下面是全部的日志,请查看。
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (root@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #5 SMP PREEMPT Tue May 17 19:56:26 PDT 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 4130304
[ 0.000000] DMA zone: 7192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 460288 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4065768
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30144(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15435796K/16521216K available (15358K kernel code, 2960K rwdata, 6744K rodata, 8640K init, 612K bss, 331756K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009620000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e90000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a174008 ( 2961 KB)
[ 0.000000] .bss : 0xffffff800a174008 - 0xffffff800a20d0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000678] Console: colour dummy device 80x25
[ 0.000689] console [tty0] enabled
[ 0.000696] bootconsole [tegra_comb_uart0] disabled
[ 0.000710] kmemleak: Kernel memory leak detector disabled
[ 0.000727] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000742] pid_max: default: 32768 minimum: 301
[ 0.001806] Security Framework initialized
[ 0.002367] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.002377] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.004097] ftrace: allocating 47116 entries in 185 pages
[ 0.399162] sched-energy: Sched-energy-costs installed from DT
[ 0.399184] ASID allocator initialised with 65536 entries
[ 0.434207] tegra-id: chipid=21917.
[ 0.434219] tegra-id: opt_subrevision=1.
[ 0.434246] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.434269] DTS File Name: /home/liuxs/share/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.434280] DTB Build time: May 18 2022 23:00:53
[ 0.482324] CPU1: Booted secondary processor [4e0f0040]
[ 0.514444] CPU2: Booted secondary processor [4e0f0040]
[ 0.546568] CPU3: Booted secondary processor [4e0f0040]
[ 0.578821] CPU4: Booted secondary processor [4e0f0040]
[ 0.610890] CPU5: Booted secondary processor [4e0f0040]
[ 0.611087] Brought up 6 CPUs
[ 0.611096] SMP: Total of 6 processors activated.
[ 0.611104] CPU features: detected feature: Privileged Access Never
[ 0.611110] CPU features: detected feature: LSE atomic instructions
[ 0.611117] CPU features: detected feature: User Access Override
[ 0.611123] CPU features: detected feature: 32-bit EL0 Support
[ 0.612583] CPU: All CPU(s) started at EL2
[ 0.612632] alternatives: patching kernel code
[ 0.619757] devtmpfs: initialized
[ 0.659172] Initilizing CustomIPI irq domain
[ 0.659376] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.659396] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.669736] pinctrl core: initialized pinctrl subsystem
[ 0.669942] OS set in device tree is not L4T.
[ 0.670184] regulator-dummy: no parameters
[ 0.670376] Initializing plugin-manager
[ 0.670428] Plugin module not found
[ 0.670462] Plugin-manager status disabled
[ 0.671620] NET: Registered protocol family 16
[ 0.672886] pstore: using zlib compression
[ 0.672910] console [pstore-1] enabled
[ 0.672918] pstore: Registered ramoops as persistent store backend
[ 0.672927] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.693306] cpuidle: using governor menu
[ 0.694297] bpmp: waiting for handshake
[ 0.694308] bpmp: handshake completed
[ 0.694341] bpmp: synchronizing channels
[ 0.694352] bpmp: channels synchronized
[ 0.694359] bpmp: mail init ok
[ 0.696883] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.697077] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.697084] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.697090] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.697096] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.697103] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.697132] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.697140] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.697146] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.697154] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.697160] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.700186] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e94000)
[ 0.700217] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.703221] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.704336] tegra_aon_clk_init: ok
[ 0.704349] Registering BPMP clocks…
[ 0.704449] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.704983] Serial: AMBA PL011 UART driver
[ 0.705148] tegra_powergate_init: DONE
[ 0.705203] DTS File Name: /home/liuxs/share/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.705220] DTB Build time: May 18 2022 23:00:53
[ 0.707739] Tegra reboot handler registered.
