Thank you for your respons @rvinobha.
I will have to confirm about the firewall/proxy settings at our end.
The output of the command shared by you is as follows:
"* Uses proxy env variable https_proxy == ‘https://10.7.9.47:9090/’
- Trying 10.7.9.47:9090…
- TCP_NODELAY set
- Connected to 10.7.9.47 (10.7.9.47) port 9090 (#0)
- ALPN, offering http/1.1
- successfully set certificate verify locations:
- CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
- TLSv1.3 (OUT), TLS handshake, Client hello (1):
- error:1408F10B:SSL routines:ssl3_get_record:wrong version number
- Closing connection 0
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number"
The complete log output of the bash riva_init.sh is as follows:
Please enter API key for ngc.nvidia.com:
Logging into NGC docker registry if necessary…
Pulling required docker images if necessary…
Note: This may take some time, depending on the speed of your Internet connection.
Pulling Riva Speech Server images.
Image nvcr.io/nvidia/riva/riva-speech:2.5.0 exists. Skipping.
Image nvcr.io/nvidia/riva/riva-speech:2.5.0-servicemaker exists. Skipping.
Downloading models (RMIRs) from NGC…
Note: this may take some time, depending on the speed of your Internet connection.
To skip this process and use existing RMIRs set the location and corresponding flag in config.sh.
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
=== Riva Speech Skills ===
NVIDIA Release (build 43645243)
Copyright (c) 2016-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Copyright (c) 2018-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
To install Python sample dependencies, run /opt/tensorrt/python/python_setup.sh
To install the open-source samples corresponding to this TensorRT release version
run /opt/tensorrt/install_opensource.sh. To build the open source parsers,
plugins, and samples for current top-of-tree on master or a different branch,
run /opt/tensorrt/install_opensource.sh -b
See https://github.com/NVIDIA/TensorRT for more information.
NOTE: CUDA Forward Compatibility mode ENABLED.
Using CUDA 11.6 driver version 510.47.03 with kernel driver version 450.191.01.
See https://docs.nvidia.com/deploy/cuda-compatibility/ for details.
/data/artifacts /opt/riva
Downloading nvidia/riva/rmir_asr_conformer_hi_in_str:2.5.0…
Url: ‘https://authn.nvidia.com/token?service=ngc&scope=group/ngc:nvidia&scope=group/ngc:nvidia/riva’ is not reachable.
Attempt 1 out of 3 failed
Trying again…
Attempt 2 out of 3 failed
Trying again…
Attempt 3 out of 3 failed
Error occurred downloading ‘nvidia/riva/rmir_asr_conformer_hi_in_str:2.5.0’. Exiting.
Error in downloading models."
