFO
- Overview (download, features, platforms, requirements)
- Getting Started
- Documentation
- Downloads (as part of CUDA Toolkit)
- Downloads (outside of CUDA Toolkit)
- Revision History
- Videos
- News & Blogs
- Nsight Compute Forum
