Dp lt randomly fails with kernel panic
Hallo,
I have a jetson xavier nx connected to an edp display. Most of the time this display works as expected, but sometimes during boot the dp lt fails (about 1 in 30 boots).
On a failed boot the kernel panic with the following message:
[2025-07-17 18:22:28] [    5.633218] ------------[ cut here ]------------
[2025-07-17 18:22:28] [    5.633235] kernel BUG at kernel/nvidia/drivers/video/tegra/dc/dp_lt.c:407!
[2025-07-17 18:22:28] [    5.633242] Internal error: Oops - BUG: 00000000f2000800 [#1] PREEMPT SMP
[2025-07-17 18:22:28] [    5.633252] Modules linked in:
[2025-07-17 18:22:28] [    5.633267] CPU: 0 PID: 178 Comm: kworker/0:5 Not tainted 5.10.216-rlmsf56873ad02a3 #1
[2025-07-17 18:22:28] [    5.633270] Hardware name: NVIDIA NVIDIA Jetson Xavier NX Developer Kit/Jetson, BIOS 202210.5.1-Unknown 07/14/2025
[2025-07-17 18:22:28] [    5.633285] Workqueue: events lt_worker
[2025-07-17 18:22:28] [    5.633297] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[2025-07-17 18:22:28] [    5.633303] pc : fast_lt_state+0x128/0x130
[2025-07-17 18:22:28] [    5.633306] lr : fast_lt_state+0x6c/0x130
[2025-07-17 18:22:28] [    5.633309] sp : ffff8000129cbd50
[2025-07-17 18:22:28] [    5.633316] x29: ffff8000129cbd50 x28: 0000000000000000
[2025-07-17 18:22:28] [    5.633328] x27: ffff4358c0f1ed48 x26: ffffb7f82d3c5b30
[2025-07-17 18:22:28] [    5.633335] x25: 0000000000000000 x24: ffff4358c521f1f0
[2025-07-17 18:22:28] [    5.633340] x23: 0000000000000000 x22: 0000000000000000
[2025-07-17 18:22:28] [    5.633346] x21: ffff4358c521f1c8 x20: ffff4358c35e9480
[2025-07-17 18:22:28] [    5.633351] x19: ffff4358c521f1b0 x18: ffffffffffffffff
[2025-07-17 18:22:28] [    5.633357] x17: 0000000000000000 x16: 00000000c16aca51
[2025-07-17 18:22:28] [    5.633362] x15: ffffb7f82cb84af8 x14: ffffb7f82d3cade8
[2025-07-17 18:22:28] [    5.633368] x13: ffffb7f82d3caa1c x12: 0720072007200720
[2025-07-17 18:22:28] [    5.633373] x11: 0000000000000040 x10: 0000000000000ab0
[2025-07-17 18:22:28] [    5.633380] x9 : ffff8000129cbb40 x8 : ffff4358c5497090
[2025-07-17 18:22:28] [    5.633386] x7 : 0000000000000000 x6 : 0000000000000003
[2025-07-17 18:22:28] [    5.633391] x5 : 0000000000000000 x4 : 0000000000000000
[2025-07-17 18:22:28] [    5.633397] x3 : 0000000000000100 x2 : 404ee30fe0f1f300
[2025-07-17 18:22:28] [    5.633403] x1 : 404ee30fe0f1f300 x0 : 0000000000000000
[2025-07-17 18:22:28] [    5.633427] Call trace:
[2025-07-17 18:22:28] [    5.633432]  fast_lt_state+0x128/0x130
[2025-07-17 18:22:28] [    5.633436]  lt_worker+0x84/0xf0
[2025-07-17 18:22:28] [    5.633443]  process_one_work+0x1f0/0x4f0
[2025-07-17 18:22:28] [    5.633446]  worker_thread+0x48/0x4a0
[2025-07-17 18:22:28] [    5.633451]  kthread+0x158/0x160
[2025-07-17 18:22:28] [    5.633456]  ret_from_fork+0x10/0x1c
[2025-07-17 18:22:28] [    5.633464] Code: d4210000 d4210000 d4210000 17ffffc7 (d4210000)
[2025-07-17 18:22:28] [    5.633473] ---[ end trace 95030f7944b5f061 ]---
[2025-07-17 18:22:28] [    5.633476] Kernel panic - not syncing: Oops - BUG: Fatal exception
[2025-07-17 18:22:28] [    5.633480] SMP: stopping secondary CPUs
[2025-07-17 18:22:28] [    5.633515] Kernel Offset: 0x37f81b380000 from 0xffff800010000000
[2025-07-17 18:22:28] [    5.633517] PHYS_OFFSET: 0xffffbca840000000
[2025-07-17 18:22:28] [    5.633520] CPU features: 0x48240002,03802a30
[2025-07-17 18:22:28] [    5.633522] Memory Limit: none
[2025-07-17 18:22:28] [    5.890804] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception ]---
I use the Jetpack 5.1.5 (L4T 35.6.1, Kernel 5.10).
Do you have any suggestions thow o debug this error, or is it possible to set the dp lt parameters in the devicetree?
The full boot log:
[2025-07-17 18:22:23] [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[2025-07-17 18:22:23] [    0.000000] Linux version 5.10.216-rlmsf56873ad02a3 (root@eros) (aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.05) 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701], GNU ld (Linaro_Binutils-2018.05) 2.28.2.20170706) #1 SMP PREEMPT Mon Jul 14 15:10:51 CEST 2025
[2025-07-17 18:22:23] [    0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[2025-07-17 18:22:23] [    0.000000] efi: EFI v2.70 by EDK II
[2025-07-17 18:22:23] [    0.000000] efi: RTPROP=0x278b4bf98 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x27cb40000 MEMATTR=0x278362018 ESRT=0x277ea8818 RNG=0x26ac70018 MEMRESERVE=0x26b62bf18
[2025-07-17 18:22:23] [    0.000000] random: crng init done
[2025-07-17 18:22:23] [    0.000000] esrt: Reserving ESRT space from 0x0000000277ea8818 to 0x0000000277ea8850.
[2025-07-17 18:22:23] [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[2025-07-17 18:22:23] [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[2025-07-17 18:22:23] [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[2025-07-17 18:22:23] [    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[2025-07-17 18:22:23] [    0.000000] Zone ranges:
[2025-07-17 18:22:23] [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[2025-07-17 18:22:23] [    0.000000]   DMA32    empty
[2025-07-17 18:22:23] [    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[2025-07-17 18:22:23] [    0.000000] Movable zone start for each node
[2025-07-17 18:22:23] [    0.000000] Early memory node ranges
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x0000000080000000-0x00000000aeffffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c79fffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x0000000100000000-0x000000026d7ebfff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x000000026d7ec000-0x000000026dcdbfff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x000000026dcdc000-0x000000027b1bffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x000000027b1c0000-0x000000027d0fffff]
[2025-07-17 18:22:23] [    0.000000]   node   0: [mem 0x000000027d100000-0x000000027fffffff]
[2025-07-17 18:22:23] [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[2025-07-17 18:22:23] [    0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[2025-07-17 18:22:23] [    0.000000] psci: probing for conduit method from DT.
[2025-07-17 18:22:23] [    0.000000] psci: PSCIv1.1 detected in firmware.
[2025-07-17 18:22:23] [    0.000000] psci: Using standard PSCI v0.2 function IDs
[2025-07-17 18:22:23] [    0.000000] psci: Trusted OS migration not required
[2025-07-17 18:22:23] [    0.000000] psci: SMC Calling Convention v1.2
[2025-07-17 18:22:23] [    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[2025-07-17 18:22:23] [    0.000000] Detected PIPT I-cache on CPU0
[2025-07-17 18:22:23] [    0.000000] CPU features: detected: Virtualization Host Extensions
[2025-07-17 18:22:23] [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[2025-07-17 18:22:23] [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[2025-07-17 18:22:23] [    0.000000] CPU features: detected: Spectre-v2
[2025-07-17 18:22:23] [    0.000000] CPU features: detected: Spectre-BHB
[2025-07-17 18:22:23] [    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[2025-07-17 18:22:23] [    0.000000] alternatives: patching kernel code
[2025-07-17 18:22:23] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1839269
[2025-07-17 18:22:23] [    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0   video=efifb:off nospectre_bhb fbcon=map:1 net.ifnames=0 pcie_aspm=off coherent_pool=16M
[2025-07-17 18:22:23] [    0.000000] PCIe ASPM is disabled
[2025-07-17 18:22:23] [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[2025-07-17 18:22:23] [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[2025-07-17 18:22:23] [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[2025-07-17 18:22:23] [    0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[2025-07-17 18:22:23] [    0.000000] Memory: 6917084K/7473856K available (18368K kernel code, 3172K rwdata, 7284K rodata, 4032K init, 1422K bss, 491236K reserved, 65536K cma-reserved)
[2025-07-17 18:22:23] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[2025-07-17 18:22:23] [    0.000000] rcu: Preemptible hierarchical RCU implementation.
[2025-07-17 18:22:23] [    0.000000] rcu: 	RCU event tracing is enabled.
[2025-07-17 18:22:23] [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[2025-07-17 18:22:23] [    0.000000] 	Trampoline variant of Tasks RCU enabled.
[2025-07-17 18:22:23] [    0.000000] 	Rude variant of Tasks RCU enabled.
[2025-07-17 18:22:23] [    0.000000] 	Tracing variant of Tasks RCU enabled.
