Here is the configuration for my pc:
With kernel: 5.15.0-58-generic
Currently the auto installed nvidia-driver-525 is in use and my computer takes long when shutting down. As far as I can see it is caused by the timeout of nvidia-persistenced service, you can see the logs below. Also, I checked with other nvidia drivers: 390, 470 and 515. The problem is the same.
Can you please help me?
Best,
Jan 18 13:44:33 oscar systemd[1]: Stopped NVIDIA Persistence Daemon.
Jan 18 13:44:33 oscar systemd[1]: nvidia-persistenced.service: Failed with result 'timeout'.
Jan 18 13:44:33 oscar systemd[1]: nvidia-persistenced.service: Main process exited, code=killed, status=9/KILL
Jan 18 13:44:33 oscar systemd[1]: nvidia-persistenced.service: Killing process 1072 (nvidia-persiste) with signal SIGKILL.
Jan 18 13:44:33 oscar systemd[1]: nvidia-persistenced.service: State 'stop-sigterm' timed out. Killing.
Jan 18 13:43:04 oscar dbus-daemon[734]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Transa>
Jan 18 13:43:04 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-resolved.service/start is de>
Jan 18 13:43:04 oscar dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedes>
Jan 18 13:43:04 oscar update-systemd-resolved[4457]: 'busctl' exited with status 1
Jan 18 13:43:04 oscar update-systemd-resolved[4453]: Link 'utun420' going down
Jan 18 13:43:04 oscar systemd[1]: Stopped ACPI event daemon.
Jan 18 13:43:04 oscar systemd[1]: acpid.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopped target Preparation for Network.
Jan 18 13:43:04 oscar systemd[1]: Stopped Network Manager.
Jan 18 13:43:04 oscar systemd[1]: NetworkManager.service: Deactivated successfully.
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.6066] exiting (success)
Jan 18 13:43:04 oscar systemd[1]: Stopped WPA supplicant.
Jan 18 13:43:04 oscar systemd[1]: wpa_supplicant.service: Deactivated successfully.
Jan 18 13:43:04 oscar dbus-daemon[734]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': T>
Jan 18 13:43:04 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for NetworkManager-dispatcher.service/st>
Jan 18 13:43:04 oscar wpa_supplicant[771]: wlp36s0: CTRL-EVENT-TERMINATING
Jan 18 13:43:04 oscar wpa_supplicant[771]: nl80211: deinit ifname=wlp36s0 disabled_11b_rates=0
Jan 18 13:43:04 oscar wpa_supplicant[771]: wlp36s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 18 13:43:04 oscar dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.fr>
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5965] device (p2p-dev-wlp36s0): state change: disconnected -> unmanaged >
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5453] dhcp6 (wlp36s0): state changed no lease
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5453] dhcp6 (wlp36s0): activation: beginning transaction (timeout in 45 >
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5453] dhcp6 (wlp36s0): canceled DHCP transaction
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5452] dhcp4 (wlp36s0): state changed no lease
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5452] dhcp4 (wlp36s0): activation: beginning transaction (timeout in 45 >
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5452] dhcp4 (wlp36s0): canceled DHCP transaction
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5181] device (wlp36s0): state change: deactivating -> unmanaged (reason >
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5180] manager: NetworkManager state is now CONNECTED_LOCAL
Jan 18 13:43:04 oscar NetworkManager[770]: <warn> [1674045784.5179] dispatcher: (14) failed: Transaction for NetworkManager-dispatcher>
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.5163] device (wlp36s0): state change: activated -> deactivating (reason >
Jan 18 13:43:04 oscar wpa_supplicant[771]: wlp36s0: CTRL-EVENT-DISCONNECTED bssid=3c:a6:2f:53:e5:c6 reason=3 locally_generated=1
Jan 18 13:43:04 oscar kernel: wlp36s0: deauthenticating from 3c:a6:2f:53:e5:c6 by local choice (Reason: 3=DEAUTH_LEAVING)
Jan 18 13:43:04 oscar wpa_supplicant[771]: p2p-dev-wlp36s0: CTRL-EVENT-TERMINATING
Jan 18 13:43:04 oscar systemd[1]: Stopped Network Name Resolution.
