None fixed over here, with Optimus enabled both monitors are at 60hz but my second monitor is black, only the mouse shows, no application or desktop environment elements shows up.
Disabling Optimus in UEFI I can see the second monitor, but both my monitors go to ~30hz, awful experience.
Please state any tests I could run or information I could provide to help solve this.
System Report:
System:
Kernel: 6.14.0-29-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: hpet
Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22.2 Zara base: Ubuntu 24.04 noble
Machine:
Type: Laptop System: SchenkerGmbH product: XMG CORE (REN/E21) v: Standard
serial: <superuser required>
Mobo: NB02 model: GMxNGxx v: Standard serial: <superuser required>
part-nu: XCO15AE21 / XCO17AE21 uuid: <superuser required> UEFI: American Megatrends v: N.1.06A03
date: 08/27/2021
Battery:
ID-1: BAT0 charge: 46.2 Wh (95.1%) condition: 48.6/62.3 Wh (78.0%) volts: 15.9 min: 15.2
model: standard type: Li-ion serial: <filter> status: not charging
CPU:
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP smt: enabled
arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1580 high: 2895 min/max: 1400/2900 boost: disabled cores: 1: 1490 2: 1488
3: 1281 4: 1345 5: 1553 6: 1551 7: 1212 8: 1400 9: 2895 10: 2895 11: 1287 12: 1400 13: 1400
14: 1400 15: 1286 16: 1400 bogomips: 92629
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Tongfang Hongkong
driver: nvidia v: 580.65.06 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8 ports: active: none
off: HDMI-A-1 empty: DP-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-2 empty: none bus-ID: 06:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 45.0 C
Device-3: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 bus-ID: 1-4:3 chip-ID: 04f2:b71a class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu,nvidia unloaded: fbdev,modesetting,nouveau,vesa dri: radeonsi
gpu: amdgpu,nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung U28E590 serial: <filter> res: 3840x2160 dpi: 160
size: 608x345mm (23.94x13.58") diag: 699mm (27.5") modes: max: 3840x2160 min: 640x480
Monitor-2: eDP-2 model: Sharp LQ156M1JW26 res: 1920x1080 dpi: 142 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 2 drv: nouveau device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.61 6.14.0-29-generic)
device-ID: 1002:1636 display-ID: :0.0
API: Vulkan v: 1.3.275 layers: 10 surfaces: xcb,xlib,wayland device: 0 type: integrated-gpu
driver: N/A device-ID: 1002:1636 device: 1 type: discrete-gpu driver: N/A device-ID: 10de:2520
device: 2 type: cpu driver: N/A device-ID: 10005:0000
Audio:
Device-1: NVIDIA GA106 High Definition Audio vendor: Tongfang Hongkong driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong driver: N/A pcie:
speed: 8 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
pcie: speed: 8 GT/s lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.0-29-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
Device-1: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169 v: kernel pcie:
speed: 5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp2s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
bus-ID: 3-4:4 chip-ID: 8087:0029 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11
sub-v: 2184 hci-v: 11 rev: 2184 class-ID: 7c010c
Drives:
Local Storage: total: 1.82 TiB used: 52.81 GiB (2.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T2B0C-00PXH0 size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 211070WD temp: 35.9 C scheme: GPT
Partition:
ID-1: / size: 125 GiB used: 52.8 GiB (42.2%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/nvme1n1p1
ID-3: /home size: 125 GiB used: 52.8 GiB (42.2%) fs: btrfs dev: /dev/nvme0n1p2
Swap:
Alert: No swap data was found.
USB:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s lanes: 1
chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s lanes: 1
chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.2:4 info: Areson Corp 2.4G Wireless Receiver type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s lanes: 1 power: 98mA
chip-ID: 25a7:fa07 class-ID: 0301
Device-2: 1-4:3 info: Chicony Integrated IR Camera type: video driver: uvcvideo interfaces: 4
rev: 2.0 speed: 480 Mb/s lanes: 1 power: 500mA chip-ID: 04f2:b71a class-ID: 0e02 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
class-ID: 0900
Device-1: 2-1:2 info: Realtek Card Reader type: mass storage driver: usb-storage interfaces: 1
rev: 3.0 speed: 5 Gb/s lanes: 1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
Hub-4: 2-2:3 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2 speed: 5 Gb/s lanes: 1
chip-ID: 05e3:0620 class-ID: 0900
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s lanes: 1
Device-1: 3-2:2 info: SINO WEALTH Gaming Keyboard type: keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s lanes: 1 power: 500mA chip-ID: 258a:002a class-ID: 0300
Hub-6: 3-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 500mA
chip-ID: 05e3:0608 class-ID: 0900
Device-1: 3-4:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s lanes: 1 chip-ID: 1d6b:0003
class-ID: 0900
Sensors:
System Temperatures: cpu: 52.2 C mobo: 43.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): N/A
Repos:
Packages: pm: dpkg pkgs: 3054
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/docker.list
1: deb [arch=amd64 signed-by=/etc/apt/keyrings/docker.asc] https: //download.docker.com/linux/ubuntu noble stable
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //packages.linuxmint.com zara main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu noble main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu noble-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu noble-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Active apt repos in: /etc/apt/sources.list.d/oibaf-graphics-drivers-noble.list
1: deb [signed-by=/etc/apt/keyrings/oibaf-graphics-drivers-noble.gpg] https: //ppa.launchpadcontent.net/oibaf/graphics-drivers/ubuntu noble main
Active apt repos in: /etc/apt/sources.list.d/tuxedo-computers.list
1: deb https: //deb.tuxedocomputers.com/ubuntu noble main
Info:
Memory: total: 32 GiB note: est. available: 30.77 GiB used: 4 GiB (13.0%)
Processes: 432 Power: uptime: 7m states: freeze,mem,disk suspend: deep wakeups: 0
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.3.0 Client: Unknown python3.12 client inxi: 3.3.34
xrandr –verbose with Optimus enabled (second monitor black):
Screen 0: minimum 16 x 16, current 3840 x 1080, maximum 32767 x 32767
eDP-2 connected 1920x1080+0+0 (0x25) normal (normal left inverted right x axis y axis) 340mm x 190mm
Identifier: 0x21
Timestamp: 127281
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 0.0
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
RANDR Emulation: 1
non-desktop: 0
supported: 0, 1
1920x1080 (0x25) 173.000MHz -HSync +VSync *current +preferred
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1440x1080 (0x26) 129.000MHz -HSync +VSync
h: width 1440 start 1528 end 1680 total 1920 skew 0 clock 67.19KHz
v: height 1080 start 1083 end 1087 total 1120 clock 59.99Hz
1400x1050 (0x27) 121.750MHz -HSync +VSync
h: width 1400 start 1488 end 1632 total 1864 skew 0 clock 65.32KHz
v: height 1050 start 1053 end 1057 total 1089 clock 59.98Hz
1280x1024 (0x28) 109.000MHz -HSync +VSync
h: width 1280 start 1368 end 1496 total 1712 skew 0 clock 63.67KHz
v: height 1024 start 1027 end 1034 total 1063 clock 59.89Hz
1280x960 (0x29) 101.250MHz -HSync +VSync
h: width 1280 start 1360 end 1488 total 1696 skew 0 clock 59.70KHz
v: height 960 start 963 end 967 total 996 clock 59.94Hz
1152x864 (0x2a) 81.750MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.78KHz
v: height 864 start 867 end 871 total 897 clock 59.96Hz
1024x768 (0x2b) 63.500MHz -HSync +VSync
h: width 1024 start 1072 end 1176 total 1328 skew 0 clock 47.82KHz
v: height 768 start 771 end 775 total 798 clock 59.92Hz
800x600 (0x2c) 38.250MHz -HSync +VSync
h: width 800 start 832 end 912 total 1024 skew 0 clock 37.35KHz
v: height 600 start 603 end 607 total 624 clock 59.86Hz
640x480 (0x2d) 23.750MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 29.69KHz
v: height 480 start 483 end 487 total 500 clock 59.38Hz
320x240 (0x2e) 6.000MHz -HSync +VSync
h: width 320 start 336 end 360 total 400 skew 0 clock 15.00KHz
v: height 240 start 243 end 247 total 252 clock 59.52Hz
1680x1050 (0x2f) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1440x900 (0x30) 106.500MHz -HSync +VSync
h: width 1440 start 1528 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x800 (0x31) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1152x720 (0x32) 66.750MHz -HSync +VSync
h: width 1152 start 1208 end 1320 total 1488 skew 0 clock 44.86KHz
v: height 720 start 723 end 729 total 748 clock 59.97Hz
960x600 (0x33) 45.250MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 37.21KHz
v: height 600 start 603 end 609 total 624 clock 59.63Hz
928x580 (0x34) 42.750MHz -HSync +VSync
h: width 928 start 968 end 1056 total 1184 skew 0 clock 36.11KHz
v: height 580 start 583 end 589 total 603 clock 59.88Hz
800x500 (0x35) 30.750MHz -HSync +VSync
h: width 800 start 824 end 896 total 992 skew 0 clock 31.00KHz
v: height 500 start 503 end 509 total 521 clock 59.50Hz
768x480 (0x36) 28.750MHz -HSync +VSync
h: width 768 start 792 end 864 total 960 skew 0 clock 29.95KHz
v: height 480 start 483 end 489 total 500 clock 59.90Hz
720x480 (0x37) 26.750MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 29.85KHz
v: height 480 start 483 end 493 total 500 clock 59.71Hz
640x400 (0x38) 20.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 25.00KHz
v: height 400 start 403 end 409 total 417 clock 59.95Hz
320x200 (0x39) 5.000MHz -HSync +VSync
h: width 320 start 336 end 360 total 400 skew 0 clock 12.50KHz
v: height 200 start 203 end 209 total 212 clock 58.96Hz
1600x900 (0x3a) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1368x768 (0x3b) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1280x720 (0x3c) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1024x576 (0x3d) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
864x486 (0x3e) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
720x400 (0x3f) 22.250MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 24.83KHz
v: height 400 start 403 end 413 total 417 clock 59.55Hz
640x350 (0x40) 17.500MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 21.88KHz
v: height 350 start 353 end 363 total 366 clock 59.77Hz
HDMI-1 connected 1920x1080+1920+0 (0x25) normal (normal left inverted right x axis y axis) 610mm x 350mm
Identifier: 0x23
Timestamp: 127281
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 0.0
Clones:
CRTC: 1
CRTCs: 1
filter:
RANDR Emulation: 1
non-desktop: 0
supported: 0, 1
Tried to catch it with Test Ufo but can’t get more than 30fps, probably because the monitor themselves are not reaching that: Imgur: The magic of the Internet