[2025-07-17 18:22:23] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[2025-07-17 18:22:23] [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[2025-07-17 18:22:23] [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[2025-07-17 18:22:23] [    0.000000] GIC: Using split EOI/Deactivate mode
[2025-07-17 18:22:23] [    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[2025-07-17 18:22:23] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[2025-07-17 18:22:23] [    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[2025-07-17 18:22:23] [    0.000716] Console: colour dummy device 80x25
[2025-07-17 18:22:23] [    0.001638] printk: console [tty0] enabled
[2025-07-17 18:22:23] [    0.001701] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[2025-07-17 18:22:23] [    0.001732] pid_max: default: 32768 minimum: 301
[2025-07-17 18:22:23] [    0.001899] LSM: Security Framework initializing
[2025-07-17 18:22:23] [    0.001995] Yama: becoming mindful.
[2025-07-17 18:22:23] [    0.002034] SELinux:  Initializing.
[2025-07-17 18:22:23] [    0.002171] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[2025-07-17 18:22:24] [    0.002204] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[2025-07-17 18:22:24] [    0.005046] rcu: Hierarchical SRCU implementation.
[2025-07-17 18:22:24] [    0.005295] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[2025-07-17 18:22:24] [    0.006220] DTS File Name: /mnt/data3/vline4/af/linux_os-testing/kernel-source/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000-nxdatarec.dts
[2025-07-17 18:22:24] [    0.006292] DTB Build time: Jul 14 2025 15:33:11
[2025-07-17 18:22:24] [    0.009474] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[2025-07-17 18:22:24] [    0.009737] Remapping and enabling EFI services.
[2025-07-17 18:22:24] [    0.011973] smp: Bringing up secondary CPUs ...
[2025-07-17 18:22:24] [    0.041196] Detected PIPT I-cache on CPU1
[2025-07-17 18:22:24] [    0.041270] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[2025-07-17 18:22:24] [    0.070604] Detected PIPT I-cache on CPU2
[2025-07-17 18:22:24] [    0.070697] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[2025-07-17 18:22:24] [    0.100168] Detected PIPT I-cache on CPU3
[2025-07-17 18:22:24] [    0.100294] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[2025-07-17 18:22:24] [    0.129749] Detected PIPT I-cache on CPU4
[2025-07-17 18:22:24] [    0.129842] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[2025-07-17 18:22:24] [    0.159293] Detected PIPT I-cache on CPU5
[2025-07-17 18:22:24] [    0.159376] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[2025-07-17 18:22:24] [    0.159756] smp: Brought up 1 node, 6 CPUs
[2025-07-17 18:22:24] [    0.159918] SMP: Total of 6 processors activated.
[2025-07-17 18:22:24] [    0.159983] CPU features: detected: Privileged Access Never
[2025-07-17 18:22:24] [    0.160011] CPU features: detected: LSE atomic instructions
[2025-07-17 18:22:24] [    0.160027] CPU features: detected: User Access Override
[2025-07-17 18:22:24] [    0.160042] CPU features: detected: 32-bit EL0 Support
[2025-07-17 18:22:24] [    0.160056] CPU features: detected: RAS Extension Support
[2025-07-17 18:22:24] [    0.160085] CPU features: detected: CRC32 instructions
[2025-07-17 18:22:24] [    0.160101] CPU features: detected: 32-bit EL1 Support
[2025-07-17 18:22:24] [    0.198144] spectre-bhb mitigation disabled by command line option
[2025-07-17 18:22:24] [    0.232647] CPU: All CPU(s) started at EL2
[2025-07-17 18:22:24] [    0.238063] devtmpfs: initialized
[2025-07-17 18:22:24] [    0.283731] KASLR enabled
[2025-07-17 18:22:24] [    0.283964] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2025-07-17 18:22:24] [    0.283991] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[2025-07-17 18:22:24] [    0.285139] pinctrl core: initialized pinctrl subsystem
[2025-07-17 18:22:24] [    0.285966] SMBIOS 3.0.0 present.
[2025-07-17 18:22:24] [    0.285989] DMI: NVIDIA NVIDIA Jetson Xavier NX Developer Kit/Jetson, BIOS 202210.5.1-Unknown 07/14/2025
[2025-07-17 18:22:24] [    0.286654] NET: Registered protocol family 16
[2025-07-17 18:22:24] [    0.289402] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[2025-07-17 18:22:24] [    0.291179] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[2025-07-17 18:22:24] [    0.292969] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[2025-07-17 18:22:24] [    0.293035] audit: initializing netlink subsys (disabled)
[2025-07-17 18:22:24] [    0.293294] audit: type=2000 audit(0.288:1): state=initialized audit_enabled=0 res=1
[2025-07-17 18:22:24] [    0.293744] thermal_sys: Registered thermal governor 'step_wise'
[2025-07-17 18:22:24] [    0.293749] thermal_sys: Registered thermal governor 'power_allocator'
[2025-07-17 18:22:24] [    0.293763] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[2025-07-17 18:22:24] [    0.297432] cpuidle: using governor menu
[2025-07-17 18:22:24] [    0.297794] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2025-07-17 18:22:24] [    0.298254] ASID allocator initialised with 32768 entries
[2025-07-17 18:22:24] [    0.298469] Serial: AMBA PL011 UART driver
[2025-07-17 18:22:24] [    0.301924] Tegra reboot handler registered.
[2025-07-17 18:22:24] [    0.361334] mc: mapped MMIO address: 0xffff800010e80000 -> 0x2c10000
[2025-07-17 18:22:24] [    0.361375] mc: mapped MMIO address: 0xffff800010ea0000 -> 0x2c20000
[2025-07-17 18:22:24] [    0.361405] mc: mapped MMIO address: 0xffff800010ec0000 -> 0x2c30000
[2025-07-17 18:22:24] [    0.361431] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c40000
[2025-07-17 18:22:24] [    0.361455] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c50000
[2025-07-17 18:22:24] [    0.361478] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2b80000
[2025-07-17 18:22:24] [    0.361501] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2b90000
[2025-07-17 18:22:24] [    0.361524] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2ba0000
[2025-07-17 18:22:24] [    0.361547] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2bb0000
[2025-07-17 18:22:24] [    0.361587] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x1700000
[2025-07-17 18:22:24] [    0.361612] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x1710000
[2025-07-17 18:22:24] [    0.361638] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x1720000
[2025-07-17 18:22:24] [    0.361663] mc: mapped MMIO address: 0xffff800011000000 -> 0x1730000
[2025-07-17 18:22:24] [    0.361686] mc: mapped MMIO address: 0xffff800011020000 -> 0x1740000
[2025-07-17 18:22:24] [    0.361708] mc: mapped MMIO address: 0xffff800011040000 -> 0x1750000
[2025-07-17 18:22:24] [    0.361731] mc: mapped MMIO address: 0xffff800011060000 -> 0x1760000
[2025-07-17 18:22:24] [    0.361767] mc: mapped MMIO address: 0xffff800011080000 -> 0x1770000
[2025-07-17 18:22:24] [    0.361859] mc-err: mcerr ops are set to t19x
[2025-07-17 18:22:24] [    0.374025] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[2025-07-17 18:22:24] [    0.374047] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[2025-07-17 18:22:24] [    0.374059] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[2025-07-17 18:22:24] [    0.374070] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[2025-07-17 18:22:24] [    0.381422] ACPI: Interpreter disabled.
[2025-07-17 18:22:24] [    0.382946] vdd-epb-1v0: supplied by vdd-3v3-cvb
[2025-07-17 18:22:24] [    0.385038] iommu: Default domain type: Translated
[2025-07-17 18:22:24] [    0.385127] eventlib_kernel: keventlib is initialized, test id: 0
[2025-07-17 18:22:24] [    0.385745] SCSI subsystem initialized
[2025-07-17 18:22:24] [    0.385985] usbcore: registered new interface driver usbfs
[2025-07-17 18:22:24] [    0.386062] usbcore: registered new interface driver hub
[2025-07-17 18:22:24] [    0.386134] usbcore: registered new device driver usb
[2025-07-17 18:22:24] [    0.386714] mc: Linux media interface: v0.10
[2025-07-17 18:22:24] [    0.386756] videodev: Linux video capture interface: v2.00
[2025-07-17 18:22:24] [    0.387179] pps_core: LinuxPPS API ver. 1 registered
[2025-07-17 18:22:24] [    0.387220] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[2025-07-17 18:22:24] [    0.387274] PTP clock support registered
[2025-07-17 18:22:24] [    0.387573] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[2025-07-17 18:22:24] [    0.388022] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[2025-07-17 18:22:24] [    0.388156] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[2025-07-17 18:22:24] [    0.388985] Registered efivars operations
[2025-07-17 18:22:24] [    0.389526] FPGA manager framework
[2025-07-17 18:22:24] [    0.389627] Advanced Linux Sound Architecture Driver Initialized.
[2025-07-17 18:22:24] [    0.390399] Bluetooth: Core ver 2.22
[2025-07-17 18:22:24] [    0.390474] NET: Registered protocol family 31
[2025-07-17 18:22:24] [    0.390491] Bluetooth: HCI device and connection manager initialized
[2025-07-17 18:22:24] [    0.390535] Bluetooth: HCI socket layer initialized
[2025-07-17 18:22:24] [    0.390553] Bluetooth: L2CAP socket layer initialized
[2025-07-17 18:22:24] [    0.390580] Bluetooth: SCO socket layer initialized
[2025-07-17 18:22:24] [    0.392229] camchar: rtcpu character device driver loaded
[2025-07-17 18:22:24] [    0.394385] clocksource: Switched to clocksource arch_sys_counter
[2025-07-17 18:22:24] [    0.672740] VFS: Disk quotas dquot_6.6.0
[2025-07-17 18:22:24] [    0.672868] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[2025-07-17 18:22:24] [    0.673462] pnp: PnP ACPI: disabled
[2025-07-17 18:22:24] [    0.684139] la/ptsa driver initialized.