Jan 18 13:43:04 oscar systemd[1]: systemd-resolved.service: Deactivated successfully.
Jan 18 13:43:04 oscar wpa_supplicant[771]: nl80211: deinit ifname=p2p-dev-wlp36s0 disabled_11b_rates=0
Jan 18 13:43:04 oscar wpa_supplicant[771]: p2p-dev-wlp36s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 18 13:43:04 oscar systemd[1]: Stopping WPA supplicant...
Jan 18 13:43:04 oscar systemd[1]: Stopping Network Name Resolution...
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.4525] caught SIGTERM, shutting down normally.
Jan 18 13:43:04 oscar systemd[1]: Stopping Network Manager...
Jan 18 13:43:04 oscar systemd[1]: Stopped target Network.
Jan 18 13:43:04 oscar systemd[1]: Stopped containerd container runtime.
Jan 18 13:43:04 oscar systemd[1]: containerd.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopping containerd container runtime...
Jan 18 13:43:04 oscar systemd[1]: Stopped Network Manager Wait Online.
Jan 18 13:43:04 oscar systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopped target Network is Online.
Jan 18 13:43:04 oscar systemd[1]: Stopped Docker Application Container Engine.
Jan 18 13:43:04 oscar systemd[1]: docker.service: Deactivated successfully.
Jan 18 13:43:04 oscar dockerd[1953]: time="2023-01-18T13:43:04.444851097+01:00" level=info msg="stopping event stream following gracefu>
Jan 18 13:43:04 oscar dockerd[1953]: time="2023-01-18T13:43:04.444837548+01:00" level=info msg="Daemon shutdown complete"
Jan 18 13:43:04 oscar dockerd[1953]: time="2023-01-18T13:43:04.444616541+01:00" level=info msg="stopping event stream following gracefu>
Jan 18 13:43:04 oscar systemd[1]: Unmounted /var/lib/docker/overlay2/5868781e05ae5a2c8b4975b3a6cd62bd82dac8bee86d1aaada310060d9e3a1bc/m>
Jan 18 13:43:04 oscar systemd[1]: var-lib-docker-overlay2-5868781e05ae5a2c8b4975b3a6cd62bd82dac8bee86d1aaada310060d9e3a1bc-merged.mount>
Jan 18 13:43:04 oscar systemd[1]: Unmounted /run/docker/netns/71e8ebc71984.
Jan 18 13:43:04 oscar systemd[1]: run-docker-netns-71e8ebc71984.mount: Deactivated successfully.
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.3422] device (veth9201249): released from master device docker0
Jan 18 13:43:04 oscar systemd[1]: Stopped Userspace Out-Of-Memory (OOM) Killer.
Jan 18 13:43:04 oscar systemd[1]: systemd-oomd.service: Deactivated successfully.
Jan 18 13:43:04 oscar kernel: docker0: port 1(veth9201249) entered disabled state
Jan 18 13:43:04 oscar kernel: device veth9201249 left promiscuous mode
Jan 18 13:43:04 oscar NetworkManager[770]: <info> [1674045784.3182] manager: (veth7f53d6b): new Veth device (/org/freedesktop/NetworkM>
Jan 18 13:43:04 oscar systemd-udevd[4372]: Using default interface naming scheme 'v249'.
Jan 18 13:43:04 oscar systemd[1]: Stopped target User and Group Name Lookups.
Jan 18 13:43:04 oscar systemd[1]: Stopped User Login Management.
Jan 18 13:43:04 oscar systemd[1]: systemd-logind.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopped target Remote File Systems.
Jan 18 13:43:04 oscar systemd[1]: Stopped Permit User Sessions.
Jan 18 13:43:04 oscar systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopping Permit User Sessions...
Jan 18 13:43:04 oscar systemd[1]: user-1000.slice: Consumed 1min 38.263s CPU time.
Jan 18 13:43:04 oscar systemd[1]: Removed slice User Slice of UID 1000.
Jan 18 13:43:04 oscar systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jan 18 13:43:04 oscar systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Unmounted /run/user/1000.
