Drive PX2 shut down or freezes randomly.
The DRIVE PX2 board shuts down randomly.
Sometimes it runs all day, but sometimes it is turned off without running any processes.
I don’t know what is the problem. Because this situation happens randomly.
How can I fix this? I can send log files if necessary.
Thank you
Dear kiminhan,
It could be possible due to over heating. If you notice this issue frequently, Can you please check with latest PDK and let us know([url]https://developer.nvidia.com/drive/downloads[/url])
Thank you for quick replaying.
I’m not sure the problem is caused by over heating. Could the problem occur when used in the office?
If so, I am afraid to use it for autonomous driving.
Is there any possibility of a hardware problem?
Is there any guide for system checking?
Thank you in advance.
Dear kiminhan,
We did not notice such issues in forum so far. It is difficult comment on the issue when you/we can not reproduce it. How frequently do you see this? Is it happening using latest PDK?
Dear SivaRamaKrishna,
We’ve installed the OS of DPX2 using Driveinstall 5.0.5.
I assume that the pdk installation is included in the driveinstall process, right?
It happens almost every time we use dpx2.
Here are the situations that we’ve encountered so far that made px2 freeze:
  • When first logging in to OS
  • When closing tabs of chrominum-browser
  • When running multiple processes of drivenets with video inputs.
  • When using recording with 4 concurrent gmsl cameras using recording tools at /usr/local/driveworks/tools/recorder
    There are a lot more of them, but these are the situations that I can remember.
It is hard to find the cause for the problem, because sometimes dpx2 doesn’t freeze even when
we reproduce the situation that are assumed to cause problem.
Dear taewook101,
Is it autocruise or autochauffer?
Did you notice this issue when you log into system just after reboot or the system is on for a while and you are trying to login?
When it gets hang, please connect to tegra via serial console and run Tegrastats to know the load on the board. Could you upgrade to Drive 5.0.10 via Devzone and let us know.
It’s autochauffer.
I noticed it just after its reboot.
We’ll let you know the results of Tegrastats after upgrading to 5.0.10
Dear taewook101,
Have you checked with 5.0.10?
It’s going to take some time to upgrade the troubled px2, due to some other issue, but I think
the problem is related to other reason rather than the version of pdk,
since the other px2(we have two px2 board in total) installed with 5.0.5 is working well, without freezes or shutdowns.
Could you please have a look at the syslog files captured at the troubled situation?
I will post the logs asap.
Dear taewook101,
Ok. COuld you please share the logs when it gets freezed.
The log below is captured when we ran the drivenet sample application.
Thanks in advance.
Apr 4 11:56:12 nvidia rsyslogd-2007: action ‘action 10’ suspended, next retry is Thu Apr 4 11:56:42 2019 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Apr 4 11:56:53 nvidia rsyslogd-2007: action ‘action 10’ suspended, next retry is Thu Apr 4 11:57:23 2019 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Apr 4 11:56:57 nvidia org.gtk.vfs.Daemon[1237]: A connection to the bus can’t be made
Apr 4 11:56:57 nvidia systemd[1]: Created slice User Slice of nvidia.
Apr 4 11:56:57 nvidia systemd[1]: Starting User Manager for UID 1001…
Apr 4 11:56:57 nvidia systemd[1]: Started Session c2 of user nvidia.
Apr 4 11:56:57 nvidia ofonod[832]: get_property_value: ERROR reply to Get
Apr 4 11:56:57 nvidia ofonod[832]: ofonod[832]: get_property_value: ERROR reply to Get
Apr 4 11:56:57 nvidia systemd[1422]: Reached target Timers.
Apr 4 11:56:57 nvidia systemd[1422]: Reached target Sockets.
Apr 4 11:56:57 nvidia systemd[1422]: Reached target Paths.
Apr 4 11:56:57 nvidia systemd[1422]: Reached target Basic System.
Apr 4 11:56:57 nvidia systemd[1422]: Reached target Default.
Apr 4 11:56:57 nvidia systemd[1422]: Startup finished in 33ms.
Apr 4 11:56:57 nvidia systemd[1]: Started User Manager for UID 1001.
Apr 4 11:56:58 nvidia org.a11y.Bus[1490]: Activating service name=‘org.a11y.atspi.Registry’
Apr 4 11:56:58 nvidia org.a11y.Bus[1490]: ** (process:1587): WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
Apr 4 11:56:58 nvidia org.a11y.Bus[1490]: Successfully activated service ‘org.a11y.atspi.Registry’
Apr 4 11:56:58 nvidia org.a11y.atspi.Registry[1593]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Apr 4 11:56:59 nvidia gnome-session[1622]: nvrm_gpu: Bug 200215060 workaround enabled.
Apr 4 11:56:59 nvidia kernel: [ 289.404615] tegradc 15200000.nvdisplay: blank - powerdown
Apr 4 11:56:59 nvidia kernel: [ 289.472398] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Apr 4 11:56:59 nvidia kernel: [ 289.472500] tegradc 15200000.nvdisplay: unblank
Apr 4 11:56:59 nvidia kernel: [ 289.472639] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Apr 4 11:56:59 nvidia kernel: [ 289.472862] Parent Clock set for DC plld2
Apr 4 11:56:59 nvidia kernel: [ 289.474810] tegradc 15200000.nvdisplay: hdmi: pclk:148500K prod-setting:prod_c_hdmi_75m_150m
Apr 4 11:56:59 nvidia kernel: [ 289.476315] tegradc 15200000.nvdisplay: unblank
Apr 4 11:56:59 nvidia kernel: [ 289.476321] tegradc 15220000.nvdisplay: blank - powerdown
Apr 4 11:56:59 nvidia kernel: [ 289.534871] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
Apr 4 11:56:59 nvidia kernel: [ 289.534966] tegradc 15220000.nvdisplay: unblank
Apr 4 11:56:59 nvidia kernel: [ 289.535158] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
Apr 4 11:56:59 nvidia kernel: [ 289.535340] Parent Clock set for DC plld3
Apr 4 11:56:59 nvidia kernel: [ 289.548732] tegradc 15220000.nvdisplay: hdmi: pclk:74680K prod-setting:prod_c_hdmi_54m_75m
Apr 4 11:56:59 nvidia kernel: [ 289.549952] tegradc 15220000.nvdisplay: unblank
Apr 4 11:56:59 nvidia kernel: [ 289.549957] tegradc 15210000.nvdisplay: blank - powerdown
Apr 4 11:56:59 nvidia rtkit-daemon[1340]: Successfully made thread 1731 of process 1731 (n/a) owned by ‘1001’ high priority at nice level -11.
Apr 4 11:56:59 nvidia rtkit-daemon[1340]: Supervising 2 threads of 2 processes of 2 users.
Apr 4 11:56:59 nvidia pulseaudio[1731]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.ofono.Error.InUse: The resource is currently in use
Apr 4 11:57:00 nvidia org.gnome.ScreenSaver[1490]: ** (gnome-screensaver:1712): WARNING **: Couldn’t get presence status: The name org.gnome.SessionManager was not provided by any .service files
Apr 4 11:57:00 nvidia dbus[811]: [system] Activating via systemd: service name=‘org.freedesktop.locale1’ unit=‘dbus-org.freedesktop.locale1.service’
Apr 4 11:57:00 nvidia systemd[1]: Starting Locale Service…
Apr 4 11:57:00 nvidia gnome-session[1622]: gnome-keyring-daemon: insufficient process capabilities, unsecure memory might get used
Apr 4 11:57:00 nvidia gnome-session[1622]: SSH_AUTH_SOCK=/run/user/1001/keyring/ssh
Apr 4 11:57:00 nvidia kernel: [ 289.977860] tegradc 15200000.nvdisplay: blank - powerdown
Apr 4 11:57:00 nvidia kernel: [ 289.978040] IPVS: Creating netns size=1744 id=3
Apr 4 11:57:00 nvidia kernel: [ 290.047230] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Apr 4 11:57:00 nvidia kernel: [ 290.048039] tegradc 15200000.nvdisplay: unblank
Apr 4 11:57:00 nvidia kernel: [ 290.048201] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Apr 4 11:57:00 nvidia kernel: [ 290.048397] Parent Clock set for DC plld2
Apr 4 11:57:00 nvidia kernel: [ 290.050616] tegradc 15200000.nvdisplay: hdmi: pclk:148500K prod-setting:prod_c_hdmi_75m_150m
Apr 4 11:57:00 nvidia kernel: [ 290.052014] tegradc 15200000.nvdisplay: unblank
Apr 4 11:57:00 nvidia kernel: [ 290.052021] tegradc 15220000.nvdisplay: blank - powerdown
Apr 4 11:57:00 nvidia dbus[811]: [system] Successfully activated service ‘org.freedesktop.locale1’
Apr 4 11:57:00 nvidia systemd[1]: Started Locale Service.
