NVIDIA RTX A6000 for vGPU no mdev_supported_types folder
I have NVIDIA RTX A6000 and enabled the SRIOV and updated the A6000 to physical_display_disabled. How ever in the virtfn0 do not has mdev_supported_types. Please help.
root@vgpu-ESC4000A-E12:/sys/bus/pci/devices/0000:01:00.0/virtfn0# nvidia-smi
Sat Jan 4 22:42:54 2025
| NVIDIA-SMI 550.127.06 Driver Version: 550.127.06 CUDA Version: N/A |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A6000 On | 00000000:01:00.0 Off | 0 |
| 30% 34C P8 28W / 300W | 0MiB / 46068MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
root@vgpu-ESC4000A-E12:/sys/bus/pci/devices/0000:01:00.0/virtfn0# nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Sat Jan 4 22:44:34 2025
Driver Version : 550.127.06
CUDA Version : Not Found
vGPU Driver Capability
Heterogenous Multi-vGPU : Supported
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA RTX A6000
Product Brand : NVIDIA RTX
Product Architecture : Ampere
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Enabled
Addressing Mode : N/A
vGPU Device Capability
Fractional Multi-vGPU : Supported
Heterogeneous Time-Slice Profiles : Supported
Heterogeneous Time-Slice Sizes : Supported
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Enabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1322721073018
GPU UUID : GPU-c5d183df-bb48-834b-e1b8-10c127ef8707
Minor Number : 0
VBIOS Version : 94.02.5C.00.06
MultiGPU Board : No
Board ID : 0x100
Board Part Number : 900-5G133-0300-000
GPU Part Number : 2230-875-A1
FRU Part Number : N/A
Module ID : 1
Inforom Version
Image Version : G133.0500.00.05
OEM Object : 2.0
ECC Object : 6.16
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : Host VGPU
Host VGPU Mode : SR-IOV
vGPU Heterogeneous Mode : Disabled
GPU Reset Status
Reset Required : No
Drain and Reset Recommended : No
GSP Firmware Version : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x2
Device Id : 0x223010DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x1459103C
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Device Current : 1
Device Max : 4
Host Max : N/A
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 50 KB/s
Rx Throughput : 50 KB/s
Atomic Caps Inbound : N/A
Atomic Caps Outbound : N/A
Fan Speed : 30 %
Performance State : P8
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 46068 MiB
Reserved : 450 MiB
Used : 0 MiB
Free : 45619 MiB
BAR1 Memory Usage
Total : 65536 MiB
Used : 1 MiB
Free : 65535 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable Parity : 0
SRAM Uncorrectable SEC-DED : 0
DRAM Correctable : 0
DRAM Uncorrectable : 0
Aggregate
SRAM Threshold Exceeded : No
Aggregate Uncorrectable SRAM Sources
SRAM L2 : 0
SRAM SM : 0
SRAM Microcontroller : 0
SRAM PCIE : 0
SRAM Other : 0
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 34 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 93 C
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : 29.01 W
Current Power Limit : 300.00 W
Requested Power Limit : 300.00 W
Default Power Limit : 300.00 W
Min Power Limit : 100.00 W
Max Power Limit : 300.00 W
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : 1800 MHz
Memory : 8001 MHz
Default Applications Clocks
Graphics : 1800 MHz
Memory : 8001 MHz
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 2100 MHz
SM : 2100 MHz
Memory : 8001 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 743.750 mV
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Processes : None
Team any insights on this? We are too hiting similar issue but on RTX Pro 6000 Blackwell while configuring vGPU with SR-IOV.
@anirudh15 Please excuse the mention, but were you able to resolve the issue in the meantime?
We are running into the same problem, no mdev_supported_types available. Developer machines are Fedora 42 and Servers are AlmaLinux9, driver installed following the official documentation and repositories from Nvidia.
Hi @anon36643592 . Yes I am able to resolve the issue in our usecase. Where we were using Ubuntu 22.04 with SR-IOV. So the issue turned out to be kernel version compatibility. As for ubuntu 22.04 and Nvidia CUDA version requirement is 6.5 kernel. Initial we had 6.8 kernel version. Post using Ubuntu 22.04 with 6.5 kernel version we see the mdev_supported_types.
NOTE: From kernel version 6.8 and above there were some changes in VFIO framework, which requires additional configurations for mdev_supported_types visibility Virtual GPU Software User Guide - NVIDIA Docs