Jan 18 13:43:04 oscar systemd[1]: run-user-1000.mount: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jan 18 13:43:04 oscar systemd[1]: Stopping Userspace Out-Of-Memory (OOM) Killer...
Jan 18 13:43:04 oscar systemd[1]: user@1000.service: Consumed 1min 34.989s CPU time.
Jan 18 13:43:04 oscar systemd[1]: Stopped User Manager for UID 1000.
Jan 18 13:43:04 oscar systemd[1]: user@1000.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1610]: Reached target Exit the Session.
Jan 18 13:43:04 oscar systemd[1610]: Finished Exit the Session.
Jan 18 13:43:04 oscar systemd[1610]: Reached target Shutdown.
Jan 18 13:43:04 oscar systemd[1610]: app.slice: Consumed 1min 23.383s CPU time.
Jan 18 13:43:04 oscar systemd[1610]: Removed slice User Application Slice.
Jan 18 13:43:04 oscar systemd[1610]: Closed REST API socket for snapd user session agent.
Jan 18 13:43:04 oscar systemd[1610]: Closed Sound System.
Jan 18 13:43:04 oscar systemd[1610]: Closed debconf communication socket.
Jan 18 13:43:04 oscar systemd[1610]: Closed PipeWire Multimedia System Socket.
Jan 18 13:43:04 oscar systemd[1610]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 18 13:43:04 oscar systemd[1610]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 18 13:43:04 oscar systemd[1610]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 18 13:43:04 oscar systemd[1610]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 18 13:43:04 oscar systemd[1610]: Closed GnuPG network certificate management daemon.
Jan 18 13:43:04 oscar systemd[1610]: Closed D-Bus User Message Bus Socket.
Jan 18 13:43:04 oscar systemd[1610]: Stopped target Timers.
Jan 18 13:43:04 oscar systemd[1610]: Stopped target Sockets.
Jan 18 13:43:04 oscar systemd[1610]: Stopped Pending report trigger for Ubuntu Report.
Jan 18 13:43:04 oscar kernel: veth7f53d6b: renamed from eth0
Jan 18 13:43:04 oscar systemd[1610]: Stopped target Paths.
Jan 18 13:43:04 oscar systemd[1610]: Stopped target Basic System.
Jan 18 13:43:04 oscar systemd[1610]: session.slice: Consumed 10.285s CPU time.
Jan 18 13:43:04 oscar systemd[1610]: Removed slice User Core Session Slice.
Jan 18 13:43:04 oscar systemd[1610]: Stopped PipeWire Multimedia Service.
Jan 18 13:43:04 oscar systemd[1610]: Stopping PipeWire Multimedia Service...
Jan 18 13:43:04 oscar systemd[1610]: Stopped PipeWire Media Session Manager.
Jan 18 13:43:04 oscar systemd[1610]: Stopped Sound Service.
Jan 18 13:43:04 oscar containerd[885]: time="2023-01-18T13:43:04.210357136+01:00" level=warning msg="cleanup warnings time=\"2023-01-18>
Jan 18 13:43:04 oscar pulseaudio[1620]: After module unload, module 'module-null-sink' was still loaded!
Jan 18 13:43:04 oscar systemd[1610]: app-flatpak-org.mozilla.firefox-3359.scope: Consumed 47.923s CPU time.
Jan 18 13:43:04 oscar systemd[1610]: Stopped app-flatpak-org.mozilla.firefox-3359.scope.
Jan 18 13:43:04 oscar systemd[1610]: Stopped Service for snap application snapd-desktop-integration.snapd-desktop-integration.
Jan 18 13:43:04 oscar systemd[1610]: Stopping PipeWire Media Session Manager...
Jan 18 13:43:04 oscar systemd[1610]: Stopped target Main User Target.
Jan 18 13:43:04 oscar systemd[1610]: Removed slice User Background Tasks Slice.
Jan 18 13:43:04 oscar systemd[1610]: app-org.gnome.Terminal.slice: Consumed 1.799s CPU time.
Jan 18 13:43:04 oscar systemd[1610]: Removed slice Slice /app/org.gnome.Terminal.
