TX2 Dev kit always loss power few minutes after startup
I got a tx2 a month ago, and I used it to control a racecar VESC controllor. I flash it with jp4.2 and install ROS melodic. Nothing goes wrong untill two week ago, I left it running in office and the next morning after that day when I get back office ,it had shutdown, and can not be started up by pressing BTN sw ,neither does the Recovery Mode. Finally, I end up doing RMA. The day before yesterday, I had recieved a new(looks like a new one) TX2 atfer RMA. I redid those setup work yesterday, and left it trainning perception model all night. This morning when I came, found it shutdown and cannot startup. Then I unpluged the power supply wait the CR5 LED turned off and pluged into the power, it can be powered on but would loss power in minutes. After that I have tried :
  1. use different power supply lines->doesn’t work
  2. use different socket and outlet->doesn’t work
  3. set power mode to m0(pnvmode -m 0)->doesn’t work
This is The video: Jetson tx2 自动断电_哔哩哔哩_bilibili ,around 21:40 in the video it loss power.
Enverionment: using a SATA HP SSD 500G disk, a FOCBOX VESC speed controllor, Jetpack 4.2 + ROS melodic + tensorflow-gpu 1.13
could anyone help me?thx!
Hi, several questions about this: what’s the meaning of “would loss power in minutes” ? Does it mean not power on again or power up afterward? Do you have the log record when this happen? Did you test without any external device attached and with default sw loaded?
Hi Trumany,
“loss power in minutes” ,mean exactly what you say. Only CR5 LED is on , and if pressed BTN at that moment, CR6 , CR1 & CR2 LEDS would flash, but it can’t power up successfully. After unplug the power till CR5 turns off, and plug it in, tx2 can be powered on successfully by pressing BTN.
I have tried powering it on without any external device ,but it doesn’t work at that time. Now the tx2 continues running with all external devices without any shutdown-event for 2 hours. I don’t know what have happened.
This is the syslog when auto shutdown happens.
Jun 10 06:51:41 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 06:51:41 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 267.
Jun 10 06:51:41 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 06:51:41 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 06:51:41 ad-desktop kernel: [32119.947129] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 06:52:04 ad-desktop NetworkManager[5320]: <info>  [1560120724.9150] connectivity: (l4tbr0) timed out
Jun 10 06:52:04 ad-desktop NetworkManager[5320]: <info>  [1560120724.9152] connectivity: (eth0) timed out
Jun 10 06:53:41 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 06:53:41 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 268.
Jun 10 06:53:41 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 06:53:41 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 06:53:41 ad-desktop kernel: [32240.200763] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 06:55:42 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 06:55:42 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 269.
Jun 10 06:55:42 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 06:55:42 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 06:55:42 ad-desktop kernel: [32360.467496] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 06:57:04 ad-desktop NetworkManager[5320]: <info>  [1560121024.9149] connectivity: (l4tbr0) timed out
Jun 10 06:57:04 ad-desktop NetworkManager[5320]: <info>  [1560121024.9151] connectivity: (eth0) timed out
Jun 10 06:57:42 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 06:57:42 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 270.
Jun 10 06:57:42 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 06:57:42 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 06:57:42 ad-desktop kernel: [32480.692719] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 06:59:42 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 06:59:42 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 271.
Jun 10 06:59:42 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 06:59:42 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 06:59:42 ad-desktop kernel: [32600.955062] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 07:00:47 ad-desktop systemd[1]: Started Run anacron jobs.
Jun 10 07:00:47 ad-desktop anacron[26741]: Anacron 2.3 started on 2019-06-10
Jun 10 07:00:47 ad-desktop anacron[26741]: Normal exit (0 jobs run)
Jun 10 07:01:42 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 07:01:42 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 272.
Jun 10 07:01:42 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 07:01:42 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 07:01:42 ad-desktop kernel: [32721.188940] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 07:02:04 ad-desktop NetworkManager[5320]: <info>  [1560121324.9144] connectivity: (l4tbr0) timed out
Jun 10 07:02:04 ad-desktop NetworkManager[5320]: <info>  [1560121324.9146] connectivity: (eth0) timed out
Jun 10 07:03:43 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 07:03:43 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 273.
Jun 10 07:03:43 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 07:03:43 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 07:03:43 ad-desktop kernel: [32841.430833] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 07:05:43 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 07:05:43 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 274.
Jun 10 07:05:43 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 07:05:43 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 07:05:43 ad-desktop kernel: [32961.699595] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
Jun 10 07:07:04 ad-desktop NetworkManager[5320]: <info>  [1560121624.9133] connectivity: (l4tbr0) timed out
Jun 10 07:07:04 ad-desktop NetworkManager[5320]: <info>  [1560121624.9135] connectivity: (eth0) timed out
Jun 10 07:07:43 ad-desktop systemd[1]: jetson_clocks.service: Service hold-off time over, scheduling restart.
Jun 10 07:07:43 ad-desktop systemd[1]: jetson_clocks.service: Scheduled restart job, restart counter is at 275.
Jun 10 07:07:43 ad-desktop systemd[1]: Stopped Jetson Clocks.
Jun 10 07:07:43 ad-desktop systemd[1]: Started Jetson Clocks.
Jun 10 07:07:43 ad-desktop kernel: [33081.934175] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.  <b><<<<<<<----!!!auto shutdown</b>
Jun 10 08:28:24 ad-desktop systemd-modules-load[2167]: Inserted module 'bluedroid_pm'
Jun 10 08:28:24 ad-desktop systemd-modules-load[2167]: Module 'nvhost_vi' is builtin
Jun 10 08:28:24 ad-desktop systemd-modules-load[2167]: Inserted module 'nvgpu'
Jun 10 08:28:24 ad-desktop systemd[1]: Started Set the console keyboard layout.
Jun 10 08:28:24 ad-desktop systemd-sysctl[2963]: Couldn't write '1' to 'net/ipv4/tcp_syncookies', ignoring: No such file or directory
Jun 10 08:28:24 ad-desktop systemd-sysctl[2963]: Couldn't write '1' to 'kernel/yama/ptrace_scope', ignoring: No such file or directory
Jun 10 08:28:24 ad-desktop systemd-sysctl[2963]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory
Jun 10 08:28:24 ad-desktop systemd[1]: Started Load/Save Random Seed.
Jun 10 08:28:24 ad-desktop systemd[1]: Started Apply Kernel Variables.
Jun 10 08:28:24 ad-desktop systemd[1]: Mounted Kernel Configuration File System.
Jun 10 08:28:24 ad-desktop systemd[1]: Starting Flush Journal to Persistent Storage...
Jun 10 08:28:24 ad-desktop systemd[1]: Started Create Static Device Nodes in /dev.
Jun 10 08:28:24 ad-desktop systemd[1]: Starting udev Kernel Device Manager...
Jun 10 08:28:24 ad-desktop systemd[1]: Started Flush Journal to Persistent Storage.
Jun 10 08:28:24 ad-desktop systemd-udevd[3015]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Jun 10 08:28:24 ad-desktop systemd[1]: Started udev Kernel Device Manager.
Jun 10 08:28:24 ad-desktop systemd[1]: Started udev Coldplug all Devices.
Jun 10 08:28:24 ad-desktop systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 10 08:28:24 ad-desktop systemd[1]: Reached target Local Encrypted Volumes.
Jun 10 08:28:24 ad-desktop systemd-udevd[3049]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 10 08:28:24 ad-desktop systemd[1]: Found device /dev/ttyS0.
Jun 10 08:28:24 ad-desktop systemd[1]: Reached target Sound Card.
Jun 10 08:28:24 ad-desktop systemd-udevd[3060]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 10 08:28:24 ad-desktop systemd-udevd[3049]: Could not generate persistent MAC address for dummy0: No such file or directory
Jun 10 08:28:24 ad-desktop systemd[1]: Created slice system-lvm2\x2dpvscan.slice.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Booting Linux on physical CPU 0x100
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2988) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Boot CPU: AArch64 Processor [411fd073]
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt: - 80000000 ,  70000000
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt: - f0200000 ,  185600000
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt: - 275e00000 ,  200000
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt: - 276600000 ,  200000
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt: - 277000000 ,  200000
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] bootconsole [uart8250] enabled
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] On node 0 totalpages: 2055168
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]   DMA zone: 8192 pages used for memmap
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]   DMA zone: 0 pages reserved
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]   DMA zone: 523776 pages, LIFO batch:31
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]   Normal zone: 24008 pages used for memmap
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]   Normal zone: 1531392 pages, LIFO batch:31
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] psci: probing for conduit method from DT.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] psci: PSCIv1.0 detected in firmware.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] psci: Using standard PSCI v0.2 function IDs
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] psci: SMC Calling Convention v1.1
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f6776000 s53400 r8192 d32616 u94208
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Speculative Store Bypass Disable mitigation not required
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2022968
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] log_buf_len min size: 32768 bytes
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] log_buf_len: 262144 bytes
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] early log buf free: 29404(89%)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Memory: 7974756K/8220672K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 180380K reserved, 65536K cma-reserved)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Virtual kernel memory layout:
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f50000   ( 15168 KB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     .rodata : 0xffffff8008f50000 - 0xffffff80095d0000   (  6656 KB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]       .init : 0xffffff80095d0000 - 0xffffff8009e20000   (  8512 KB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]       .data : 0xffffff8009e20000 - 0xffffff800a0f8808   (  2915 KB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]        .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c   (   606 KB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]               0xffffffbf00000000 - 0xffffffbf07dc8000   (   125 MB actual)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc1f7200000   (  8050 MB)
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] Preemptible hierarchical RCU implementation.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] 	Build-time adjustment of leaf fanout to 64.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] NR_IRQS:64 nr_irqs:64 0
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
Jun 10 08:28:24 ad-desktop kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
Jun 10 08:28:24 ad-desktop kernel: [    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Jun 10 08:28:24 ad-desktop kernel: [    0.010007] Console: colour dummy device 80x25
Jun 10 08:28:24 ad-desktop kernel: [    0.014670] console [tty0] enabled
Jun 10 08:28:24 ad-desktop kernel: [    0.018225] bootconsole [uart8250] disabled
Jun 10 08:28:24 ad-desktop kernel: [    0.022599] kmemleak: Kernel memory leak detector disabled
Jun 10 08:28:24 ad-desktop kernel: [    0.022616] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
Jun 10 08:28:24 ad-desktop kernel: [    0.022629] pid_max: default: 32768 minimum: 301
Jun 10 08:28:24 ad-desktop kernel: [    0.022947] Security Framework initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.023108] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.023119] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.023743] ftrace: allocating 46802 entries in 183 pages
Jun 10 08:28:24 ad-desktop kernel: [    0.148693] sched-energy: Sched-energy-costs installed from DT
Jun 10 08:28:24 ad-desktop kernel: [    0.148713] ASID allocator initialised with 65536 entries
Jun 10 08:28:24 ad-desktop kernel: [    0.184191] tegra-id: chipid=21817.
Jun 10 08:28:24 ad-desktop kernel: [    0.184207] tegra-id: opt_subrevision=1.
Jun 10 08:28:24 ad-desktop kernel: [    0.184228] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
Jun 10 08:28:24 ad-desktop kernel: [    0.184241] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
Jun 10 08:28:24 ad-desktop kernel: [    0.184258] DTB Build time: Mar 13 2019 00:34:41
Jun 10 08:28:24 ad-desktop kernel: [    0.229917] CPU1: Booted secondary processor [4e0f0030]
Jun 10 08:28:24 ad-desktop kernel: [    0.261573] CPU2: Booted secondary processor [4e0f0030]
Jun 10 08:28:24 ad-desktop kernel: [    0.293419] CPU3: Booted secondary processor [411fd073]
Jun 10 08:28:24 ad-desktop kernel: [    0.325423] CPU4: Booted secondary processor [411fd073]
Jun 10 08:28:24 ad-desktop kernel: [    0.357414] CPU5: Booted secondary processor [411fd073]
Jun 10 08:28:24 ad-desktop kernel: [    0.357467] Brought up 6 CPUs
Jun 10 08:28:24 ad-desktop kernel: [    0.357511] SMP: Total of 6 processors activated.