[2025-07-17 18:22:24] [    0.684302] NET: Registered protocol family 2
[2025-07-17 18:22:24] [    0.684465] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[2025-07-17 18:22:24] [    0.689066] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[2025-07-17 18:22:24] [    0.689220] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[2025-07-17 18:22:24] [    0.689490] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[2025-07-17 18:22:24] [    0.689940] TCP: Hash tables configured (established 65536 bind 65536)
[2025-07-17 18:22:24] [    0.690054] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[2025-07-17 18:22:24] [    0.690145] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[2025-07-17 18:22:24] [    0.690397] NET: Registered protocol family 1
[2025-07-17 18:22:24] [    0.691251] RPC: Registered named UNIX socket transport module.
[2025-07-17 18:22:24] [    0.691278] RPC: Registered udp transport module.
[2025-07-17 18:22:24] [    0.691291] RPC: Registered tcp transport module.
[2025-07-17 18:22:24] [    0.691303] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2025-07-17 18:22:24] [    0.691325] PCI: CLS 0 bytes, default 64
[2025-07-17 18:22:24] [    0.691530] Trying to unpack rootfs image as initramfs...
[2025-07-17 18:22:24] [    1.041103] Freeing initrd memory: 9836K
[2025-07-17 18:22:24] [    1.046991] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[2025-07-17 18:22:24] [    1.047474] kvm [1]: IPA Size Limit: 40 bits
[2025-07-17 18:22:24] [    1.047928] kvm [1]: vgic interrupt IRQ9
[2025-07-17 18:22:24] [    1.048510] kvm [1]: VHE mode initialized successfully
[2025-07-17 18:22:24] [    1.050128] Initialise system trusted keyrings
[2025-07-17 18:22:24] [    1.050554] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[2025-07-17 18:22:24] [    1.057185] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2025-07-17 18:22:24] [    1.058245] NFS: Registering the id_resolver key type
[2025-07-17 18:22:24] [    1.058286] Key type id_resolver registered
[2025-07-17 18:22:24] [    1.058353] Key type id_legacy registered
[2025-07-17 18:22:24] [    1.058444] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[2025-07-17 18:22:24] [    1.058467] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[2025-07-17 18:22:24] [    1.058511] ntfs: driver 2.1.32 [Flags: R/W].
[2025-07-17 18:22:24] [    1.069052] NET: Registered protocol family 38
[2025-07-17 18:22:24] [    1.069077] Key type asymmetric registered
[2025-07-17 18:22:24] [    1.069090] Asymmetric key parser 'x509' registered
[2025-07-17 18:22:24] [    1.069143] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[2025-07-17 18:22:24] [    1.069385] io scheduler mq-deadline registered
[2025-07-17 18:22:24] [    1.069404] io scheduler kyber registered
[2025-07-17 18:22:24] [    1.080613] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:24] [    1.080697] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:24] [    1.080768] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:24] [    1.080834] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:24] [    1.080927] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:24] [    1.088137] scrncapt: init (heads:4 wins:6 planes:4)
[2025-07-17 18:22:24] [    1.088235] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[2025-07-17 18:22:24] [    1.089435] EINJ: ACPI disabled.
[2025-07-17 18:22:24] [    1.093335] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[2025-07-17 18:22:24] [    1.093359] tegra-pmc: ### PMC reset source: SYS_RESET_N
[2025-07-17 18:22:24] [    1.093372] tegra-pmc: ### PMC reset level: L0
[2025-07-17 18:22:24] [    1.093384] tegra-pmc: ### PMC reset status reg: 0x0
[2025-07-17 18:22:24] [    1.093441] tegra-pmc: PMC Prod config success
[2025-07-17 18:22:24] [    1.099287] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[2025-07-17 18:22:24] [    2.413915] printk: console [ttyTCU0] enabled
[2025-07-17 18:22:24] [    2.420170] arm-smmu 10000000.iommu: probing hardware configuration...
[2025-07-17 18:22:24] [    2.424804] arm-smmu 10000000.iommu: SMMUv2 with:
[2025-07-17 18:22:24] [    2.429339] arm-smmu 10000000.iommu: 	stage 1 translation
[2025-07-17 18:22:24] [    2.434678] arm-smmu 10000000.iommu: 	stage 2 translation
[2025-07-17 18:22:24] [    2.439931] arm-smmu 10000000.iommu: 	nested translation
[2025-07-17 18:22:24] [    2.445705] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[2025-07-17 18:22:24] [    2.452647] arm-smmu 10000000.iommu: 	64 context banks (0 stage-2 only)
[2025-07-17 18:22:24] [    2.464103] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[2025-07-17 18:22:24] [    2.465635] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[2025-07-17 18:22:24] [    2.472480] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[2025-07-17 18:22:24] [    2.480034] arm-smmu 12000000.iommu: probing hardware configuration...
[2025-07-17 18:22:24] [    2.485258] arm-smmu 12000000.iommu: SMMUv2 with:
[2025-07-17 18:22:24] [    2.489983] arm-smmu 12000000.iommu: 	stage 1 translation
[2025-07-17 18:22:24] [    2.495511] arm-smmu 12000000.iommu: 	stage 2 translation
[2025-07-17 18:22:24] [    2.500919] arm-smmu 12000000.iommu: 	nested translation
[2025-07-17 18:22:24] [    2.506620] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[2025-07-17 18:22:24] [    2.513782] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[2025-07-17 18:22:24] [    2.525075] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[2025-07-17 18:22:24] [    2.526663] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[2025-07-17 18:22:24] [    2.533473] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[2025-07-17 18:22:24] [    2.541112] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[2025-07-17 18:22:24] [    2.551075] tegra_profiler: version: 1.151, samples/io: 51/30
[2025-07-17 18:22:24] [    2.553677] tegra_profiler: auth: init
[2025-07-17 18:22:25] [    2.557952] THERMAL EST: found 3 subdevs
[2025-07-17 18:22:25] [    2.561562] THERMAL EST num_resources: 0
[2025-07-17 18:22:25] [    2.565146] [THERMAL EST subdev 0]
[2025-07-17 18:22:25] [    2.568725] [THERMAL EST subdev 1]
[2025-07-17 18:22:25] [    2.571879] [THERMAL EST subdev 2]
[2025-07-17 18:22:25] [    2.575382] THERMAL EST: Found 2 profiles, default profile is quiet
[2025-07-17 18:22:25] [    2.581562] THERMAL EST: thz register success.
[2025-07-17 18:22:25] [    2.586088] THERMAL EST: end of probe, return err: 0
[2025-07-17 18:22:25] [    2.591191] nvsciipc: loaded module
[2025-07-17 18:22:25] [    2.598784] tun: Universal TUN/TAP device driver, 1.6
[2025-07-17 18:22:25] [    2.601102] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[2025-07-17 18:22:25] [    2.607157] hns3: Copyright (c) 2017 Huawei Corporation.
[2025-07-17 18:22:25] [    2.612495] e1000e: Intel(R) PRO/1000 Network Driver
[2025-07-17 18:22:25] [    2.617380] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[2025-07-17 18:22:25] [    2.623458] igb: Intel(R) Gigabit Ethernet Network Driver
[2025-07-17 18:22:25] [    2.628754] igb: Copyright (c) 2007-2014 Intel Corporation.