Jan 18 13:43:04 oscar systemd[1610]: Removed slice Slice /app/gnome-session-manager.
Jan 18 13:43:04 oscar containerd[885]: time="2023-01-18T13:43:04.180653000+01:00" level=info msg="cleaning up dead shim"
Jan 18 13:43:04 oscar containerd[885]: time="2023-01-18T13:43:04.180632500+01:00" level=warning msg="cleaning up after shim disconnecte>
Jan 18 13:43:04 oscar dockerd[1953]: time="2023-01-18T13:43:04.180617411+01:00" level=info msg="ignoring event" container=63151cc6698c2>
Jan 18 13:43:04 oscar systemd[1610]: Stopped Application launched by gnome-session-binary.
Jan 18 13:43:04 oscar containerd[885]: time="2023-01-18T13:43:04.180370825+01:00" level=info msg="shim disconnected" id=63151cc6698c266>
Jan 18 13:43:04 oscar systemd-logind[766]: Removed session 2.
Jan 18 13:43:04 oscar systemd[1610]: Stopping app-flatpak-org.mozilla.firefox-3359.scope...
Jan 18 13:43:04 oscar systemd[1]: Stopping User Manager for UID 1000...
Jan 18 13:43:04 oscar systemd[1]: Stopping User Login Management...
Jan 18 13:43:04 oscar systemd[1]: Condition check resulted in Tell Plymouth To Jump To initramfs being skipped.
Jan 18 13:43:04 oscar dbus-daemon[734]: [system] Activation via systemd failed for unit 'rtkit-daemon.service': Transaction for rtkit-d>
Jan 18 13:43:04 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for rtkit-daemon.service/start is destru>
Jan 18 13:43:04 oscar systemd[1]: session-2.scope: Consumed 3.268s CPU time.
Jan 18 13:43:04 oscar systemd[1]: Stopped Session 2 of User oscarbadiko.
Jan 18 13:43:04 oscar systemd[1]: session-2.scope: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: docker-63151cc6698c266aa14915eb60d37efbac3cab3ecc642b932b34aaa2a0106d6c.scope: Deactivated successful>
Jan 18 13:43:04 oscar systemd[1]: Started Show Plymouth Power Off Screen.
Jan 18 13:43:04 oscar systemd[1]: Stopped Firmware update daemon.
Jan 18 13:43:04 oscar systemd[1]: fwupd.service: Deactivated successfully.
Jan 18 13:43:04 oscar systemd[1]: Stopped Switcheroo Control Proxy service.
Jan 18 13:43:04 oscar systemd[1]: switcheroo-control.service: Deactivated successfully.
Jan 18 13:43:04 oscar /usr/libexec/gdm-x-session[1755]: (II) Server terminated successfully (0). Closing log file.
Jan 18 13:43:04 oscar /usr/libexec/gdm-x-session[1755]: (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
Jan 18 13:43:04 oscar /usr/libexec/gdm-x-session[1755]: (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
Jan 18 13:43:04 oscar /usr/libexec/gdm-x-session[1755]: (II) NVIDIA(GPU-0): Deleting GPU-0
Jan 18 13:43:03 oscar tracker-miner-fs-3[1693]: OK
Jan 18 13:43:03 oscar systemd[1610]: flatpak-session-helper.service: Failed with result 'exit-code'.
Jan 18 13:43:03 oscar systemd[1610]: flatpak-session-helper.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 13:43:03 oscar systemd[1610]: Stopped D-Bus User Message Bus.
Jan 18 13:43:03 oscar systemd[1610]: xdg-document-portal.service: Failed with result 'exit-code'.
Jan 18 13:43:03 oscar dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon>
Jan 18 13:43:03 oscar systemd[1610]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:65
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) UnloadModule: "libinput"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:64
Jan 18 13:43:03 oscar systemd[1]: Unmounted /run/user/1000/doc.
Jan 18 13:43:03 oscar systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:71
Jan 18 13:43:03 oscar systemd[1]: Unmounted /run/user/1000/gvfs.
Jan 18 13:43:03 oscar systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:66
Jan 18 13:43:03 oscar systemd[1610]: xdg-permission-store.service: Failed with result 'exit-code'.
