And I know nineties!
Trying to get my feet on the ground with the Nvidia SDK. Except segmentation faults, compiling errors, tons of warnings and bad docs there’s not much fun yet.
Example given:
# less /opt/nVidia/OpenCL/Samples.html
<head>
<META http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>NVIDIA OpenCL SDK Code Samples</title>
Lets have a look and browse that file with firefox (firefox Samples.html):
file:///opt/nVidia/OpenCL/Samples.html
Nice. Let’s click on some “Browse files” links in there:
d:/bld_sdk10.pl/devrel/SDK10/Compute/C/src/inlinePTX BOOM
Maybe it’s the “Last Update: 4/30/2011”
Ok. Let’s try to compile something. After having adjusted gcc to be actually gcc-5 (instead of gcc being 6.2 here)
# /opt/nVidia/OpenCL> make
cc1plus: warning: command line option ‘-Wimplicit’ is valid for C/ObjC but not for C++
In file included from ../../..//OpenCL//common//inc/CL/opencl.h:44:0,
from ../../..//OpenCL//common//inc/oclUtils.h:26,
from oclTridiagonal.cpp:42:
../../..//OpenCL//common//inc/CL/cl_gl_ext.h:38:4: warning: "/*" within comment [-Wcomment]
* /* cl_VEN_extname extension */
In file included from oclTridiagonal.cpp:45:0:
test_gen_result_check.h: In function ‘void test_gen_cyclic(float*, float*, float*, float*, float*, int, int)’:
test_gen_result_check.h:105:51: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
file_read_array(a, system_size, "a256.txt");
...(like 50 times)...
sweep_small_systems.h:40:102: warning: unused parameter ‘kernelTime’ [-Wunused-parameter]
double runReorderKernel(int devCount, cl_mem *dev_a, cl_mem *dev_t, int *width, int *height, double *kernelTime)
In file included from oclTridiagonal.cpp:61:0:
sweep_small_systems.h:96:120: warning: unused parameter ‘dev_t’ [-Wunused-parameter]
double runSweepKernel(int devCount, cl_mem *dev_a, cl_mem *dev_b, cl_mem *dev_c, cl_mem *dev_d, cl_mem *dev_x, cl_mem *dev_t, cl_mem *dev_w, int system_size, int *workSi
sweep_small_systems.h:96:146: warning: unused parameter ‘system_size’ [-Wunused-parameter]
make[1]: Entering directory '/opt/nVidia/OpenCL/src/oclHiddenMarkovModel'
from oclHiddenMarkovModel.cpp:12:
oclHiddenMarkovModel.cpp: In function ‘int main(int, const char**)’:
oclHiddenMarkovModel.cpp:140:12: warning: variable ‘szWorkGroup’ set but not used [-Wunused-but-set-variable]
size_t szWorkGroup;
... another 1000 lines spared
Ok, after lots of vomiting it runs through. Not sure if I should attempt to execute the resulting binaries but let’s try…
Ah - wow - 20% of the binaries in /opt/nVidia/OpenCL/bin/linux/release do even run without error.
For the rest it is
/opt/nVidia/OpenCL/bin/linux/release/oclMedianFilter Starting (Using MedianFilter.cl)...
!!! Error # -11 at file oclMedianFilter.cpp, line 298
Build Log:
<kernel>:51:72: error: call to 'mul24' is ambiguous
uc4LocalData[iLocalPixOffset] = uc4Source[iDevGMEMOffset + mul24(get_local_size(1), get_global_size(0))];
cl_kernel.h:3285:22: note: candidate function
int __OVERLOADABLE__ mul24(int, int);
or
/opt/nVidia/OpenCL/bin/linux/release/oclHistogram Starting...
!!! Error # -5 at line 119 , in file src/main.cpp !!!
Exiting...
and similar. Also cutting it off here to spare the fellow reader another hundreds of lines of misery.
Not sure what I am supposed to learn from this. Of course I am frustrated after a week poking around and nothing coming out of my nvidia. But I’m sure someone here will again explain to me how all these experiences of nVidia software quality is in fact my fault and my fault only.
If nVidias “policy” is in fact to just pretend OpenCL support while in fact throwing 99% of its effort on CUDA, please state so (like real men).