Apr 4 11:57:00 nvidia kernel: [ 290.120912] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
Apr 4 11:57:00 nvidia kernel: [ 290.121715] tegradc 15220000.nvdisplay: unblank
Apr 4 11:57:00 nvidia kernel: [ 290.121852] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
Apr 4 11:57:00 nvidia kernel: [ 290.122048] Parent Clock set for DC plld3
Apr 4 11:57:00 nvidia kernel: [ 290.135344] tegradc 15220000.nvdisplay: hdmi: pclk:74680K prod-setting:prod_c_hdmi_54m_75m
Apr 4 11:57:00 nvidia kernel: [ 290.136544] tegradc 15220000.nvdisplay: unblank
Apr 4 11:57:00 nvidia kernel: [ 290.136550] tegradc 15210000.nvdisplay: blank - powerdown
Apr 4 11:57:00 nvidia gnome-session[1622]: (process:1775): indicator-application-service-WARNING **: Unable to get watcher name ‘org.kde.StatusNotifierWatcher’
Apr 4 11:57:00 nvidia gnome-session[1622]: (process:1775): indicator-application-service-WARNING **: Name Lost
Apr 4 11:57:00 nvidia gnome-session-binary[1622]: Entering running state
Apr 4 11:57:00 nvidia dbus[811]: [system] Activating via systemd: service name=‘org.freedesktop.UDisks2’ unit=‘udisks2.service’
Apr 4 11:57:00 nvidia systemd[1]: Starting Disk Manager…
Apr 4 11:57:00 nvidia udisksd[1824]: udisks daemon version 2.1.7 starting
Apr 4 11:57:00 nvidia systemd[1]: Started Snappy daemon.
Apr 4 11:57:00 nvidia dbus[811]: [system] Successfully activated service ‘org.freedesktop.UDisks2’
Apr 4 11:57:00 nvidia systemd[1]: Started Disk Manager.
Apr 4 11:57:00 nvidia udisksd[1824]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 4 11:57:00 nvidia gnome-session[1622]: (nm-applet:1773): nm-applet-WARNING **: NetworkManager is not running
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/system-info
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/login
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/logout
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/icons/{name}/icon
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/find
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/snaps
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/snaps/{name}
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/interfaces
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/assertions
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/assertions/{assertType}
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/events
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:212: DEBUG: adding /v2/changes/{id}
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:202: DEBUG: init done in 3.209ms
Apr 4 11:57:00 nvidia /usr/lib/snapd/snapd[1839]: daemon.go:180: DEBUG: uid=1001;@ GET /v2/system-info 1.329ms 200
Apr 4 11:57:00 nvidia gnome-session[1622]: (gnome-software:1781): Json-CRITICAL **: json_object_get_string_member: assertion ‘node != NULL’ failed
Apr 4 11:57:01 nvidia dbus[811]: [system] Activating service name=‘org.freedesktop.fwupd’ (using servicehelper)
Apr 4 11:57:01 nvidia org.gtk.vfs.AfcVolumeMonitor[1490]: Volume monitor alive
Apr 4 11:57:02 nvidia kernel: [ 292.299436] IPVS: Creating netns size=1744 id=4
Apr 4 11:57:02 nvidia org.freedesktop.fwupd[811]: (fwupd:1860): Fu-WARNING **: Failed to coldplug: UEFI firmware updating not supported
Apr 4 11:57:02 nvidia dbus[811]: [system] Successfully activated service ‘org.freedesktop.fwupd’
Apr 4 11:57:02 nvidia org.gnome.ScreenSaver[1490]: ** Message: Lost the name, shutting down.
Apr 4 11:57:05 nvidia gnome-session[1622]: nvrm_gpu: Bug 200215060 workaround enabled.
Apr 4 11:57:05 nvidia gnome-session[1622]: OGL tried to load Ocg library: libnvidia-glcore-ocg.so.390.00
Apr 4 11:57:06 nvidia gnome-session[1622]: message repeated 6 times: [ OGL tried to load Ocg library: libnvidia-glcore-ocg.so.390.00]
Apr 4 11:57:06 nvidia gnome-session[1622]: Could not load compiler library: libnvidia-glcore-cg.so.390.00
Apr 4 11:57:06 nvidia gnome-session[1622]: message repeated 2 times: [ Could not load compiler library: libnvidia-glcore-cg.so.390.00]
Apr 4 11:57:06 nvidia gnome-session[1622]: Received signal 11 SEGV_MAPERR 1bd1d5e7c8347b
Apr 4 11:57:06 nvidia gnome-session[1622]: #0 0x007f97d0ee50 base::debug::StackTrace::StackTrace()
Apr 4 11:57:06 nvidia gnome-session[1622]: #1 0x007f97d0f29c
Apr 4 11:57:06 nvidia gnome-session[1622]: #2 0x007f97eff6c0 ([vdso]+0x6bf)
Apr 4 11:57:06 nvidia gnome-session[1622]: #3 0x007f8b414444
Apr 4 11:57:06 nvidia gnome-session[1622]: #4 0x007f8b414d24
Apr 4 11:57:06 nvidia gnome-session[1622]: #5 0x007f8b421db4
Apr 4 11:57:06 nvidia gnome-session[1622]: #6 0x007f8bc98414
Apr 4 11:57:06 nvidia gnome-session[1622]: [end of stack trace]
Apr 4 11:57:07 nvidia gnome-session[1622]: nvrm_gpu: Bug 200215060 workaround enabled.
Apr 4 11:57:07 nvidia gnome-session[1622]: OGL tried to load Ocg library: libnvidia-glcore-ocg.so.390.00
Apr 4 11:57:08 nvidia gnome-session[1622]: message repeated 6 times: [ OGL tried to load Ocg library: libnvidia-glcore-ocg.so.390.00]
Apr 4 11:57:08 nvidia gnome-session[1622]: Could not load compiler library: libnvidia-glcore-cg.so.390.00
Apr 4 11:57:08 nvidia gnome-session[1622]: message repeated 2 times: [ Could not load compiler library: libnvidia-glcore-cg.so.390.00]
Apr 4 11:57:08 nvidia gnome-session[1622]: Received signal 11 SEGV_MAPERR 1bd1d5e7c8347b
Apr 4 11:57:08 nvidia gnome-session[1622]: #0 0x007f982f8e50 base::debug::StackTrace::StackTrace()
Apr 4 11:57:08 nvidia gnome-session[1622]: #1 0x007f982f929c
Apr 4 11:57:08 nvidia gnome-session[1622]: #2 0x007f984e96c0 ([vdso]+0x6bf)
Apr 4 11:57:08 nvidia gnome-session[1622]: #3 0x007f87837444
Apr 4 11:57:08 nvidia gnome-session[1622]: #4 0x007f87837d24
Apr 4 11:57:08 nvidia gnome-session[1622]: #5 0x007f87844db4
Apr 4 11:57:08 nvidia gnome-session[1622]: #6 0x007f8c282414
Apr 4 11:57:08 nvidia gnome-session[1622]: [end of stack trace]
Apr 4 11:57:09 nvidia gnome-session[1622]: nvrm_gpu: Bug 200215060 workaround enabled.
Apr 4 11:57:09 nvidia gnome-session[1622]: OGL tried to load Ocg library: libnvidia-glcore-ocg.so.390.00
Apr 4 11:57:09 nvidia gnome-session[1622]: message repeated 6 times: [ OGL tried to load Ocg library: libnvidia-glcore-ocg.so.390.00]
Apr 4 11:57:09 nvidia gnome-session[1622]: Could not load compiler library: libnvidia-glcore-cg.so.390.00
Apr 4 11:57:09 nvidia gnome-session[1622]: message repeated 2 times: [ Could not load compiler library: libnvidia-glcore-cg.so.390.00]
Apr 4 11:57:09 nvidia gnome-session[1622]: Received signal 11 SEGV_MAPERR 1bd1d5e7c8347b
Apr 4 11:57:09 nvidia gnome-session[1622]: #0 0x007fa0f4de50 base::debug::StackTrace::StackTrace()
Apr 4 11:57:09 nvidia gnome-session[1622]: #1 0x007fa0f4e29c
Apr 4 11:57:09 nvidia gnome-session[1622]: #2 0x007fa113e6c0 ([vdso]+0x6bf)
Apr 4 11:57:09 nvidia gnome-session[1622]: #3 0x007f94653444
Apr 4 11:57:09 nvidia gnome-session[1622]: #4 0x007f94653d24
Apr 4 11:57:09 nvidia gnome-session[1622]: #5 0x007f94660db4
Apr 4 11:57:09 nvidia gnome-session[1622]: #6 0x007f94ed7414
Apr 4 11:57:09 nvidia gnome-session[1622]: [end of stack trace]
Apr 4 11:57:10 nvidia gnome-session[1622]: nvrm_gpu: Bug 200215060 workaround enabled.