Jun 10 08:28:24 ad-desktop kernel: [    0.357523] CPU features: detected feature: 32-bit EL0 Support
Jun 10 08:28:24 ad-desktop kernel: [    0.358339] CPU: All CPU(s) started at EL2
Jun 10 08:28:24 ad-desktop kernel: [    0.358393] alternatives: patching kernel code
Jun 10 08:28:24 ad-desktop kernel: [    0.367720] devtmpfs: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.404984] Initilizing CustomIPI irq domain
Jun 10 08:28:24 ad-desktop kernel: [    0.405230] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun 10 08:28:24 ad-desktop kernel: [    0.405255] futex hash table entries: 2048 (order: 5, 131072 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.406123] pinctrl core: initialized pinctrl subsystem
Jun 10 08:28:24 ad-desktop kernel: [    0.406339] OS set in device tree is not L4T.
Jun 10 08:28:24 ad-desktop kernel: [    0.406509] regulator-dummy: no parameters
Jun 10 08:28:24 ad-desktop kernel: [    0.406654] Initializing plugin-manager
Jun 10 08:28:24 ad-desktop kernel: [    0.406718] Plugin module not found
Jun 10 08:28:24 ad-desktop kernel: [    0.406763] Plugin-manager status disabled
Jun 10 08:28:24 ad-desktop kernel: [    0.408526] NET: Registered protocol family 16
Jun 10 08:28:24 ad-desktop kernel: [    0.409252] pstore: using zlib compression
Jun 10 08:28:24 ad-desktop kernel: [    0.409634] console [pstore-1] enabled
Jun 10 08:28:24 ad-desktop kernel: [    0.409646] pstore: Registered ramoops as persistent store backend
Jun 10 08:28:24 ad-desktop kernel: [    0.409659] ramoops: attached 0x200000@0x275880000, ecc: 0/0
Jun 10 08:28:24 ad-desktop kernel: [    0.425054] cpuidle: using governor menu
Jun 10 08:28:24 ad-desktop kernel: [    0.426502] bpmp: waiting for handshake
Jun 10 08:28:24 ad-desktop kernel: [    0.426521] bpmp: handshake completed
Jun 10 08:28:24 ad-desktop kernel: [    0.426544] bpmp: synchronizing channels
Jun 10 08:28:24 ad-desktop kernel: [    0.426561] bpmp: channels synchronized
Jun 10 08:28:24 ad-desktop kernel: [    0.426572] bpmp: mail init ok
Jun 10 08:28:24 ad-desktop kernel: [    0.428636] arm-smmu 12000000.iommu: probing hardware configuration...
Jun 10 08:28:24 ad-desktop kernel: [    0.428655] arm-smmu 12000000.iommu: SMMUv2 with:
Jun 10 08:28:24 ad-desktop kernel: [    0.428669] arm-smmu 12000000.iommu: 	stage 1 translation
Jun 10 08:28:24 ad-desktop kernel: [    0.428682] arm-smmu 12000000.iommu: 	stage 2 translation
Jun 10 08:28:24 ad-desktop kernel: [    0.428694] arm-smmu 12000000.iommu: 	nested translation
Jun 10 08:28:24 ad-desktop kernel: [    0.428709] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
Jun 10 08:28:24 ad-desktop kernel: [    0.428728] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
Jun 10 08:28:24 ad-desktop kernel: [    0.428747] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
Jun 10 08:28:24 ad-desktop kernel: [    0.428761] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
Jun 10 08:28:24 ad-desktop kernel: [    0.428773] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
Jun 10 08:28:24 ad-desktop kernel: [    0.430913] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
Jun 10 08:28:24 ad-desktop kernel: [    0.430944] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jun 10 08:28:24 ad-desktop kernel: [    0.433239] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
Jun 10 08:28:24 ad-desktop kernel: [    0.435056] Registering BPMP clocks...
Jun 10 08:28:24 ad-desktop kernel: [    0.435159] tegra_bpmp_clk_init: clock init ok (636 clks)
Jun 10 08:28:24 ad-desktop kernel: [    0.435875] tegra_bpmp_of_clk_init: EMC proxy not found.
Jun 10 08:28:24 ad-desktop kernel: [    0.437388] tegra_powergate_init: DONE
Jun 10 08:28:24 ad-desktop kernel: [    0.437410] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
Jun 10 08:28:24 ad-desktop kernel: [    0.437437] DTB Build time: Mar 13 2019 00:34:41
Jun 10 08:28:24 ad-desktop kernel: [    0.439379] Tegra reboot handler registered.
Jun 10 08:28:24 ad-desktop kernel: [    0.440952] tegra-pmc c360000.pmc: scratch reg offset dts data not present
Jun 10 08:28:24 ad-desktop kernel: [    0.441065] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
Jun 10 08:28:24 ad-desktop kernel: [    0.441091] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
Jun 10 08:28:24 ad-desktop kernel: [    0.441106] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
Jun 10 08:28:24 ad-desktop kernel: [    0.441118] tegra-pmc: ### PMC reset status reg: 0x0
Jun 10 08:28:24 ad-desktop kernel: [    0.441286] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Jun 10 08:28:24 ad-desktop kernel: [    0.441314] tegra-pmc c360000.pmc: IO padctrl driver initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.441666] iommu: Adding device 3460000.sdhci to group 0
Jun 10 08:28:24 ad-desktop kernel: [    0.442379] iommu: Adding device 3400000.sdhci to group 1
Jun 10 08:28:24 ad-desktop kernel: [    0.443490] iommu: Adding device 3507000.ahci-sata to group 2
Jun 10 08:28:24 ad-desktop kernel: [    0.443517] arm-smmu: forcing sodev map for 3507000.ahci-sata
Jun 10 08:28:24 ad-desktop kernel: [    0.443984] iommu: Adding device 3160000.i2c to group 3
Jun 10 08:28:24 ad-desktop kernel: [    0.444444] iommu: Adding device c240000.i2c to group 4
Jun 10 08:28:24 ad-desktop kernel: [    0.444822] iommu: Adding device 3180000.i2c to group 5
Jun 10 08:28:24 ad-desktop kernel: [    0.445209] iommu: Adding device 3190000.i2c to group 6
Jun 10 08:28:24 ad-desktop kernel: [    0.445664] iommu: Adding device 31b0000.i2c to group 7
Jun 10 08:28:24 ad-desktop kernel: [    0.446018] iommu: Adding device 31c0000.i2c to group 8
Jun 10 08:28:24 ad-desktop kernel: [    0.446366] iommu: Adding device c250000.i2c to group 9
Jun 10 08:28:24 ad-desktop kernel: [    0.446720] iommu: Adding device 31e0000.i2c to group 10
Jun 10 08:28:24 ad-desktop kernel: [    0.448248] iommu: Adding device 3210000.spi to group 11
Jun 10 08:28:24 ad-desktop kernel: [    0.448607] iommu: Adding device c260000.spi to group 12
Jun 10 08:28:24 ad-desktop kernel: [    0.448958] iommu: Adding device 3240000.spi to group 13
Jun 10 08:28:24 ad-desktop kernel: [    0.449706] iommu: Adding device 3100000.serial to group 14
Jun 10 08:28:24 ad-desktop kernel: [    0.450071] iommu: Adding device 3110000.serial to group 15
Jun 10 08:28:24 ad-desktop kernel: [    0.450419] iommu: Adding device c280000.serial to group 16
Jun 10 08:28:24 ad-desktop kernel: [    0.450768] iommu: Adding device 3130000.serial to group 17
Jun 10 08:28:24 ad-desktop kernel: [    0.452147] iommu: Adding device 2490000.ether_qos to group 18
Jun 10 08:28:24 ad-desktop kernel: [    0.452171] arm-smmu: forcing sodev map for 2490000.ether_qos
Jun 10 08:28:24 ad-desktop kernel: [    0.452777] iommu: Adding device b000000.rtcpu to group 19
Jun 10 08:28:24 ad-desktop kernel: [    0.455066] iommu: Adding device 13e10000.host1x to group 20
Jun 10 08:28:24 ad-desktop kernel: [    0.455385] iommu: Adding device 13e10000.host1x:ctx0 to group 21
Jun 10 08:28:24 ad-desktop kernel: [    0.455707] iommu: Adding device 13e10000.host1x:ctx1 to group 22
Jun 10 08:28:24 ad-desktop kernel: [    0.456029] iommu: Adding device 13e10000.host1x:ctx2 to group 23
Jun 10 08:28:24 ad-desktop kernel: [    0.456339] iommu: Adding device 13e10000.host1x:ctx3 to group 24
Jun 10 08:28:24 ad-desktop kernel: [    0.456657] iommu: Adding device 13e10000.host1x:ctx4 to group 25
Jun 10 08:28:24 ad-desktop kernel: [    0.456972] iommu: Adding device 13e10000.host1x:ctx5 to group 26
Jun 10 08:28:24 ad-desktop kernel: [    0.457333] iommu: Adding device 13e10000.host1x:ctx6 to group 27
Jun 10 08:28:24 ad-desktop kernel: [    0.457664] iommu: Adding device 13e10000.host1x:ctx7 to group 28
Jun 10 08:28:24 ad-desktop kernel: [    0.458143] iommu: Adding device 150c0000.nvcsi to group 29
Jun 10 08:28:24 ad-desktop kernel: [    0.458812] iommu: Adding device 15700000.vi to group 30
Jun 10 08:28:24 ad-desktop kernel: [    0.459177] iommu: Adding device 15600000.isp to group 31
Jun 10 08:28:24 ad-desktop kernel: [    0.459649] iommu: Adding device 15210000.nvdisplay to group 32
Jun 10 08:28:24 ad-desktop kernel: [    0.460262] iommu: Adding device 15340000.vic to group 33
Jun 10 08:28:24 ad-desktop kernel: [    0.460493] iommu: Adding device 154c0000.nvenc to group 34
Jun 10 08:28:24 ad-desktop kernel: [    0.460723] iommu: Adding device 15480000.nvdec to group 35
Jun 10 08:28:24 ad-desktop kernel: [    0.461107] iommu: Adding device 15380000.nvjpg to group 36
Jun 10 08:28:24 ad-desktop kernel: [    0.461351] iommu: Adding device 15500000.tsec to group 37
Jun 10 08:28:24 ad-desktop kernel: [    0.461582] iommu: Adding device 15100000.tsecb to group 38
Jun 10 08:28:24 ad-desktop kernel: [    0.462264] iommu: Adding device 15810000.se to group 39
Jun 10 08:28:24 ad-desktop kernel: [    0.462497] iommu: Adding device 15820000.se to group 40
Jun 10 08:28:24 ad-desktop kernel: [    0.462719] iommu: Adding device 15830000.se to group 41
Jun 10 08:28:24 ad-desktop kernel: [    0.462947] iommu: Adding device 15840000.se to group 42
Jun 10 08:28:24 ad-desktop kernel: [    0.463833] iommu: Adding device smmu_test to group 43
Jun 10 08:28:24 ad-desktop kernel: [    0.464444] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2c10000
Jun 10 08:28:24 ad-desktop kernel: [    0.464469] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2c20000
Jun 10 08:28:24 ad-desktop kernel: [    0.464490] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c30000
Jun 10 08:28:24 ad-desktop kernel: [    0.464510] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c40000
Jun 10 08:28:24 ad-desktop kernel: [    0.464530] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
Jun 10 08:28:24 ad-desktop kernel: [    0.464549] nv-tegra-mc 2c10000.mc: No mssnvlink node
Jun 10 08:28:24 ad-desktop kernel: [    0.464570] mc-err: mcerr ops are set to t18x
Jun 10 08:28:24 ad-desktop kernel: [    0.464724] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
Jun 10 08:28:24 ad-desktop kernel: [    0.465874] iommu: Adding device 3530000.xhci to group 44
Jun 10 08:28:24 ad-desktop kernel: [    0.465898] arm-smmu: forcing sodev map for 3530000.xhci
Jun 10 08:28:24 ad-desktop kernel: [    0.466345] iommu: Adding device 3550000.xudc to group 45
Jun 10 08:28:24 ad-desktop kernel: [    0.466367] arm-smmu: forcing sodev map for 3550000.xudc
Jun 10 08:28:24 ad-desktop kernel: [    0.467089] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
Jun 10 08:28:24 ad-desktop kernel: [    0.467108] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
Jun 10 08:28:24 ad-desktop kernel: [    0.467685] iommu: Adding device 17000000.gp10b to group 46
Jun 10 08:28:24 ad-desktop kernel: [    0.468728] tegra-reset 5000000.clock: registered 193 resets.
Jun 10 08:28:24 ad-desktop kernel: [    0.470976] iommu: Adding device d000000.bpmp to group 47
Jun 10 08:28:24 ad-desktop kernel: [    0.471197] bpmp: ping status is 0
Jun 10 08:28:24 ad-desktop kernel: [    0.471300] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
Jun 10 08:28:24 ad-desktop kernel: [    0.473816] bpmp d000000.bpmp: probe ok
Jun 10 08:28:24 ad-desktop kernel: [    0.477106] iommu: Adding device 2600000.dma to group 48
Jun 10 08:28:24 ad-desktop kernel: [    0.478404] GPIO line 461 (camera-control-output-low) hogged as output/low
Jun 10 08:28:24 ad-desktop kernel: [    0.478442] GPIO line 456 (camera-control-output-low) hogged as output/low
Jun 10 08:28:24 ad-desktop kernel: [    0.478476] GPIO line 457 (camera-control-output-low) hogged as output/low
Jun 10 08:28:24 ad-desktop kernel: [    0.478508] GPIO line 426 (camera-control-output-low) hogged as output/low
Jun 10 08:28:24 ad-desktop kernel: [    0.478543] GPIO line 424 (wifi-enable) hogged as output/high
Jun 10 08:28:24 ad-desktop kernel: [    0.478575] GPIO line 445 (sdmmc-wake-support-input) hogged as input
Jun 10 08:28:24 ad-desktop kernel: [    0.478608] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
Jun 10 08:28:24 ad-desktop kernel: [    0.478816] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
Jun 10 08:28:24 ad-desktop kernel: [    0.482584] GPIO line 315 (wifi-wake-ap) hogged as input
Jun 10 08:28:24 ad-desktop kernel: [    0.482766] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
Jun 10 08:28:24 ad-desktop kernel: [    0.484387] iommu: Adding device 10003000.pcie-controller to group 49
Jun 10 08:28:24 ad-desktop kernel: [    0.484414] arm-smmu: forcing sodev map for 10003000.pcie-controller
Jun 10 08:28:24 ad-desktop kernel: [    0.484749] iommu: Adding device sound to group 50
Jun 10 08:28:24 ad-desktop kernel: [    0.485164] iommu: Adding device 3510000.hda to group 51
Jun 10 08:28:24 ad-desktop kernel: [    0.492865] iommu: Adding device c1a0000.aon to group 52
Jun 10 08:28:24 ad-desktop kernel: [    0.493346] vdd-ac-bat: 5000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.495037] vdd-1v8-ap: 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.517586] random: fast init done
Jun 10 08:28:24 ad-desktop kernel: [    0.534684] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jun 10 08:28:24 ad-desktop kernel: [    0.541016] eventlib_kernel: keventlib is initialized, test id: 0
Jun 10 08:28:24 ad-desktop kernel: [    0.541613] SCSI subsystem initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.541965] libata version 3.00 loaded.
Jun 10 08:28:24 ad-desktop kernel: [    0.542226] usbcore: registered new interface driver usbfs
Jun 10 08:28:24 ad-desktop kernel: [    0.542314] usbcore: registered new interface driver hub
Jun 10 08:28:24 ad-desktop kernel: [    0.542466] usbcore: registered new device driver usb
Jun 10 08:28:24 ad-desktop kernel: [    0.546648] GPIO line 241 (touch-rails) hogged as output/high
Jun 10 08:28:24 ad-desktop kernel: [    0.546938] GPIO line 242 (touch-rails) hogged as output/high
Jun 10 08:28:24 ad-desktop kernel: [    0.547255] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
Jun 10 08:28:24 ad-desktop kernel: [    0.548373] GPIO line 228 (lcd-bias-rails) hogged as output/high
Jun 10 08:28:24 ad-desktop kernel: [    0.548682] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
Jun 10 08:28:24 ad-desktop kernel: [    0.561203] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
Jun 10 08:28:24 ad-desktop kernel: [    0.565811] vddio-ddr: at 1125 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.569609] avdd_dsi_csi: 1200 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.573608] vdd-1v8: 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.577620] vdd-3v3-sys: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.579110] spmic-ldo0: at 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.580061] spmic-ldo1: at 800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.585608] vddio-3v3: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.586410] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.589613] vdd-rtc: at 800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.590539] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.593609] spmic-ldo6: at 1500 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.597622] vdd-pex-1v00: 1000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.598478] dvdd-pex: 1000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.599175] GPIO line 221 (spmic_gpio_input) hogged as input
Jun 10 08:28:24 ad-desktop kernel: [    0.599381] GPIO line 222 (spmic_gpio_input) hogged as input
Jun 10 08:28:24 ad-desktop kernel: [    0.599779] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
Jun 10 08:28:24 ad-desktop kernel: [    0.602343] max77620 4-003c: max77620 probe successful
Jun 10 08:28:24 ad-desktop kernel: [    0.602998] media: Linux media interface: v0.10
Jun 10 08:28:24 ad-desktop kernel: [    0.603174] Linux video capture interface: v2.00
Jun 10 08:28:24 ad-desktop kernel: [    0.607631] pps_core: LinuxPPS API ver. 1 registered
Jun 10 08:28:24 ad-desktop kernel: [    0.607675] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jun 10 08:28:24 ad-desktop kernel: [    0.607841] PTP clock support registered
Jun 10 08:28:24 ad-desktop kernel: [    0.608638] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
Jun 10 08:28:24 ad-desktop kernel: [    0.608705] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
Jun 10 08:28:24 ad-desktop kernel: [    0.612853] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
Jun 10 08:28:24 ad-desktop kernel: [    0.617281] Advanced Linux Sound Architecture Driver Initialized.
Jun 10 08:28:24 ad-desktop kernel: [    0.617860] Bluetooth: Core ver 2.22
Jun 10 08:28:24 ad-desktop kernel: [    0.617924] NET: Registered protocol family 31
Jun 10 08:28:24 ad-desktop kernel: [    0.617951] Bluetooth: HCI device and connection manager initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.617987] Bluetooth: HCI socket layer initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.618016] Bluetooth: L2CAP socket layer initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.618084] Bluetooth: SCO socket layer initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.618988] en-vdd-sd: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.619658] en-vdd-cam: 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.621647] vdd-hdmi: 5000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.622124] vdd-usb0-5v: 5000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.622534] vdd-usb1-5v: 5000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.625640] en-vdd-ts-1v8: 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.629633] en-vdd-ts-hv-3v3: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.630268] en-vdd-disp-3v3: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.630858] en-mdm-pwr-3v7: 3700 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.631492] en-vdd-disp-1v8: 1800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.632116] en-vdd-cam-hv-2v8: 2800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.632822] en-vdd-cam-1v2: 1200 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.633471] vdd-fan: 5000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.633890] vdd-3v3: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.634701] dis-vdd-1v2: 1200 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.635064] en-vdd-vcm-2v8: 2800 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.635859] vdd-usb2-5v: 5000 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.636310] vdd-sys-bl: 3300 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.637019] en-vdd-sys: 1200 mV
Jun 10 08:28:24 ad-desktop kernel: [    0.640342] camchar: rtcpu character device driver loaded
Jun 10 08:28:24 ad-desktop kernel: [    0.641034] gpio tegra-gpio wake53 for gpio=159(X:7)
Jun 10 08:28:24 ad-desktop kernel: [    0.643063] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
Jun 10 08:28:24 ad-desktop kernel: [    0.644559] clocksource: Switched to clocksource arch_sys_counter
Jun 10 08:28:24 ad-desktop kernel: [    0.685275] VFS: Disk quotas dquot_6.6.0
Jun 10 08:28:24 ad-desktop kernel: [    0.685537] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.686192] nvmap_heap_init: nvmap_heap_init: created heap block cache
Jun 10 08:28:24 ad-desktop kernel: [    0.687132] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
Jun 10 08:28:24 ad-desktop kernel: [    0.687172] nvmap_page_pool_init: Total RAM pages: 2010073
Jun 10 08:28:24 ad-desktop kernel: [    0.687203] nvmap_page_pool_init: nvmap page pool size: 251259 pages (981 MB)
Jun 10 08:28:24 ad-desktop kernel: [    0.687411] nvmap_background_zero_thread: PP zeroing thread starting.
Jun 10 08:28:24 ad-desktop kernel: [    0.691978] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
Jun 10 08:28:24 ad-desktop kernel: [    0.704617] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
Jun 10 08:28:24 ad-desktop kernel: [    0.704913] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
Jun 10 08:28:24 ad-desktop kernel: [    0.705373] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Jun 10 08:28:24 ad-desktop kernel: [    0.705510] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Jun 10 08:28:24 ad-desktop kernel: [    0.705688] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
Jun 10 08:28:24 ad-desktop kernel: [    0.705885] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
Jun 10 08:28:24 ad-desktop kernel: [    0.706133] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
Jun 10 08:28:24 ad-desktop kernel: [    0.706414] la/ptsa driver initialized.
Jun 10 08:28:24 ad-desktop kernel: [    0.706447] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
Jun 10 08:28:24 ad-desktop kernel: [    0.706476] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
Jun 10 08:28:24 ad-desktop kernel: [    0.707644] NET: Registered protocol family 2
Jun 10 08:28:24 ad-desktop kernel: [    0.709679] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.710415] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.711242] TCP: Hash tables configured (established 65536 bind 65536)
Jun 10 08:28:24 ad-desktop kernel: [    0.711319] UDP hash table entries: 4096 (order: 5, 131072 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.711517] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
Jun 10 08:28:24 ad-desktop kernel: [    0.712399] NET: Registered protocol family 1
Jun 10 08:28:24 ad-desktop kernel: [    0.713600] RPC: Registered named UNIX socket transport module.
Jun 10 08:28:24 ad-desktop kernel: [    0.713634] RPC: Registered udp transport module.
Jun 10 08:28:24 ad-desktop kernel: [    0.713660] RPC: Registered tcp transport module.
Jun 10 08:28:24 ad-desktop kernel: [    0.713686] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 10 08:28:24 ad-desktop kernel: [    0.713719] PCI: CLS 0 bytes, default 64
Jun 10 08:28:24 ad-desktop kernel: [    0.713955] Trying to unpack rootfs image as initramfs...
Jun 10 08:28:24 ad-desktop kernel: [    0.741336] host1x 13e10000.host1x: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.742811] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jun 10 08:28:24 ad-desktop kernel: [    0.747834] audit: initializing netlink subsys (disabled)
Jun 10 08:28:24 ad-desktop kernel: [    0.747927] audit: type=2000 audit(0.628:1): initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.748843] workingset: timestamp_bits=46 max_order=21 bucket_order=0
Jun 10 08:28:24 ad-desktop kernel: [    0.761836] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jun 10 08:28:24 ad-desktop kernel: [    0.764617] ntfs: driver 2.1.32 [Flags: R/W].