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:67
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:68
Jan 18 13:43:03 oscar systemd[1610]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 13:43:03 oscar systemd[1610]: Stopping D-Bus User Message Bus...
Jan 18 13:43:03 oscar gvfsd[2028]: A connection to the bus can't be made
Jan 18 13:43:03 oscar gvfsd[1644]: A connection to the bus can't be made
Jan 18 13:43:03 oscar systemd[1610]: Stopped Start gnome-keyring as SSH agent.
Jan 18 13:43:03 oscar sh[4374]: /bin/sh: 1: initctl: not found
Jan 18 13:43:03 oscar systemd[1610]: Started Restart DBus after GNOME Session shutdown.
Jan 18 13:43:03 oscar dbus-daemon[734]: [system] Activation via systemd failed for unit 'rtkit-daemon.service': Transaction for rtkit-d>
Jan 18 13:43:03 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for rtkit-daemon.service/start is destru>
Jan 18 13:43:03 oscar systemd[1]: Stopped Daemon for power management.
Jan 18 13:43:03 oscar systemd[1]: upower.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped CUPS Scheduler.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target Shutdown running GNOME Session.
Jan 18 13:43:03 oscar systemd[1]: cups.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1610]: Starting Restart DBus after GNOME Session shutdown...
Jan 18 13:43:03 oscar systemd[1]: Stopped Authorization Manager.
Jan 18 13:43:03 oscar systemd[1]: polkit.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1610]: Stopping Start gnome-keyring as SSH agent...
Jan 18 13:43:03 oscar systemd[1610]: Reached target Shutdown running GNOME Session.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target Session services which should run early before the graphical session is brought up.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target Tasks to be run before GNOME Session starts.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME Session Manager (session: ubuntu).
Jan 18 13:43:03 oscar systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Jan 18 13:43:03 oscar systemd[1610]: Stopped Monitor Session leader for GNOME Session.
Jan 18 13:43:03 oscar systemd[1]: avahi-daemon.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Disk Manager.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME Shell.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME Session Manager is ready.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME Session is initialized.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME XSettings target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME Wacom tablet support target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME sound sample caching target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME smartcard target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME file sharing target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME FreeDesktop screensaver target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME RFKill support target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME printer notifications target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME power management target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME keyboard shortcuts target.
Jan 18 13:43:03 oscar systemd[1]: udisks2.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME keyboard configuration target.
Jan 18 13:43:03 oscar avahi-daemon[733]: avahi-daemon 0.8 exiting.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME maintenance of expirable data target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME date & time target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME color management target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME accessibility target.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME Session (session: ubuntu).
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME X11 Session.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME Session.
Jan 18 13:43:03 oscar systemd[1610]: Stopped Path trigger for new release of Ubuntu notifications.
Jan 18 13:43:03 oscar systemd[1610]: Stopped Path trigger for Apport crash notifications.
Jan 18 13:43:03 oscar kernel: [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00002700] Failed to grab modeset owne>
Jan 18 13:43:03 oscar dbus-daemon[734]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Transacti>
Jan 18 13:43:03 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for avahi-daemon.service/start is destru>
Jan 18 13:43:03 oscar dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedeskto>
Jan 18 13:43:03 oscar systemd[1]: Received SIGRTMIN+20 from PID 4368 (plymouthd).
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface wlp36s0.IPv4 with address 192.168.178.27.
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface wlp36s0.IPv6 with address 2a01:c22:d49b:c300:5882:11>
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface br-1beff4638eac.IPv4 with address 172.18.0.1.
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1.
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface docker0.IPv6 with address fe80::42:57ff:fe5f:5440.
Jan 18 13:43:03 oscar avahi-daemon[733]: Leaving mDNS multicast group on interface veth9201249.IPv6 with address fe80::7002:9aff:fea1:4>
Jan 18 13:43:03 oscar systemd[1]: Starting Show Plymouth Power Off Screen...
Jan 18 13:43:03 oscar systemd[1]: Stopping Firmware update daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopping CUPS Scheduler...