[2025-07-17 18:22:25] [    2.635287] PPP generic driver version 2.4.2
[2025-07-17 18:22:25] [    2.639410] PPP BSD Compression module registered
[2025-07-17 18:22:25] [    2.643998] PPP Deflate Compression module registered
[2025-07-17 18:22:25] [    2.649240] PPP MPPE Compression module registered
[2025-07-17 18:22:25] [    2.653999] usbcore: registered new interface driver r8152
[2025-07-17 18:22:25] [    2.659503] usbcore: registered new interface driver asix
[2025-07-17 18:22:25] [    2.665095] usbcore: registered new interface driver ax88179_178a
[2025-07-17 18:22:25] [    2.671215] usbcore: registered new interface driver cdc_ether
[2025-07-17 18:22:25] [    2.676909] usbcore: registered new interface driver net1080
[2025-07-17 18:22:25] [    2.682765] usbcore: registered new interface driver cdc_subset
[2025-07-17 18:22:25] [    2.688543] usbcore: registered new interface driver zaurus
[2025-07-17 18:22:25] [    2.694282] usbcore: registered new interface driver cdc_ncm
[2025-07-17 18:22:25] [    2.699947] usbcore: registered new interface driver aqc111
[2025-07-17 18:22:25] [    2.705938] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[2025-07-17 18:22:25] [    2.711669] ohci-pci: OHCI PCI platform driver
[2025-07-17 18:22:25] [    2.716216] ohci-platform: OHCI generic platform driver
[2025-07-17 18:22:25] [    2.722024] tegra-xusb 3610000.xhci: Adding to iommu group 0
[2025-07-17 18:22:25] [    2.728388] usbcore: registered new interface driver uas
[2025-07-17 18:22:25] [    2.732520] usbcore: registered new interface driver usb-storage
[2025-07-17 18:22:25] [    2.738437] tegra-xudc 3550000.xudc: Adding to iommu group 1
[2025-07-17 18:22:25] [    2.744642] mousedev: PS/2 mouse device common for all mice
[2025-07-17 18:22:25] [    2.749648] usbcore: registered new interface driver xpad
[2025-07-17 18:22:25] [    2.757734] tegra_rtc c2a0000.rtc: registered as rtc1
[2025-07-17 18:22:25] [    2.760433] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[2025-07-17 18:22:25] [    2.767978] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[2025-07-17 18:22:25] [    2.774895] i2c /dev entries driver
[2025-07-17 18:22:25] [    2.778074] tegra-i2c 3160000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.783618] tegra-i2c c240000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.788998] tegra-i2c 3180000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.794347] tegra-i2c 3190000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.799658] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.805447] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.810843] tegra-i2c c250000.i2c: Adding to iommu group 2
[2025-07-17 18:22:25] [    2.823527] pps pps0: new PPS source ktimer
[2025-07-17 18:22:25] [    2.823677] pps pps0: ktimer PPS source registered
[2025-07-17 18:22:25] [    2.824733] pps_ldisc: PPS line discipline registered
[2025-07-17 18:22:25] [    2.831955] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[2025-07-17 18:22:25] [    2.837407] device-mapper: uevent: version 1.0.3
[2025-07-17 18:22:25] [    2.841657] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[2025-07-17 18:22:25] [    2.852358] cpuidle: Initializing cpuidle driver
[2025-07-17 18:22:25] [    2.856556] sdhci: Secure Digital Host Controller Interface driver
[2025-07-17 18:22:25] [    2.861171] sdhci: Copyright(c) Pierre Ossman
[2025-07-17 18:22:25] [    2.865619] Synopsys Designware Multimedia Card Interface Driver
[2025-07-17 18:22:25] [    2.871834] sdhci-pltfm: SDHCI platform and OF driver helper
[2025-07-17 18:22:25] [    2.877822] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[2025-07-17 18:22:25] [    2.878366] sdhci-tegra 3440000.sdhci: Adding to iommu group 4
[2025-07-17 18:22:25] [    2.878788] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[2025-07-17 18:22:25] [    2.879861] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[2025-07-17 18:22:25] [    2.896318] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[2025-07-17 18:22:25] [    2.918271] vdd-1v0: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.923838] vdd-1v8-hs: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.928694] vdd-1v8-ls: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.933603] vdd-1v8-ao: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.937554] vddio-ddr-1v1: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.942387] vdd-rtc: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.944504] spmic-ldo1: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.946048] vdd-ao-3v3: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.953618] vddio-emmc-3v3: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.960295] spmic-ldo4: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.961823] vdd-usb-3v3: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.968289] vddio-sdmmc1-3v3: supplied by regulator-dummy
[2025-07-17 18:22:25] [    2.974832] vdd-csi-1v2: supplied by vdd-1v8-ls
[2025-07-17 18:22:25] [    2.981066] spmic-ldo8: supplied by vdd-1v8-ls
[2025-07-17 18:22:25] [    2.983164] gpio-510 (gpio_default): hogged as output/high
[2025-07-17 18:22:25] [    2.985122] gpio-511 (gpio_default): hogged as output/high
[2025-07-17 18:22:25] [    2.990075] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[2025-07-17 18:22:25] [    3.129103] max77686-rtc max77620-rtc: registered as rtc0
[2025-07-17 18:22:25] [    3.130467] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[2025-07-17 18:22:25] [    3.130789] max77620 4-003c: max77620 probe successful
[2025-07-17 18:22:25] rm_rail_debugfs_init: /rm/vdd_cpu: failed
[2025-07-17 18:22:25] debugfs initialized
[2025-07-17 18:22:26] [    4.002102] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[2025-07-17 18:22:26] [    4.003545] hid: raw HID events driver (C) Jiri Kosina
[2025-07-17 18:22:26] [    4.004441] usbcore: registered new interface driver usbhid
[2025-07-17 18:22:26] [    4.004603] usbhid: USB HID core driver
[2025-07-17 18:22:26] [    4.007107] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[2025-07-17 18:22:26] [    4.008493] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[2025-07-17 18:22:26] [    26.649438] Camera-FW on t194-rce-safe started
[2025-07-17 18:22:26] TCU early console enabled.
[2025-07-17 18:22:26] [    26.723346] Camera-FW on t194-rce-safe ready SHA1=23eee394 (crt 0.775 ms, total boot 74.713 ms)
[2025-07-17 18:22:26] [    4.092995] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[2025-07-17 18:22:26] [    4.093705] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[2025-07-17 18:22:26] [    4.095007] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[2025-07-17 18:22:26] [    4.095727] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[2025-07-17 18:22:26] [    4.097682] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[2025-07-17 18:22:26] [    4.098649] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[2025-07-17 18:22:26] [    4.099340] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[2025-07-17 18:22:26] [    4.101532] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[2025-07-17 18:22:26] [    4.101762] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[2025-07-17 18:22:26] [    4.105311] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=23eee394bd15a5275ceb1c464c8cd08f816570a1
[2025-07-17 18:22:26] [    4.109144] tegra_aon c1a0000.aon: Adding to iommu group 6
[2025-07-17 18:22:26] [    4.116358] tegra_aon c1a0000.aon: tegra aon driver probe OK
[2025-07-17 18:22:26] [    4.121086] tegra186-aondbg aondbg: aondbg driver probe() OK
[2025-07-17 18:22:26] [    4.127442] denver_knobs_init:MTS_VERSION:72064061
[2025-07-17 18:22:26] [    4.139194] t19x_cache tegra-cache: probed
[2025-07-17 18:22:26] [    4.143294] optee: probing for conduit method.
[2025-07-17 18:22:26] C: Reserved shared memory is disabled
[2025-07-17 18:22:26] I/TC: Dynamic shared memory is enabled
[2025-07-17 18:22:26] I/TC: Normal World virtualization support is disabled
[2025-07-17 18:22:26] I/TC: Asynchronous notifications are disabled
[2025-07-17 18:22:26] [    4.144508] optee: revision 3.22 (eb8130c7)
[2025-07-17 18:22:26] [    4.262059] optee: dynamic shared memory is enabled
[2025-07-17 18:22:26] [    4.264014] optee: initialized driver
[2025-07-17 18:22:26] [    4.267737] PCIe RLMS: module init
[2025-07-17 18:22:26] [    4.269162] nvpmodel: initialized successfully
[2025-07-17 18:22:26] [    4.269851] tegra_hv: get_hvd: not initialized yet
[2025-07-17 18:22:26] [    4.270080] user_ivc_mempool: hypervisor not present
[2025-07-17 18:22:26] [    4.271741] usbcore: registered new interface driver snd-usb-audio
[2025-07-17 18:22:26] [    4.273508] u32 classifier
[2025-07-17 18:22:26] [    4.273624]     input device check on
[2025-07-17 18:22:26] [    4.273743]     Actions configured
[2025-07-17 18:22:26] [    4.274087] Initializing XFRM netlink socket
[2025-07-17 18:22:26] [    4.275417] NET: Registered protocol family 10
[2025-07-17 18:22:26] [    4.279248] Segment Routing with IPv6
[2025-07-17 18:22:26] [    4.279507] NET: Registered protocol family 17
[2025-07-17 18:22:26] [    4.279695] NET: Registered protocol family 15
[2025-07-17 18:22:26] [    4.279953] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[2025-07-17 18:22:26] [    4.281122] Bluetooth: RFCOMM socket layer initialized
[2025-07-17 18:22:26] [    4.281392] Bluetooth: RFCOMM ver 1.11
[2025-07-17 18:22:26] [    4.281600] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[2025-07-17 18:22:26] [    4.281796] Bluetooth: HIDP socket layer initialized
[2025-07-17 18:22:26] [    4.283126] 9pnet: Installing 9P2000 support
[2025-07-17 18:22:26] [    4.283372] Key type dns_resolver registered
[2025-07-17 18:22:26] [    4.285017] registered taskstats version 1
[2025-07-17 18:22:26] [    4.285239] Loading compiled-in X.509 certificates
[2025-07-17 18:22:26] [    4.324467] Loaded X.509 cert 'Build time autogenerated kernel key: 307948a67c666d7e0ea4a0aedf966391ecd89419'
[2025-07-17 18:22:26] [    4.326143] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[2025-07-17 18:22:26] [    4.328287] tegra_pcie_hack_create_i2c_devices: i2c_get_adapter(1) failed
[2025-07-17 18:22:26] [    4.329456] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[2025-07-17 18:22:26] [    4.330778] tegra_pcie_hack_create_i2c_devices: i2c_get_adapter(1) failed
[2025-07-17 18:22:26] [    4.362168] host1x 13e10000.host1x: Adding to iommu group 9
[2025-07-17 18:22:26] [    4.388666] host1x 13e10000.host1x: initialized
[2025-07-17 18:22:26] [    4.390193] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[2025-07-17 18:22:26] [    4.391171] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.391930] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[2025-07-17 18:22:26] [    4.392735] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.393419] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[2025-07-17 18:22:26] [    4.394128] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.395164] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[2025-07-17 18:22:26] [    4.395924] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.402814] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[2025-07-17 18:22:26] [    4.409905] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.419733] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[2025-07-17 18:22:26] [    4.426857] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.436940] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[2025-07-17 18:22:26] [    4.444170] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.453884] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[2025-07-17 18:22:26] [    4.461007] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[2025-07-17 18:22:26] [    4.470630] falcon 15340000.vic: Adding to iommu group 18
[2025-07-17 18:22:26] [    4.485657] falcon 15340000.vic: initialized
[2025-07-17 18:22:26] [    4.486836] falcon 15380000.nvjpg: Adding to iommu group 18
[2025-07-17 18:22:26] [    4.492225] falcon 15380000.nvjpg: initialized
[2025-07-17 18:22:26] [    4.492853] falcon 154c0000.nvenc: Adding to iommu group 18
[2025-07-17 18:22:26] [    4.504454] falcon 154c0000.nvenc: initialized
[2025-07-17 18:22:26] [    4.505177] falcon 15a80000.nvenc1: Adding to iommu group 18
[2025-07-17 18:22:26] [    4.513851] falcon 15a80000.nvenc1: initialized
[2025-07-17 18:22:26] [    4.514641] nvdec 15480000.nvdec: Adding to iommu group 18
[2025-07-17 18:22:26] [    4.526759] nvdec 15480000.nvdec: initialized
[2025-07-17 18:22:26] [    4.527351] nvdec 15140000.nvdec1: Adding to iommu group 18
[2025-07-17 18:22:26] [    4.537667] nvdec 15140000.nvdec1: initialized
[2025-07-17 18:22:26] [    4.538513] tsec 15500000.tsec: Adding to iommu group 19
[2025-07-17 18:22:26] [    4.544408] tsec 15500000.tsec: initialized
[2025-07-17 18:22:26] [    4.545035] tsec 15100000.tsecb: Adding to iommu group 20
[2025-07-17 18:22:26] [    4.551432] tsec 15100000.tsecb: initialized
[2025-07-17 18:22:26] [    4.555447] gic 2a41000.agic-controller: GIC IRQ controller registered
[2025-07-17 18:22:27] [    4.582900] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[2025-07-17 18:22:27] [    4.596304] gpio-374 (wifi-enable): hogged as output/high
[2025-07-17 18:22:27] [    4.598034] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[2025-07-17 18:22:27] [    4.600283] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[2025-07-17 18:22:27] [    4.600841] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:27] [    4.602496] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:27] [    4.603686] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:27] [    4.605066] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:27] [    4.606642] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[2025-07-17 18:22:27] [    4.614570] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[2025-07-17 18:22:27] [    4.621782] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[2025-07-17 18:22:27] [    4.633891] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[2025-07-17 18:22:27] [    4.638388] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[2025-07-17 18:22:27] [    4.644162] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[2025-07-17 18:22:27] [    4.652997] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[2025-07-17 18:22:27] [    4.661567] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[2025-07-17 18:22:27] [    4.671155] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[2025-07-17 18:22:27] [    4.678234] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[2025-07-17 18:22:27] [    4.686495] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[2025-07-17 18:22:27] [    4.692460] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[2025-07-17 18:22:27] [    4.701976] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[2025-07-17 18:22:27] [    4.708209] pva 16000000.pva0: Adding to iommu group 23
[2025-07-17 18:22:27] [    4.735810] pva 16000000.pva0: initialized
[2025-07-17 18:22:27] [    4.741024] pva 16800000.pva1: Adding to iommu group 24
[2025-07-17 18:22:27] [    4.752507] pva 16800000.pva1: initialized
[2025-07-17 18:22:27] [    4.757439] nvdla 15880000.nvdla0: Adding to iommu group 25
[2025-07-17 18:22:27] [    4.770696] nvdla 15880000.nvdla0: initialized
[2025-07-17 18:22:27] [    4.771883] nvdla 158c0000.nvdla1: Adding to iommu group 26
[2025-07-17 18:22:27] [    4.781085] nvdla 158c0000.nvdla1: initialized
[2025-07-17 18:22:27] [    4.783602] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[2025-07-17 18:22:27] [    4.783674] tegradccommon 15200000.display-hub: host1x channel mapped
[2025-07-17 18:22:27] [    4.783954] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[2025-07-17 18:22:27] [    4.784466] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[2025-07-17 18:22:27] [    4.784574] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[2025-07-17 18:22:27] [    4.784855] tegradccommon 15200000.display-hub: dma mapping done
[2025-07-17 18:22:27] [    4.785244] tegradc 15210000.display: Adding to iommu group 27
[2025-07-17 18:22:27] [    4.785481] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[2025-07-17 18:22:27] [    4.786964] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[2025-07-17 18:22:27] [    4.794322] tegradc 15210000.display: disp0 connected to head1->sor
[2025-07-17 18:22:27] [    4.797542] tegra_cec 3960000.tegra_cec: probed
[2025-07-17 18:22:27] [    4.803317] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[2025-07-17 18:22:27] [    4.810115] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[2025-07-17 18:22:27] [    4.814166] tegradc 15210000.display: DT parsed successfully
[2025-07-17 18:22:27] [    4.823896] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[2025-07-17 18:22:27] [    4.827339] tegradc 15210000.display: Display dc.00000000f7f368da registered with id=0
[2025-07-17 18:22:27] [    4.833324] kfuse 3830000.kfuse: initialized
[2025-07-17 18:22:27] [    4.843388] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[2025-07-17 18:22:27] [    4.848632] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[2025-07-17 18:22:27] [    4.852369] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[2025-07-17 18:22:27] [    4.860452] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[2025-07-17 18:22:27] [    4.861222] serial-tegra 3100000.serial: Adding to iommu group 2
[2025-07-17 18:22:27] [    4.866933] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[2025-07-17 18:22:27] [    4.868328] tegradc 15210000.display: vblank syncpt # 8 for dc 1
[2025-07-17 18:22:27] [    4.876952] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[2025-07-17 18:22:27] [    4.881395] tegradc 15210000.display: vpulse3 syncpt # 9 for dc 1
[2025-07-17 18:22:27] [    4.904139] tegradc 15210000.display: probed
[2025-07-17 18:22:27] [    4.913359] serial-tegra 3110000.serial: Adding to iommu group 2
[2025-07-17 18:22:27] [    4.926912] tegradc 15210000.display: fb registered
[2025-07-17 18:22:27] [    4.927912] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[2025-07-17 18:22:27] [    4.943277] serial-tegra 3140000.serial: Adding to iommu group 2
[2025-07-17 18:22:27] [    4.945037] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[2025-07-17 18:22:27] [    4.947474] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[2025-07-17 18:22:27] [    4.953285] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[2025-07-17 18:22:27] [    4.969163] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[2025-07-17 18:22:27] [    4.974443] tegra-xusb 3610000.xhci: Firmware timestamp: 2024-04-10 14:55:13 UTC, Version: 60.14 release
[2025-07-17 18:22:27] [    4.983045] tegra-xusb 3610000.xhci: xHCI Host Controller
[2025-07-17 18:22:27] [    4.988117] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[2025-07-17 18:22:27] [    4.996058] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-07-17 18:22:27] [    4.996467] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[2025-07-17 18:22:27] [    5.013591] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[2025-07-17 18:22:27] [    5.015837] dp lt: state 0 (Reset), pending_lt_evt 1
[2025-07-17 18:22:27] [    5.019800] tegra-xusb 3610000.xhci: xHCI Host Controller
[2025-07-17 18:22:27] [    5.024572] dp lt: switching from state 0 (Reset) to state 0 (Reset)
[2025-07-17 18:22:27] [    5.024581] dp lt: state 0 (Reset), pending_lt_evt 0
[2025-07-17 18:22:27] [    5.029922] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[2025-07-17 18:22:27] [    5.037760] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[2025-07-17 18:22:27] [    5.041485] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[2025-07-17 18:22:27] [    5.049105] dp lt: state 2 (clock recovery), pending_lt_evt 0
[2025-07-17 18:22:27] [    5.056450] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[2025-07-17 18:22:27] [    5.063509] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.069066] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2025-07-17 18:22:27] [    5.077350] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.084081] usb usb1: Product: xHCI Host Controller
[2025-07-17 18:22:27] [    5.084095] usb usb1: Manufacturer: Linux 5.10.216-rlmsf56873ad02a3 xhci-hcd
[2025-07-17 18:22:27] [    5.091351] dp lt: tx_pu: 0x20
[2025-07-17 18:22:27] [    5.098087] usb usb1: SerialNumber: 3610000.xhci
[2025-07-17 18:22:27] [    5.103893] dp lt: CR done
[2025-07-17 18:22:27] [    5.110797] hub 1-0:1.0: USB hub found
[2025-07-17 18:22:27] [    5.113411] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[2025-07-17 18:22:27] [    5.117916] hub 1-0:1.0: 4 ports detected