Jun 10 08:28:24 ad-desktop kernel: [    0.766198] 9p: Installing v9fs 9p2000 file system support
Jun 10 08:28:24 ad-desktop kernel: [    0.772656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
Jun 10 08:28:24 ad-desktop kernel: [    0.772869] io scheduler noop registered
Jun 10 08:28:24 ad-desktop kernel: [    0.773529] io scheduler cfq registered (default)
Jun 10 08:28:24 ad-desktop kernel: [    0.778699] gic 2a41000.agic-controller: GIC IRQ controller registered
Jun 10 08:28:24 ad-desktop kernel: [    0.839479] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
Jun 10 08:28:24 ad-desktop kernel: [    0.879976] iommu: Adding device 2993000.adsp to group 54
Jun 10 08:28:24 ad-desktop kernel: [    0.881207] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
Jun 10 08:28:24 ad-desktop kernel: [    0.884371] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
Jun 10 08:28:24 ad-desktop kernel: [    0.888711] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
Jun 10 08:28:24 ad-desktop kernel: [    0.890251] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
Jun 10 08:28:24 ad-desktop kernel: [    0.891643] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
Jun 10 08:28:24 ad-desktop kernel: [    0.893015] tegra-pwm c340000.pwm: PWM clk can sleep in ops
Jun 10 08:28:24 ad-desktop kernel: [    0.895643] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
Jun 10 08:28:24 ad-desktop kernel: [    0.896825] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
Jun 10 08:28:24 ad-desktop kernel: [    0.897282] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
Jun 10 08:28:24 ad-desktop kernel: [    0.897489] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Jun 10 08:28:24 ad-desktop kernel: [    0.897695] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
Jun 10 08:28:24 ad-desktop kernel: [    0.897774] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
Jun 10 08:28:24 ad-desktop kernel: [    0.900914] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
Jun 10 08:28:24 ad-desktop kernel: [    0.902521] tsec 15500000.tsec: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.904033] tsec 15100000.tsecb: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.908689] nvdec 15480000.nvdec: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.916490] falcon 15340000.vic: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.918173] falcon 154c0000.nvenc: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.919615] falcon 15380000.nvjpg: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.923099] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
Jun 10 08:28:24 ad-desktop kernel: [    0.924801] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
Jun 10 08:28:24 ad-desktop kernel: [    0.926400] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
Jun 10 08:28:24 ad-desktop kernel: [    0.928027] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
Jun 10 08:28:24 ad-desktop kernel: [    0.929619] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
Jun 10 08:28:24 ad-desktop kernel: [    0.931195] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
Jun 10 08:28:24 ad-desktop kernel: [    0.932832] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
Jun 10 08:28:24 ad-desktop kernel: [    0.934342] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
Jun 10 08:28:24 ad-desktop kernel: [    0.938097] tegradccommon 15200000.dc_common: host1x channel mapped
Jun 10 08:28:24 ad-desktop kernel: [    0.938142] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
Jun 10 08:28:24 ad-desktop kernel: [    0.938199] tegradccommon 15200000.dc_common: dma mapping done
Jun 10 08:28:24 ad-desktop kernel: [    0.939447] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
Jun 10 08:28:24 ad-desktop kernel: [    0.939535] generic_infoframe_type: 0x87
Jun 10 08:28:24 ad-desktop kernel: [    0.939682] tegradc 15210000.nvdisplay: DT parsed successfully
Jun 10 08:28:24 ad-desktop kernel: [    0.939744] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
Jun 10 08:28:24 ad-desktop kernel: [    0.949362] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
Jun 10 08:28:24 ad-desktop kernel: [    0.949419] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
Jun 10 08:28:24 ad-desktop kernel: [    0.949457] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
Jun 10 08:28:24 ad-desktop kernel: [    0.949768] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
Jun 10 08:28:24 ad-desktop kernel: [    0.949799] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
Jun 10 08:28:24 ad-desktop kernel: [    0.951335] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
Jun 10 08:28:24 ad-desktop kernel: [    0.952583] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.953618] kfuse 3830000.kfuse: initialized
Jun 10 08:28:24 ad-desktop kernel: [    0.953893] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
Jun 10 08:28:24 ad-desktop kernel: [    0.953921] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
Jun 10 08:28:24 ad-desktop kernel: [    0.955307] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
Jun 10 08:28:24 ad-desktop kernel: [    0.960216] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jun 10 08:28:24 ad-desktop kernel: [    0.963349] console [ttyS0] disabled
Jun 10 08:28:24 ad-desktop kernel: [    0.963444] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
Jun 10 08:28:24 ad-desktop kernel: [    1.328861] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jun 10 08:28:24 ad-desktop kernel: [    1.737019] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jun 10 08:28:24 ad-desktop kernel: [    2.145309] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jun 10 08:28:24 ad-desktop kernel: [    2.147372] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
Jun 10 08:28:24 ad-desktop kernel: [    2.553751] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
Jun 10 08:28:24 ad-desktop kernel: [    2.961082] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
Jun 10 08:28:24 ad-desktop kernel: [    3.265575] console [ttyS0] enabled
Jun 10 08:28:24 ad-desktop kernel: [    3.271030] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
Jun 10 08:28:24 ad-desktop kernel: [    3.281044] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
Jun 10 08:28:24 ad-desktop kernel: [    3.290111] serial-tegra 3130000.serial: RX in PIO mode
Jun 10 08:28:24 ad-desktop kernel: [    3.296354] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
Jun 10 08:28:24 ad-desktop kernel: [    3.306260] [drm] Initialized
Jun 10 08:28:24 ad-desktop kernel: [    3.319891] brd: module loaded
Jun 10 08:28:24 ad-desktop kernel: [    3.328447] loop: module loaded
Jun 10 08:28:24 ad-desktop kernel: [    3.331847] tegra_profiler: version: 1.132, samples/io: 46/26
Jun 10 08:28:24 ad-desktop kernel: [    3.337905] tegra_profiler: auth: init
Jun 10 08:28:24 ad-desktop kernel: [    3.342306] nct1008_nct72 7-004c: starting parse dt
Jun 10 08:28:24 ad-desktop kernel: [    3.342549] THERMAL EST: found 3 subdevs
Jun 10 08:28:24 ad-desktop kernel: [    3.342552] THERMAL EST num_resources: 0
Jun 10 08:28:24 ad-desktop kernel: [    3.342556] [THERMAL EST subdev 0]
Jun 10 08:28:24 ad-desktop kernel: [    3.342561] [THERMAL EST subdev 1]
Jun 10 08:28:24 ad-desktop kernel: [    3.342564] [THERMAL EST subdev 2]
Jun 10 08:28:24 ad-desktop kernel: [    3.342881] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
Jun 10 08:28:24 ad-desktop kernel: [    3.342884] THERMAL EST: thz register success.
Jun 10 08:28:24 ad-desktop kernel: [    3.351906] THERMAL EST: end of probe, return err: 0
Jun 10 08:28:24 ad-desktop kernel: [    3.352978] hisi_sas: driver version v1.6
Jun 10 08:28:24 ad-desktop kernel: [    3.357207] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
Jun 10 08:28:24 ad-desktop kernel: [    3.357218] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
Jun 10 08:28:24 ad-desktop kernel: [    3.362248] scsi host0: tegra_ahci
Jun 10 08:28:24 ad-desktop kernel: [    3.363163] scsi host1: tegra_ahci
Jun 10 08:28:24 ad-desktop kernel: [    3.363330] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
Jun 10 08:28:24 ad-desktop kernel: [    3.363333] ata2: DUMMY
Jun 10 08:28:24 ad-desktop kernel: [    3.369246] libphy: Fixed MDIO Bus: probed
Jun 10 08:28:24 ad-desktop kernel: [    3.370244] tun: Universal TUN/TAP device driver, 1.6
Jun 10 08:28:24 ad-desktop kernel: [    3.370246] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jun 10 08:28:24 ad-desktop kernel: [    3.370898] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun 10 08:28:24 ad-desktop kernel: [    3.370900] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun 10 08:28:24 ad-desktop kernel: [    3.370933] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
Jun 10 08:28:24 ad-desktop kernel: [    3.370935] igb: Copyright (c) 2007-2014 Intel Corporation.
Jun 10 08:28:24 ad-desktop kernel: [    3.371084] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jun 10 08:28:24 ad-desktop kernel: [    3.371087] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jun 10 08:28:24 ad-desktop kernel: [    3.371134] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
Jun 10 08:28:24 ad-desktop kernel: [    3.371136] Copyright(c) 1999 - 2017 Intel Corporation.
Jun 10 08:28:24 ad-desktop kernel: [    3.376538] eqos 2490000.ether_qos: no PHY interrupt found
Jun 10 08:28:24 ad-desktop kernel: [    3.376771] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
Jun 10 08:28:24 ad-desktop kernel: [    3.380442] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c6 da 4a
Jun 10 08:28:24 ad-desktop kernel: [    3.380579] libphy: dwc_phy: probed
Jun 10 08:28:24 ad-desktop kernel: [    3.380932] bcm54xx_low_power_mode(): put phy in iddq-lp mode
Jun 10 08:28:24 ad-desktop kernel: [    3.383234] PPP generic driver version 2.4.2
Jun 10 08:28:24 ad-desktop kernel: [    3.383375] PPP BSD Compression module registered
Jun 10 08:28:24 ad-desktop kernel: [    3.383378] PPP Deflate Compression module registered
Jun 10 08:28:24 ad-desktop kernel: [    3.383396] PPP MPPE Compression module registered
Jun 10 08:28:24 ad-desktop kernel: [    3.383400] NET: Registered protocol family 24
Jun 10 08:28:24 ad-desktop kernel: [    3.383448] usbcore: registered new interface driver r8152
Jun 10 08:28:24 ad-desktop kernel: [    3.383483] usbcore: registered new interface driver asix
Jun 10 08:28:24 ad-desktop kernel: [    3.383512] usbcore: registered new interface driver ax88179_178a
Jun 10 08:28:24 ad-desktop kernel: [    3.383546] usbcore: registered new interface driver cdc_ether
Jun 10 08:28:24 ad-desktop kernel: [    3.383577] usbcore: registered new interface driver net1080
Jun 10 08:28:24 ad-desktop kernel: [    3.383614] usbcore: registered new interface driver cdc_subset
Jun 10 08:28:24 ad-desktop kernel: [    3.383644] usbcore: registered new interface driver zaurus
Jun 10 08:28:24 ad-desktop kernel: [    3.383681] usbcore: registered new interface driver cdc_ncm
Jun 10 08:28:24 ad-desktop kernel: [    3.383828] VFIO - User Level meta-driver version: 0.3
Jun 10 08:28:24 ad-desktop kernel: [    3.389609] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 10 08:28:24 ad-desktop kernel: [    3.389631] ehci-pci: EHCI PCI platform driver
Jun 10 08:28:24 ad-desktop kernel: [    3.389666] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 10 08:28:24 ad-desktop kernel: [    3.389678] ohci-pci: OHCI PCI platform driver
Jun 10 08:28:24 ad-desktop kernel: [    3.389709] ohci-platform: OHCI generic platform driver
Jun 10 08:28:24 ad-desktop kernel: [    3.395385] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
Jun 10 08:28:24 ad-desktop kernel: [    3.397187] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ead9e800 id
Jun 10 08:28:24 ad-desktop kernel: [    3.397337] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
Jun 10 08:28:24 ad-desktop kernel: [    3.397342] tegra-xusb 3530000.xhci: Falling back to user helper
Jun 10 08:28:24 ad-desktop kernel: [    3.397720] usbcore: registered new interface driver uas
Jun 10 08:28:24 ad-desktop kernel: [    3.397760] usbcore: registered new interface driver usb-storage
Jun 10 08:28:24 ad-desktop kernel: [    3.397840] usbcore: registered new interface driver usbserial
Jun 10 08:28:24 ad-desktop kernel: [    3.402665] tegra-xudc-new 3550000.xudc: device count: 1
Jun 10 08:28:24 ad-desktop kernel: [    3.403889] tegra-xudc-new 3550000.xudc: vbus state: 0
Jun 10 08:28:24 ad-desktop kernel: [    3.403914] tegra-xudc-new 3550000.xudc: entering ELPG
Jun 10 08:28:24 ad-desktop kernel: [    3.405243] tegra-xudc-new 3550000.xudc: entering ELPG done
Jun 10 08:28:24 ad-desktop kernel: [    3.406121] mousedev: PS/2 mouse device common for all mice
Jun 10 08:28:24 ad-desktop kernel: [    3.406221] usbcore: registered new interface driver xpad
Jun 10 08:28:24 ad-desktop kernel: [    3.410633] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
Jun 10 08:28:24 ad-desktop kernel: [    3.412634] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
Jun 10 08:28:24 ad-desktop kernel: [    3.412644] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
Jun 10 08:28:24 ad-desktop kernel: [    3.412950] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
Jun 10 08:28:24 ad-desktop kernel: [    3.534707] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Jun 10 08:28:24 ad-desktop kernel: [    3.535849] Wake73 for irq=42
Jun 10 08:28:24 ad-desktop kernel: [    3.537068] rtc rtc1: alarm rtc device
Jun 10 08:28:24 ad-desktop kernel: [    3.537105] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
Jun 10 08:28:24 ad-desktop kernel: [    3.537131] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
Jun 10 08:28:24 ad-desktop kernel: [    3.537294] i2c /dev entries driver
Jun 10 08:28:24 ad-desktop kernel: [    3.540595] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
Jun 10 08:28:24 ad-desktop kernel: [    3.545036] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
Jun 10 08:28:24 ad-desktop kernel: [    3.545649] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
Jun 10 08:28:24 ad-desktop kernel: [    3.547147] parse_throttle_dt_data: Num cap clks = 4
Jun 10 08:28:24 ad-desktop kernel: [    3.547152] parse_throttle_dt_data: clk=mcpu type=1
Jun 10 08:28:24 ad-desktop kernel: [    3.547155] parse_throttle_dt_data: clk=bcpu type=2
Jun 10 08:28:24 ad-desktop kernel: [    3.547162] parse_throttle_dt_data: clk=gpu type=4
Jun 10 08:28:24 ad-desktop kernel: [    3.547165] parse_throttle_dt_data: clk=emc type=3
Jun 10 08:28:24 ad-desktop kernel: [    3.548379] tegra_throttle_probe: probe successful. #cdevs=4
Jun 10 08:28:24 ad-desktop kernel: [    3.549058] FAN dev name: pwm-fan
Jun 10 08:28:24 ad-desktop kernel: [    3.549117] FAN:gpio request success.