[ 0.714393] iommu: Adding device 14160000.pcie to group 0
[ 0.715038] iommu: Adding device 141a0000.pcie to group 1
[ 0.716247] iommu: Adding device 2490000.ether_qos to group 2
[ 0.716665] iommu: Adding device 3100000.serial to group 3
[ 0.717136] iommu: Adding device 3110000.serial to group 4
[ 0.717488] iommu: Adding device 3140000.serial to group 5
[ 0.718073] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.718326] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.718372] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.718378] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.718383] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.718427] tegra-pmc: PMC Prod config success
[ 0.718587] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.718600] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.718880] iommu: Adding device 3460000.sdhci to group 6
[ 0.719344] iommu: Adding device 3440000.sdhci to group 7
[ 0.719767] iommu: Adding device 3210000.spi to group 8
[ 0.720114] iommu: Adding device 3230000.spi to group 9
[ 0.720470] iommu: Adding device 3270000.spi to group 10
[ 0.721390] iommu: Adding device 3160000.i2c to group 11
[ 0.721787] iommu: Adding device c240000.i2c to group 12
[ 0.722236] iommu: Adding device 3180000.i2c to group 13
[ 0.722596] iommu: Adding device 3190000.i2c to group 14
[ 0.723060] iommu: Adding device 31b0000.i2c to group 15
[ 0.723481] iommu: Adding device 31c0000.i2c to group 16
[ 0.723837] iommu: Adding device c250000.i2c to group 17
[ 0.724206] iommu: Adding device 31e0000.i2c to group 18
[ 0.724741] iommu: Adding device sound to group 19
[ 0.725198] iommu: Adding device 3510000.hda to group 20
[ 0.725754] iommu: Adding device bc00000.rtcpu to group 21
[ 0.727826] iommu: Adding device 13e10000.host1x to group 22
[ 0.728244] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.728628] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.728979] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.729320] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.729696] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.730046] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.730356] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.730697] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.731143] iommu: Adding device 15340000.vic to group 31
[ 0.731573] iommu: Adding device 15380000.nvjpg to group 32
[ 0.731826] iommu: Adding device 15500000.tsec to group 33
[ 0.732067] iommu: Adding device 15100000.tsecb to group 34
[ 0.732324] iommu: Adding device 15480000.nvdec to group 35
[ 0.732613] iommu: Adding device 15140000.nvdec1 to group 36
[ 0.732878] iommu: Adding device 154c0000.nvenc to group 37
[ 0.733119] iommu: Adding device 15a80000.nvenc1 to group 38
[ 0.733516] iommu: Adding device 15880000.nvdla0 to group 39
[ 0.733902] iommu: Adding device 158c0000.nvdla1 to group 40
[ 0.734398] iommu: Adding device 15200000.nvdisplay to group 41
[ 0.738477] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.738554] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.739196] iommu: Adding device 15210000.nvdisplay to group 42
[ 0.739285] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.740913] iommu: Adding device 15c10000.vi to group 43
[ 0.741092] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.741414] iommu: Adding device 14800000.isp to group 44
[ 0.742239] iommu: Adding device 16000000.pva0 to group 45
[ 0.742770] iommu: Adding device 16800000.pva1 to group 46
[ 0.743155] iommu: Adding device 15810000.se to group 47
[ 0.743500] iommu: Adding device 15820000.se to group 48
[ 0.743738] iommu: Adding device 15830000.se to group 49
[ 0.743971] iommu: Adding device 15840000.se to group 50
[ 0.744226] iommu: Adding device c1a0000.aon to group 51
[ 0.745626] iommu: Adding device d000000.bpmp to group 52
[ 0.745915] bpmp: ping status is 0
[ 0.746032] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.749152] bpmp d000000.bpmp: probe ok
[ 0.750987] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.751472] iommu: Adding device smmu_test to group 53
[ 0.752626] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c10000
[ 0.752647] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c20000
[ 0.752665] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c30000
[ 0.752685] mc: mapped MMIO address: 0xffffff800b010000 → 0x2c40000
[ 0.752703] mc: mapped MMIO address: 0xffffff800b030000 → 0x2c50000
[ 0.752720] mc: mapped MMIO address: 0xffffff800b050000 → 0x2b80000
[ 0.752737] mc: mapped MMIO address: 0xffffff800b070000 → 0x2b90000
[ 0.752754] mc: mapped MMIO address: 0xffffff800b090000 → 0x2ba0000
[ 0.752771] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x2bb0000
[ 0.752788] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1700000
[ 0.752805] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1710000
[ 0.752823] mc: mapped MMIO address: 0xffffff800b110000 → 0x1720000
[ 0.752840] mc: mapped MMIO address: 0xffffff800b130000 → 0x1730000
[ 0.752857] mc: mapped MMIO address: 0xffffff800b150000 → 0x1740000
[ 0.752874] mc: mapped MMIO address: 0xffffff800b170000 → 0x1750000
[ 0.752891] mc: mapped MMIO address: 0xffffff800b190000 → 0x1760000
[ 0.752908] mc: mapped MMIO address: 0xffffff800b1b0000 → 0x1770000
[ 0.752984] mc-err: mcerr ops are set to t19x
[ 0.758647] iommu: Adding device 2600000.dma to group 54
[ 0.763500] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.764707] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.764746] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.764782] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.765051] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.771018] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.771088] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.771123] GPIO line 266 (w-disable1) hogged as output/high
[ 0.771156] GPIO line 264 (w-disable2) hogged as output/high
[ 0.771189] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.771428] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.773620] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.773631] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.773641] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.774550] iommu: Adding device 3550000.xudc to group 55
[ 0.775155] iommu: Adding device 3610000.xhci to group 56
[ 0.777189] arm64_ras arm64_ras: probed
[ 0.777533] ras_fhi_enable: FHI 470 enabled on CPU0
[ 0.777578] ras_fhi_enable: FHI 471 enabled on CPU1
[ 0.777651] ras_fhi_enable: FHI 472 enabled on CPU2
[ 0.777726] ras_fhi_enable: FHI 473 enabled on CPU3
[ 0.777830] ras_fhi_enable: FHI 474 enabled on CPU4
[ 0.777926] ras_fhi_enable: FHI 475 enabled on CPU5
[ 0.778121] carmel_ras_enable: RAS enabled on cpu0
[ 0.778298] carmel_ras_enable: RAS enabled on cpu1
[ 0.778506] carmel_ras_enable: RAS enabled on cpu2
[ 0.778724] carmel_ras_enable: RAS enabled on cpu3
[ 0.778910] carmel_ras_enable: RAS enabled on cpu4
[ 0.779093] carmel_ras_enable: RAS enabled on cpu5
[ 0.779181] carmel_ras carmel_ras: probed
[ 0.780270] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.780737] tegra-cbb c600000.aon-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.781575] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.782364] tegra-cbb be00000.rce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.783250] tegra-cbb b600000.sce-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[ 0.783592] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.784703] vdd-ac-bat: 5000 mV
[ 0.785218] vdd-sdmmc1-sw: 3300 mV
[ 0.785519] vdd-1v8-sd: 1800 mV
[ 0.785788] vdd-3v3-cvb: 3300 mV
[ 0.786039] vdd-1v8-cvb: 1800 mV
[ 0.786300] vdd-epb-1v0: 1000 mV
[ 0.786447] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.786745] avdd-cam-2v8: 2800 mV
[ 0.787015] vdd-fan: 5000 mV
[ 0.787350] vdd-hdmi-5v0: 5000 mV
[ 0.787618] vdd_sys_en: 1200 mV
[ 0.823640] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.828244] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.828531] SCSI subsystem initialized
[ 0.828736] libata version 3.00 loaded.