Jan 18 13:43:03 oscar systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Jan 18 13:43:03 oscar avahi-daemon[733]: Got SIGTERM, quitting.
Jan 18 13:43:03 oscar udisksd[768]: udisks daemon version 2.9.4 exiting
Jan 18 13:43:03 oscar systemd[1]: Stopped LSB: automatic crash report generation.
Jan 18 13:43:03 oscar systemd[1]: apport.service: Deactivated successfully.
Jan 18 13:43:03 oscar apport[4337]: ...done.
Jan 18 13:43:03 oscar systemd[1]: Stopped Make remote CUPS printers available locally.
Jan 18 13:43:03 oscar systemd[1]: cups-browsed.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: gdm.service: Failed to enqueue OnFailure= job, ignoring: Transaction for plymouth-quit.service/start >
Jan 18 13:43:03 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for plymouth-quit.service/start is destr>
Jan 18 13:43:03 oscar systemd[1]: gdm.service: Triggering OnFailure= dependencies.
Jan 18 13:43:03 oscar systemd[1]: Stopped GNOME Display Manager.
Jan 18 13:43:03 oscar apport[4337]: * Stopping automatic crash report generation: apport
Jan 18 13:43:03 oscar systemd[1]: gdm.service: Failed with result 'exit-code'.
Jan 18 13:43:03 oscar systemd[1]: gdm.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 13:43:03 oscar systemd[1610]: Stopped target Current graphical user session.
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME X11 Session (session: ubuntu).
Jan 18 13:43:03 oscar systemd[1610]: Stopped target GNOME session X11 services.
Jan 18 13:43:03 oscar systemd[1]: Stopped Samba NMB Daemon.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME keyboard shortcuts service.
Jan 18 13:43:03 oscar gdm3[1042]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts>
Jan 18 13:43:03 oscar dbus-daemon[734]: [system] Activation via systemd failed for unit 'accounts-daemon.service': Transaction for acco>
Jan 18 13:43:03 oscar systemd[1]: nmbd.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Requested transaction contradicts existing jobs: Transaction for accounts-daemon.service/start is des>
Jan 18 13:43:03 oscar dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.>
Jan 18 13:43:03 oscar systemd[1]: Stopping Switcheroo Control Proxy service...
Jan 18 13:43:03 oscar systemd[1]: Stopping Authorization Manager...
Jan 18 13:43:03 oscar systemd[1]: Stopping Samba NMB Daemon...
Jan 18 13:43:03 oscar systemd[1610]: app-gnome-gnome\x2dsoftware\x2dservice-2435.scope: Consumed 2.227s CPU time.
Jan 18 13:43:03 oscar systemd[1]: Stopped target System Time Set.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Host and Network Name Lookups.
Jan 18 13:43:03 oscar systemd[1610]: snap.snap-store.snap-store.d49ffcc3-c07a-4ce0-8679-08b7f6ec0554.scope: Consumed 2.362s CPU time.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME XSettings service.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME Wacom tablet support service.
Jan 18 13:43:03 oscar systemd-logind[766]: Session 2 logged out. Waiting for processes to exit.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME maintenance of expirable data service.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME color management service.
Jan 18 13:43:03 oscar systemd[1610]: org.gnome.Shell@x11.service: Consumed 8.460s CPU time.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME Shell on X11.
Jan 18 13:43:03 oscar systemd[1]: Stopped Tool to automatically collect and submit kernel crash signatures.
Jan 18 13:43:03 oscar systemd[1]: kerneloops.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME sound sample caching service.
Jan 18 13:43:03 oscar systemd[1]: Stopped Load/Save Random Seed.
Jan 18 13:43:03 oscar systemd[1]: systemd-random-seed.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Save/Restore Sound Card State.
Jan 18 13:43:03 oscar systemd[1]: alsa-restore.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: snapd.service: Consumed 1.673s CPU time.
Jan 18 13:43:03 oscar systemd[1]: Stopped Snap Daemon.
Jan 18 13:43:03 oscar systemd[1]: snapd.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: packagekit.service: Consumed 6.282s CPU time.