Apr 4 11:57:10 nvidia gnome-session[1622]: [1771:1968:0404/115710:ERROR:browser_gpu_channel_host_factory.cc(131)] Failed to create channel.
Apr 4 11:57:17 nvidia systemd[1]: Stopping User Manager for UID 106…
Apr 4 11:57:17 nvidia systemd[1224]: Reached target Shutdown.
Apr 4 11:57:17 nvidia systemd[1224]: Starting Exit the Session…
Apr 4 11:57:17 nvidia systemd[1224]: Stopped target Default.
Apr 4 11:57:17 nvidia systemd[1224]: Stopped target Basic System.
Apr 4 11:57:17 nvidia systemd[1224]: Stopped target Timers.
Apr 4 11:57:17 nvidia systemd[1224]: Stopped target Sockets.
Apr 4 11:57:17 nvidia systemd[1224]: Stopped target Paths.
Apr 4 11:57:17 nvidia systemd[1224]: Received SIGRTMIN+24 from PID 2233 (kill).
Apr 4 11:57:17 nvidia systemd[1]: Stopped User Manager for UID 106.
Apr 4 11:57:17 nvidia systemd[1]: Removed slice User Slice of lightdm.
Apr 4 11:57:21 nvidia org.gnome.zeitgeist.Engine[1490]: ** (zeitgeist-datahub:2258): WARNING **: zeitgeist-datahub.vala:229: Unable to get name “org.gnome.zeitgeist.datahub” on the bus!
Apr 4 11:57:22 nvidia dbus[811]: [system] Activating via systemd: service name=‘org.freedesktop.timedate1’ unit=‘dbus-org.freedesktop.timedate1.service’
Apr 4 11:57:22 nvidia systemd[1]: Starting Time & Date Service…
Apr 4 11:57:22 nvidia dbus[811]: [system] Successfully activated service ‘org.freedesktop.timedate1’
Apr 4 11:57:22 nvidia systemd[1]: Started Time & Date Service.
Apr 4 11:56:42 nvidia rsyslogd: [origin software=“rsyslogd” swVersion=“8.16.0” x-pid=“789” x-info=“http://www.rsyslog.com”] start
Apr 4 11:56:42 nvidia rsyslogd-2222: command ‘KLogPermitNonKernelFacility’ is currently not permitted - did you already set it via a RainerScript command (v6+ config)? [v8.16.0 try http://www.rsyslog.com/e/2222 ]
Apr 4 11:56:42 nvidia rsyslogd: rsyslogd’s groupid changed to 115
Apr 4 11:56:42 nvidia rsyslogd: rsyslogd’s userid changed to 108
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra_alt_utils’ is blacklisted
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_xbar_utils’ is blacklisted
Apr 4 11:56:42 nvidia nv-run-date[442]: /etc/init.d/nv-run-date: 9: [: -gt: unexpected operator
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra186_alt_xbar’ is blacklisted
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_admaif’ is blacklisted
Apr 4 11:56:42 nvidia rsyslogd-2039: Could not open output pipe ‘/dev/xconsole’:: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Booting Linux on physical CPU 0x100
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_spdif_tx’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Linux version 4.9.38-rt25-tegra (buildbrain@mobile-u64-290) (gcc version 4.9.2 (GCC) ) #1 SMP PREEMPT RT Mon Jan 8 01:00:48 PST 2018
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Boot CPU: AArch64 Processor [411fd073]
Apr 4 11:56:42 nvidia kernel: [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_i2s’ is blacklisted
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_dmic’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] OF: fdt: - 80000000 , 7fe00000
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_amx’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] OF: fdt: - 100000000 , 15ca00000
Apr 4 11:56:42 nvidia kernel: [ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003110000 (options ‘’)
Apr 4 11:56:42 nvidia rsyslogd-2007: action ‘action 10’ suspended, next retry is Thu Apr 4 11:57:12 2019 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Apr 4 11:56:42 nvidia kernel: [ 0.000000] bootconsole [uart8250] enabled
Apr 4 11:56:42 nvidia kernel: [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_adx’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] OF: reserved mem: initialized node generic_carveout, compatible id nvidia,generic_carveout
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_mixer’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] cma: Reserved 256 MiB at 0x00000000bec00000
Apr 4 11:56:42 nvidia kernel: [ 0.000000] On node 0 totalpages: 1750528
Apr 4 11:56:42 nvidia kernel: [ 0.000000] DMA zone: 5040 pages used for memmap
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_sfc’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] DMA zone: 0 pages reserved
Apr 4 11:56:42 nvidia kernel: [ 0.000000] DMA zone: 322560 pages, LIFO batch:31
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Normal zone: 22312 pages used for memmap
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_mvc’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Normal zone: 1427968 pages, LIFO batch:31
Apr 4 11:56:42 nvidia kernel: [ 0.000000] psci: probing for conduit method from DT.
Apr 4 11:56:42 nvidia kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Apr 4 11:56:42 nvidia kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Apr 4 11:56:42 nvidia kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_spdif’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1dc82e000 s56192 r8192 d29824 u94208
Apr 4 11:56:42 nvidia kernel: [ 0.000000] pcpu-alloc: s56192 r8192 d29824 u94208 alloc=23*4096
Apr 4 11:56:42 nvidia kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1723176
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_peq’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Kernel command line: root=/dev/mmcblk0p3 earlycon=uart8250,mmio32,0x03110000 console=ttyS0,115200n8 no_console_suspend=1 tegra_keep_boot_clocks cma=268435456 tegraid=18.1.2.0.0 ratchet_status=0x0 uid=1642d98421c00000019fe8080 earlycon=uart8250,mmio32,0x03110000 bl_prof_dataptr=65536@0x25e4b0000
Apr 4 11:56:42 nvidia kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_mbdrc’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Memory: 6556088K/7002112K available (12414K kernel code, 2284K rwdata, 5176K rodata, 4736K init, 829K bss, 183880K reserved, 262144K cma-reserved)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_ope’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Virtual kernel memory layout:
Apr 4 11:56:42 nvidia kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ca0000 ( 12416 KB)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_adsp’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] .rodata : 0xffffff8008ca0000 - 0xffffff80091c0000 ( 5248 KB)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] .init : 0xffffff80091c0000 - 0xffffff8009660000 ( 4736 KB)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra_virt_alt_ivc’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] .data : 0xffffff8009660000 - 0xffffff800989b008 ( 2285 KB)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] .bss : 0xffffff800989b008 - 0xffffff800996a528 ( 830 KB)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_virt_alt_admaif’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra_virt_t210ref_pcm’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf07728000 ( 119 MB actual)
Apr 4 11:56:42 nvidia kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1dca00000 ( 7626 MB)
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra186_alt_arad’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Apr 4 11:56:42 nvidia kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra186_alt_asrc’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
Apr 4 11:56:42 nvidia kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra210_alt_afc’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] **********************************************************
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** **
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** trace_printk() being used. Allocating extra memory. **
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra186_alt_dspk’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** This means that this is a DEBUG kernel and it is **
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra_asoc_machine_alt_t18x’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** unsafe for production use. **
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** If you see this message and you are not debugging **
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Module ‘snd_soc_tegra_alt_t186ref_p2382’ is blacklisted
Apr 4 11:56:42 nvidia kernel: [ 0.000000] ** the kernel, report this immediately to your vendor! **
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Inserted module ‘atmel_mxt_ts’
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Inserted module ‘rndis_host’
Apr 4 11:56:42 nvidia kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Inserted module ‘saf775x_hwdep’
Apr 4 11:56:42 nvidia kernel: [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (virt).
Apr 4 11:56:42 nvidia kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Inserted module ‘eqos_ape’
Apr 4 11:56:42 nvidia kernel: [ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Apr 4 11:56:42 nvidia systemd-modules-load[461]: Inserted module ‘atlantic’
Apr 4 11:56:42 nvidia kernel: [ 0.000224] Console: colour dummy device 80x25
Apr 4 11:56:42 nvidia kernel: [ 0.365552] kmemleak: Kernel memory leak detector disabled
Apr 4 11:56:42 nvidia kernel: [ 0.365561] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
Apr 4 11:56:42 nvidia systemd[1]: Started nv-run-date.service.
Apr 4 11:56:42 nvidia kernel: [ 0.365563] pid_max: default: 32768 minimum: 301
Apr 4 11:56:42 nvidia kernel: [ 0.365617] Security Framework initialized
Apr 4 11:56:42 nvidia kernel: [ 0.365646] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
Apr 4 11:56:42 nvidia systemd[1]: Started Create list of required static device nodes for the current kernel.
Apr 4 11:56:42 nvidia kernel: [ 0.365648] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
Apr 4 11:56:42 nvidia systemd[1]: Started Uncomplicated firewall.
Apr 4 11:56:42 nvidia kernel: [ 0.367436] sched-energy: Sched-energy-costs installed from DT
Apr 4 11:56:42 nvidia kernel: [ 0.410048] ASID allocator initialised with 65536 entries
Apr 4 11:56:42 nvidia kernel: [ 0.462879] tegra-id: chipid=21817.
Apr 4 11:56:42 nvidia kernel: [ 0.463127] tegra-id: opt_subrevision=1.
Apr 4 11:56:42 nvidia systemd[1]: Started Remount Root and Kernel File Systems.
Apr 4 11:56:42 nvidia kernel: [ 0.466930] Tegra Revision: A02p SKU: 144 CPU Process: 0 SoC Process: 0
Apr 4 11:56:42 nvidia kernel: [ 0.473535] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p2379-0000-c01-00-base-a-safety-vm.dts
Apr 4 11:56:42 nvidia kernel: [ 0.492686] DTB Build time: Dec 2 2017 10:53:08
Apr 4 11:56:42 nvidia systemd[1]: Started Load Kernel Modules.
Apr 4 11:56:42 nvidia kernel: [ 0.557070] CPU1: Booted secondary processor [4e0f0030]
Apr 4 11:56:42 nvidia kernel: [ 0.601122] CPU2: Booted secondary processor [4e0f0030]
Apr 4 11:56:42 nvidia systemd[1]: Mounting Configuration File System…
Apr 4 11:56:42 nvidia kernel: [ 0.645033] CPU3: Booted secondary processor [411fd073]
Apr 4 11:56:42 nvidia kernel: [ 0.689117] CPU4: Booted secondary processor [411fd073]
Apr 4 11:56:42 nvidia kernel: [ 0.733204] CPU5: Booted secondary processor [411fd073]
Apr 4 11:56:42 nvidia systemd[1]: Starting Apply Kernel Variables…
Apr 4 11:56:42 nvidia kernel: [ 0.733270] Brought up 6 CPUs
Apr 4 11:56:42 nvidia kernel: [ 0.759066] SMP: Total of 6 processors activated.
Apr 4 11:56:42 nvidia kernel: [ 0.763767] CPU features: detected feature: 32-bit EL0 Support
Apr 4 11:56:42 nvidia systemd-sysctl[466]: Couldn’t write ‘1’ to ‘kernel/yama/ptrace_scope’, ignoring: No such file or directory
Apr 4 11:56:42 nvidia kernel: [ 0.769858] CPU: All CPU(s) started at EL1
Apr 4 11:56:42 nvidia systemd-sysctl[466]: Couldn’t write ‘1’ to ‘net/ipv4/tcp_syncookies’, ignoring: No such file or directory
Apr 4 11:56:42 nvidia kernel: [ 0.774586] devtmpfs: initialized
Apr 4 11:56:42 nvidia kernel: [ 0.787369] Initilizing CustomIPI irq domain
Apr 4 11:56:42 nvidia systemd[1]: Mounting FUSE Control File System…
Apr 4 11:56:42 nvidia kernel: [ 0.788434] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Apr 4 11:56:42 nvidia kernel: [ 0.798030] futex hash table entries: 2048 (order: 6, 262144 bytes)
Apr 4 11:56:42 nvidia systemd[1]: Activating swap /swapfile…
Apr 4 11:56:42 nvidia kernel: [ 0.806485] pinctrl core: initialized pinctrl subsystem
Apr 4 11:56:42 nvidia systemd[1]: Starting Load/Save Random Seed…
Apr 4 11:56:42 nvidia kernel: [ 0.809762] regulator-dummy: no parameters
Apr 4 11:56:42 nvidia kernel: [ 0.813686] Initializing plugin-manager
Apr 4 11:56:42 nvidia kernel: [ 0.817626] Plugin module not found
Apr 4 11:56:42 nvidia systemd[1]: Starting udev Coldplug all Devices…
Apr 4 11:56:42 nvidia kernel: [ 0.821561] Adding domain adsp-pd to PM domain ape-pd
Apr 4 11:56:42 nvidia kernel: [ 0.826635] tegra_hv: adding ivc0: rx_base=ffffff8009a00000 tx_base = ffffff8009a08000 size=8000 irq = 5 (321)
Apr 4 11:56:42 nvidia kernel: [ 0.836063] tegra_hv: added ivc0
Apr 4 11:56:42 nvidia systemd[1]: Starting Create Static Device Nodes in /dev…
Apr 4 11:56:42 nvidia kernel: [ 0.839227] tegra_hv: adding ivc1: rx_base=ffffff8009a10000 tx_base = ffffff8009a18000 size=8000 irq = 6 (322)
Apr 4 11:56:42 nvidia kernel: [ 0.849292] tegra_hv: added ivc1
Apr 4 11:56:42 nvidia kernel: [ 0.852457] tegra_hv: adding ivc2: rx_base=ffffff8009a20000 tx_base = ffffff8009a28000 size=8000 irq = 7 (323)
Apr 4 11:56:42 nvidia kernel: [ 0.862526] tegra_hv: added ivc2
Apr 4 11:56:42 nvidia systemd[1]: Starting LSB: controls configuration of serial ports…
Apr 4 11:56:42 nvidia kernel: [ 0.865687] tegra_hv: adding ivc3: rx_base=ffffff8009a30000 tx_base = ffffff8009a38000 size=8000 irq = 8 (324)
Apr 4 11:56:42 nvidia systemd[1]: Starting Flush Journal to Persistent Storage…
Apr 4 11:56:42 nvidia kernel: [ 0.875760] tegra_hv: added ivc3
Apr 4 11:56:42 nvidia systemd[1]: Mounted FUSE Control File System.
Apr 4 11:56:42 nvidia systemd[1]: Mounted Configuration File System.
Apr 4 11:56:42 nvidia systemd[1]: Started Apply Kernel Variables.
Apr 4 11:56:42 nvidia systemd[1]: Started Load/Save Random Seed.
Apr 4 11:56:42 nvidia systemd[1]: Started Create Static Device Nodes in /dev.
Apr 4 11:56:42 nvidia systemd[1]: Started Flush Journal to Persistent Storage.
Apr 4 11:56:42 nvidia systemd[1]: Starting udev Kernel Device Manager…
Apr 4 11:56:42 nvidia systemd[1]: Reached target Local File Systems (Pre).
Apr 4 11:56:42 nvidia kernel: [ 0.878923] tegra_hv: adding ivc4: rx_base=ffffff8009a40000 tx_base = ffffff8009a48000 size=8000 irq = 9 (325)
Apr 4 11:56:42 nvidia systemd[1]: Started LSB: controls configuration of serial ports.
Apr 4 11:56:42 nvidia kernel: [ 0.888993] tegra_hv: added ivc4
Apr 4 11:56:42 nvidia kernel: [ 0.892154] tegra_hv: adding ivc5: rx_base=ffffff8009a50000 tx_base = ffffff8009a58000 size=8000 irq = 10 (326)
Apr 4 11:56:42 nvidia kernel: [ 0.902231] tegra_hv: added ivc5
Apr 4 11:56:42 nvidia systemd[1]: Started udev Kernel Device Manager.
Apr 4 11:56:42 nvidia kernel: [ 0.905554] tegra_hv: adding ivc6: rx_base=ffffff8009a60000 tx_base = ffffff8009a68000 size=8000 irq = 11 (327)
Apr 4 11:56:42 nvidia kernel: [ 0.915632] tegra_hv: added ivc6
Apr 4 11:56:42 nvidia kernel: [ 0.918794] tegra_hv: adding ivc7: rx_base=ffffff8009a70000 tx_base = ffffff8009a78000 size=8000 irq = 12 (328)
Apr 4 11:56:42 nvidia systemd[1]: Starting lvm2.service…
Apr 4 11:56:42 nvidia kernel: [ 0.928872] tegra_hv: added ivc7
Apr 4 11:56:42 nvidia systemd[1]: Activated swap /swapfile.
Apr 4 11:56:42 nvidia kernel: [ 0.932193] tegra_hv: adding ivc8: rx_base=ffffff8009a80000 tx_base = ffffff8009a88000 size=8000 irq = 13 (329)
Apr 4 11:56:42 nvidia systemd[1]: Reached target Swap.
Apr 4 11:56:42 nvidia kernel: [ 0.942272] tegra_hv: added ivc8
Apr 4 11:56:42 nvidia kernel: [ 0.945432] tegra_hv: adding ivc9: rx_base=ffffff8009a90000 tx_base = ffffff8009a98000 size=8000 irq = 14 (330)
Apr 4 11:56:42 nvidia kernel: [ 0.955512] tegra_hv: added ivc9
Apr 4 11:56:42 nvidia systemd[1]: Started lvm2.service.
Apr 4 11:56:42 nvidia kernel: [ 0.958833] tegra_hv: adding ivc10: rx_base=ffffff8009aa0000 tx_base = ffffff8009aa8000 size=8000 irq = 15 (331)
Apr 4 11:56:42 nvidia kernel: [ 0.968919] tegra_hv: added ivc10
Apr 4 11:56:42 nvidia kernel: [ 0.972251] tegra_hv: adding ivc11: rx_base=ffffff8009ab0000 tx_base = ffffff8009ab8000 size=8000 irq = 16 (332)
Apr 4 11:56:42 nvidia systemd[1]: Found device /dev/ttyS0.