[ 0.828960] usbcore: registered new interface driver usbfs
[ 0.829010] usbcore: registered new interface driver hub
[ 0.829085] usbcore: registered new device driver usb
[ 0.839794] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.842560] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 0.847182] vdd-1v0: at 1000 mV
[ 0.851258] vdd-1v8-hs: at 1800 mV
[ 0.855242] vdd-1v8-ls: at 1800 mV
[ 0.859257] vdd-1v8-ao: at 1800 mV
[ 0.863283] vddio-ddr-1v1: at 1100 mV
[ 0.867056] vdd-rtc: at 800 mV
[ 0.868285] spmic-ldo1: at 2375 mV
[ 0.875091] vdd-ao-3v3: at 3300 mV
[ 0.883121] vddio-emmc-3v3: at 3300 mV
[ 0.884360] spmic-ldo4: at 1587 mV
[ 0.891159] vdd-usb-3v3: at 3300 mV
[ 0.899195] vddio-sdmmc1-3v3: at 3300 mV
[ 0.903220] vdd-csi-1v2: at 1200 mV
[ 0.904774] spmic-ldo8: at 1800 mV
[ 0.909489] GPIO line 246 (gpio_default) hogged as output/high
[ 0.910862] GPIO line 247 (gpio_default) hogged as output/high
[ 0.911145] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.911420] max77620 4-003c: max77620 probe successful
[ 0.912139] media: Linux media interface: v0.10
[ 0.912217] Linux video capture interface: v2.00
[ 0.913851] pps_core: LinuxPPS API ver. 1 registered
[ 0.913858] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.913874] PTP clock support registered
[ 0.914210] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.914487] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.914533] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.917394] trusty trusty: trusty version: Built: 08:57:16 Feb 19 2022
[ 0.917452] trusty trusty: selected api version: 3 (requested 3)
[ 0.918738] Advanced Linux Sound Architecture Driver Initialized.
[ 0.919098] Bluetooth: Core ver 2.22
[ 0.919131] NET: Registered protocol family 31
[ 0.919136] Bluetooth: HCI device and connection manager initialized
[ 0.919146] Bluetooth: HCI socket layer initialized
[ 0.919153] Bluetooth: L2CAP socket layer initialized
[ 0.919177] Bluetooth: SCO socket layer initialized
[ 0.922367] camchar: rtcpu character device driver loaded
[ 0.922731] extcon-gpio-states external-connection:extcon@1: No Cable connected on boot
[ 0.924201] clocksource: Switched to clocksource arch_sys_counter
[ 0.969048] VFS: Disk quotas dquot_6.6.0
[ 0.969141] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.969446] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.970800] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.970850] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.971068] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.971076] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.971087] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.971123] nvmap_page_pool_init: Total RAM pages: 4047365
[ 0.971130] nvmap_page_pool_init: nvmap page pool size: 505920 pages (1976 MB)
[ 0.971264] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.971596] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.973555] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 0.984721] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.984924] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.985123] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 0.985278] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 0.985449] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.986618] la/ptsa driver initialized.
[ 0.986934] NET: Registered protocol family 2
[ 0.987022] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.994334] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.995048] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.995626] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.995672] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.995897] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.996543] NET: Registered protocol family 1
[ 0.997045] RPC: Registered named UNIX socket transport module.
[ 0.997050] RPC: Registered udp transport module.
[ 0.997056] RPC: Registered tcp transport module.