Jan 18 13:43:03 oscar systemd[1]: Stopped PackageKit Daemon.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME RFKill support service.
Jan 18 13:43:03 oscar systemd[1]: packagekit.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1610]: Stopped GNOME power management service.
Jan 18 13:43:03 oscar systemd[1610]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Jan 18 13:43:03 oscar systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Jan 18 13:43:03 oscar systemd[1610]: xdg-desktop-portal-gtk.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 13:43:03 oscar systemd[1610]: Stopped Rygel DLNA/UPnP server.
Jan 18 13:43:03 oscar systemd[1610]: Stopped IBus Daemon for GNOME.
Jan 18 13:43:03 oscar systemd[1610]: xdg-desktop-portal-gnome.service: Failed with result 'exit-code'.
Jan 18 13:43:03 oscar systemd[1610]: xdg-desktop-portal-gnome.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 13:43:03 oscar systemd[1]: colord.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Power Profiles daemon.
Jan 18 13:43:03 oscar systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Samba SMB Daemon.
Jan 18 13:43:03 oscar systemd[1]: smbd.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Jan 18 13:43:03 oscar systemd[1]: rtkit-daemon.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Modem Manager.
Jan 18 13:43:03 oscar systemd[1]: ModemManager.service: Deactivated successfully.
Jan 18 13:43:03 oscar snapd[753]: overlord.go:512: Released state lock file
Jan 18 13:43:03 oscar systemd[1]: Stopped Regular background program processing daemon.
Jan 18 13:43:03 oscar systemd[1]: cron.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Accounts Service.
Jan 18 13:43:03 oscar systemd[1]: accounts-daemon.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped System Logging Service.
Jan 18 13:43:03 oscar systemd[1]: rsyslog.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Dispatcher daemon for systemd-networkd.
Jan 18 13:43:03 oscar systemd[1]: networkd-dispatcher.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped irqbalance daemon.
Jan 18 13:43:03 oscar systemd[1]: irqbalance.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopping Daemon for power management...
Jan 18 13:43:03 oscar systemd[1]: Stopping Disk Manager...
Jan 18 13:43:03 oscar systemd[1]: Stopping Load/Save Random Seed...
Jan 18 13:43:03 oscar systemd[1]: Condition check resulted in Ubuntu core (all-snaps) system shutdown helper setup service being skippe>
Jan 18 13:43:03 oscar systemd[1]: Stopping Snap Daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopped Wait until snapd is fully seeded.
Jan 18 13:43:03 oscar systemd[1]: snapd.seeded.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopping Samba SMB Daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Jan 18 13:43:03 oscar systemd[1]: Stopping System Logging Service...
Jan 18 13:43:03 oscar systemd[1]: Stopping Power Profiles daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopped Hold until boot process finishes up.
Jan 18 13:43:03 oscar systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopping PackageKit Daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopped OpenVPN service.
Jan 18 13:43:03 oscar systemd[1]: openvpn.service: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopping NVIDIA Persistence Daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopping Dispatcher daemon for systemd-networkd...
Jan 18 13:43:03 oscar systemd[1]: Stopping Tool to automatically collect and submit kernel crash signatures...
Jan 18 13:43:03 oscar systemd[1]: Stopping irqbalance daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopping GNOME Display Manager...
Jan 18 13:43:03 oscar systemd[1]: Stopping Docker Application Container Engine...
Jan 18 13:43:03 oscar systemd[1]: Stopping Make remote CUPS printers available locally...
Jan 18 13:43:03 oscar systemd[1]: Stopping Regular background program processing daemon...
Jan 18 13:43:03 oscar rsyslogd[750]: [origin software="rsyslogd" swVersion="8.2112.0" x-pid="750" x-info="https://www.rsyslog.com"] exi>
Jan 18 13:43:03 oscar systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Jan 18 13:43:03 oscar nvidia-persistenced[1072]: Received signal 15
Jan 18 13:43:03 oscar systemd[1]: Stopping LSB: automatic crash report generation...