[2025-07-17 18:22:27] [    5.121015] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-07-17 18:22:27] [    5.122351] dp lt: CE not done
[2025-07-17 18:22:27] [    5.125300] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[2025-07-17 18:22:27] [    5.133335] dp lt: new config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.137322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2025-07-17 18:22:27] [    5.143587] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.143602] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.146682] usb usb2: Product: xHCI Host Controller
[2025-07-17 18:22:27] [    5.155325] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.162327] usb usb2: Manufacturer: Linux 5.10.216-rlmsf56873ad02a3 xhci-hcd
[2025-07-17 18:22:27] [    5.169567] dp lt: tx_pu: 0x20
[2025-07-17 18:22:27] [    5.170105] dp lt: CE retry
[2025-07-17 18:22:27] [    5.177200] usb usb2: SerialNumber: 3610000.xhci
[2025-07-17 18:22:27] [    5.183911] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[2025-07-17 18:22:27] [    5.183921] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-07-17 18:22:27] [    5.189183] hub 2-0:1.0: USB hub found
[2025-07-17 18:22:27] [    5.196091] dp lt: CE not done
[2025-07-17 18:22:27] [    5.202017] hub 2-0:1.0: 4 ports detected
[2025-07-17 18:22:27] [    5.205206] dp lt: new config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.218690] pca954x 2-0070: supply vcc-pullup not found, using dummy regulator
[2025-07-17 18:22:27] [    5.221796] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.228212] pca954x 2-0070: pca954x_probe: could not read force bus number
[2025-07-17 18:22:27] [    5.231632] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.235476] pca954x 2-0070: probe failed
[2025-07-17 18:22:27] [    5.238867] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.238881] dp lt: tx_pu: 0x20
[2025-07-17 18:22:27] [    5.246491] pca954x: probe of 2-0070 failed with error -121
[2025-07-17 18:22:27] [    5.254208] dp lt: CE retry
[2025-07-17 18:22:27] [    5.270038] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[2025-07-17 18:22:27] [    5.274675] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[2025-07-17 18:22:27] [    5.288550] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1902000 KHz, changing to: 1907200 KHz
[2025-07-17 18:22:27] [    5.293815] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-07-17 18:22:27] [    5.294849] dp lt: CE not done
[2025-07-17 18:22:27] [    5.302096] tegra194-cpufreq ccplex: probed with BWMGR, cl:4
[2025-07-17 18:22:27] [    5.311210] dp lt: new config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.323689] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[2025-07-17 18:22:27] [    5.325069] sdhci-tegra 3440000.sdhci: Got CD GPIO
[2025-07-17 18:22:27] [    5.325153] sdhci-tegra 3440000.sdhci: BWMGR client registration for eMC Successful
[2025-07-17 18:22:27] [    5.326385] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[2025-07-17 18:22:27] [    5.326414] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[2025-07-17 18:22:27] [    5.326432] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[2025-07-17 18:22:27] [    5.326443] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[2025-07-17 18:22:27] [    5.328103] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.328110] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.328116] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:27] [    5.328121] dp lt: tx_pu: 0x20
[2025-07-17 18:22:27] [    5.328627] dp lt: CE retry
[2025-07-17 18:22:27] [    5.334429] irq: IRQ261: trimming hierarchy from :pmc@c360000
[2025-07-17 18:22:27] [    5.336851] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[2025-07-17 18:22:27] [    5.336858] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-07-17 18:22:27] [    5.338572] dp lt: CE done
[2025-07-17 18:22:27] [    5.344099] sdhci-tegra 3440000.sdhci: wakeup init done, cdirq 261
[2025-07-17 18:22:27] [    5.352085] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[2025-07-17 18:22:27] [    5.352187] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[2025-07-17 18:22:27] [    5.357254] sdhci-tegra 3440000.sdhci: Failed getting OCR mask: 0
[2025-07-17 18:22:27] [    5.364595] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[2025-07-17 18:22:27] [    5.364675] mmc0: CQHCI version 5.10
[2025-07-17 18:22:27] [    5.393710] tegradc 15210000.display: dp: irq event received
[2025-07-17 18:22:27] [    5.397077] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[2025-07-17 18:22:27] [    5.466398] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[2025-07-17 18:22:27] [    5.469882] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit
[2025-07-17 18:22:27] [    5.475479] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[2025-07-17 18:22:27] [    5.476076] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[2025-07-17 18:22:27] [    5.534348] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[2025-07-17 18:22:27] [    5.534766] tegradc 15210000.display: dp: aux write retry (0x10000400) -- 2
[2025-07-17 18:22:27] [    5.542372] tegra194-pcie 14160000.pcie: Link up
[2025-07-17 18:22:28] [    5.542379] dp lt: state 5 (link training pass), pending_lt_evt 1
[2025-07-17 18:22:28] [    5.542388] dp lt: switching from state 5 (link training pass) to state 1 (fast link training)
[2025-07-17 18:22:28] [    5.560927] dp lt: state 1 (fast link training), pending_lt_evt 0
[2025-07-17 18:22:28] [    5.562355] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-07-17 18:22:28] [    5.571279] usb 1-2: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.05
[2025-07-17 18:22:28] [    5.583505] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2025-07-17 18:22:28] [    5.590829] usb 1-2: Product: USB2744
[2025-07-17 18:22:28] [    5.594519] usb 1-2: Manufacturer: Microchip Tech
[2025-07-17 18:22:28] [    5.600896] hub 1-2:1.0: USB hub found
[2025-07-17 18:22:28] [    5.605541] hub 1-2:1.0: 4 ports detected
[2025-07-17 18:22:28] [    5.612577] mmc0: Command Queue Engine enabled
[2025-07-17 18:22:28] [    5.612726] mmc0: periodic cache flush enabled
[2025-07-17 18:22:28] [    5.616276] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[2025-07-17 18:22:28] [    5.616588] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-07-17 18:22:28] [    5.616829] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[2025-07-17 18:22:28] [    5.616868] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x0 did not specify bpp
[2025-07-17 18:22:28] [    5.616875] tegradc 15210000.display: blank - powerdown
[2025-07-17 18:22:28] [    5.617012] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (509:0)
[2025-07-17 18:22:28] [    5.620967]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[2025-07-17 18:22:28] [    5.632527] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:28] [    5.632537] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-07-17 18:22:28] [    5.632546] dp lt: tx_pu: 0x20
I can also provide the boot log of a successfull boot if that is helpfull to you.
Could you add some print to fast_lt_state and see what got crashed there?
I have added the following messages in the fast_lt_state function:
static void fast_lt_state(struct tegra_dp_lt_data *lt_data)
	struct tegra_dc_dp_data *dp;
	struct tegra_dc_sor_data *sor;
	int tgt_state;
	int timeout;
	bool lt_status;
	BUG_ON(!lt_data || !lt_data->dp || !lt_data->dp->sor);
	dp = lt_data->dp;
	sor = dp->sor;
	BUG_ON(!lt_data->no_aux_handshake);
	WARN_ON(lt_data->tps != TEGRA_DC_DP_TRAINING_PATTERN_DISABLE);
	pr_info("fast_lt_state: Pre condition check finished.");
	print_tegra_dp_lt_data(lt_data);
	mutex_lock(&lt_data->lock);
	pr_info("fast_lt_state: Mutex acquired.");
	tegra_dc_sor_detach(sor); pr_info("fast_lt_state: 'tegra_dc_sor_detach' called .");
	set_lt_config(lt_data); pr_info("fast_lt_state: 'set_lt_config' called .");
	tegra_sor_precharge_lanes(sor); pr_info("fast_lt_state: 'tegra_sor_precharge_lanes' called .");
	mutex_unlock(&lt_data->lock);
	pr_info("fast_lt_state: Mutex released.");
	do_fast_lt_no_handshake(lt_data); pr_info("fast_lt_state: 'do_fast_lt_no_handshake' called .");
	lt_status = get_lt_status(lt_data); pr_info("fast_lt_state: 'get_lt_status' called .");
	pr_info("lt_status: %d\n", lt_status);
	if (lt_status) {
		lt_passed(lt_data); pr_info("fast_lt_state: 'lt_passed' called .");
		tgt_state = STATE_DONE_PASS;
		timeout = -1;
	} else {
		lt_failed(lt_data); pr_info("fast_lt_state: 'lt_failed' called .");
		tgt_state = STATE_RESET;
		timeout = 0;
	pr_info("dp lt: fast link training %s\n",
		tgt_state == STATE_DONE_PASS ? "pass" : "fail");
	set_lt_state(lt_data, tgt_state, timeout);
This is the new output on a failed boot:
[    5.606309] fast_lt_state: Pre condition check finished.
[    5.606313] tegra_dp_lt_data:
[    5.607829]   shutdown: 0
[    5.610179]   state: 1
[    5.612724]   tps: 0
[    5.614818]   pending_evt: 0
[    5.617891]   force_disable: 0
[    5.621037]   force_trigger: 0
[    5.624011]   no_aux_handshake: 1
[    5.627430]   aux_rd_interval: 0
[    5.630649]   lt_config_valid: 1
[    5.633816]   drive_current: 0 0 0 0
[    5.637660]   pre_emphasis: 0 0 0 0
[    5.641079]   post_cursor2: 0 0 0 0
[    5.644836]   tx_pu: 32
[    5.647203]   n_lanes: 2
[    5.649817]   link_bw: 10
[    5.652537]   cr_adj_retry: 0
[    5.655685]   cr_max_retry: 0
[    5.658825]   ce_retry: 5
[    5.661460] fast_lt_state: Mutex acquired.
[    5.662965] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    5.671631] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    5.694393] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    5.694558] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    5.698932] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    5.723578] mmc1: new ultra high speed SDR50 SDHC card at address 0001
[    5.724321] mmcblk1: mmc1:0001 0016G 15.2 GiB
[    5.728676] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    5.728910] GPT:30777343 != 31834111
[    5.729021] GPT:Alternate GPT header not at the end of the disk.
[    5.729178] GPT:30777343 != 31834111
[    5.729305] GPT: Use GNU Parted to correct GPT errors.
[    5.732304]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[    5.733462] fast_lt_state: 'tegra_dc_sor_detach' called .
[    5.741366] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[    5.753623] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[    5.760447] dp lt: tx_pu: 0x20
[    5.763729] fast_lt_state: 'set_lt_config' called .
[    5.763858] fast_lt_state: 'tegra_sor_precharge_lanes' called .
[    5.768272] fast_lt_state: Mutex released.
[    5.774304] tegra_dp_lt_data:
[    5.781744]   shutdown: 0
[    5.784001]   state: 1
[    5.786651]   tps: 0
[    5.788720] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[    5.798934]   pending_evt: 0
[    5.800046]   force_disable: 0
[    5.803207]   force_trigger: 0
[    5.806085]   no_aux_handshake: 1
[    5.822986]   aux_rd_interval: 0
[    5.823110]   lt_config_valid: 0
[    5.823206]   drive_current: 0 0 0 0
[    5.823329]   pre_emphasis: 0 0 0 0
[    5.823842]   post_cursor2: 0 0 0 0
[    5.827540]   tx_pu: 32
[    5.830056]   n_lanes: 2
[    5.842976]   link_bw: 10
[    5.843100]   cr_adj_retry: 0
[    5.843199]   cr_max_retry: 0
[    5.843292]   ce_retry: 5
Are you talking about the hang happened in do_fast_lt_no_handshake?
No not directly.
do_fast_lt_no_handshake() triggers a BUG_ON statement because lt_config_valid = false, (this can be seen in the log [ 5.823110]). During the non failing boots the lt_config_validstays true.
The call of tegra_dc_sor_detach causes lt_config_valid to become false, I don’t know why this happens, I don’t see anything that indicated that this function fails.
this is the lt_data after tegra_dc_sor_detach:
[    5.819533] fast_lt_state: 'tegra_dc_sor_detach' called .
[    5.819537] tegra_dp_lt_data:
[    5.819541]   state: 1
[    5.819543]   tps: 0
[    5.819545]   pending_evt: 0
[    5.819547]   force_disable: 0
[    5.819548]   force_triggeno_aux_handshake: 1
[    5.819553]   aux_rd_interval: 0
[    5.819555]   lt_config_valid: 0
[    5.819556]   drive_current: 0 0 0 0
[    5.819576]   post_cursor2: 0 0 0 0
[    5.819603]   tx_pu: 32
[    5.819605]   n_lanes: 2
[    5.819607]   link_bw: 10
[    5.819609]   cr_adj_retry: 0
[                cr_max_retry: 0
[    5.819613]   ce_retry: 4
Can you offer any insights into this problem?
It also seems to be connected to the ce_retry count. In the last tests I ran ce_retry was always 0 when the boot succeed and > 0 when it failed.
After some further tests it seems as if the tegradc driver processes an event while the dp_lt is alread in the fast_lt_state function:
[2025-07-22 11:11:36] [    5.982148] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[2025-07-22 11:11:36] [    6.024104] tegradc 15210000.display: dp: irq event received
[2025-07-22 11:11:36] [    6.085887] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[2025-07-22 11:11:36] [    6.086068] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[2025-07-22 11:11:36] [    6.093880] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[2025-07-22 11:11:36] [    6.094304] tegradc 15210000.display: dp: aux write retry (0x10000400) -- 2
[2025-07-22 11:11:36] [    6.097915] dp lt: state 5 (link training pass), pending_lt_evt 1
[2025-07-22 11:11:36] [    6.098097] dp lt: switching from state 5 (link training pass) to state 1 (fast link training)
[2025-07-22 11:11:36] [    6.098329] dp lt: state 1 (fast link training), pending_lt_evt 0
[2025-07-22 11:11:36] [    6.098530] fast_lt_state: Pre condition check finished.
[2025-07-22 11:11:36] [    6.098535] tegra_dp_lt_data:
[2025-07-22 11:11:36] [    6.098789]   shutdown: 0
[2025-07-22 11:11:36] [    6.098864]   state: 1
[2025-07-22 11:11:36] [    6.098948]   tps: 0
[2025-07-22 11:11:36] [    6.099035]   pending_evt: 0
[2025-07-22 11:11:36] [    6.099125]   force_disable: 0
[2025-07-22 11:11:36] [    6.099224]   force_trigger: 0
[2025-07-22 11:11:36] [    6.099321]   no_aux_handshake: 1
[2025-07-22 11:11:36] [    6.099429]   aux_rd_interval: 0
[2025-07-22 11:11:36] [    6.099531]   lt_config_valid: 1
[2025-07-22 11:11:36] [    6.099698]  ---- tegra_dp_lt_invalidate: set lt_config_valid to false ----
[2025-07-22 11:11:36] [    6.101952]   drive_current:
[2025-07-22 11:11:36] [    6.103340] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
This evente causes tegra_dp_lt_invalidate to be called and lt_config_valid is set to false during the execution of the fast_lt_state function.
Yes this is still an issue.
I added some additional debug messages and this dropped the frequency of the error further down, therefor it took some time until I could recreate the error-state. However I now suspect, that a timing issue between the edid ready signal and the link training is the root cause:
Log for a working boot sequence:
[2025-08-25 09:50:39] [   10.884529] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[2025-08-25 09:50:39] [   10.884740] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[2025-08-25 09:50:39] [   10.892500] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[2025-08-25 09:50:39] [   10.897082]  ---- tegra_dp_hpd_op_edid_ready: call tegra_dp_lt_invalidate ----
[2025-08-25 09:50:39] [   10.897089]  ---- tegra_dp_lt_invalidate: set lt_config_valid to false ----
[2025-08-25 09:50:39] [   10.898718] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:39] [   10.920655] EXT4-fs (mmcblk0p1): warning: maximal mount count reached, running e2fsck is recommended
[2025-08-25 09:50:39] [   10.922326] EXT4-fs (mmcblk0p1): recovery complete
[2025-08-25 09:50:39] [   10.923194] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[2025-08-25 09:50:39] [   10.930303] [INITRD] Rootfs mounted over mmcblk0p1
[2025-08-25 09:50:39] [   10.935789] [INITRD] Init display
[2025-08-25 09:50:40] [   10.951217] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:40] [   10.951487] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x0 did not specify bpp
[2025-08-25 09:50:40] [   10.951493] tegradc 15210000.display: blank - powerdown
[2025-08-25 09:50:40] [   11.009749] dp lt: state 5 (link training pass), pending_lt_evt 1
[2025-08-25 09:50:40] [   11.009758] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[2025-08-25 09:50:40] [   11.009783] dp lt: state 0 (Reset), pending_lt_evt 0
[2025-08-25 09:50:40] [   11.009789] dp lt: link training force disable
[2025-08-25 09:50:40] [   11.009792] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[2025-08-25 09:50:40] [   11.036752] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[2025-08-25 09:50:40] [   11.036918] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[2025-08-25 09:50:40] [   11.037907] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[2025-08-25 09:50:40] [   11.038210] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:40] [   11.038223] tegradc 15210000.display: unblank
[2025-08-25 09:50:40] [   11.039480] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[2025-08-25 09:50:40] [   11.039671] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[2025-08-25 09:50:40] [   11.039899] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[2025-08-25 09:50:40] [   11.046368] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:40] [   11.057215] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[2025-08-25 09:50:40] [   11.057219] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[2025-08-25 09:50:40] [   11.057223] dp lt: state 0 (Reset), pending_lt_evt 0
[2025-08-25 09:50:40] [   11.057227]  ---- lt_data_sw_reset: set lt_config_valid to false ----
[2025-08-25 09:50:40] [   11.058709] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[2025-08-25 09:50:40] [   11.058714] dp lt: state 2 (clock recovery), pending_lt_evt 0
[2025-08-25 09:50:40] [   11.059173] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:50:40] [   11.059179] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:50:40] [   11.059184] dp lt: tx_pu: 0x20
[2025-08-25 09:50:40] [   11.060115] dp lt: CR done
[2025-08-25 09:50:40] [   11.060119] dp lt: switching from state 2 (clock recovery) to state 3 (channel equalization)
[2025-08-25 09:50:40] [   11.060123] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-08-25 09:50:40] [   11.061575]  ---- lt_passed: set lt_config_valid to true ----
[2025-08-25 09:50:40] [   11.062040] dp lt: CE done
[2025-08-25 09:50:40] [   11.062044] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[2025-08-25 09:50:40] [   11.081728] tegradc 15210000.display: sync windows ret = 245
[2025-08-25 09:50:40] [   11.197601] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:40] [   11.197841] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x0 did not specify bpp
[2025-08-25 09:50:40] [   11.197846] tegradc 15210000.display: blank - powerdown
[2025-08-25 09:50:40] [   11.238435] dp lt: state 5 (link training pass), pending_lt_evt 1
[2025-08-25 09:50:40] [   11.238438] dp lt: switching from state 5 (link training pass) to state 0 (Reset)
[2025-08-25 09:50:40] [   11.238442] dp lt: state 0 (Reset), pending_lt_evt 0
[2025-08-25 09:50:40] [   11.238446] dp lt: link training force disable
[2025-08-25 09:50:40] [   11.238449] dp lt: switching from state 0 (Reset) to state 4 (link training fail/disable)
[2025-08-25 09:50:40] [   11.265487] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[2025-08-25 09:50:40] [   11.265648] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[2025-08-25 09:50:40] [   11.266640] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[2025-08-25 09:50:40] [   11.266934] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:40] [   11.266944] tegradc 15210000.display: unblank
[2025-08-25 09:50:40] [   11.268213] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[2025-08-25 09:50:40] [   11.268405] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[2025-08-25 09:50:40] [   11.268631] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[2025-08-25 09:50:40] [   11.275088] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:50:40] [   11.286337] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[2025-08-25 09:50:40] [   11.286341] dp lt: switching from state 4 (link training fail/disable) to state 1 (fast link training)
[2025-08-25 09:50:40] [   11.286344] dp lt: state 1 (fast link training), pending_lt_evt 0
[2025-08-25 09:50:40] [   11.808495] fast_lt_state: Pre condition check finished.
[2025-08-25 09:50:40] [   11.808519] tegra_dp_lt_data:
[2025-08-25 09:50:40] [   11.808522]   shutdown: 0
[2025-08-25 09:50:40] [   11.808523]   state: 1
[2025-08-25 09:50:40] [   11.808525]   tps: 0
[2025-08-25 09:50:40] [   11.808527]   pending_evt: 0
[2025-08-25 09:50:40] [   11.808528]   force_disable: 0
[2025-08-25 09:50:40] [   11.808530]   force_trigger: 0
[2025-08-25 09:50:41] [   11.808531]   no_aux_handshake: 1
[2025-08-25 09:50:41] [   11.808533]   aux_rd_interval: 0
[2025-08-25 09:50:41] [   11.808535]   lt_config_valid: 1
[2025-08-25 09:50:41] [   11.808536]   drive_current: 0 0 0 0
[2025-08-25 09:50:41] [   11.808568]   pre_emphasis: 0 0 0 0
[2025-08-25 09:50:41] [   11.808577]   post_cursor2: 0 0 0 0
[2025-08-25 09:50:41] [   11.808586]   tx_pu: 32
[2025-08-25 09:50:41] [   11.808587]   n_lanes: 2
[2025-08-25 09:50:41] [   11.808589]   link_bw: 10
[2025-08-25 09:50:41] [   11.808591]   cr_adj_retry: 0
[2025-08-25 09:50:41] [   11.808592]   cr_max_retry: 0
[2025-08-25 09:50:41] [   11.808594]   ce_retry: 0
Log for a failing boot sequence:
[2025-08-25 09:48:12] [    5.151450] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.151457] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.151469] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.185670] dp lt: tx_pu: 0x20
[2025-08-25 09:48:12] [    5.189380] dp lt: CE retry
[2025-08-25 09:48:12] [    5.191774] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[2025-08-25 09:48:12] [    5.200828] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-08-25 09:48:12] [    5.202783] mmc1: host does not support reading read-only switch, assuming write-enable
[2025-08-25 09:48:12] [    5.208043] dp lt: CE not done
[2025-08-25 09:48:12] [    5.218104] dp lt: new config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.225241] dp lt: new config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.232500] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.238122] usb 1-2: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.05
[2025-08-25 09:48:12] [    5.239394] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[2025-08-25 09:48:12] [    5.247796] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2025-08-25 09:48:12] [    5.247800] usb 1-2: Product: USB2744
[2025-08-25 09:48:12] [    5.247804] usb 1-2: Manufacturer: Microchip Tech
[2025-08-25 09:48:12] [    5.249140] hub 1-2:1.0: USB hub found
[2025-08-25 09:48:12] [    5.254614] dp lt: tx_pu: 0x20
[2025-08-25 09:48:12] [    5.255105] dp lt: CE retry
[2025-08-25 09:48:12] [    5.261899] hub 1-2:1.0: 4 ports detected
[2025-08-25 09:48:12] [    5.265223] dp lt: switching from state 3 (channel equalization) to state 3 (channel equalization)
[2025-08-25 09:48:12] [    5.292796] dp lt: state 3 (channel equalization), pending_lt_evt 0
[2025-08-25 09:48:12] [    5.300409]  ---- lt_passed: set lt_config_valid to true ----
[2025-08-25 09:48:12] [    5.300898] dp lt: CE done
[2025-08-25 09:48:12] [    5.308061] dp lt: switching from state 3 (channel equalization) to state 5 (link training pass)
[2025-08-25 09:48:12] [    5.313027] tegradc 15210000.display: dp: irq event received
[2025-08-25 09:48:12] [    5.317283] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[2025-08-25 09:48:12] [    5.329524] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[2025-08-25 09:48:12] [    5.365410] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[2025-08-25 09:48:12] [    5.386021] usb 2-3: New USB device found, idVendor=0424, idProduct=5744, bcdDevice= 2.05
[2025-08-25 09:48:12] [    5.386261] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[2025-08-25 09:48:12] [    5.386472] usb 2-3: Product: USB5744
[2025-08-25 09:48:12] [    5.386585] usb 2-3: Manufacturer: Microchip Tech
[2025-08-25 09:48:12] [    5.389212] hub 2-3:1.0: USB hub found
[2025-08-25 09:48:12] [    5.389721] hub 2-3:1.0: 3 ports detected
[2025-08-25 09:48:12] [    5.397408] tegradc 15210000.display: dp: aux read retry (0x10000401) -- 2
[2025-08-25 09:48:12] [    5.399880] dp lt: state 5 (link training pass), pending_lt_evt 1
[2025-08-25 09:48:12] [    5.400081] dp lt: switching from state 5 (link training pass) to state 1 (fast link training)
[2025-08-25 09:48:12] [    5.400314] dp lt: state 1 (fast link training), pending_lt_evt 0
[2025-08-25 09:48:12] [    5.441191] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[2025-08-25 09:48:12] [    5.441370] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[2025-08-25 09:48:12] [    5.449162] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[2025-08-25 09:48:12] [    5.453913]  ---- tegra_dp_hpd_op_edid_ready: call tegra_dp_lt_invalidate ----
[2025-08-25 09:48:12] [    5.453917]  ---- tegra_dp_lt_invalidate: set lt_config_valid to false ----
[2025-08-25 09:48:12] [    5.455553] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:48:12] [    5.497170] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x200000 did not specify bpp
[2025-08-25 09:48:12] [    5.497415] tegradc 15210000.display: tegra_dp_get_bpp: vmode=0x0 did not specify bpp
[2025-08-25 09:48:12] [    5.497421] tegradc 15210000.display: blank - powerdown
[2025-08-25 09:48:12] [    5.500455] mmc1: new ultra high speed SDR50 SDHC card at address 0001
[2025-08-25 09:48:12] [    5.501124] mmcblk1: mmc1:0001 0016G 15.2 GiB
[2025-08-25 09:48:12] [    5.505802] GPT:Primary header thinks Alt. header is not at the end of the disk.
[2025-08-25 09:48:12] [    5.505825] GPT:30777343 != 31834111
[2025-08-25 09:48:12] [    5.505828] GPT:Alternate GPT header not at the end of the disk.
[2025-08-25 09:48:12] [    5.505840] GPT:30777343 != 31834111
[2025-08-25 09:48:12] [    5.505842] GPT: Use GNU Parted to correct GPT errors.
[2025-08-25 09:48:12] [    5.505913]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[2025-08-25 09:48:12] [    5.605177] tegra_cec 3960000.tegra_cec: Can't find physical address.
[2025-08-25 09:48:12] [    5.605181] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[2025-08-25 09:48:12] [    5.925145] fast_lt_state: Pre condition check finished.
[2025-08-25 09:48:12] [    5.925149] tegra_dp_lt_data:
[2025-08-25 09:48:12] [    5.925151]   shutdown: 0
[2025-08-25 09:48:12] [    5.925153]   state: 1
[2025-08-25 09:48:12] [    5.925155]   tps: 0
[2025-08-25 09:48:12] [    5.925172]   pending_evt: 1
[2025-08-25 09:48:12] [    5.925174]   force_disable: 1
[2025-08-25 09:48:12] [    5.925176]   force_trigger: 0
[2025-08-25 09:48:12] [    5.925181]   no_aux_handshake: 1
[2025-08-25 09:48:12] [    5.925183]   aux_rd_interval: 0
[2025-08-25 09:48:12] [    5.925184]   lt_config_valid: 0
[2025-08-25 09:48:12] [    5.925186]   drive_current: 0 0 0 0
[2025-08-25 09:48:12] [    5.925196]   pre_emphasis: 0 0 0 0
[2025-08-25 09:48:12] [    5.925205]   post_cursor2: 0 0 0 0
[2025-08-25 09:48:12] [    5.925231]   tx_pu: 32
[2025-08-25 09:48:12] [    5.925233]   n_lanes: 2
[2025-08-25 09:48:12] [    5.925235]   link_bw: 10
[2025-08-25 09:48:12] [    5.925236]   cr_adj_retry: 0
[2025-08-25 09:48:12] [    5.925238]   cr_max_retry: 0
[2025-08-25 09:48:12] [    5.925240]   ce_retry: 3
In the failing case, the tegra_dp_hpd_op_edid_ready function is called after the lt_passed function and therefor lt_config_valid is false during the fast lt phase.
The whole display port initialization also occurs at least 1s earlier in the boot sequence when it fails, compared to the working boot attempts.
Is there any way to fix this timing?
Are there any updates on this Topic?
Any news?
I have “fixed” the problem for my use case.
In my case the kernel panic occurred when the another PCIE driver was not initialized.
The the error case the dp lt was also executed about 6s earlier in the kernel boot procedure compared to the working case, I dont know if this caused the kernel panic.
I still think its a Bug that the dp lt causes a kernel panic if another unrelated PCIE driver is not initialized, maybe due to the different boot timings with and without the initialization of the PCIE driver.