[ 0.997060] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.997071] PCI: CLS 0 bytes, default 64
[ 0.997298] Trying to unpack rootfs image as initramfs…
[ 1.222299] Freeing initrd memory: 7068K
[ 1.235091] random: fast init done
[ 1.239211] host1x 13e10000.host1x: initialized
[ 1.241031] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.245610] audit: initializing netlink subsys (disabled)
[ 1.245660] audit: type=2000 audit(0.868:1): initialized
[ 1.246270] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.253437] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.254460] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.254976] 9p: Installing v9fs 9p2000 file system support
[ 1.260014] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.260163] io scheduler noop registered
[ 1.260419] io scheduler cfq registered (default)
[ 1.263881] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.267549] iommu: Adding device 2993000.adsp to group 57
[ 1.295335] iommu: Adding device aconnect@2a41000:adsp_audio to group 58
[ 1.296429] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.309444] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.309909] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.310517] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.310881] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.311266] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.314384] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.314562] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.317161] tsec 15500000.tsec: initialized
[ 1.318801] tsec 15100000.tsecb: initialized
[ 1.322456] nvdec 15480000.nvdec: initialized
[ 1.324891] nvdec 15140000.nvdec1: initialized
[ 1.330393] falcon 15340000.vic: initialized
[ 1.332168] falcon 15380000.nvjpg: initialized
[ 1.334143] falcon 154c0000.nvenc: initialized
[ 1.336071] falcon 15a80000.nvenc1: initialized
[ 1.338983] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.341180] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.342835] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.344475] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.346083] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.347592] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.349194] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.350687] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.354534] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.360155] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.360626] scare-pigeon 14b00000.isp-thi: initialized
[ 1.366464] pva 16000000.pva0: initialized
[ 1.372286] pva 16800000.pva1: initialized
[ 1.377539] nvdla 15880000.nvdla0: initialized
[ 1.382203] nvdla 158c0000.nvdla1: initialized
[ 1.383790] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.383803] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.383847] tegradccommon 15200000.dc_common: dma mapping done
[ 1.384673] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.384701] tegradc 15200000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.384780] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.384805] tegradc 15200000.nvdisplay: Display dc.ffffff800bd50000 registered with id=0
[ 1.388344] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.388351] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.388356] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.388563] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.388573] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.398484] tegradc 15200000.nvdisplay: probed
[ 1.399001] Console: switching to colour frame buffer device 80x30
[ 1.399029] tegradc 15200000.nvdisplay: fb registered
[ 1.402526] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.402559] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.402572] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.402588] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.402656] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.402665] Extcon DP: HPD disabled
[ 1.402669] hpd: hpd_switch 0
[ 1.402675] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.402686] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.402694] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.403021] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.403046] generic_infoframe_type: 0x87
[ 1.403101] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.403130] tegradc 15210000.nvdisplay: Display dc.ffffff800be50000 registered with id=1
[ 1.403296] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.403305] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.405773] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.405781] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.407612] tegradc 15210000.nvdisplay: probed
[ 1.407850] tegradc 15210000.nvdisplay: fb registered
[ 1.408021] gpio tegra-gpio wake60 for gpio=96(M:0)
[ 1.408908] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.409037] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.409163] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.410963] tegradc 15210000.nvdisplay: dc_hdmi_out_enable: couldn’t get regulator avdd_hdmi
[ 1.411108] Parent Clock set for DC pll_d
[ 1.414370] edid invalid
[ 1.416326] tegradc 15210000.nvdisplay: hdmi: tmds rate:25200K prod-setting:prod_c_hdmi_0m_54m
[ 1.417753] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.452675] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 1.452681] Extcon AUX0(HDMI) enable
[ 1.452905] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=78
[ 1.452913] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.453198] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.453324] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.453485] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.453493] tegra_cec 3960000.tegra_cec: probed
[ 1.463058] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.463769] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.463780] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.464168] kfuse 3830000.kfuse: initialized
[ 1.470167] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.472895] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.473896] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.474591] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.475834] console [ttyTCU0] enabled
[ 1.476165] [drm] Initialized
[ 1.486579] brd: module loaded
[ 1.491177] loop: module loaded
[ 1.491234] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.491353] tegra_profiler: auth: init
[ 1.492213] THERMAL EST: found 3 subdevs
[ 1.492236] THERMAL EST num_resources: 0
[ 1.492247] [THERMAL EST subdev 0]
[ 1.492255] [THERMAL EST subdev 1]
[ 1.492262] [THERMAL EST subdev 2]
[ 1.492273] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.492515] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.492520] THERMAL EST: thz register success.
