Nvidia Riva Connection
Hardware - GPU - RTX 4060
Hardware - CPU - Ryzen 5600
Ubuntu 20.04
2.15.0
ERROR:
filip@ai:~/riva_quickstart_v2.15.0$ sudo docker run --rm -it --gpus all nvcr.io/nvidia/riva/riva-speech:2.15.0 bash
=== Riva Speech Skills ===
NVIDIA Release 24.02 (build 86328927)
Copyright (c) 2018-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
root@4db3c4060559:/opt/riva# <riva_tts_client --voice_name=English-US.Female-1
–text=“Hello, this is a speech synthesizer.”
–audio_file=/opt/riva/wav/output.wav
bash: riva_tts_client: No such file or directory
root@4db3c4060559:/opt/riva# riva_tts_client --voice_name=English-US.Female-1
I0506 09:24:27.603174 98 grpc.h:94] Using Insecure Server Credentials
Error creating GRPC channel: Unable to establish connection to server. Current state: 3
Exiting.
Can you try riva_start before the command, to initialize the triton server?
I did.
Still doesn’t work
When I ran nvidia-smi:
Fri Jul 12 20:37:35 2024
| NVIDIA-SMI 550.54.15 Driver Version: 550.54.15 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 Off | 00000000:07:00.0 On | N/A |
| 0% 51C P8 N/A / 115W | 7668MiB / 8188MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1223 G /usr/lib/xorg/Xorg 101MiB |
| 0 N/A N/A 1421 G /usr/bin/gnome-shell 76MiB |
| 0 N/A N/A 2780 G /usr/lib/firefox/firefox 0MiB |
| 0 N/A N/A 10180 C tritonserver 7318MiB |
Hi @0to1000subs1.0 ,
I see
Did you check on that?
I dont know what to do with it…
ERROR: The NVIDIA Driver is present, but CUDA failed to initialize. GPU functionality will not be available.
[[ Unable to initialize CUDA driver (error ???) ]]
Failed to detect NVIDIA driver version.
root@ai:/opt/riva# riva_tts_client --voice_name=English-US.Female-1
I0716 07:49:22.694196 95 grpc.h:94] Using Insecure Server Credentials
E0716 07:49:22.743340 95 riva_tts_client.cc:179] Request time: 0.0472879 s
E0716 07:49:22.743549 95 riva_tts_client.cc:189] Got 241664 bytes back from server
↑Its when i run it as it should ↑
(sudo bash riva_start_client.sh)