Apr 4 11:56:42 nvidia kernel: [ 0.982493] tegra_hv: added ivc11
Apr 4 11:56:42 nvidia kernel: [ 0.985822] tegra_hv: adding ivc12: rx_base=ffffff8009ac0000 tx_base = ffffff8009ac8000 size=8000 irq = 17 (333)
Apr 4 11:56:42 nvidia kernel: [ 0.995907] tegra_hv: added ivc12
Apr 4 11:56:42 nvidia systemd[1]: Found device /dev/disk/by-partlabel/devota-fs.
Apr 4 11:56:42 nvidia kernel: [ 0.999236] tegra_hv: adding ivc13: rx_base=ffffff8009ad0000 tx_base = ffffff8009ad8000 size=8000 irq = 18 (334)
Apr 4 11:56:42 nvidia kernel: [ 1.009481] tegra_hv: added ivc13
Apr 4 11:56:42 nvidia systemd[1]: Starting File System Check on /dev/disk/by-partlabel/devota-fs…
Apr 4 11:56:42 nvidia kernel: [ 1.012810] tegra_hv: adding ivc28: rx_base=ffffff8009980000 tx_base = ffffff8009988000 size=8000 irq = 19 (335)
Apr 4 11:56:42 nvidia systemd[1]: Started File System Check Daemon to report status.
Apr 4 11:56:42 nvidia kernel: [ 1.022894] tegra_hv: added ivc28
Apr 4 11:56:42 nvidia kernel: [ 1.026224] tegra_hv: adding ivc29: rx_base=ffffff8009990000 tx_base = ffffff8009998000 size=8000 irq = 20 (336)
Apr 4 11:56:42 nvidia kernel: [ 1.036471] tegra_hv: added ivc29
Apr 4 11:56:42 nvidia systemd-fsck[553]: /dev/mmcblk0p2: recovering journal
Apr 4 11:56:42 nvidia kernel: [ 1.039798] tegra_hv: adding ivc30: rx_base=ffffff80099a0000 tx_base = ffffff80099a8000 size=8000 irq = 21 (337)
Apr 4 11:56:42 nvidia kernel: [ 1.049884] tegra_hv: added ivc30
Apr 4 11:56:42 nvidia systemd-fsck[553]: /dev/mmcblk0p2: clean, 14/960512 files, 64975/4194304 blocks
Apr 4 11:56:42 nvidia kernel: [ 1.053211] tegra_hv: adding ivc31: rx_base=ffffff80099b0000 tx_base = ffffff80099b8000 size=8000 irq = 22 (338)
Apr 4 11:56:42 nvidia systemd[1]: Started File System Check on /dev/disk/by-partlabel/devota-fs.
Apr 4 11:56:42 nvidia kernel: [ 1.063458] tegra_hv: added ivc31
Apr 4 11:56:42 nvidia kernel: [ 1.066786] tegra_hv: adding ivc32: rx_base=ffffff8008040000 tx_base = ffffff8008048000 size=8000 irq = 23 (339)
Apr 4 11:56:42 nvidia systemd[1]: Mounting /driveota…
Apr 4 11:56:42 nvidia kernel: [ 1.076872] tegra_hv: added ivc32
Apr 4 11:56:42 nvidia systemd[1]: Started udev Coldplug all Devices.
Apr 4 11:56:42 nvidia kernel: [ 1.080200] tegra_hv: adding ivc33: rx_base=ffffff8009b00000 tx_base = ffffff8009b18000 size=18000 irq = 24 (340)
Apr 4 11:56:42 nvidia kernel: [ 1.090452] tegra_hv: added ivc33
Apr 4 11:56:42 nvidia kernel: [ 1.093781] tegra_hv: adding ivc56: rx_base=ffffff80099c0000 tx_base = ffffff80099c8000 size=8000 irq = 25 (341)
Apr 4 11:56:42 nvidia systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Apr 4 11:56:42 nvidia kernel: [ 1.104026] tegra_hv: added ivc56
Apr 4 11:56:42 nvidia systemd[1]: Mounted /driveota.
Apr 4 11:56:42 nvidia kernel: [ 1.107356] tegra_hv: adding ivc76: rx_base=ffffff8009b40000 tx_base = ffffff8009b50000 size=10000 irq = 26 (342)
Apr 4 11:56:42 nvidia systemd-udevd[521]: Could not generate persistent MAC address for ip6tnl0: No such file or directory
Apr 4 11:56:42 nvidia kernel: [ 1.117609] tegra_hv: added ivc76
Apr 4 11:56:42 nvidia kernel: [ 1.120937] tegra_hv: adding ivc99: rx_base=ffffff8009ae0000 tx_base = ffffff8009ae8000 size=8000 irq = 27 (343)
Apr 4 11:56:42 nvidia systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Apr 4 11:56:42 nvidia kernel: [ 1.131023] tegra_hv: added ivc99
Apr 4 11:56:42 nvidia kernel: [ 1.134350] tegra_hv: adding ivc101: rx_base=ffffff80099d0000 tx_base = ffffff80099d8000 size=8000 irq = 28 (344)
Apr 4 11:56:42 nvidia systemd[1]: Reached target Local File Systems.
Apr 4 11:56:42 nvidia kernel: [ 1.144604] tegra_hv: added ivc101
Apr 4 11:56:42 nvidia systemd[1]: Starting Set console keymap…
Apr 4 11:56:42 nvidia kernel: [ 1.148099] tegra_hv: adding ivc102: rx_base=ffffff8008060000 tx_base = ffffff8008068000 size=8000 irq = 29 (345)
Apr 4 11:56:42 nvidia kernel: [ 1.158353] tegra_hv: added ivc102
Apr 4 11:56:42 nvidia kernel: [ 1.161668] tegra_hv: added mempool 0: ipa=25cd80000 size=400000 peer=2
Apr 4 11:56:42 nvidia systemd[1]: Starting Create Volatile Files and Directories…
Apr 4 11:56:42 nvidia kernel: [ 1.168284] tegra_hv: added mempool 1: ipa=25d180000 size=800000 peer=2
Apr 4 11:56:42 nvidia kernel: [ 1.174901] tegra_hv: added mempool 2: ipa=25d980000 size=10000 peer=2
Apr 4 11:56:42 nvidia kernel: [ 1.181511] tegra_hv: added mempool 3: ipa=25da00000 size=400000 peer=1
Apr 4 11:56:42 nvidia systemd-tmpfiles[642]: [/usr/lib/tmpfiles.d/var.conf:14] Duplicate line for path “/var/log”, ignoring.
Apr 4 11:56:42 nvidia kernel: [ 1.188126] tegra_hv: added mempool 5: ipa=25de00000 size=40000 peer=5
Apr 4 11:56:42 nvidia kernel: [ 1.194575] tegra_hv: added mempool 6: ipa=25de40000 size=10000 peer=3
Apr 4 11:56:42 nvidia kernel: [ 1.201185] tegra_hv: added mempool 7: ipa=25de50000 size=40000 peer=6
Apr 4 11:56:42 nvidia systemd[1]: Starting Tell Plymouth To Write Out Runtime Data…
Apr 4 11:56:42 nvidia kernel: [ 1.207634] tegra_hv: initialized
Apr 4 11:56:42 nvidia kernel: [ 1.211132] NET: Registered protocol family 16
Apr 4 11:56:42 nvidia kernel: [ 1.217314] pstore: using zlib compression
Apr 4 11:56:42 nvidia loadkeys[619]: Loading /etc/console-setup/cached.kmap.gz
Apr 4 11:56:42 nvidia kernel: [ 1.220189] console [pstore-1] enabled
Apr 4 11:56:42 nvidia systemd[1]: Starting LSB: AppArmor initialization…
Apr 4 11:56:42 nvidia kernel: [ 1.223308] pstore: Registered ramoops as persistent store backend
Apr 4 11:56:42 nvidia kernel: [ 1.229415] ramoops: attached 0x200000@0xffc00000, ecc: 0/0
Apr 4 11:56:42 nvidia systemd[1]: Starting Clean up any mess left by 0dns-up…
Apr 4 11:56:42 nvidia kernel: [ 1.241015] bpmp: mail init ok
Apr 4 11:56:42 nvidia kernel: [ 1.242994] arm-smmu 12000000.iommu: probing hardware configuration…
Apr 4 11:56:42 nvidia systemd[1]: Started Set console keymap.
Apr 4 11:56:42 nvidia kernel: [ 1.247281] arm-smmu 12000000.iommu: SMMUv2 with:
Apr 4 11:56:42 nvidia kernel: [ 1.251976] arm-smmu 12000000.iommu: stage 1 translation
Apr 4 11:56:42 nvidia systemd[1]: Started Create Volatile Files and Directories.
Apr 4 11:56:42 nvidia kernel: [ 1.257374] arm-smmu 12000000.iommu: stream indexing with 128 indices
Apr 4 11:56:42 nvidia kernel: [ 1.263982] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
Apr 4 11:56:42 nvidia kernel: [ 1.274434] arm-smmu 12000000.iommu: 32 context banks (0 stage-2 only)
Apr 4 11:56:42 nvidia systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Apr 4 11:56:42 nvidia kernel: [ 1.281064] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
Apr 4 11:56:42 nvidia kernel: [ 1.292084] vdso: 2 pages (1 code @ ffffff8008ca7000, 1 data @ ffffff8009664000)
Apr 4 11:56:42 nvidia kernel: [ 1.296189] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Apr 4 11:56:42 nvidia systemd[1]: Started Clean up any mess left by 0dns-up.
Apr 4 11:56:42 nvidia kernel: [ 1.306626] atomic_pool_init():529: DMA: preallocated 2048 KiB pool for atomic allocations
Apr 4 11:56:42 nvidia kernel: [ 1.312836] Registering BPMP clocks…
Apr 4 11:56:42 nvidia systemd[1]: Started LSB: AppArmor initialization.
Apr 4 11:56:42 nvidia kernel: [ 1.315594] clock init ok
Apr 4 11:56:42 nvidia kernel: [ 1.318257] tegra_bpmp_of_clk_init: EMC proxy not found.
Apr 4 11:56:42 nvidia systemd[1]: Starting Raise network interfaces…
Apr 4 11:56:42 nvidia kernel: [ 1.327199] tegra_powergate_init: DONE
Apr 4 11:56:42 nvidia kernel: [ 1.327791] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p2379-0000-c01-00-base-a-safety-vm.dts
Apr 4 11:56:42 nvidia kernel: [ 1.346778] DTB Build time: Dec 2 2017 10:53:08
Apr 4 11:56:42 nvidia systemd[1]: Starting Update UTMP about System Boot/Shutdown…
Apr 4 11:56:42 nvidia kernel: [ 1.351455] Tegra reboot handler registered.
Apr 4 11:56:42 nvidia kernel: [ 1.356493] tegra-pmc c360000.pmc: create /sys/kernel/debug/PMC/boot-chain-type
Apr 4 11:56:42 nvidia kernel: [ 1.363058] tegra-pmc: ### PMC reset source: Power on reset
Apr 4 11:56:42 nvidia systemd[1]: Starting Network Time Synchronization…
Apr 4 11:56:42 nvidia kernel: [ 1.368605] tegra-pmc: ### PMC reset level: L0
Apr 4 11:56:42 nvidia kernel: [ 1.372973] tegra-pmc: ### PMC reset status reg: 0x0
Apr 4 11:56:42 nvidia mtp-probe: checking bus 1, device 3: “/sys/devices/3530000.xhci/usb1/1-3/1-3.4”
Apr 4 11:56:42 nvidia kernel: [ 1.378167] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Apr 4 11:56:42 nvidia kernel: [ 1.385165] tegra-pmc c360000.pmc: IO padctrl driver initialized
Apr 4 11:56:42 nvidia mtp-probe: checking bus 1, device 4: “/sys/devices/3530000.xhci/usb1/1-3/1-3.3”
Apr 4 11:56:42 nvidia kernel: [ 1.391509] iommu: Adding device 3460000.sdhci to group 0
Apr 4 11:56:42 nvidia kernel: [ 1.398220] iommu: Adding device 3160000.i2c to group 1
Apr 4 11:56:42 nvidia systemd-timesyncd[707]: System clock time unset or jumped backwards, restoring from recorded timestamp: Thu 2019-04-04 11:56:41 KST
Apr 4 11:56:42 nvidia kernel: [ 1.402127] iommu: Adding device c240000.i2c to group 2
Apr 4 11:56:42 nvidia kernel: [ 1.407352] iommu: Adding device 3180000.i2c to group 3
Apr 4 11:56:42 nvidia systemd[1]: Started Network Time Synchronization.
Apr 4 11:56:42 nvidia kernel: [ 1.412557] iommu: Adding device 3190000.i2c to group 4
Apr 4 11:56:42 nvidia kernel: [ 1.417768] iommu: Adding device 31b0000.i2c to group 5
Apr 4 11:56:42 nvidia systemd[1]: Time has been changed
Apr 4 11:56:42 nvidia kernel: [ 1.422960] iommu: Adding device 31c0000.i2c to group 6
Apr 4 11:56:42 nvidia kernel: [ 1.428150] iommu: Adding device c250000.i2c to group 7
Apr 4 11:56:42 nvidia systemd[1]: Started Update UTMP about System Boot/Shutdown.
Apr 4 11:56:42 nvidia kernel: [ 1.433473] iommu: Adding device 31e0000.i2c to group 8
Apr 4 11:56:42 nvidia kernel: [ 1.439697] iommu: Adding device 3210000.spi to group 9
Apr 4 11:56:42 nvidia mtp-probe: bus: 1, device: 4 was not an MTP device
Apr 4 11:56:42 nvidia kernel: [ 1.443820] iommu: Adding device 3230000.spi to group 10
Apr 4 11:56:42 nvidia kernel: [ 1.449124] iommu: Adding device 3270000.spi to group 11
Apr 4 11:56:42 nvidia mtp-probe: bus: 1, device: 3 was not an MTP device
Apr 4 11:56:42 nvidia kernel: [ 1.454591] iommu: Adding device 3110000.serial to group 12
Apr 4 11:56:42 nvidia kernel: [ 1.460689] iommu: Adding device 2490000.ether_qos to group 13
Apr 4 11:56:42 nvidia systemd[1]: Reached target System Initialization.
Apr 4 11:56:42 nvidia kernel: [ 1.466207] iommu: Adding device b040000.sce to group 14
Apr 4 11:56:42 nvidia kernel: [ 1.471736] iommu: Adding device smmu_test to group 15
Apr 4 11:56:42 nvidia systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Apr 4 11:56:42 nvidia kernel: [ 1.476465] mc: mapped MMIO address: 0xffffff8009f80000 → 0x2c10000
Apr 4 11:56:42 nvidia systemd[1]: Listening on D-Bus System Message Bus Socket.
Apr 4 11:56:42 nvidia kernel: [ 1.482499] mc: mapped MMIO address: 0xffffff8009fa0000 → 0x2c20000
Apr 4 11:56:42 nvidia kernel: [ 1.488772] mc: mapped MMIO address: 0xffffff8009fc0000 → 0x2c30000
Apr 4 11:56:42 nvidia kernel: [ 1.495198] mc: mapped MMIO address: 0xffffff8009fe0000 → 0x2c40000
Apr 4 11:56:42 nvidia kernel: [ 1.501479] mc: mapped MMIO address: 0xffffff800b210000 → 0x2c50000
Apr 4 11:56:42 nvidia kernel: [ 1.508193] mc-err: mcerr ops are set to t18x
Apr 4 11:56:42 nvidia kernel: [ 1.513100] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
Apr 4 11:56:42 nvidia kernel: [ 1.519044] iommu: Adding device 3530000.xhci to group 16
Apr 4 11:56:42 nvidia kernel: [ 1.524095] iommu: Adding device 3550000.xudc to group 17
Apr 4 11:56:42 nvidia kernel: [ 1.530061] iommu: Adding device 13e10000.host1x to group 18
Apr 4 11:56:42 nvidia kernel: [ 1.535021] iommu: Adding device 13e10000.host1x:ctx0 to group 19
Apr 4 11:56:42 nvidia kernel: [ 1.541050] iommu: Adding device 13e10000.host1x:ctx1 to group 20
Apr 4 11:56:42 nvidia kernel: [ 1.547238] iommu: Adding device 13e10000.host1x:ctx2 to group 21
Apr 4 11:56:42 nvidia kernel: [ 1.553343] iommu: Adding device 13e10000.host1x:ctx3 to group 22
Apr 4 11:56:42 nvidia kernel: [ 1.559352] iommu: Adding device 13e10000.host1x:ctx4 to group 23
Apr 4 11:56:42 nvidia systemd[1]: Started CUPS Scheduler.
Apr 4 11:56:42 nvidia systemd[1]: Reached target Paths.
Apr 4 11:56:42 nvidia systemd[1]: Listening on RPCbind Server Activation Socket.
Apr 4 11:56:42 nvidia systemd[1]: Listening on CUPS Scheduler.
Apr 4 11:56:42 nvidia systemd[1]: Started Daily Cleanup of Temporary Directories.
Apr 4 11:56:42 nvidia systemd[1]: Reached target Timers.
Apr 4 11:56:42 nvidia systemd[1]: Listening on GPS (Global Positioning System) Daemon Sockets.
Apr 4 11:56:42 nvidia systemd[1]: Starting Socket activation for snappy daemon.
Apr 4 11:56:42 nvidia systemd[1]: Reached target System Time Synchronized.
Apr 4 11:56:42 nvidia systemd[1]: Listening on Socket activation for snappy daemon.
Apr 4 11:56:42 nvidia systemd[1]: Reached target Sockets.
Apr 4 11:56:42 nvidia systemd[1]: Reached target Basic System.
Apr 4 11:56:42 nvidia kernel: [ 1.565516] iommu: Adding device 13e10000.host1x:ctx5 to group 24
Apr 4 11:56:42 nvidia kernel: [ 1.571533] iommu: Adding device 13e10000.host1x:ctx6 to group 25
Apr 4 11:56:42 nvidia kernel: [ 1.577709] iommu: Adding device 13e10000.host1x:ctx7 to group 26
Apr 4 11:56:42 nvidia systemd[1]: Started mnand refresh daemon service.
Apr 4 11:56:42 nvidia kernel: [ 1.583885] iommu: Adding device 150c0000.nvcsi to group 27
Apr 4 11:56:42 nvidia kernel: [ 1.591098] tegra-reset 5000000.clock: registered 193 resets.
Apr 4 11:56:42 nvidia kernel: [ 1.595412] iommu: Adding device d000000.bpmp to group 28
Apr 4 11:56:42 nvidia systemd[1]: Starting Accounts Service…
Apr 4 11:56:42 nvidia kernel: [ 1.600420] bpmp d000000.bpmp: Found mempool with id 3
Apr 4 11:56:42 nvidia kernel: [ 1.605343] bpmp d000000.bpmp: ivm 0x000000025da00000
Apr 4 11:56:42 nvidia kernel: [ 1.610665] bpmp: ping status is 0
Apr 4 11:56:42 nvidia systemd[1]: Started Hypervisor initiated Shutdown Service.
Apr 4 11:56:42 nvidia kernel: [ 1.613944] bpmp d000000.bpmp: firmware tag is 7a20186dd4ae720b05ab8a27657a7223
Apr 4 11:56:42 nvidia kernel: [ 1.624452] bpmp d000000.bpmp: probe ok
Apr 4 11:56:42 nvidia kernel: [ 1.626815] iommu: Adding device 2600000.dma to group 29
Apr 4 11:56:42 nvidia systemd[1]: Starting Avahi mDNS/DNS-SD Stack…
Apr 4 11:56:42 nvidia kernel: [ 1.632324] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
Apr 4 11:56:42 nvidia kernel: [ 1.645892] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
Apr 4 11:56:42 nvidia avahi-daemon[785]: Found user ‘avahi’ (UID 110) and group ‘avahi’ (GID 117).
Apr 4 11:56:42 nvidia kernel: [ 1.654144] iommu: Adding device 10003000.pcie-controller to group 30
Apr 4 11:56:42 nvidia kernel: [ 1.659197] iommu: Adding device c1a0000.aon to group 31
Apr 4 11:56:42 nvidia kernel: [ 1.663810] sys-3v3: 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 1.666500] sys-5v0: 5000 mV
Apr 4 11:56:42 nvidia kernel: [ 1.671786] iommu: Adding device 13e20000.host1xb to group 32
Apr 4 11:56:42 nvidia avahi-daemon[785]: Successfully dropped root privileges.
Apr 4 11:56:42 nvidia kernel: [ 1.675286] iommu: Adding device 15600000.isp to group 33
Apr 4 11:56:42 nvidia kernel: [ 1.680582] iommu: Adding device 15340000.vic to group 34
Apr 4 11:56:42 nvidia kernel: [ 1.685879] iommu: Adding device 154c0000.nvenc to group 35
Apr 4 11:56:42 nvidia kernel: [ 1.691556] iommu: Adding device 15480000.nvdec to group 36
Apr 4 11:56:42 nvidia avahi-daemon[785]: avahi-daemon 0.6.32-rc starting up.
Apr 4 11:56:42 nvidia kernel: [ 1.697125] iommu: Adding device 15380000.nvjpg to group 37
Apr 4 11:56:42 nvidia kernel: [ 1.702576] iommu: Adding device 15500000.tsec to group 38
Apr 4 11:56:42 nvidia systemd[1]: Started Regular background program processing daemon.
Apr 4 11:56:42 nvidia kernel: [ 1.708153] iommu: Adding device 15100000.tsecb to group 39
Apr 4 11:56:42 nvidia kernel: [ 1.714628] iommu: Adding device vse@15810000 to group 40
Apr 4 11:56:42 nvidia cron[787]: (CRON) INFO (pidfile fd = 3)
Apr 4 11:56:42 nvidia kernel: [ 1.719258] iommu: Adding device vse@15820000 to group 41
Apr 4 11:56:42 nvidia kernel: [ 1.724554] iommu: Adding device vse@15830000 to group 42
Apr 4 11:56:42 nvidia cron[787]: (CRON) INFO (Running @reboot jobs)
Apr 4 11:56:42 nvidia kernel: [ 1.729885] iommu: Adding device vse@15840000 to group 43
Apr 4 11:56:42 nvidia kernel: [ 1.735840] irq: type mismatch, failed to map hwirq-328 for /interrupt-controller@3881000!
Apr 4 11:56:42 nvidia systemd[1]: Started GPS (Global Positioning System) Daemon.
Apr 4 11:56:42 nvidia kernel: [ 1.743431] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
Apr 4 11:56:42 nvidia kernel: [ 1.761191] SCSI subsystem initialized
Apr 4 11:56:42 nvidia systemd[1]: Starting System Logging Service…
Apr 4 11:56:42 nvidia kernel: [ 1.762038] libata version 3.00 loaded.
Apr 4 11:56:42 nvidia kernel: [ 1.762162] usbcore: registered new interface driver usbfs
Apr 4 11:56:42 nvidia kernel: [ 1.767115] usbcore: registered new interface driver hub
Apr 4 11:56:42 nvidia kernel: [ 1.772689] usbcore: registered new device driver usb
Apr 4 11:56:42 nvidia kernel: [ 1.792363] media: Linux media interface: v0.10
Apr 4 11:56:42 nvidia kernel: [ 1.793588] Linux video capture interface: v2.00
Apr 4 11:56:42 nvidia kernel: [ 1.798270] pps_core: LinuxPPS API ver. 1 registered
Apr 4 11:56:42 nvidia kernel: [ 1.803130] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Apr 4 11:56:42 nvidia kernel: [ 1.812361] PTP clock support registered
Apr 4 11:56:42 nvidia kernel: [ 1.816759] trusty trusty: trusty version: Built: 21:28:29 Nov 29 2017
Apr 4 11:56:42 nvidia kernel: [ 1.822924] trusty trusty: selected api version: 3 (requested 3)
Apr 4 11:56:42 nvidia kernel: [ 1.831373] max77620 4-003c: PMIC Version OTP:0x4A and ES:0x1
Apr 4 11:56:42 nvidia kernel: [ 1.836170] max77620-sd0: at 1125 mV
Apr 4 11:56:42 nvidia kernel: [ 1.839030] max77620-sd1: at 1200 mV
Apr 4 11:56:42 nvidia kernel: [ 1.842594] max77620-sd2: at 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 1.846405] max77620-sd3: at 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 1.850062] max77620-sd4: at 600 mV
Apr 4 11:56:42 nvidia kernel: [ 1.853564] max77620-ldo0: at 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 1.857104] max77620-ldo1: at 800 mV
Apr 4 11:56:42 nvidia kernel: [ 1.860672] max77620-ldo2: at 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 1.864741] i2c i2c-4: deserialize_i2c ret -22
Apr 4 11:56:42 nvidia kernel: [ 1.868337] i2c i2c-4: — message dump for debugging —
Apr 4 11:56:42 nvidia kernel: [ 1.873738] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
Apr 4 11:56:42 nvidia kernel: [ 1.878945] i2c i2c-4: 29
Apr 4 11:56:42 nvidia kernel: [ 1.881572] i2c i2c-4: f2
Apr 4 11:56:42 nvidia kernel: [ 1.884344] i2c i2c-4:
Apr 4 11:56:42 nvidia kernel: [ 1.886786] max77620-pmic max20024-pmic: Regulator 8 mode set failed: -22
Apr 4 11:56:42 nvidia kernel: [ 1.893572] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo3
Apr 4 11:56:42 nvidia kernel: [ 1.902388] max77620-ldo3: at 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 1.906528] max77620-ldo4: at 800 mV
Apr 4 11:56:42 nvidia kernel: [ 1.910133] random: fast init done
Apr 4 11:56:42 nvidia kernel: [ 1.913129] i2c i2c-4: deserialize_i2c ret -22
Apr 4 11:56:42 nvidia kernel: [ 1.917350] i2c i2c-4: — message dump for debugging —
Apr 4 11:56:42 nvidia kernel: [ 1.922749] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
Apr 4 11:56:42 nvidia kernel: [ 1.927959] i2c i2c-4: 2d
Apr 4 11:56:42 nvidia kernel: [ 1.930581] i2c i2c-4: f2
Apr 4 11:56:42 nvidia kernel: [ 1.933357] i2c i2c-4:
Apr 4 11:56:42 nvidia kernel: [ 1.935799] max77620-pmic max20024-pmic: Regulator 10 mode set failed: -22
Apr 4 11:56:42 nvidia kernel: [ 1.942612] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo5
Apr 4 11:56:42 nvidia kernel: [ 1.951554] max77620-ldo5: at 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 1.955615] max77620-ldo6: at 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 1.959360] max77620-ldo7: at 1000 mV
Apr 4 11:56:42 nvidia kernel: [ 1.963196] max77620-ldo8: at 800 mV
Apr 4 11:56:42 nvidia kernel: [ 1.966740] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
Apr 4 11:56:42 nvidia kernel: [ 1.977158] i2c i2c-4: deserialize_i2c ret -22
Apr 4 11:56:42 nvidia kernel: [ 1.979410] i2c i2c-4: — message dump for debugging —
Apr 4 11:56:42 nvidia kernel: [ 1.984811] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
Apr 4 11:56:42 nvidia kernel: [ 1.989868] i2c i2c-4: 0d
Apr 4 11:56:42 nvidia kernel: [ 1.992644] i2c i2c-4: ef
Apr 4 11:56:42 nvidia kernel: [ 1.995267] i2c i2c-4:
Apr 4 11:56:42 nvidia kernel: [ 1.997702] max77620 4-003c: Failed to sync masks in d
Apr 4 11:56:42 nvidia kernel: [ 2.003333] max77620 4-003c: max77620 probe successful
Apr 4 11:56:42 nvidia kernel: [ 2.009371] sn65dsi85_dsi2lvds_panel_create_debugfs: dsi2lvds->debugdir = ffffffc1d28f0c30
Apr 4 11:56:42 nvidia kernel: [ 2.016252] sn65dsi85_dsi2lvds_panel_create_debugfs: debugfs_create_file returned ffffffc1d28f0d20
Apr 4 11:56:42 nvidia kernel: [ 2.025292] sn65dsi85_i2c_probe: returning with err=0
Apr 4 11:56:42 nvidia kernel: [ 2.030373] max929x_i2c_client_init: called
Apr 4 11:56:42 nvidia kernel: [ 2.034608] max929x_i2c_probe: returning 0
Apr 4 11:56:42 nvidia kernel: [ 2.039313] tegra_hv_wdt tegra_hv_wdt: id=32 irq=23 peer=3 num=1 size=128
Apr 4 11:56:42 nvidia kernel: [ 2.039388] tegra_hv_wdt tegra_hv_wdt: ivc channel ready
Apr 4 11:56:42 nvidia kernel: [ 2.050762] vdd-1v1: Bringing 0uV into 1100000-1100000uV
Apr 4 11:56:42 nvidia kernel: [ 2.055953] vdd-1v1: 1100 mV
Apr 4 11:56:42 nvidia kernel: [ 2.059166] vdd-1v2: Bringing 0uV into 1200000-1200000uV
Apr 4 11:56:42 nvidia kernel: [ 2.064234] vdd-1v2: 1200 mV
Apr 4 11:56:42 nvidia kernel: [ 2.067369] vdd-1v8-ddr: Bringing 0uV into 1800000-1800000uV
Apr 4 11:56:42 nvidia kernel: [ 2.072918] vdd-1v8-ddr: 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.076446] vdd-3v3: Bringing 0uV into 3300000-3300000uV
Apr 4 11:56:42 nvidia kernel: [ 2.081537] vdd-3v3: 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 2.084701] spmic-sd4: Bringing 0uV into 1100000-1100000uV
Apr 4 11:56:42 nvidia kernel: [ 2.089900] spmic-sd4: 1100 mV
Apr 4 11:56:42 nvidia kernel: [ 2.093255] vdd-1v8-pll: Bringing 0uV into 1800000-1800000uV
Apr 4 11:56:42 nvidia kernel: [ 2.098707] vdd-1v8-pll: 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.102190] spmic-ldo1: Bringing 0uV into 800000-800000uV
Apr 4 11:56:42 nvidia kernel: [ 2.107401] spmic-ldo1: 800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.110715] vdd-v3v-ao: Bringing 0uV into 3300000-3300000uV
Apr 4 11:56:42 nvidia kernel: [ 2.116110] vdd-v3v-ao: 3300 mV
Apr 4 11:56:42 nvidia kernel: [ 2.119568] en-vdd-rtc: Bringing 0uV into 800000-800000uV
Apr 4 11:56:42 nvidia kernel: [ 2.124802] en-vdd-rtc: 800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.128111] vdd-1v8-ao: Bringing 0uV into 1800000-1800000uV
Apr 4 11:56:42 nvidia kernel: [ 2.133523] vdd-1v8-ao: 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.136847] vdd-1v05: Bringing 0uV into 1050000-1050000uV
Apr 4 11:56:42 nvidia kernel: [ 2.142062] vdd-1v05: 1050 mV
Apr 4 11:56:42 nvidia kernel: [ 2.145352] spmic-ldo8: Bringing 0uV into 800000-800000uV
Apr 4 11:56:42 nvidia kernel: [ 2.150571] spmic-ldo8: 800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.155041] vdd-1v8: supplied by vdd-1v8-ddr
Apr 4 11:56:42 nvidia kernel: [ 2.158004] vdd-1v8: 1800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.161160] vdd-rtc: supplied by en-vdd-rtc
Apr 4 11:56:42 nvidia kernel: [ 2.165070] vdd-rtc: at 800 mV
Apr 4 11:56:42 nvidia kernel: [ 2.168542] vdd-usb2-5v: supplied by vdd-1v8
Apr 4 11:56:42 nvidia kernel: [ 2.172455] vdd-usb2-5v: 5000 mV
Apr 4 11:56:42 nvidia kernel: [ 2.287522] mxm-pwr-gpio-1: 5000 mV
Apr 4 11:56:42 nvidia kernel: [ 2.288245] mxm-pwr_en: supplied by mxm-pwr-gpio-1
Apr 4 11:56:42 nvidia kernel: [ 2.400111] mxm-pwr_en: 5000 mV
Apr 4 11:56:42 nvidia kernel: [ 2.402523] camchar: rtcpu character device driver loaded
Apr 4 11:56:42 nvidia kernel: [ 2.405640] clocksource: Switched to clocksource arch_sys_counter
Apr 4 11:56:42 nvidia kernel: [ 2.442403] VFS: Disk quotas dquot_6.6.0
Apr 4 11:56:42 nvidia kernel: [ 2.443128] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Apr 4 11:56:42 nvidia kernel: [ 2.458525] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
Apr 4 11:56:42 nvidia kernel: [ 2.463830] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
Apr 4 11:56:42 nvidia kernel: [ 2.472370] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Apr 4 11:56:42 nvidia kernel: [ 2.480732] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Apr 4 11:56:42 nvidia kernel: [ 2.489410] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
Apr 4 11:56:42 nvidia kernel: [ 2.497688] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tj-therm
Apr 4 11:56:42 nvidia kernel: [ 2.505933] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
Apr 4 11:56:42 nvidia kernel: [ 2.514737] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type Tegra_tx
Apr 4 11:56:42 nvidia kernel: [ 2.523021] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type Tegra_rx
Apr 4 11:56:42 nvidia kernel: [ 2.532854] isomgr_init(): iso emc max clk=1600000KHz
Apr 4 11:56:42 nvidia kernel: [ 2.536316] isomgr_init(): max_iso_bw=23040000KB
Apr 4 11:56:42 nvidia kernel: [ 2.541144] nvmap_heap_init: nvmap_heap_init: created heap block cache
Apr 4 11:56:42 nvidia kernel: [ 2.548047] tegra-carveouts tegra-carveouts: generic-0 :dma coherent mem declare 0x00000000cec00000,822083584
Apr 4 11:56:42 nvidia kernel: [ 2.557482] tegra-carveouts tegra-carveouts: assigned reserved memory node generic_carveout
Apr 4 11:56:42 nvidia kernel: [ 2.599289] nvmap: nvmap_setup_t18x_cache_ops()
Dear taewook101,
Could you please file a bug with all the relevant information. We will follow it up via bug for further investigation. Please share bug ID here for follow up.
Dear SivaRamaKrishna,
Could you please let me know where to file a bug?
Please provide me a link where I can file it.
Dear taewook101,
Please login to https://developer.nvidia.com/drive with your credentials. Please check MyAccount->MyBugs->Submit a new bug to file bug.
Please share ID here to follow up. Thanks
We’ve reported the bug and the ID is 2582701.
Thank you for your help.