[ 1.492756] THERMAL EST: end of probe, return err: 0
[ 1.493510] sd: No Scsi addr parsed to reserve index
[ 1.493541] hisi_sas: driver version v1.6
[ 1.504077] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.504086] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.504096] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.504386] 1 ofpart partitions found on MTD device spi6.0
[ 1.504391] Creating 1 MTD partitions on “spi6.0”:
[ 1.504401] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.506639] libphy: Fixed MDIO Bus: probed
[ 1.507163] tun: Universal TUN/TAP device driver, 1.6
[ 1.507168] tun: (C) 1999-2004 Max Krasnyansky
[ 1.507895] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.507900] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.507966] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.507970] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.508010] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.508014] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.508061] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.508065] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.587504] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.634651] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 1.634654] Extcon AUX0(HDMI) disable
[ 1.660649] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.660888] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.662326] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.755556] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.756974] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5f 93 89
[ 1.757024] Using phyrst_lpmode = 1 from DT
[ 1.758119] libphy: dwc_phy: probed
[ 1.767074] PPP generic driver version 2.4.2
[ 1.768004] PPP BSD Compression module registered
[ 1.768013] PPP Deflate Compression module registered
[ 1.768114] PPP MPPE Compression module registered
[ 1.768122] NET: Registered protocol family 24
[ 1.768362] usbcore: registered new interface driver r8152
[ 1.768409] usbcore: registered new interface driver asix
[ 1.768497] usbcore: registered new interface driver ax88179_178a
[ 1.768599] usbcore: registered new interface driver cdc_ether
[ 1.768627] usbcore: registered new interface driver net1080
[ 1.768660] usbcore: registered new interface driver cdc_subset
[ 1.768695] usbcore: registered new interface driver zaurus
[ 1.768752] usbcore: registered new interface driver cdc_ncm
[ 1.769371] VFIO - User Level meta-driver version: 0.3
[ 1.772968] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.773055] ehci-pci: EHCI PCI platform driver
[ 1.773103] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.773118] ohci-pci: OHCI PCI platform driver
[ 1.773153] ohci-platform: OHCI generic platform driver
[ 1.783095] usb3: Requested PHY is disabled
[ 1.783302] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.786702] tegra-xusb 3610000.xhci: extcon 0: ffffffc3ec2a8c00 id
[ 1.789766] usbcore: registered new interface driver uas
[ 1.789888] usbcore: registered new interface driver usb-storage
[ 1.790037] usbcore: registered new interface driver usbserial
[ 1.790135] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 1.790225] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.790268] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.791327] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.791455] tegra-xusb 3610000.xhci: irq 465, io mem 0x03610000
[ 1.791867] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.791874] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.791880] usb usb1: Product: xHCI Host Controller
[ 1.791885] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.791889] usb usb1: SerialNumber: 3610000.xhci
[ 1.793130] hub 1-0:1.0: USB hub found
[ 1.793202] hub 1-0:1.0: 4 ports detected
[ 1.793909] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.793924] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.793941] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.794293] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.794299] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.794304] usb usb2: Product: xHCI Host Controller
[ 1.794307] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.794311] usb usb2: SerialNumber: 3610000.xhci
[ 1.795215] hub 2-0:1.0: USB hub found
[ 1.795268] hub 2-0:1.0: 4 ports detected
[ 1.796843] Wake76 for irq=199
[ 1.796847] Wake77 for irq=199
[ 1.796849] Wake78 for irq=199
[ 1.796851] Wake79 for irq=199
[ 1.796853] Wake80 for irq=199
[ 1.796855] Wake81 for irq=199
[ 1.796857] Wake82 for irq=199
[ 1.796973] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 1.796980] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 1.797865] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.798019] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.799893] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.799909] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.800029] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.800678] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.801596] mousedev: PS/2 mouse device common for all mice
[ 1.801802] usbcore: registered new interface driver xpad
[ 1.817363] tegradc 15210000.nvdisplay: unblank
[ 1.819060] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.819283] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.819526] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.827110] tegradc 15210000.nvdisplay: dc_hdmi_out_enable: couldn’t get regulator avdd_hdmi
[ 1.827346] Parent Clock set for DC pll_d
[ 1.832424] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.833882] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.868845] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 1.868848] Extcon AUX0(HDMI) enable
[ 1.884052] tegradc 15210000.nvdisplay: sync windows ret = 247
[ 1.884306] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 1.884311] Extcon HDMI: HPD enabled
[ 1.884333] tegradc 15210000.nvdisplay: hdmi: plugged
[ 1.896803] usb usb2: usb_suspend_both: status 0
[ 1.939494] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.941119] Wake73 for irq=42
[ 1.942470] rtc rtc1: alarm rtc device
[ 1.942488] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.942519] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.942700] i2c /dev entries driver
[ 1.945413] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.945995] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.946003] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.946692] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.970224] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 1.970305] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.970645] imx219 9-0010: board setup failed
[ 1.970837] imx219: probe of 9-0010 failed with error -121
[ 1.971315] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.994586] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 1.994689] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.994964] imx219 10-0010: board setup failed
[ 1.995141] imx219: probe of 10-0010 failed with error -121
[ 1.997112] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 2.005125] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.005578] FAN dev name: pwm-fan
[ 2.005628] FAN:gpio request success.