Jun 10 08:28:24 ad-desktop kernel: [    3.549125] FAN: can't find tach_gpio
Jun 10 08:28:24 ad-desktop kernel: [    3.549157] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
Jun 10 08:28:24 ad-desktop kernel: [    3.549462] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
Jun 10 08:28:24 ad-desktop kernel: [    3.549467] pwm_fan_driver pwm-fan: tach period: 1000
Jun 10 08:28:24 ad-desktop kernel: [    3.549846] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
Jun 10 08:28:24 ad-desktop kernel: [    3.549852] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
Jun 10 08:28:24 ad-desktop kernel: [    3.549883] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
Jun 10 08:28:24 ad-desktop kernel: [    3.549887] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
Jun 10 08:28:24 ad-desktop kernel: [    3.549891] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
Jun 10 08:28:24 ad-desktop kernel: [    3.549895] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
Jun 10 08:28:24 ad-desktop kernel: [    3.549899] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
Jun 10 08:28:24 ad-desktop kernel: [    3.549903] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
Jun 10 08:28:24 ad-desktop kernel: [    3.549908] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
Jun 10 08:28:24 ad-desktop kernel: [    3.549913] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
Jun 10 08:28:24 ad-desktop kernel: [    3.551784] device-mapper: uevent: version 1.0.3
Jun 10 08:28:24 ad-desktop kernel: [    3.553280] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Jun 10 08:28:24 ad-desktop kernel: [    3.576143] cpufreq: platform driver Initialization: pass
Jun 10 08:28:24 ad-desktop kernel: [    3.581438] cpuidle: Initializing cpuidle driver init for Denver cluster
Jun 10 08:28:24 ad-desktop kernel: [    3.581558] cpuidle: Initializing cpuidle driver init for A57 cluster
Jun 10 08:28:24 ad-desktop kernel: [    3.588051] sdhci: Secure Digital Host Controller Interface driver
Jun 10 08:28:24 ad-desktop kernel: [    3.588053] sdhci: Copyright(c) Pierre Ossman
Jun 10 08:28:24 ad-desktop kernel: [    3.588055] sdhci-pltfm: SDHCI platform and OF driver helper
Jun 10 08:28:24 ad-desktop kernel: [    3.589605] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
Jun 10 08:28:24 ad-desktop kernel: [    3.591574] CMDQ: cmdq_platfm_init successful
Jun 10 08:28:24 ad-desktop kernel: [    3.592753] CQE: CMD_TIMING bit set for R1B DCMD
Jun 10 08:28:24 ad-desktop kernel: [    3.596665] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
Jun 10 08:28:24 ad-desktop kernel: [    3.601867] sdhci-tegra 3400000.sdhci: Got CD GPIO
Jun 10 08:28:24 ad-desktop kernel: [    3.601915] sdhci-tegra 3400000.sdhci: Got WP GPIO
Jun 10 08:28:24 ad-desktop kernel: [    3.603628] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
Jun 10 08:28:24 ad-desktop kernel: [    3.605491] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
Jun 10 08:28:24 ad-desktop kernel: [    3.610229] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
Jun 10 08:28:24 ad-desktop kernel: [    3.644575] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
Jun 10 08:28:24 ad-desktop kernel: [    3.644642] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
Jun 10 08:28:24 ad-desktop kernel: [    3.660701] gpio tegra-gpio wake71 for gpio=125(P:5)
Jun 10 08:28:24 ad-desktop kernel: [    3.660752] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
Jun 10 08:28:24 ad-desktop kernel: [    3.718138] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
Jun 10 08:28:24 ad-desktop kernel: [    3.731851] mmc0: periodic cache flush enabled
Jun 10 08:28:24 ad-desktop kernel: [    3.731865] mmc0: new HS400 Enhanced strobe MMC card at address 0001
Jun 10 08:28:24 ad-desktop kernel: [    3.732446] mmcblk0: mmc0:0001 032G34 29.1 GiB
Jun 10 08:28:24 ad-desktop kernel: [    3.732670] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
Jun 10 08:28:24 ad-desktop kernel: [    3.732885] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
Jun 10 08:28:24 ad-desktop kernel: [    3.733087] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
Jun 10 08:28:24 ad-desktop kernel: [    3.735790]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
Jun 10 08:28:24 ad-desktop kernel: [    3.832580] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jun 10 08:28:24 ad-desktop kernel: [    3.838495] ata1.00: ATA-9: HP SSD S700 500GB, R0522A1, max UDMA/133
Jun 10 08:28:24 ad-desktop kernel: [    3.838498] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 31/32)
Jun 10 08:28:24 ad-desktop kernel: [    3.849822] ata1.00: configured for UDMA/133
Jun 10 08:28:24 ad-desktop kernel: [    3.891304] mmc1: hw tuning done ...
Jun 10 08:28:24 ad-desktop kernel: [    3.898169] mmc1: new ultra high speed SDR104 SDIO card at address 0001
Jun 10 08:28:24 ad-desktop kernel: [    4.131651] nct1008_nct72 7-004c: !!!Found deprecated property!!!
Jun 10 08:28:24 ad-desktop kernel: [    4.137759] nct1008_nct72 7-004c: success parsing dt
Jun 10 08:28:24 ad-desktop kernel: [    4.142853] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
Jun 10 08:28:24 ad-desktop kernel: [    4.181684] nct1008_nct72 7-004c: LOC shutdown limit 107
Jun 10 08:28:24 ad-desktop kernel: [    4.187574] nct1008_nct72 7-004c: EXT shutdown limit 107
Jun 10 08:28:24 ad-desktop kernel: [    4.225740] nct1008_nct72 7-004c: initial LOC temp: 27000
Jun 10 08:28:24 ad-desktop kernel: [    4.231573] nct1008_nct72 7-004c: initial EXT temp: 39000
Jun 10 08:28:24 ad-desktop kernel: [    4.237775] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
Jun 10 08:28:24 ad-desktop kernel: [    4.243039] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
Jun 10 08:28:24 ad-desktop kernel: [    4.248523] nct1008_nct72 7-004c: nct100
syslog.tar.gz (638 KB)
Here is tergrastats logfile before shutdown automatically:
RAM 5967/7860MB (lfb 120x4MB) CPU [14%@2035,41%@2035,33%@2035,16%@2035,19%@2035,14%@2035] EMC_FREQ 0% GR3D_FREQ 24% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@34C BCPU@34C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1247 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 19/24 VDD_IN 6623/5910 VDD_SYS_CPU 1606/1498 VDD_SYS_DDR 1694/1552
RAM 5967/7860MB (lfb 134x4MB) CPU [15%@2035,34%@2035,47%@2035,14%@2035,14%@2035,15%@2035] EMC_FREQ 0% GR3D_FREQ 21% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34C Tdiode@31.75C VDD_SYS_GPU 1683/1247 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6547/5910 VDD_SYS_CPU 1683/1498 VDD_SYS_DDR 1675/1552
RAM 5967/7860MB (lfb 134x4MB) CPU [20%@2035,38%@2035,39%@2035,20%@2035,18%@2035,18%@2035] EMC_FREQ 0% GR3D_FREQ 26% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1248 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6662/5911 VDD_SYS_CPU 1606/1498 VDD_SYS_DDR 1694/1552
RAM 5967/7860MB (lfb 118x4MB) CPU [14%@2035,37%@2035,44%@2035,13%@2035,16%@2035,14%@2035] EMC_FREQ 0% GR3D_FREQ 20% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1248 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6547/5912 VDD_SYS_CPU 1683/1498 VDD_SYS_DDR 1694/1553
RAM 5967/7860MB (lfb 118x4MB) CPU [15%@2035,37%@2035,40%@2035,13%@2035,18%@2035,16%@2035] EMC_FREQ 0% GR3D_FREQ 26% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.5C VDD_SYS_GPU 1683/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6662/5913 VDD_SYS_CPU 1606/1499 VDD_SYS_DDR 1656/1553
RAM 5967/7860MB (lfb 133x4MB) CPU [18%@2035,42%@2035,37%@2035,13%@2035,19%@2035,16%@2035] EMC_FREQ 0% GR3D_FREQ 25% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6700/5914 VDD_SYS_CPU 1683/1499 VDD_SYS_DDR 1656/1553
RAM 5967/7860MB (lfb 133x4MB) CPU [24%@2035,24%@2035,48%@2035,9%@2035,11%@2035,13%@2035] EMC_FREQ 0% GR3D_FREQ 0% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@33C BCPU@34C thermal@34.3C Tdiode@30.75C VDD_SYS_GPU 688/1248 VDD_SYS_SOC 841/883 VDD_4V0_WIFI 0/24 VDD_IN 4979/5912 VDD_SYS_CPU 1530/1499 VDD_SYS_DDR 1332/1553
RAM 6063/7860MB (lfb 117x4MB) CPU [8%@2035,25%@2035,64%@2035,7%@2035,7%@2035,6%@2035] EMC_FREQ 0% GR3D_FREQ 0% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@33.5C BCPU@34.5C thermal@33.6C Tdiode@31.5C VDD_SYS_GPU 1147/1248 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6087/5913 VDD_SYS_CPU 1606/1499 VDD_SYS_DDR 1561/1553
RAM 5967/7860MB (lfb 117x4MB) CPU [21%@2035,40%@2035,35%@2035,14%@2035,18%@2035,14%@2035] EMC_FREQ 0% GR3D_FREQ 27% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@33.5C BCPU@34.5C thermal@34.1C Tdiode@31.75C VDD_SYS_GPU 1606/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6508/5913 VDD_SYS_CPU 1683/1499 VDD_SYS_DDR 1675/1553
RAM 5967/7860MB (lfb 133x4MB) CPU [13%@2035,34%@2035,46%@2035,15%@2035,15%@2035,20%@2035] EMC_FREQ 0% GR3D_FREQ 0% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@33.5C BCPU@34.5C thermal@34.3C Tdiode@31.25C VDD_SYS_GPU 1377/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6432/5914 VDD_SYS_CPU 1683/1499 VDD_SYS_DDR 1675/1553
RAM 5967/7860MB (lfb 133x4MB) CPU [17%@2035,36%@2035,39%@2035,16%@2035,19%@2035,18%@2035] EMC_FREQ 0% GR3D_FREQ 30% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1683/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6547/5915 VDD_SYS_CPU 1606/1499 VDD_SYS_DDR 1675/1553
RAM 5967/7860MB (lfb 113x4MB) CPU [19%@2035,44%@2035,35%@2035,16%@2035,16%@2035,17%@2035] EMC_FREQ 0% GR3D_FREQ 20% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@33.5C BCPU@34.5C thermal@34.3C Tdiode@31.25C VDD_SYS_GPU 1377/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6394/5915 VDD_SYS_CPU 1683/1500 VDD_SYS_DDR 1713/1553
RAM 5967/7860MB (lfb 113x4MB) CPU [18%@2035,37%@2035,44%@2035,17%@2035,16%@2035,15%@2035] EMC_FREQ 0% GR3D_FREQ 26% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1250 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6662/5916 VDD_SYS_CPU 1606/1500 VDD_SYS_DDR 1675/1553
RAM 5967/7860MB (lfb 133x4MB) CPU [14%@2035,37%@2035,45%@2035,14%@2035,11%@2035,14%@2035] EMC_FREQ 0% GR3D_FREQ 30% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.1C Tdiode@31.75C VDD_SYS_GPU 1453/1250 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6432/5917 VDD_SYS_CPU 1683/1500 VDD_SYS_DDR 1713/1553
RAM 5966/7860MB (lfb 133x4MB) CPU [12%@2035,59%@2035,20%@2035,11%@2035,9%@2035,11%@2035] EMC_FREQ 0% GR3D_FREQ 0% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@33C BCPU@34C thermal@34.1C Tdiode@31C VDD_SYS_GPU 765/1250 VDD_SYS_SOC 841/883 VDD_4V0_WIFI 19/24 VDD_IN 5209/5916 VDD_SYS_CPU 1530/1500 VDD_SYS_DDR 1408/1553
RAM 5966/7860MB (lfb 133x4MB) CPU [2%@2035,93%@2035,4%@2035,3%@2035,2%@2035,1%@2035] EMC_FREQ 0% GR3D_FREQ 28% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@33.5C BCPU@34C thermal@33.6C Tdiode@30.75C VDD_SYS_GPU 612/1249 VDD_SYS_SOC 841/883 VDD_4V0_WIFI 0/24 VDD_IN 5017/5915 VDD_SYS_CPU 1607/1500 VDD_SYS_DDR 1294/1553
RAM 5966/7860MB (lfb 133x4MB) CPU [15%@2035,35%@2035,44%@2035,13%@2035,18%@2035,16%@2035] EMC_FREQ 0% GR3D_FREQ 26% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@34C BCPU@34C thermal@33.8C Tdiode@31.5C VDD_SYS_GPU 1606/1249 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6317/5915 VDD_SYS_CPU 1683/1500 VDD_SYS_DDR 1656/1553
RAM 5966/7860MB (lfb 113x4MB) CPU [27%@2035,36%@2035,32%@2035,17%@2035,16%@2035,15%@2035] EMC_FREQ 0% GR3D_FREQ 25% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@34C BCPU@34C thermal@33.8C Tdiode@31.75C VDD_SYS_GPU 1683/1250 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6585/5916 VDD_SYS_CPU 1606/1500 VDD_SYS_DDR 1694/1553
RAM 5969/7860MB (lfb 113x4MB) CPU [14%@2035,40%@2035,38%@2035,17%@2035,19%@2035,16%@2035] EMC_FREQ 0% GR3D_FREQ 26% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1683/1250 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6662/5917 VDD_SYS_CPU 1606/1500 VDD_SYS_DDR 1656/1553
RAM 5967/7860MB (lfb 133x4MB) CPU [18%@2035,34%@2035,43%@2035,16%@2035,12%@2035,16%@2035] EMC_FREQ 0% GR3D_FREQ 26% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6662/5918 VDD_SYS_CPU 1683/1501 VDD_SYS_DDR 1713/1554
RAM 6085/7860MB (lfb 108x4MB) CPU [13%@2035,40%@2035,41%@2035,19%@2035,13%@2035,14%@2035] EMC_FREQ 0% GR3D_FREQ 0% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@33.5C BCPU@34.5C thermal@34C Tdiode@31.75C VDD_SYS_GPU 1453/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 19/24 VDD_IN 6547/5918 VDD_SYS_CPU 1683/1501 VDD_SYS_DDR 1713/1554
RAM 5967/7860MB (lfb 110x4MB) CPU [21%@2035,39%@2035,40%@2035,15%@2035,18%@2035,17%@2035] EMC_FREQ 0% GR3D_FREQ 23% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@34C BCPU@34C thermal@34C Tdiode@31.75C VDD_SYS_GPU 1606/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6508/5919 VDD_SYS_CPU 1606/1501 VDD_SYS_DDR 1732/1554
RAM 5967/7860MB (lfb 129x4MB) CPU [13%@2035,48%@2035,31%@2035,17%@2035,16%@2035,14%@2035] EMC_FREQ 0% GR3D_FREQ 10% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@33.5C BCPU@34.5C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1377/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/24 VDD_IN 6470/5919 VDD_SYS_CPU 1683/1501 VDD_SYS_DDR 1694/1554
RAM 5967/7860MB (lfb 129x4MB) CPU [0%@2035,1%@2035,96%@2035,0%@2035,1%@2035,0%@2035] EMC_FREQ 0% GR3D_FREQ 0% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@33C BCPU@34C thermal@33.6C Tdiode@30.75C VDD_SYS_GPU 306/1250 VDD_SYS_SOC 765/883 VDD_4V0_WIFI 0/23 VDD_IN 4558/5918 VDD_SYS_CPU 1607/1501 VDD_SYS_DDR 1199/1554
RAM 5967/7860MB (lfb 129x4MB) CPU [22%@2035,33%@2035,42%@2035,15%@2035,16%@2035,18%@2035] EMC_FREQ 0% GR3D_FREQ 31% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@34C BCPU@34C thermal@33.6C Tdiode@31.75C VDD_SYS_GPU 1530/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/23 VDD_IN 6470/5919 VDD_SYS_CPU 1606/1501 VDD_SYS_DDR 1618/1554
RAM 5967/7860MB (lfb 110x4MB) CPU [13%@2035,36%@2035,40%@2035,16%@2035,16%@2035,13%@2035] EMC_FREQ 0% GR3D_FREQ 21% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@33.5C BCPU@34C thermal@34C Tdiode@31.75C VDD_SYS_GPU 1377/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 0/23 VDD_IN 6394/5919 VDD_SYS_CPU 1683/1502 VDD_SYS_DDR 1675/1554
RAM 5967/7860MB (lfb 110x4MB) CPU [19%@2035,32%@2035,39%@2035,18%@2035,19%@2035,20%@2035] EMC_FREQ 0% GR3D_FREQ 21% PLL@34C MCPU@34C PMIC@100C Tboard@30C GPU@34C BCPU@34C thermal@34.3C Tdiode@31.75C VDD_SYS_GPU 1606/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 19/23 VDD_IN 6585/5920 VDD_SYS_CPU 1606/1502 VDD_SYS_DDR 1713/1554
RAM 5967/7860MB (lfb 129x4MB) CPU [15%@2035,43%@2035,33%@2035,15%@2035,14%@2035,18%@2035] EMC_FREQ 0% GR3D_FREQ 25% PLL@34.5C MCPU@34.5C PMIC@100C Tboard@30C GPU@34C BCPU@34.5C thermal@34C Tdiode@31.75C VDD_SYS_GPU 1453/1251 VDD_SYS_SOC 918/883 VDD_4V0_WIFI 19/23 VDD_IN 6470/5920 VDD_SYS_CPU 1606/1502 VDD_SYS_DDR 1713/1554
ergouu,
What is “jetson_clocks.service”?
Hi, WayneWWW, Thanks for your reply.
It seems to be part of the ZED driver process which I have installed. So I try to execute it, and find that it is the same as “/usr/bin/jetson_clocks”, I have checked it ,it is not a link file. Do you have any suggestion?
ad@ad-desktop:~$ <b>service jetson_clocks status</b>
● jetson_clocks.service - Jetson Clocks
   Loaded: loaded (/etc/systemd/system/jetson_clocks.service; enabled; vendor pr
   Active: activating (auto-restart) since Tue 2019-06-11 14:57:44 CST; 31s ago
  Process: 9062 ExecStart=/usr/local/zed/tools/jetson_clocks (code=exited, statu
 Main PID: 9062 (code=exited, status=0/SUCCESS)
ad@ad-desktop:~$ <b>/usr/local/zed/tools/jetson_clocks -h</b>
Maximize jetson performance by setting static max frequency to CPU, GPU and EMC clocks.
Usage:
jetson_clocks.sh [options]
  options,
  --show             display current settings
  --store [file]     store current settings to a file (default: ${HOME}/l4t_dfs.conf)
  --restore [file]   restore saved settings from a file (default: ${HOME}/l4t_dfs.conf)
  run jetson_clocks.sh without any option to set static max frequency to CPU, GPU and EMC clocks.
ad@ad-desktop:~$ <b>/usr/local/zed/tools/jetson_clocks --show</b>
SOC family:tegra186  Machine:quill
Error: Run this script(/usr/local/zed/tools/jetson_clocks) as a root user
ad@ad-desktop:~$ <b>sudo /usr/local/zed/tools/jetson_clocks --show</b>
[sudo] password for ad:
Online CPUs: 0-5
CPU Cluster Switching: Disabled
cpu0: Online=1 Governor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200 IdleStates: C1=0 c7=0
cpu1: Online=1 Governor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200 IdleStates: C1=0 c6=0 c7=0
cpu2: Online=1 Governor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200 IdleStates: C1=0 c6=0 c7=0
cpu3: Online=1 Governor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200 IdleStates: C1=0 c7=0
cpu4: Online=1 Governor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200 IdleStates: C1=0 c7=0
cpu5: Online=1 Governor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200 IdleStates: C1=0 c7=0
GPU MinFreq=1300500000 MaxFreq=1300500000 CurrentFreq=1300500000
EMC MinFreq=40800000 MaxFreq=1866000000 CurrentFreq=1866000000 FreqOverride=1
Fan: speed=255
NV Power Mode: MAXN
ad@ad-desktop:~$ <b>which jetson_clocks </b>
Jeston clocks is a binary file that could pull cpu/gpu/emc frequency to maximum and also disable the power saving features.
You only need to set jetson_clock once in the beginning when system boots up.
I don’t think it is a good behavior to keep setting the the jetson clock while your application is running. According to your log, the system also shuts down when the service is again running.
I think you need to find out why does this service keeps running.