Jan 18 13:43:03 oscar ModemManager[834]: <info> ModemManager is shut down
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: releasing fd for 13:69
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) systemd-logind: not releasing fd for 13:68, still in use
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event4 - MOSART Semi. 2.4G Keyboard Mouse Consumer Control: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "47"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event5 - MOSART Semi. 2.4G Keyboard Mouse System Control: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "48"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event3 - MOSART Semi. 2.4G Keyboard Mouse: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "46"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event2 - MOSART Semi. 2.4G Keyboard Mouse: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "45"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event7 - HD Web Camera: HD Web Camera: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "44"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event0 - Power Button: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "43"
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (II) event1 - Power Button: device removed
Jan 18 13:43:03 oscar /usr/libexec/gdm-x-session[1755]: (**) Option "fd" "40"
Jan 18 13:43:03 oscar org.kde.kdeconnect.daemon.desktop[2436]: ICE default IO error handler doing an exit(), pid = 2436, errno = 32
Jan 18 13:43:03 oscar dockerd[1953]: time="2023-01-18T13:43:03.868728612+01:00" level=info msg="Processing signal 'terminated'"
Jan 18 13:43:03 oscar snapd[753]: main.go:155: Exiting on terminated signal.
Jan 18 13:43:03 oscar systemd[1]: Stopping Save/Restore Sound Card State...
Jan 18 13:43:03 oscar NetworkManager[770]: <info> [1674045783.8431] modem-manager: ModemManager no longer available
Jan 18 13:43:03 oscar systemd[1]: Stopping ACPI event daemon...
Jan 18 13:43:03 oscar systemd[1]: Stopping Accounts Service...
Jan 18 13:43:03 oscar ModemManager[834]: <info> caught signal, shutting down...
Jan 18 13:43:03 oscar systemd[1]: Stopping Modem Manager...
Jan 18 13:43:03 oscar systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jan 18 13:43:03 oscar systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Check to see whether there is a new version of Ubuntu available.
Jan 18 13:43:03 oscar systemd[1]: update-notifier-motd.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Download data for packages that failed at package install time.
Jan 18 13:43:03 oscar systemd[1]: update-notifier-download.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Ubuntu Advantage Timer for running repeated jobs.
Jan 18 13:43:03 oscar systemd[1]: ua-timer.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jan 18 13:43:03 oscar systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Message of the Day.
Jan 18 13:43:03 oscar systemd[1]: motd-news.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Daily man-db regeneration.
Jan 18 13:43:03 oscar systemd[1]: man-db.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Daily rotation of log files.
Jan 18 13:43:03 oscar systemd[1]: logrotate.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Refresh fwupd metadata regularly.
Jan 18 13:43:03 oscar systemd[1]: fwupd-refresh.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Discard unused blocks once a week.
Jan 18 13:43:03 oscar systemd[1]: fstrim.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Periodic ext4 Online Metadata Check for All Filesystems.
Jan 18 13:43:03 oscar systemd[1]: e2scrub_all.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Daily dpkg database backup timer.
Jan 18 13:43:03 oscar systemd[1]: dpkg-db-backup.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Daily apt download activities.
Jan 18 13:43:03 oscar systemd[1]: apt-daily.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Daily apt upgrade and clean activities.
Jan 18 13:43:03 oscar systemd[1]: apt-daily-upgrade.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped Trigger anacron every hour.
Jan 18 13:43:03 oscar systemd[1]: anacron.timer: Deactivated successfully.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Timer Units.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Sound Card.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Printer Support.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Login Prompts.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Multi-User System.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Graphical Interface.
Jan 18 13:43:03 oscar systemd[1]: Stopped target Preparation for Logins.
Jan 18 13:43:03 oscar systemd[1]: Removed slice Slice /system/modprobe.
Jan 18 13:43:03 oscar systemd[1]: Removed slice Slice /system/getty.
Jan 18 13:43:03 oscar rygel[2352]: Error sending SSDP packet to FF02::C: Error sending message: Operation not permitted
Jan 18 13:43:03 oscar rygel[2352]: Error sending SSDP packet to FF05::C: Error sending message: Operation not permitted
Jan 18 13:43:03 oscar rygel[2352]: Error sending SSDP packet to 239.255.255.250: Error sending message: Operation not permitted