[ 2.005661] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.005687] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.005954] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.006107] gpio tegra-gpio wake51 for gpio=130(Q:2)
[ 2.006196] pwm_fan_driver pwm-fan: fan tach request irq success
[ 2.006207] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.006734] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.006742] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.006749] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.006755] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.006761] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.006767] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.006773] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.006779] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.006786] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.006793] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.007548] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.008814] device-mapper: uevent: version 1.0.3
[ 2.009232] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.013233] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.014453] cpuidle: Initializing cpuidle driver
[ 2.015540] sdhci: Secure Digital Host Controller Interface driver
[ 2.015544] sdhci: Copyright(c) Pierre Ossman
[ 2.015547] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.016906] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.018877] CMDQ: cmdq_platfm_init successful
[ 2.019600] sdhci-tegra 3440000.sdhci: Got CD GPIO
[ 2.021905] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.023445] sdhci-tegra 3440000.sdhci: wakeup init done, cdirq 393
[ 2.028034] tegra-se-nvhost 15810000.se: initialized
[ 2.029210] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.029835] tegra-se-nvhost 15820000.se: initialized
[ 2.031085] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.031670] tegra-se-nvhost 15830000.se: initialized
[ 2.032392] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.032980] tegra-se-nvhost 15840000.se: initialized
[ 2.033774] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.035001] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.035144] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.036296] usbcore: registered new interface driver usbhid
[ 2.036300] usbhid: USB HID core driver
[ 2.040671] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.041860] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.042404] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.043338] denver_knobs_init:MTS_VERSION:54811859
[ 2.043713] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.044393] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.044804] t19x_cache tegra-cache: probed
[ 2.047226] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.047233] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.047827] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.048296] PLL_AON clock registered
[ 2.050124] Clocks initialized successfully
[ 2.051616] nvpmodel: initialized successfully
[ 2.053013] trusty-virtio trusty:virtio: initializing
[ 2.053218] trusty_ipc virtio0: vring0: va¶ ffffffc3d9588000(0) qsz 32 notifyid 1
[ 2.053228] trusty_ipc virtio0: vring1: va¶ ffffffc3d958a000(0) qsz 32 notifyid 2
[ 2.053380] trusty-virtio trusty:virtio: initializing done
[ 2.053682] trusty_ipc virtio0: is online
[ 2.054123] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.054503] usbcore: registered new interface driver snd-usb-audio
[ 2.055051] ++++++++++es8316_i2c_probe 1158++++++++++
[ 2.055055] ++++++++++es8316_i2c_probe 1164++++++++++
[ 2.055145] ++++++++++es8316_i2c_probe 1179++++++++++
[ 2.055148] ++++++++++es8316_i2c_probe 1183++++++++++
[ 2.064279] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.072397] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 2.072492] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.074957] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.075133] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.075336] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.075501] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.130033] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.142818] mmc0: periodic cache flush enabled
[ 2.142831] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.143345] mmcblk0: mmc0:0001 HAG4a2 14.7 GiB
[ 2.143656] mmcblk0boot0: mmc0:0001 HAG4a2 partition 1 8.00 MiB
[ 2.147906] mmcblk0boot1: mmc0:0001 HAG4a2 partition 2 8.00 MiB
[ 2.148106] mmcblk0rpmb: mmc0:0001 HAG4a2 partition 3 4.00 MiB
[ 2.152400] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.164884] OPE platform probe
[ 2.165040] OPE platform probe successful
[ 2.175923] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 2.175975] ++++++++++add_dai_links 723++++++++++
[ 2.176686] ++++++++++codec_init 644++++++++++
[ 2.176893] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 2.177065] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 2.177175] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 2.177665] u32 classifier
[ 2.177668] Actions configured
[ 2.177798] Initializing XFRM netlink socket
[ 2.178422] NET: Registered protocol family 10
[ 2.179225] NET: Registered protocol family 17
[ 2.179240] NET: Registered protocol family 15
[ 2.179294] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.179360] Bluetooth: RFCOMM socket layer initialized
[ 2.179370] Bluetooth: RFCOMM ver 1.11
[ 2.179377] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.179382] Bluetooth: HIDP socket layer initialized
[ 2.179402] 9pnet: Installing 9P2000 support
[ 2.179439] Key type dns_resolver registered
[ 2.179699] Registered cp15_barrier emulation handler
[ 2.179721] Registered setend emulation handler
[ 2.181577] registered taskstats version 1
[ 2.181956] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.182856] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.182872] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.182880] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.182885] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.484253] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.548791] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.548798] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.600239] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.623000] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[ 2.623007] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.623012] usb 1-2: Product: USB2.1 Hub
[ 2.623016] usb 1-2: Manufacturer: GenesysLogic
[ 2.623887] hub 1-2:1.0: USB hub found
[ 2.624157] hub 1-2:1.0: 4 ports detected
[ 2.696747] tegra-pcie-dw 14160000.pcie: link is down
[ 2.696913] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.696923] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.696930] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.696937] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.696941] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.696969] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.697124] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.697322] iommu: Adding device 0004:00:00.0 to group 59
[ 2.697528] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.697552] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.697765] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.697772] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.697869] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.698067] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.698189] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 2.698331] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 2.698474] iommu: Removing device 0004:00:00.0 from group 59
[ 2.698538] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 2.700072] tegra-pcie-dw 14160000.pcie: PCIe link is not up…!