OK, I get it . I have already stoped the service by executing “service jetson_clocks stop” ,then I checked the syslog and there is no such logs any more. Finally, execute “systemctl disable jetson_clocks.service” to prevent it from startup when system boots up .
Hope it works.
But I don’t know why this application keep setting the jetson clock, I think it is just a driver for ZED camera, and I download it from its official website https://download.stereolabs.com/zedsdk/2.8/jetson_jp42 and its plug for ROS GitHub - stereolabs/zed-ros-wrapper: ROS wrapper for the ZED SDK
Thanks for your advice, WayneWWW.
It doesn’t work I think, because the TX2 just shut down automatically a moment ago.
And one more thing is the FAN doesn’t spin ,the temerature of the CPU/GPU is 40C, is it normal?
I look up the DG document, the default threshold is 51C. So it’s normal.
Here is the syslog when the system crashed:
Jun 11 18:10:57 ad-desktop kernel: [12332.040063] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jun 11 18:10:57 ad-desktop kernel: [12332.040154] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jun 11 18:10:57 ad-desktop kernel: [12332.040234] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
Jun 11 18:10:57 ad-desktop kernel: [12332.041503] Parent Clock set for DC plld2
Jun 11 18:10:57 ad-desktop kernel: [12332.044707] tegradc 15210000.nvdisplay: hdmi: tmds rate:108000K prod-setting:prod_c_hdmi_54m_111m
Jun 11 18:10:57 ad-desktop kernel: [12332.045952] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
Jun 11 18:10:57 ad-desktop kernel: [12332.045958] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
Jun 11 18:10:57 ad-desktop kernel: [12332.051298] extcon-disp-state external-connection:disp-state: cable 47 state 1
Jun 11 18:10:57 ad-desktop kernel: [12332.051300] Extcon AUX1(HDMI) enable
Jun 11 18:10:57 ad-desktop /usr/lib/gdm3/gdm-x-session[7495]: (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1280x1024 +0+0 {ViewPortIn=1280x1024, ViewPortOut=1280x1024+0+0}"
Jun 11 18:10:57 ad-desktop kernel: [12332.064567] tegradc 15210000.nvdisplay: unblank
Jun 11 18:11:13 ad-desktop NetworkManager[5005]: <info>  [1560247873.0423] connectivity: (l4tbr0) timed out
Jun 11 18:12:17 ad-desktop unity-panel-ser[7980]: menus_destroyed: assertion 'IS_WINDOW_MENU(wm)' failed
Jun 11 18:12:17 ad-desktop compiz[7972]: WARN  2019-06-11 18:12:17 unity.glib.dbus.proxy GLibDBusProxy.cpp:487 Calling method "EmitEvent" on object path: "/com/ubuntu/Upstart" failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name com.canonical.Unity.Test.Upstart was not provided by any .service files
Jun 11 18:12:17 ad-desktop systemd[7470]: Stopped target A target that, when running, represents the screen being locked.
Jun 11 18:12:17 ad-desktop systemd[7470]: Stopping Backing Service for the Unity Panel in Lockscreen mode...
Jun 11 18:12:18 ad-desktop systemd[7470]: Stopped Backing Service for the Unity Panel in Lockscreen mode.
Jun 11 18:12:30 ad-desktop kernel: [12424.834750] ifidx:0 DHCP - REQUEST [TX]
Jun 11 18:12:30 ad-desktop dhclient[6586]: DHCPREQUEST of 10.180.101.232 on wlan0 to 10.180.96.1 port 67 (xid=0x2ed091e2)
Jun 11 18:12:30 ad-desktop dhclient[6586]: DHCPACK of 10.180.101.232 from 10.180.96.1
Jun 11 18:12:30 ad-desktop kernel: [12424.849959] ifidx:0 DHCP - ACK [RX]
Jun 11 18:12:30 ad-desktop NetworkManager[5005]: <info>  [1560247950.4949] dhcp4 (wlan0):   address 10.180.101.232
Jun 11 18:12:30 ad-desktop NetworkManager[5005]: <info>  [1560247950.4950] dhcp4 (wlan0):   plen 20 (255.255.240.0)
Jun 11 18:12:30 ad-desktop NetworkManager[5005]: <info>  [1560247950.4950] dhcp4 (wlan0):   gateway 10.180.96.1
Jun 11 18:12:30 ad-desktop NetworkManager[5005]: <info>  [1560247950.4950] dhcp4 (wlan0):   lease time 3600
Jun 11 18:12:30 ad-desktop NetworkManager[5005]: <info>  [1560247950.4951] dhcp4 (wlan0):   nameserver '10.10.0.21'
Jun 11 18:12:30 ad-desktop NetworkManager[5005]: <info>  [1560247950.4951] dhcp4 (wlan0): state changed bound -> bound
Jun 11 18:12:30 ad-desktop dbus-daemon[4926]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.9' (uid=0 pid=5005 comm="/usr/sbin/NetworkManager --no-daemon ")
Jun 11 18:12:30 ad-desktop dhclient[6586]: bound to 10.180.101.232 -- renewal in 1366 seconds.
Jun 11 18:12:30 ad-desktop systemd[1]: Starting Network Manager Script Dispatcher Service...
Jun 11 18:12:30 ad-desktop dbus-daemon[4926]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 11 18:12:30 ad-desktop systemd[1]: Started Network Manager Script Dispatcher Service.
Jun 11 18:12:30 ad-desktop nm-dispatcher: req:1 'dhcp4-change' [wlan0]: new request (1 scripts)
Jun 11 18:12:30 ad-desktop nm-dispatcher: req:1 'dhcp4-change' [wlan0]: start running ordered scripts...
Jun 11 18:16:13 ad-desktop NetworkManager[5005]: <info>  [1560248173.0433] connectivity: (l4tbr0) timed out
Jun 11 18:17:01 ad-desktop CRON[9328]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 11 18:17:16 ad-desktop gnome-session[7801]: gnome-session-binary[7801]: WARNING: Could not get session path for session. Check that logind is properly installed and pam_systemd is getting used at login.
Jun 11 18:17:16 ad-desktop gnome-session-binary[7801]: WARNING: Could not get session path for session. Check that logind is properly installed and pam_systemd is getting used at login.
Jun 11 18:17:27 ad-desktop kernel: [12721.334270] tegradc 15210000.nvdisplay: blank - powerdown
Jun 11 18:17:27 ad-desktop kernel: [12721.385342] extcon-disp-state external-connection:disp-state: cable 47 state 0
Jun 11 18:17:27 ad-desktop kernel: [12721.385344] Extcon AUX1(HDMI) disable
Jun 11 18:17:27 ad-desktop kernel: [12721.407183] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
Jun 11 18:17:27 ad-desktop kernel: [12721.407257] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Jun 11 18:17:27 ad-desktop kernel: [12721.407738] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
Jun 11 18:17:27 ad-desktop unity-settings-[7743]: failed to turn the kbd backlight off: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.UPower.KbdBacklight' on object at path /org/freedesktop/UPower/KbdBacklight
Jun 11 18:17:27 ad-desktop gnome-session[7801]: gnome-session-binary[7801]: WARNING: Could not get session path for session. Check that logind is properly installed and pam_systemd is getting used at login.
Jun 11 18:17:27 ad-desktop gnome-session-binary[7801]: WARNING: Could not get session path for session. Check that logind is properly installed and pam_systemd is getting used at login.
Jun 11 18:17:27 ad-desktop unity-panel-ser[7980]: menus_destroyed: assertion 'IS_WINDOW_MENU(wm)' failed
Jun 11 18:17:27 ad-desktop compiz[7972]: WARN  2019-06-11 18:17:27 unity.glib.dbus.proxy GLibDBusProxy.cpp:487 Calling method "EmitEvent" on object path: "/com/ubuntu/Upstart" failed: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name com.canonical.Unity.Test.Upstart was not provided by any .service files
Jun 11 18:17:27 ad-desktop systemd[7470]: Starting Backing Service for the Unity Panel in Lockscreen mode...
Jun 11 18:17:27 ad-desktop systemd[7470]: Started Backing Service for the Unity Panel in Lockscreen mode.
Jun 11 18:17:27 ad-desktop systemd[7470]: Reached target A target that, when running, represents the screen being locked.
Jun 11 18:20:57 ad-desktop kernel: [12931.675712] ifidx:262 DHCP - 0x0 [RX]
Jun 11 18:21:13 ad-desktop NetworkManager[5005]: <info>  [1560248473.0433] connectivity: (l4tbr0) timed out
Jun 11 18:26:13 ad-desktop NetworkManager[5005]: <info>  [1560248773.0430] connectivity: (l4tbr0) timed out
Jun 11 18:31:13 ad-desktop NetworkManager[5005]: <info>  [1560249073.0428] connectivity: (l4tbr0) timed out
Jun 11 18:35:16 ad-desktop kernel: [13790.802616] ifidx:0 DHCP - REQUEST [TX]
Jun 11 18:35:16 ad-desktop dhclient[6586]: DHCPREQUEST of 10.180.101.232 on wlan0 to 10.180.96.1 port 67 (xid=0x2ed091e2)
Jun 11 18:35:16 ad-desktop dhclient[6586]: DHCPACK of 10.180.101.232 from 10.180.96.1
Jun 11 18:35:16 ad-desktop kernel: [13790.817820] ifidx:0 DHCP - ACK [RX]
Jun 11 18:35:16 ad-desktop NetworkManager[5005]: <info>  [1560249316.4938] dhcp4 (wlan0):   address 10.180.101.232
Jun 11 18:35:16 ad-desktop NetworkManager[5005]: <info>  [1560249316.4939] dhcp4 (wlan0):   plen 20 (255.255.240.0)
Jun 11 18:35:16 ad-desktop NetworkManager[5005]: <info>  [1560249316.4940] dhcp4 (wlan0):   gateway 10.180.96.1
Jun 11 18:35:16 ad-desktop NetworkManager[5005]: <info>  [1560249316.4940] dhcp4 (wlan0):   lease time 3600
Jun 11 18:35:16 ad-desktop NetworkManager[5005]: <info>  [1560249316.4941] dhcp4 (wlan0):   nameserver '10.10.0.21'
Jun 11 18:35:16 ad-desktop NetworkManager[5005]: <info>  [1560249316.4941] dhcp4 (wlan0): state changed bound -> bound
Jun 11 18:35:16 ad-desktop dbus-daemon[4926]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.9' (uid=0 pid=5005 comm="/usr/sbin/NetworkManager --no-daemon ")
Jun 11 18:35:16 ad-desktop systemd[1]: Starting Network Manager Script Dispatcher Service...
Jun 11 18:35:16 ad-desktop dhclient[6586]: bound to 10.180.101.232 -- renewal in 1496 seconds.
Jun 11 18:35:16 ad-desktop dbus-daemon[4926]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 11 18:35:16 ad-desktop systemd[1]: Started Network Manager Script Dispatcher Service.
Jun 11 18:35:16 ad-desktop nm-dispatcher: req:1 'dhcp4-change' [wlan0]: new request (1 scripts)
Jun 11 18:35:16 ad-desktop nm-dispatcher: req:1 'dhcp4-change' [wlan0]: start running ordered scripts...