[ 2.700972] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.701220] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 2.701234] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 2.808553] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.808572] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.808581] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.808586] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.940225] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 2.980806] usb 1-2.1: New USB device found, idVendor=04d9, idProduct=1605
[ 2.980812] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.980816] usb 1-2.1: Product: USB Keyboard
[ 2.980820] usb 1-2.1: Manufacturer:
[ 2.991753] input: USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:04D9:1605.0001/input/input4
[ 3.048594] hid-generic 0003:04D9:1605.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-3610000.xhci-2.1/input0
[ 3.065195] input: USB Keyboard as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:04D9:1605.0002/input/input5
[ 3.124416] hid-generic 0003:04D9:1605.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-3610000.xhci-2.1/input1
[ 3.228243] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 3.251279] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c52f
[ 3.251286] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.251291] usb 1-2.3: Product: USB Receiver
[ 3.251295] usb 1-2.3: Manufacturer: Logitech
[ 3.253866] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C52F.0003/input/input6
[ 3.254286] hid-generic 0003:046D:C52F.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2.3/input0
[ 3.256516] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C52F.0004/input/input7
[ 3.316554] hid-generic 0003:046D:C52F.0004: input,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-2.3/input1
[ 3.318426] tegra-pcie-dw 141a0000.pcie: link is down
[ 3.318532] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 3.318539] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 3.318546] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 3.318552] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 3.318557] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 3.318583] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 3.318732] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.318961] iommu: Adding device 0005:00:00.0 to group 59
[ 3.319172] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 3.319214] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 3.319378] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.319385] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.319463] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 3.319601] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 3.319656] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 3.319734] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 3.319806] iommu: Removing device 0005:00:00.0 from group 59
[ 3.319834] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 3.321370] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
[ 3.333277] tegra-cbb 14040000.cv-noc: noc_secure_irq = 91, noc_nonsecure_irq = 90>
[ 3.337774] tegra194-isp5 14800000.isp: initialized
[ 3.344964] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 3.348317] tegra194-vi5 15c10000.vi: initialized
[ 3.352612] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 3.352707] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 3.352928] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 3.357268] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 3.357293] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 3.357299] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 3.357371] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 3.357408] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 3.357413] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 3.361430] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 3.361488] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 3.361494] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 3.361897] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 3.361944] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 3.361949] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 3.362484] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 3.362526] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 3.362530] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 3.362774] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 3.363672] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.440644] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 3.441030] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.441265] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 3.441423] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 3.441911] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 3.442014] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 3.442240] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (66)
[ 3.442245] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.443311] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=1d7bd17f78528535d57449fa59ec355e37add4f8
[ 3.443792] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 3.443831] ++++++++++add_dai_links 723++++++++++
[ 3.444557] ++++++++++codec_init 644++++++++++
[ 3.444746] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 3.444902] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.445011] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 3.445551] Wake83 for irq=211
[ 3.445660] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 3.445746] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 3.445948] input: gpio-keys as /devices/gpio-keys/input/input8
[ 3.446901] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 3.446961] ++++++++++add_dai_links 723++++++++++
[ 3.447646] ++++++++++codec_init 644++++++++++
[ 3.447859] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 3.448015] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.448126] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 3.479891] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:01:23 UTC (946688483)
[ 3.480533] mmcblk mmc0:0001: Card claimed for testing.
[ 3.519190] bpmp: mounted debugfs mirror
[ 3.525245] ALSA device list:
[ 3.525257] #0: tegra-hda-xnx at 0x3518000 irq 65
[ 3.528334] Freeing unused kernel memory: 8640K
[ 3.567180] Root device found: mmcblk0p1
[ 3.569250] Found dev node: /dev/mmcblk0p1
[ 3.726079] EXT4-fs (mmcblk0p1): 15 orphan inodes deleted
[ 3.726091] EXT4-fs (mmcblk0p1): recovery complete
[ 3.736482] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.739436] Rootfs mounted over mmcblk0p1
[ 3.756391] Switching from initrd to actual rootfs
[ 3.843512] systemd[1]: System time before build time, advancing clock.
[ 3.870159] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.873226] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.880315] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.881063] systemd[1]: Detected architecture arm64.
[ 3.886276] systemd[1]: Set hostname to .
[ 3.967033] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.967046] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.115141] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.118113] systemd[1]: Created slice User and Session Slice.
[ 4.118336] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.119522] systemd[1]: Created slice System Slice.
[ 4.119617] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.119970] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.120225] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.120395] systemd[1]: Listening on udev Kernel Socket.
[ 4.147797] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.464342] systemd-journald[2376]: Received request to flush runtime journal from PID 1
[ 4.651748] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.662388] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 4.662438] ++++++++++add_dai_links 723++++++++++
[ 4.663244] ++++++++++codec_init 644++++++++++
[ 4.663467] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 4.663627] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 4.663736] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 5.348181] using random self ethernet address
[ 5.348346] using random host ethernet address
[ 5.438975] random: crng init done
[ 5.439086] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.726432] cpu-throttle-alert cooling device registered.
[ 5.727072] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 5.727123] ++++++++++add_dai_links 723++++++++++
[ 5.727901] ++++++++++codec_init 644++++++++++
[ 5.728139] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 5.728379] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.728495] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 5.728971] gpu-throttle-alert cooling device registered.
[ 5.729514] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 5.729561] ++++++++++add_dai_links 723++++++++++
[ 5.730170] ++++++++++codec_init 644++++++++++
[ 5.730371] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 5.730537] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.730658] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 5.732632] aux-throttle-alert cooling device registered.