Jun 11 18:36:13 ad-desktop NetworkManager[5005]: <info>  [1560249373.0423] connectivity: (l4tbr0) timed out
Jun 11 18:36:30 ad-desktop kernel: [13865.035284] ifidx:262 DHCP - 0x0 [RX]
Jun 11 18:41:13 ad-desktop NetworkManager[5005]: <info>  [1560249673.0432] connectivity: (l4tbr0) timed out
Jun 11 18:46:13 ad-desktop NetworkManager[5005]: <info>  [1560249973.0429] connectivity: (l4tbr0) timed out
Jun 11 18:51:13 ad-desktop NetworkManager[5005]: <info>  [1560250273.0424] connectivity: (l4tbr0) timed out
Jun 11 18:54:30 ad-desktop kernel: [14945.113056] ifidx:262 DHCP - 0x0 [RX]
Jun 11 18:55:17 ad-desktop kernel: [14992.109588] ifidx:262 DHCP - 0x0 [RX]
Jun 11 18:55:48 ad-desktop kernel: [15023.057132] ifidx:262 DHCP - 0x0 [RX]
Jun 11 18:56:13 ad-desktop NetworkManager[5005]: <info>  [1560250573.0427] connectivity: (l4tbr0) timed out
Jun 11 18:57:01 ad-desktop kernel: [15095.433240] ifidx:262 DHCP - 0x0 [RX]
Jun 11 18:57:40 ad-desktop kernel: [15135.059979] ifidx:0 DHCP - OFFER [RX]
Jun 11 18:57:40 ad-desktop kernel: [15135.060070] ifidx:0 DHCP - OFFER [RX] <b><<<<----system crashed</b>
Jun 11 19:10:44 ad-desktop systemd-modules-load[2244]: Inserted module 'bluedroid_pm'
Jun 11 19:10:44 ad-desktop systemd-modules-load[2244]: Module 'nvhost_vi' is builtin
Jun 11 19:10:44 ad-desktop systemd-modules-load[2244]: Inserted module 'nvgpu'
Jun 11 19:10:44 ad-desktop systemd[1]: Mounted Huge Pages File System.
Jun 11 19:10:44 ad-desktop systemd[1]: Started LVM2 metadata daemon.
Jun 11 19:10:44 ad-desktop systemd[1]: Starting Apply Kernel Variables...
Jun 11 19:10:44 ad-desktop systemd[1]: Mounting Kernel Configuration File System...
Jun 11 19:10:44 ad-desktop systemd[1]: Starting Create Static Device Nodes in /dev...
Jun 11 19:10:44 ad-desktop systemd-sysctl[2952]: Couldn't write '1' to 'net/ipv4/tcp_syncookies', ignoring: No such file or directory
Jun 11 19:10:44 ad-desktop systemd-sysctl[2952]: Couldn't write '1' to 'kernel/yama/ptrace_scope', ignoring: No such file or directory
Jun 11 19:10:44 ad-desktop systemd-sysctl[2952]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory
Jun 11 19:10:44 ad-desktop systemd[1]: Starting Load/Save Random Seed...
Jun 11 19:10:44 ad-desktop systemd[1]: Starting Flush Journal to Persistent Storage...
Jun 11 19:10:44 ad-desktop systemd[1]: Started Apply Kernel Variables.
Jun 11 19:10:44 ad-desktop systemd[1]: Mounted Kernel Configuration File System.
Jun 11 19:10:44 ad-desktop systemd[1]: Started Load/Save Random Seed.
Jun 11 19:10:44 ad-desktop systemd[1]: Started Create Static Device Nodes in /dev.
Jun 11 19:10:44 ad-desktop systemd[1]: Starting udev Kernel Device Manager...
Jun 11 19:10:44 ad-desktop systemd[1]: Started Flush Journal to Persistent Storage.
Jun 11 19:10:44 ad-desktop systemd-udevd[3026]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Jun 11 19:10:44 ad-desktop systemd[1]: Started udev Kernel Device Manager.
Jun 11 19:10:44 ad-desktop systemd[1]: Started udev Coldplug all Devices.
Jun 11 19:10:44 ad-desktop systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 11 19:10:44 ad-desktop systemd[1]: Reached target Local Encrypted Volumes.
Jun 11 19:10:44 ad-desktop systemd-udevd[3051]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 11 19:10:44 ad-desktop systemd[1]: Found device /dev/ttyS0.
Jun 11 19:10:44 ad-desktop systemd[1]: Reached target Sound Card.
Jun 11 19:10:44 ad-desktop systemd[1]: Created slice system-lvm2\x2dpvscan.slice.
Jun 11 19:10:44 ad-desktop systemd[1]: Starting LVM2 PV scan on device 8:0...
Jun 11 19:10:44 ad-desktop systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 11 19:10:44 ad-desktop systemd[1]: Starting Load/Save RF Kill Switch Status...
Jun 11 19:10:44 ad-desktop lvm[4058]:   WARNING: lvmetad is being updated, retrying (setup) for 10 more seconds.
Jun 11 19:10:44 ad-desktop systemd-udevd[3061]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 11 19:10:44 ad-desktop systemd-udevd[3061]: Could not generate persistent MAC address for dummy0: No such file or directory
Jun 11 19:10:44 ad-desktop systemd-udevd[3065]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 11 19:10:44 ad-desktop systemd[1]: Started Load/Save RF Kill Switch Status.
Jun 11 19:10:44 ad-desktop lvm[2290]:   /dev/mmcblk0rpmb: read failed after 0 of 4096 at 0: Input/output error
Jun 11 19:10:44 ad-desktop lvm[2290]:   /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4128768: Input/output error
Jun 11 19:10:44 ad-desktop lvm[2290]:   /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4186112: Input/output error
Jun 11 19:10:44 ad-desktop lvm[2290]:   /dev/mmcblk0rpmb: read failed after 0 of 4096 at 4096: Input/output error
Jun 11 19:10:44 ad-desktop systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Jun 11 19:10:44 ad-desktop systemd-udevd[3047]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jun 11 19:10:44 ad-desktop systemd[1]: Reached target Local File Systems (Pre).
Jun 11 19:10:44 ad-desktop lvm[4058]:   1 logical volume(s) in volume group "racecar_vg" now active
The TX2 auto shutdown several times after stop the jetson_clocks.service.
Notice two things:
  • Once the TX2 shutdown automatically I never boots up the system successfully without disconnecting the power supply though the CR5 LED is on.
  • If I didn't unplug the power cable from power jack immediately ,I must disconnect power firstly and have to wait a few minutes before reconnect it to boots it up ,or nothing happens while pressing the power button
  • And this morning ,after a few minutes running, it suddenly appears information on the screen like this and shutdown automatically in seconds
    Have anyone meet the same problem?
    I think Zed might maximize clocks because it is sensitive to USB3 not providing all of the bandwidth the camera needs.
    I see as soon as LVM2 kicks in (which default installs don’t use) the filesystem becomes unreadable. The interesting thing is that sysctl echoes to to “/proc/sys/” also fails (and “/proc” is a driver interface without real files, so it should be immune to eMMC issues):
    Jun 10 08:28:24 ad-desktop systemd-sysctl[2963]: Couldn't write '1' to 'net/ipv4/tcp_syncookies', ignoring: No such file or directory
    Jun 10 08:28:24 ad-desktop systemd-sysctl[2963]: Couldn't write '1' to 'kernel/yama/ptrace_scope', ignoring: No such file or directory
    Jun 10 08:28:24 ad-desktop systemd-sysctl[2963]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory
    Is this a stock kernel, or was it modified? What is the output from:
    uname -a
    head -n 1 /etc/nv_tegra_release
    …sorry, I know this won’t work if you can’t boot far enough, but I’m hoping serial console will have part of that.
    I guess it may be the jetson_clocks.service that cause the system crash. And the crash or something else damaged some sensitive parts. Though, I stop the service after that crash, tx2 has already been damaged and began to auto shutdown again and again.
    I don’t think it is an occurrence. It happens twice in succession.
    And in the pic I post , this info also said tx2 has some hw problems.
    vdd-1v8: voltage operation not allowed
    sdhci-tegra 3440000.sdhci:could not set regulator OCR (-1)
    LVM2 is not default installed in jp4.2, I use apt-get to install it.
    I didn’t modify the kernel, it is original.
    Here is the result.
    ad@ad-desktop:~$ uname -a
    Linux ad-desktop 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:30:11 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
    ad@ad-desktop:~$ head -n 1 /etc/nv_tegra_release
    # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64, DATE: Wed Mar 13 07:41:08 UTC 2019
    I use LVM on the external ssd disk. Actually, every time it shutdown automatically, the data of the running process in system is damaged, which means the data in the memory has not written into the disk yet.
    I can’t put my finger right on the cause, but it is obvious the filesystem is not responding. There is a very high chance this is related to the LVM2, and for testing purposes you might consider disconnecting the external disk. Overall you are losing the ability to read or write to all filesystems…not just eMMC, but also pseudo filesystems.
    I could see the possibility that something is going on with the hardware such that it is being driven to a point of high temperature, and then fails under higher temperature, but this only seems low probability.
    I have done RMA today, so I can’t do that test now. But, I still want to find out what happened.
    Why does sysctl tried to write these files every beginning of boot before the Kernel Module been loaded?
    I think because this action is before the Kernel was loaded, these file doesn’t exist at that time instead of the filesystem’s problem.
    And if the LVM2 caused the overall filesystem unreachable at the beginning of the boot, I think it is not possible to boots up the OS successfully.
    I have done that before. I removed all the external devices including the ssd disk and umounted all the lvs & vgs to observe weather tx2 would shutdown automatically again .And it does.
    According to the tegrastat log, the temperature of the sensors are below 35C when the system crashed, not too high. Why did you think so?
    Some kernel parameters are intentionally exposed for setup as the system boots. This is the “sysctl” setup. It allows fine tuning things like network setup without hard coding for a specific setup. The content of “/etc/sysctl.conf” is for example a way to echo into that content. Some of the prefix directories are left out of the syntax in the file, but refers to “/proc/sys” prefix. “tcp_syncookies” is one example for protection against TCP SYN flood attacks.
    The important thing is that the files in “/proc” are pseudo files, which live in RAM, and are a result of kernel drivers…these are not real files. Now if the eMMC failed to respond, then I would still expect pseudo files to work if it was just a hardware failure (an exception would be if drivers had to be loaded from disk to work, and the disk was not accessible…often this is taken care of via an initrd…a mini minimal initial filesystem with the right drivers so U-Boot itself doesn’t need to read the actual device…the initrd is just a compressed tarball loaded to RAM without needing to understand LVM2). This isn’t the case though, so I suspect it is a software failure. LVM2 could in fact have been added such that it interferes with hardware drivers, and this in turn could cause both pseudo file access and eMMC access to both fail.
    LVM2 by itself should not cause such a failure, but if you use LVM2 as the rootfs, then U-Boot cannot understand this and this would be a cause of failure. Before U-Boot (or any bootloader) can hand off to the Linux kernel it has to find the rootfs…U-Boot presumably does not have LVM2 drivers or any means to understand this. The combination of GRUB and BIOS/UEFI on a desktop PC offers quite a bit more in terms of universal understanding of various devices than does U-Boot, but even on a desktop PC not all distributions support “/boot” or “/” on LVM2.
    Overall I am thinking that how LVM2 was used would need to be investigated to actually point out the issue, and LVM2 is high on the list of “probably the cause”, but that’s just guessing without something to test.
    I didn’t use LVM device as the rootfs.
    After I got tx2, I flashed the tx2 OS on the eMMC with JP4.2, then I reboot it to connect the SSD disk with SATA cables. And I use “vgscan” and "vgchange -ay " to activate the file system in the SSD disk , and then activate the lvs on the vg, and never put all those raw device(like mmcblk0*) into the LVM management.
    LVM is not used as overall block device management software. I used LVM because the external disk was formatted by it and I don’t want to loss the data in it .
    I think it is little bit early to file a RMA. You could still flash your board with pure jetpack and see if it would have this auto power off issue. If it still shuts down, then it is a hardware issue.
    If it is not, I would guess the 3rdparty driver causing the trouble.
    Also, these two are not error message.
    Actually, I tried to flash tx2 again and it auto shutdown in Force Recovery Mode. The flashing process was interrupted, so I do RMA, and it is already on the way.
    Thanks for checking. If there would be new TX2, please do remove the Jetson_Clocks.service from systemd first. Currently, there are still not enough clues to narrow down the root cause.
    Hi WayneWWW, I have stoped that service already, and it doesn’t work.