[ 5.733242] ++++++++++tegra_machine_driver_probe 783++++++++++
[ 5.733284] ++++++++++add_dai_links 723++++++++++
[ 5.734199] ++++++++++codec_init 644++++++++++
[ 5.734428] tegra-asoc: sound: ASoC: CODEC DAI es8316-hifi not registered
[ 5.734585] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.734695] ++++++++++tegra_machine_driver_probe 850++++++++++
[ 5.894493] Mass Storage Function, version: 2009/09/11
[ 5.894517] LUN: removable file: (no medium)
[ 5.906978] using random self ethernet address
[ 5.907681] using random host ethernet address
[ 5.989030] rndis0: HOST MAC d6:a8:75:17:82:30
[ 5.989394] rndis0: MAC d6:a8:75:17:82:31
[ 5.994526] usb0: HOST MAC d6:a8:75:17:82:32
[ 5.994577] usb0: MAC d6:a8:75:17:82:33
[ 5.994599] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.995337] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.995358] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.995408] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.995641] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.995658] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 5.996099] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 5.996113] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.996992] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 6.007589] l4tbr0: port 1(rndis0) entered blocking state
[ 6.007598] l4tbr0: port 1(rndis0) entered disabled state
[ 6.008889] device rndis0 entered promiscuous mode
[ 6.022829] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.035595] l4tbr0: port 2(usb0) entered blocking state
[ 6.035602] l4tbr0: port 2(usb0) entered disabled state
[ 6.035784] device usb0 entered promiscuous mode
[ 6.053954] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.286287] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.304865] ras_fhi_disable: FHI 474 disabled
[ 6.306024] CPU4: shutdown
[ 6.306141] psci: CPU4 killed (polled 0 ms)
[ 6.396829] ras_fhi_disable: FHI 475 disabled
[ 6.399112] CPU5: shutdown
[ 6.399238] psci: CPU5 killed (polled 0 ms)
[ 6.430446] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 6.605090] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 6.611529] net eth0: get_configure_l3v4_filter →
[ 6.619525] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.736890] zram: Added device: zram0
[ 6.750509] zram: Added device: zram1
[ 6.755704] zram: Added device: zram2
[ 6.757703] zram: Added device: zram3
[ 6.781455] zram0: detected capacity change from 0 to 2074263552
[ 6.828841] Adding 2025644k swap on /dev/zram0. Priority:5 extents:1 across:2025644k SS
[ 6.835615] zram1: detected capacity change from 0 to 2074263552
[ 6.859576] Adding 2025644k swap on /dev/zram1. Priority:5 extents:1 across:2025644k SS
[ 6.864164] zram2: detected capacity change from 0 to 2074263552
[ 6.899039] Adding 2025644k swap on /dev/zram2. Priority:5 extents:1 across:2025644k SS
[ 6.902675] zram3: detected capacity change from 0 to 2074263552
[ 6.927918] Adding 2025644k swap on /dev/zram3. Priority:5 extents:1 across:2025644k SS
[ 7.211997] Bridge firewalling registered
[ 7.264787] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 7.686768] Netfilter messages via NETLINK v0.30.
[ 7.701438] ctnetlink v0.93: registering with nfnetlink.
[ 7.991010] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 8.224483] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 8.225108] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.257300] tegradc 15210000.nvdisplay: unblank
[ 8.257317] tegradc 15200000.nvdisplay: blank - powerdown
[ 10.046011] fuse init (API version 7.26)
[ 12.119604] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.119618] Bluetooth: BNEP socket layer initialized
[ 13.114326] tegradc 15210000.nvdisplay: unblank
[ 13.114338] tegradc 15200000.nvdisplay: blank - powerdown
[ 34.132459] vdd-sdmmc1-sw: disabling
[ 34.132467] vdd-1v8-sd: disabling
[ 34.132473] vdd-1v8-cvb: disabling
[ 34.132478] vdd-epb-1v0: disabling
[ 34.132482] avdd-cam-2v8: disabling
[ 34.132487] vdd-fan: disabling
[ 34.132492] vdd_sys_en: disabling
[ 327.114827] tegradc 15210000.nvdisplay: blank - powerdown
[ 327.167532] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 327.167537] Extcon AUX0(HDMI) disable
[ 327.191000] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 327.191208] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 327.192159] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 833.872357] tegradc 15210000.nvdisplay: unblank
[ 833.874618] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 833.875011] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 833.875229] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 833.882752] tegradc 15210000.nvdisplay: dc_hdmi_out_enable: couldn’t get regulator avdd_hdmi
[ 833.883054] Parent Clock set for DC pll_d
[ 833.887456] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 833.888887] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 833.925428] extcon-disp-state external-connection:disp-state: cable 46 state 1
[ 833.925433] Extcon AUX0(HDMI) enable
[ 833.932164] tegradc 15210000.nvdisplay: unblank
[ 833.932180] tegradc 15200000.nvdisplay: blank - powerdown
[ 1146.852478] tegradc 15210000.nvdisplay: blank - powerdown
[ 1146.907104] extcon-disp-state external-connection:disp-state: cable 46 state 0
[ 1146.907107] Extcon AUX0(HDMI) disable
[ 1146.928067] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1146.928138] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1146.928584] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
On 5/19/2022 14:50,WayneWWW via NVIDIA Developer Forumsnvidia@discoursemail.com wrote:
